CEL on for P1136 & 1138 so o2 Sensors? (2004 S4)
ElectricMayo
C?ID=546632
I have a constant ABS and ESP light on any advice on where to start is appreciated
Thursday,23,March,2023,17:32:35:42693
VCDS Version: 23.3.0.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: WAUPL68E54A228260   License Plate: OO0-000
Mileage: 259960km-161531mi   Repair Order:
          67 69 75 76 77
VIN: WAUPL68E54A228260   Mileage: 259960km-161531miles
Address 01: Engine        Labels: 079-910-560-BBK.lbl
   Part No SW: 8E0 910 560 A    HW: 8E0 907 560
   Component: 4.2L V8/5V      G   0020
   Coding: 0007711
   Shop #: WSC 93023 999 01307
   VCID: 2313FC74C7CF9442321-5160
   VINID: 9D1960706215144442088086005FFF5251
18010 - Power Supply Terminal 30
17544 - Fuel Trim: Bank 1 (Add)
            P1136 - 001 - System too Lean - MIL ON
17546 - Fuel Trim: Bank 2 (Add)
            P1138 - 001 - System too Lean - Intermittent
Readiness: 0000 1000
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 Q
   Component: ABS/ESP allrad      4533
   Coding: 04595
   Shop #: WSC 12345
   VCID: 36353520615D11EAE5F-51CE
            57-00 - Electric Circuit Failure
   Part No: 8E0 820 043 AD
   Component:   A4 Klimaautomat   1323
   Coding: 00000
   Shop #: WSC 63351
   VCID: 6393BC74824FD442721-513C
            41-10 - Blocked or No Voltage - Intermittent
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  KAN 0517
   Coding: 01014
   Shop #: WSC 63351
   VCID: 3537322C7C5B1AF2EC5-4B00
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 K
   Component: Airbag 8.4EP        1001
   Coding: 0010607
   Shop #: WSC 63351 000 00000
   VCID: 3FDB50044B67D0A2369-5184
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0611
   Coding: 01041
   Shop #: WSC 63351
   VCID: 3E252D00496DD9AA3DF-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.clb
   Part No: 8E0 920 931 A
   Component: KOMBI+WEGFAHRS. RB4 D42
   Coding: 01231
   Shop #: WSC 05136
   VCID: 2615E560B1FD616A55F-5160
   WAUPL68E54A228260     AUZ6Z0D0006979
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   Shop #: WSC 63351
   VCID: 71BFC63C488376D2F0D-4B3C
   Part No: 8E0 959 433 BB
   Component: Komfortgerát T7B    1512
   Coding: 11788
   Shop #: WSC 63351
   VCID: 72BDC9304DB54DCA097-4B00
   Subsystem 1 - Part No: 8E1959801
   Component: Tõrsteuer.FS BRM 0004
   Component: Tõrsteuer.BF BRM 0004
10 Faults Found:
            49-00 - No Communications
00962 - Alarm via. Tilt Sensor
            35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 - -
01374 - Alarm triggered by Terminal 15
            35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
            35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
            35-00 - -
00956 - Key 2
            35-10 - - - Intermittent
01561 - Rear left door
            59-10 - Can't Unlock - Intermittent
01562 - Rear right door
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00060
   Shop #: WSC 63351
   VCID: 04519FE86731737A2BB-4B3C
End----------(Elapsed Time: 05:34, VBatt start/end: 12.1V/12.1V)-----------
Hi and welcome.
Additive (idle) fuel trim lean is most often due to an intake air leak.
Check wiring diagram for your car to see if you have a separate brake pressure sensor. If so,check wiring and connectors for it. Some ABS module have the integral to the module. If that's the case with yours, you'll need a new ABS module.
ElectricMayo
C?ID=546632
i have sprayed the intake down while it was cold with some carb cleaner and no jumps in idle smoke test ?
The G201 is your main problem and from memory that is inside the Bosch ABS pump.
ElectricMayo
C?ID=546632
well i have a sensor on the side of the pump which i believe is it its reading 290+ bar so and the pop up says thats a short to plus what does that mean ?
Start with a new sensor, 8E0 907 597.
