Q7 4M not taking active radiator grille adaptation
gtg196w
C?ID=105780
I just replaced the motor on the active radiator grille on a 2017 Q7.
Made sure to put the assembly in the “closed” position after putting all the fins back in. Then tried to run the active radiator grille adaptation under basic settings in engine module. It just hangs and stays in the “running” state. Grille does nothing.. triple checked the electrical connection.. any ideas? Not sure if this is on the VCDS side or on the car side…. So apologies if this should have been in vehicle repair support.
Thanks!
gtg196w
C?ID=105780
Saturday,25,March,2023,14:25:24:63200
VCDS Version: 23.3.0.0 (x64)  HEX-NET2 CB: 0.4631.5
VIN: WA1VAAF71HD004182   License Plate:
Mileage: 147394km-91586mi   Repair Order:
Chassis Type: F7-AU73 (8W8)
Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 36 39 3C 42 44 46 47
          50 52 5F 69 6C 6D 74 81 82 8B A5 BB BC CA CB CF D6 D7
VIN: WA1VAAF71HD004182   Mileage: 147394km-91586miles
50-Seat Adj. 3rd row -- Status: OK 0000
BB-Door Rear Drv -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4M0 907 551 A    HW: 06E 907 425
   Component: 3.0l V6 TFSI  H10 0005
   Revision: --H10---    CVN: 08BDF7A0
   Coding: 2A2A0032057E010D74280000000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TFS0214M0907551A 001007
   ROD: EV_ECM30TFS021_AU73.rod
   VCID: 2D0C64A64DEE5062945-8178
   VINID: 9D10664515870585000040480865AE26C7
23955 - Active Radiator Shutter 1
          P05A3 00 [101] - Implausible Signal
                    Mileage: 147394 km
                    Date: 2023.03.25
                    Time: 11:39:25
                    Engine RPM: 680.00 /min
                    Normed load value: 15.3 %
                    Coolant temperature: 77 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 14.316 V
                    Activation radiator shutter result: 0.00 %
                    T_AST_SAE: 599 s
                    Calculated oil temperature: 51.0 °C
                    TCO_1_SYS: 77 °C
                    Outside temperature: 22.0 °C
Readiness: 1010 0101
   Part No SW: 4M0 927 158 L    HW: 0D5 927 156 H
   Component: 0D5  30TSIUSA H03 1003
   Revision: --H03---    CVN: 3655CB50
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011_AU49.rod
   VCID: 3D2C54E69D8EC0E2245-8168
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M0 907 379 K    HW: 4M0 907 379 K
   Component: ESP9 Premium  H08 0521
   Dataset Number: 4M0909504G  0029 CVN: F1B6AFC9
   Coding: 28AA149C30A20A9A969F5899187F56A2E6269A14280C50691A186A45676459
   Shop #: WSC 47878 001 1048576
   ASAM Dataset: EV_ESP9BOSCHAU736 011006
   ROD: EV_ESP9BOSCHAU736_AU73.rod
   VCID: 3FD02EEE9782D2F2369-816A
   Part No SW: 4M0 959 760 B    HW: 4M0 959 760 B
   Component: MEM-BFS       008 0014
   Serial number: 00000173199895 Dataset Number: 4M0909866B  0013
   Coding: 000410000000B0A10060210101010000110000171700171700000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 372046CEBFB2EAB2FE9-8162
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4M0 907 182     HW: 4M0 907 182
   Component: N477 VB1 BFSv  H06 0030
   Serial number: SJ800102111501100064
   Coding: B72F00
   Valve block 2 in front seat passenger side:
   Subsystem 2 - Part No SW: 4M0 907 182 A    HW: 4M0 907 182 A
   Component: N478 VB2 BFSv  H06 0030
   Serial number: SJ8001251015011000D4
   Part No SW: 4M0 820 043 AB    HW: 4M0 820 043 AB
   Component: Klima Zone 4  H52 0083
   Coding: 6608090C55480111106C0180800000000000000000000000000000000000
   Shop #: WSC 24326 005 1048576
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 659CDC86559EA8229C5-8130
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000664752
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: 811888D7000000000001
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [008] - -
                    Reset counter: 52
                    Mileage: 147394 km
                    Date: 2023.03.25
                    Time: 09:37:16
                    Compressor shut-off condition: Shut-off from Engine Control Module (ECM) via CAN
                    Engine RPM: 707 /min
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 AG    HW: 8W0 907 063 G
   Component: BCM1 MLBevo   H12 0228
   Dataset Number: 4M0909514M  0051
   Coding: 07500363E0691CCD010F5719583E1CB911033D019000000000000000220016010869012B025509
   ASAM Dataset: EV_BCM1BOSCHAU736 015005
   ROD: EV_BCM1BOSCHAU736_015.rod
   VCID: 0052ED12AAFC6D0A0F3-8154
   Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 150912  043 0893
   Serial number: 895553?0401525501655
   Coding: 1BC7F7
   Serial number: 60892797
