RS4 4.2 B8.5 8113 - Performance Malfunction in Cooling System P2181 00 [237]
BenJones
C?ID=170414 (NRRT)
Dear support,
Plesae could you help me diagnose a problem with my RS4?
I've done some DIY. The temp sensor seems fine as it steadily reads temp. So I was thinking this is a problem with the thermostat. I check all values with VCDS realting to coolant temps and found that the Max coolant temp is set to -48 degrees and the min coolant temp is set to 148 degrees. Could this be my problem? I've had this issue since I bought the card second hand. If this is the issue, how do I use the Rosstech device to re-program these temperatures please?
Fault code is as follows:
P2181 00 [237] - -
Mileage: 79189 km
Date: 2023.03.08
Time: 09:23:45
Engine RPM: 2863.50 /min
Normed load value: 19.2 %
Vehicle speed: 109 km/h
Coolant temperature: 55 °C
Intake air temperature: 12 °C
Voltage terminal 30: 14.159 V
selected gear-Bits 0-7: 6
Cruise control switch actuation-Bits 0-7: 0
I've done some DIY
Viking
C?ID=151455
First things first, please follow the link below and post a complete (unedited) autoscan from the vehicle in question.
Please post a complete and unedited Auto-Scan. Note: the VCDS you use needs to be a Genuine Interface ; if your not sure regarding the legitimacy of your "cable" ask the Administrators.
BenJones
C?ID=170414 (NRRT)
Hi Viking and stefdds,
Thanks very much for your help. I cleared all the fault codes so had to wait until it reappeared. Please see full list below and also the fault in question.
Saturday,01,April,2023,15:52:26:57579
VCDS Version: 22.10.0.1 (x64)
VIN: WUAZZZ8K0FA900071   License Plate:
Gateway Installation List:  8R0 907 468 N
Saturday,01,April,2023,15:53:05:57579
VCDS Version: Release 22.10.0 (x64) Running on Windows 10 x64
                Address 01: Engine       Labels: 079-907-560-CFS2.clb
Control Module Part Number: 8T2 907 560 E    HW: 8T1 907 560
  Component and/or Version: 4.2l V8HDZ /  H04 0003
           Software Coding: 1225003225A6000A2000
            Work Shop Code: WSC 06208 000 00000
              ASAM Dataset: EV_ECM42FSI0118T2907560E 001002 (AU48)
                       ROD: EV_ECM42FSI0118T2907560E.rod
                      VCID: 3E73F981A1975E7DB0-806A
          P2181 00 [101] - -
                    Mileage: 79785 km
                    Date: 2023.03.26
                    Time: 08:31:53
                    Engine RPM: 2933.50 /min
                    Normed load value: 49.4 %
                    Vehicle speed: 134 km/h
                    Coolant temperature: 66 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 14.229 V
                    selected gear-Bits 0-7: 7
Readiness: 0000 0001
Any idea?
Thanks,
Ben
Viking
C?ID=151455
Do another scan please, and post the complete Autoscan without editing it.
BenJones
C?ID=170414 (NRRT)
Dear Viking,
Complete scan:
Monday,03,April,2023,19:28:42:57579
VCDS Version: 21.3.0.0
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 1B 22 30 36 42 44 46 47 52
          53 56 5F 62 6C 6D 72
VIN: WUAZZZ8K0FA900071   Mileage: 79890km-49641miles
Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
   Part No SW: 8T2 907 560 E    HW: 8T1 907 560
   Component: 4.2l V8HDZ /  H04 0003
   Revision: NAH04---
   Shop #: WSC 06208 000 00000
   VCID: 3E73F981A1975E7BF1-806A
          P2181 00 [101] - -
                    Mileage: 79785 km
                    Date: 2023.03.26
                    Time: 08:31:53
   Part No SW: 8T0 927 156 J    HW: 0B5 927 156 K
   Component: 0B5 42 FSIRdW H02 0004
   Revision: --H02---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 44878B69CF7B34ABA7-8010
   Part No SW: 8T0 907 379 G    HW: 8T0 907 379 G
   Component: ESP8 quattro  H09 0010
   Coding: 342DEA
   VCID: 46839161F14706BBB9-8012
   Part No SW: 8K0 907 064 JG    HW: 8K0 907 064 JG
   Component: BCM2 2.0      H14 0650
   Coding: 01924040000000000000
   VCID: 7EF33981E9179E7BB1-802A
   Subsystem 1 - Part No SW: 8K0 959 754 CH    HW: 8K0 959 754 CH
   Serial number: 0514000070900006
   Serial number: 0214000088933012
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01200520140161
   Coding: 4804000000
   VCID: 78FF2F99CB33A04BFB-802C
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000817272001
   Coding: 0600001000349FF03D8140C3000019090F9DC70A23090201000008004400010200020034000000
   VCID: 7AFB3591F53FB25B8D-802E
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 170514  H06 0080
   Serial number: SWF14055175048
   Coding: 00FD11
   Serial number: 22692052
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001005141472
   Subsystem 4 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 30388E27000000000001
Address 14: Susp. Elect.        Labels: None
   Part No SW: 8T0 907 376     HW: 8T0 907 376 A
   Component: J250 DRC FahrwerH01 0030
   Revision: 00000000    Serial number: 00875015595500
   Coding: 0000000
   Shop #: WSC 06435 000 00000
   VCID: 7CF733893F0B8C6B9F-8028
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KFDC1TH0O
   Coding: 30534435363030303030554A3052384B3053
   Shop #: WSC 57001 001 1048576
   VCID: 489F9F59F35310CB4B-801C
   Serial number: 6334MSME45490D5AN
   Serial number: 6344MSME4549260EI
   Serial number: 6352QSME6642395CO
   Serial number: 6362QSME323D5640E
   Serial number: 63732SME29431C5C4
   Serial number: 63832SME2943114E
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372NEL000QT
   Coding: 000037
   VCID: 44878B69C77B34ABA7-8010
   Part No SW: 8K0 920 983 D    HW: 8K0 920 983 D
   Component: KOMBIINSTR.   H35 0564
   Revision: 00200000    Serial number: ZCN54KD5F
   Coding: 33AF1100BB012600010000
   VCID: 3663E1A181A7963B29-8062
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y1452107FA
   Coding: 80E3031600
   VCID: 4A9BA551E55FE2DB5D-801E
   Serial number: 0666803403
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Revision: 52001005    Serial number: --------------
   Coding: 030000
   VCID: 3979EA9DB0B97943C4-806C
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H14 0100
   Serial number: 001005140001025
   VCID: 2F6DD4C576FDA7F36A-807A
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0020
   Revision: S0H04000    Serial number: 00000000103638
   Coding: 01010101000000000001000102
   VCID: 2D51CECD74F1D5E358-8078
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000102016712
   Coding: 00781300000000000000
   VCID: 3B75F095BA854B53D6-806E
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C02205E21410001
   VCID: 56A3412121E7B63BC9-8002
   Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0001449486
   Coding: 010000010001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3561E6AD94A19D2320-8060
   Revision: 00002001    Serial number: 0336881404
   Coding: 013B0622A0B938948330023280000000
   Subsystem 3 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J245 PS151  H08 0043
   Subsystem 4 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J394 PS240  H08 0043
   Revision: 00005001    Serial number: 94813030043904
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   VCID: 55A1462D3CE1BD23C0-8000
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 00000001484394
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7BF591BDBF725BCD-806E
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109E 0E7930536
   Coding: 010103010000000001
   VCID: 285F3FD95B13F0CBAB-807C
   Part No SW: 8R2 035 666 G    HW: 8R2 035 666 C
   Component: H-BN-EU       H47 0809
   Revision: --------    Serial number: 206ES0EB002282
   Coding: 120101010306A1EF45808B5E00000403E40000020000000000
   VCID: 3D71FE8DA4914563E8-8068
   Subsystem 1 - Part No: 8R0 060 884 BT
   Component: EUR 2014  1903
   Component: DU7 High  H42 0104
   Serial number: A130EL0E3036244
   Subsystem 3 - Part No SW: 8T0 919 611 M    HW: 8T0 919 611 H
   Serial number: 00000001864198
   Component: CD-Database  5950
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C02204021210001
   VCID: 59B94A1D50F99943E4-800C
   Revision: --H09---    Serial number: 525PA8-J4392UV
   Coding: 1021007
   VCID: 387FEF994BB3604B3B-806C
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
   Component: J605  Master  H53 0330
   Revision: --------    Serial number: 8K9827851C
   VCID: 3E73F981A9975E7BF1-806A
   Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
   Component: J756  Slave  H53 0330
   Serial number: 8K9827852C
   Component: TSG HR        H07 0305
End-------------------------(Elapsed Time: 04:29)--------------------------
BenJones
C?ID=170414 (NRRT)
I didnt know how to upload a photo so I've used my profile photo to show what I think might be a software problem.
-48C is generally indicative of an open circuit to the sensor in question.
Oh, and not every measuring value in every control module contains meaningful data. Some of them are there as place-holders.
BenJones
C?ID=170414 (NRRT)
Thanks Uwe. Iff you look at the first parameter in the list 'Coolant Temperature' - it is measuring 100 deg C. The coolant temperature does rise in a linear fashion so i seems the coolant temerature snesir is measuring correctly.
BenJones
C?ID=170414 (NRRT)
Hi Uwe,
I've bought a new waterpump with internal thermostat and will install this. I also have a coolant temop sensor as well. Once instlalled I'll update the forum and let you guys know which part rectified this issue for our learning.
I contacted Audi and showed them the fault code but they said that it's not an audi diagnostic fault code and therefore they couldn't confirm which part was required to rectify the fault. They charge £140 (circa $180) for a diagnostic readout which I personally think is extortionate and they say that their diagnostic readout will always tell them the faulty part. Apparently the AUDI diagnostic fault codes start with a 'J'? I wondered if you have a conversion table which matches rossTech fault codes to VAG fault codes?
Whoever told you that is full of it. We have the factory software. Fault codes are the same.
BenJones
C?ID=170414 (NRRT)
I thought that might be the case. It's Audi trying to make $$$ out of them diagnosing what we already know.