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 P    HW: 4M0 941 531 P
   Component: E1 - LDS  H06 0008
   Serial number: 24 09 2015  00110488
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H04 0040
   Serial number: 0000009600335Z08TR02
   Coding: 350000
   Garage door opener control head:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20151016110146 00153
   Subsystem 6 - Part No SW: 4M0 857 511 B    HW: 4M0 857 511 B
   Component: Y7_Innenspieg  H04 0002
   Serial number: GX1CE129101511520288
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 4M0 947 135 AN    HW: 4M0 947 135
   Component: J528-Dachele  H13 0080
   Serial number: Q00063260
   Subsystem 8 - Part No SW: 4M0 907 705 A    HW: 4M0 907 705 A
   Component: J866-EVLS-SG  H03 0060
   Serial number: WA121419000014983108
   Coding: 020100
   Subsystem 9 - Part No SW: 4M0 925 301 A    HW: 4M0 925 301 A
   Component: SL-Q7NF/AU736  H09 0006
   Serial number: 00000000000000020244
   Subsystem 10 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V512 LLR1SLvL  H03 0012
   Serial number: L14CF21700572
   Subsystem 11 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V514 LLR1SKvL  H03 0012
   Serial number: L14CF21000048
   Subsystem 12 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V516 LLR1SLvR  H03 0012
   Serial number: L14CF21700574
   Subsystem 13 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V518 LLR1SKvR  H03 0012
   Serial number: L14CF21000031
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 E    HW: 4M0 907 561
   Component: LRR4          H08 0220
   Dataset Number: 4M0909863K  0024
   Coding: B4779FFA78FFEC09949880A5
   ASAM Dataset: EV_ACCBOSCHAU736 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 323677DA54D00F9AC97-8166
   Part No SW: 4M0 959 655 A    HW: 4M0 959 655 A
   Component: Airbag10.44   H61 0086
   Serial number: 003M50004S7Q Dataset Number: 4M0909602WP 0001
   Coding: AECCFCC000800000A0F00033C24C00000000
   Shop #: WSC 43214 002 1048576
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005.rod
   VCID: 392440F689A6FCC208D-816C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705E0316P00165
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706E0311P00737
   Coding: 88001B
   Serial number: IBH0000J150003NU7B0G
   Subsystem 4 - Part No SW: -----------    HW: 442 063 010 15
   Serial number: 3577Y00B71A87822033W
   Subsystem 5 - Part No SW: -----------    HW: 442 063 010 15
   Serial number: 3587Y00B71A87821B4CA
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 910 15
   Serial number: 3517700B71D69104E2EJ
   Subsystem 7 - Part No SW: -----------    HW: 442 0B2 110 15
   Serial number: 3527700C11D69105A0FB
   Subsystem 8 - Part No SW: -----------    HW: 442 0C0 311 15
   Serial number: 35575009F1D72E76033J
   Subsystem 9 - Part No SW: -----------    HW: 442 0C0 311 15
   Serial number: 3567500A71D72E73626I
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 410 201 610 15
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O7800BF18AA412E026
   Part No SW: 4M0 907 129 GS    HW: 4M0 907 129 GS
   Component: Lenks.Modul   H11 0008
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 0740F60E8FD25A324E9-8152
   Part No SW: 4M0 920 890 A    HW: 4M0 920 890 A
   Component: FBenUSA       H12 0280
   Coding: 08C600E17C88D70502A369601800600000000000
   ASAM Dataset: EV_DashBoardAU736 001020
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 2E0E63AA40E82B7AADF-817A
   Part No SW: 8W8 907 468     HW: 8W8 907 468
   Component: Gateway       H12 4079
   Revision: 3N070045    Serial number: 4583N304218522 Dataset Number: 4M0909515H  0062
   Coding: 0301000100000F405207000000590030DC9200070C0000000150000000000000
   GVL: 01503C0C08000000C0FCC8000102C800110C2000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 0944F03699C62C4258D-815C
   Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
   Component: J453 MFL  H06 0002
   Serial number: 20151106133303 01237
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 2155658303
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 D    HW: 4M0 919 158 D
   Component: Klima Zone 2  H52 0080
   Coding: 000000000000000100840080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
   VCID: 363E4BCAB8B813BAE5F-8162
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0022
   ASAM Dataset: EV_LCMLeftHELLAAU736 001011
   VCID: 78A285F2F22C25CA373-812C
   Component: MEM-FS        008 0014
   Serial number: 00000173192384 Dataset Number: 4M0909856B  0013
   Coding: 001C1B000000B0A10000210101010000110000171700171700000000000000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H06 0030
   Serial number: SJ800102111501100063
   Coding: BF2F00
   Valve block 2 in front seat driver side:
   Component: N476 VB2 FSv  H06 0030
   Serial number: SJ8001251015011000D7
   ASAM Dataset: EV_LCMRightHELLAAU736 001011
   Part No SW: 4M0 907 566 B    HW: 4M0 907 566
   Component: MRR1Rear      H13 0230
   Revision: --------    Dataset Number: 4M0909535K  0012
   Coding: 1EE002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   VCID: 343A71C2AEC401AADBB-8160
   Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
   Component: TSG FS        009 0052
   Serial number: 0000174225438  Dataset Number: 4M0909872F  0026
   Coding: 005D9B005E001080000920B0
   VCID: 42D6271AE470BF1A597-8116
196665 - Switch for Central Locking
          B122D 29 [009] - Signal Implausible
                    Reset counter: 7
                    Mileage: 147344 km
                    Date: 2023.03.20
                    Time: 17:23:19
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000253749 Dataset Number: 4M0909852P  0002
   Coding: B0000101000101
   Shop #: WSC 04949 003 1048576
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   Part No SW: 8W0 907 064 CD    HW: 8W0 907 064 D
   Component: BCM2 MLBevo   015 0344
   Dataset Number: 4M0909501VF 0001
   Coding: 01341E00490100C0650B80006E01580003004000000001502F0400000F04803F001E0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU73.rod
   Subsystem 1 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000033947889
   Subsystem 2 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0816
   Serial number: 94039153
131120 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Reset counter: 47
                    Mileage: 147122 km
                    Date: 2023.03.11
                    Time: 05:52:53
                    Supply voltages-Terminal 30 power supply: 12.337 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.323 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.242 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 04 98
                    key_error_freeze_frame: 01011001 11111111 11111111 11111111
   Part No SW: 4M0 035 223 A    HW: 4M0 035 223
   Component: MIB2_amp_PD   H02 0420
   Serial number: 00000000012227 Dataset Number: 4M1909510C  0008
   Coding: 0135060A008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 211488960136840220D-8174
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M0 959 760 G    HW: 4M0 959 760 G
   Component: MEM-SR3       008 0014
   Serial number: 00000174583390 Dataset Number: 4M0909467B  0014
   Coding: FF041020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
   VCID: 3C2A59E28694C9EA13B-8168
   Part No SW: 4M0 959 792 D    HW: 4M0 959 792 C
   Component: TSG BFS       009 0039
   Serial number: 0000174371039  Dataset Number: 4M0909873E  0023
   VCID: 3E2E53EA9088DBFA3DF-816A
                    Reset counter: 87
                    Mileage: 144577 km
                    Date: 2023.01.25
                    Time: 10:30:35
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M0 035 880 N    HW: 4M0 035 880
   Component: MU-P-LNS-US   051 0384
   Serial number: A289K0FB003199 Dataset Number: 4M0909545D  0030
   Coding: 013706020000000013220002041A00102F001BE501700104BE
   Subsystem 1 - Part No SW: V03 959 802 DK    HW: -----------
   Component: NAR 2018/2019  --- 0066
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9FJ40170W
   Subsystem 3 - Part No SW: 4M0 919 615 D    HW: 4M0 919 615 D
   Component: ControlUnit_P  H14 0165
   Serial number: 09111500000000000064
   Compact disc data bank:
   Component: Gracenote2  --- 3007
          B11CF 53 [009] - Deactivated
                    Reset counter: 68
                    Mileage: 144248 km
                    Date: 2023.01.20
                    Time: 11:42:32
                    Voltage terminal 30: 14.7 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Part No SW: 4M0 907 383 C    HW: 4M0 907 383
   Component: Anhaenger     H20 0211
   Revision: 9C001003    Serial number: 0385463039 Dataset Number: 4M0909527C  0021
   Coding: 0210000200000000
   Part No SW: 4M0 907 428 B    HW: 4M0 907 428
   Component: Areaview 2    H11 0301
   Serial number: C854606JG002040 Dataset Number: 4M1909460D  0014
   Coding: 02370602BB0FA10008404000
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004013
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   VCID: 313478D651D63482B0D-8164
   Part No SW: 8W8 959 107     HW: 8W8 959 107
   Component: HDSG-Modul    H13 0153
   Revision: --------    Serial number: 30338413000000 Dataset Number: 4M0909541F  0021
   Coding: 00B0
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   ROD: EV_DeckLidCONTIAU736_AU37.rod
   VCID: 065EFB0A88D8433A35F-8152
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M0 907 777     HW: 4M0 907 777
   Component: Fahrwerk-SG   H10 0102
   Serial number: 0811150132 Dataset Number: 4M0909576N  0040
   Coding: B8505848F8
   ASAM Dataset: EV_ChassContrContiAU736 002013
   ROD: EV_ChassContrContiAU736.rod
   VCID: 76BE8BCAF83853BA25F-8122
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 589 B    HW: 4M0 907 589 B
   Component: V66LFKompOLV  H06 0012
   Serial number: 00000000004130030294
   Coding: 303030
   Part No SW: 4M1 713 041 D    HW: 4M1 713 041 D
   Component: GSM-LL        H07 0068
   Revision: 0L0D5012    Serial number: 20151009001832
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 261E9B8A6818633A55F-8172
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 4M0 919 617     HW: 4M0 919 617
   Component: HeadUpDisplay H26 1524
   Coding: 4F00C0
   ASAM Dataset: EV_HudNSEIKAU736 001012
   ROD: EV_HudNSEIKAU736_AU73.rod
   VCID: 72B6B7DA94504F9A097-8126
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 E    HW: 4M0 907 541
   Dataset Number: 4M0909885H  0021
   ASAM Dataset: EV_ACC2BOSCHAU736 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 30327DD25ADC3D8ABF3-8164
   Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
   Component: BVS           H12 0042
   Dataset Number: 4M0909466J  0038
   Coding: 0407030600000202032023A7AD0000B4B0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
   VCID: 2F307EAE47E22272A69-817A
   Part No SW: 4M0 959 795 D    HW: 4M0 959 795 C
   Component: TSG HFS       009 0039
   Serial number: 0000174518673  Dataset Number: 4M0909897E  0024
   Coding: 004D9B0000001080400820A0
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 41D42816E176A40240D-8114
                    Reset counter: 158
                    Mileage: 145267 km
                    Date: 2023.02.11
                    Time: 13:17:33
   Component: TSG HBFS      009 0039
   Serial number: 0000174518674  Dataset Number: 4M0909896E  0024
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
   Part No SW: 4M0 907 594     HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Dataset Number: 4M0909469E  0013
   Coding: 208000053602
   VCID: 73B8B2DEEB4A4692021-8126
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4M0 909 145 G    HW: 4M0 909 145 D
   Component: HAL_MLBevoH07 0607
   Revision: --------    Serial number: CCC_007_D_07_03 Dataset Number: 4M0909904H  0017
   Coding: 008428
   ASAM Dataset: EV_RearAxleSteerZFAU736 005010
   ROD: EV_RearAxleSteerZFAU736_005.rod
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 B    HW: 4M0 907 590
   Revision: --------
   Coding: 1EE002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001015
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   Dataset Number: 4M0909471C  0011
   ROD: EV_LEDModLeftMELCOAU736_AU73.rod
   VCID: 167EAB4AD878F3BAC5F-8142
   Component: LED1R         H09 0003
   Dataset Number: 4M0909472C  0011
End----------(Elapsed Time: 03:15, VBatt start/end: 14.4V/14.4V)-----------
Is this a used part? Are you sure you have the correct / exact part number?
Perhaps you could list the PN you have as others here on the forum can
check as well.
Thanks for the A.S.
gtg196w
C?ID=105780
no, got it from the dealer new. The only maybe strange thing about my situation is i had the ecu software updated per the active radiator shutter TSB by the dealer.
the other strange thing is that I just did a 3mile drive and the check engine light is gone (usually I also have a stuck open or stuck closed fault that seems to trigger the check engine light). I'm skeptical this will remain the case though, motor's gotta figure out where the shutter physical open and closed positions are right?
PN: 95B-965-501-AA
I'm not sure, but perhaps it needed a few key cycles to self adapt. I would let it be as is and see what develops ; you may be all set as the CEL going off (IMO) is a great sign.
gtg196w
C?ID=105780
sounds like good plan.. really don't want to clip all the bumper's fender tabs back in lol... cannot believe how painful it was to release those, especially when the shop manual said to just "pull" for that step.
gtg196w
C?ID=105780
Ughh... CEL came on after a longer drive. now also have the "radiator shutter stuck open fault".
I also just noticed that whenever I first click on the engine module, I get a warning saying there's a missing VIN... It gives me the option to continue using UDS, whatever that means.
Tried putting it back to closed manually, and redoing the adaptation, but no luck... :(
gtg196w
C?ID=105780
Alright well I took it to a shop to see if they could use Odis to do the adaptation. They decided to give VCDS a quick shot… it worked….. super weird. Oh well..
