Speakers not working
kats20t
Australia
C?ID=414983
Audi 2016 SQ5 was running a scan and 4 speakers are simultaneously not working.
I've checked the fuses passenger and trunk.
I read sometimes the amplifier gets wet from blocked sunroof drains but no evidence of this.
Played around with the fader/ balance controls no difference.
Car is on original battery.
Before I start removing amplifier and/or door cards can anyone offer some advice?
Thanks Michael.
Sunday,05,March,2023,21:58:56:28944
VCDS Version: 21.3.0.0  HEX-V2 CB: 0.4543.4
Workshop Code: 444 29511 000000
VIN: WAUZZZ8R8GA140822   License Plate: DTG 6 MARCH
Mileage: 99700km-61950mi   Repair Order:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 36 3C 42 44 46 47 52 53
          56 5F 62 69 6C 6D 72 A9 AC C0
VIN: WAUZZZ8R8GA140822   Mileage: 99700km-61950miles
Address 01: Engine (J623-CVUB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 589 C    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0008
   Revision: 54H23---
   Coding: 2A2A4032257603030000
   Shop #: WSC 29511 444 00000
   ASAM Dataset: EV_ECM30BTD0118K5907589C 001010
   ROD: EV_ECM30BTD0118K5907589C.rod
   VCID: 41DF4163A10EDB03C0D-8014
   Part No SW: 8R0 927 158 AR    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H19 1006
   Revision: --H19---
   VCID: 0D47AD53ADD64F63F45-8058
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 BF    HW: 8R0 907 379 BF
   Component: ESP8 quattro  H09 0020
   Coding: 35DD0C01
   Shop #: WSC 06335 123 12345
   VCID: 05579573F5263723BC5-8050
   Part No SW: 8K0 907 064 KR    HW: 8K0 907 064 KR
   Component: BCM2 2.0      H15 0711
   Coding: 05B54000000000000000
   Shop #: WSC 06335 000 00000
   VCID: 0A4DA64FDC38585BD17-805E
   Part No SW: 8K2 820 043 AP    HW: 8K2 820 043 AP
   Revision: D0000000    Serial number: 01150420160528
   Coding: 3625628080
   VCID: 77ABEFBBBFCA55B3BE9-8022
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00001330882601
   Coding: 260000108074AFE2018140C000001D0D0F9DE70827090201000008004401010200020034000000
   VCID: 7AADF68F8CD848DBC17-802E
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 160331  H13 0050
   Serial number: 90243015160225105720
   Coding: 01DD13
   Serial number: 61663627
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000804161616
   Subsystem 4 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 6 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 4172573900PAG0MUFU03
02235 - Stationary Cornering Lamp (Left) (M51)
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 214
                    Mileage: 99670 km
                    Date: 2023.03.06
                    Time: 05:59:19
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H11 0110
   Coding: 008189
   VCID: 372B2FBBFF4A95B37E9-8062
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H49 0610
   Serial number: 003JPDD24J6I
   Coding: 304A3531313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 48C95C478234EA4B073-801C
   Serial number: 6334MSME56782C7EY
   Serial number: 6344MSME56784C0FV
   Serial number: 6352QSME716B3C62P
   Serial number: 6362QSME4D6B3E7A3
   Serial number: 63732SME4F541F7CJ
   Serial number: 63832SME2E54025C1
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372PDG0009X
   Coding: 00003F
   VCID: 44D14877BE9CCE2BEBB-8010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 931 G    HW: 8R0 920 931 G
   Component: KOMBIINSTR.   H35 0567
   Revision: 00300000    Serial number: 03G26GD4H
   Coding: B3A722000F010008010000
   VCID: 392F2983C95E83C388D-806C
   Part No SW: 8R0 907 468 AA    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0070
   Revision: 1Z130032    Serial number: 3241Z16331011C
   Coding: 80CD07FF00
   VCID: 7EA5FA9F90F064FBFDF-802A
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 6514999803
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 16098002909011200410
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02022064747464545425363E00
   VCID: 7CA1F09786EC76EBD3B-8028
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000193867814
   Coding: 01781B00000000000000
   VCID: 42DD4E6FA488C01BD97-8016
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H07 0071
   Serial number: 0401543435
   Coding: 010312
   Shop #: WSC 06334 000 00000
   VCID: 3FDB479BD7FAADF3B69-806A
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H07 0071
   Serial number: 0401584843
   Coding: 010312
   Component: TSG FA        H03 0511
   Revision:             Serial number: 0000195435664
   Coding: 011D13215E01440004
   VCID: 4FFB775B67DA3D73469-801A
   Part No SW: 8R0 909 144 Q    HW: 8R0 909 144 L
   Component: RCevo         H54 0702
   Revision: 00000001    Serial number: 0000840821
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 104002
   ROD: EV_RCEPSAU48X_104.rod
   VCID: 46D5527F8820FC3BF5F-8012
   Revision: 00002001    Serial number: 0399571281
   Coding: 01000E3A20B930958720053680040047
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
   Revision: 00005001    Serial number: 94813058250107
   VCID: 2D070DD30D162F63145-8078
                    Reset counter: 212
                    Voltage: 12.30 V
                    Temperature: 28.0°C
                    Temperature: 29.0°C
                    Bin. Bits: 00000100
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 212
                    Voltage: 12.30 V
                    Temperature: 28.0°C
                    Temperature: 29.0°C
                    Bin. Bits: 00000100
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Fault Status: 00101011
                    Fault Frequency: 18
                    Reset counter: 1
                    Voltage: 12.30 V
                    Temperature: 28.0°C
                    Temperature: 29.0°C
                    Bin. Bits: 00000100
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                    Fault Frequency: 18
                    Reset counter: 1
                    Voltage: 12.30 V
                    Temperature: 28.0°C
                    Temperature: 29.0°C
                    Bin. Bits: 00000100
   Component: TSG BF        H03 0511
   Revision:             Serial number: 0000195663439
   VCID: 4EC56A5F60D0347B4DF-801A
   Component: EPB-4         H03 0005
   Revision: --------    Serial number: 00000001798622
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2D368FCCD888DB817-806E
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109D$0G2545386
   Coding: 040103010000000001
   VCID: 2B0303CB330221530A1-807E
   Part No SW: 8R2 035 764 L    HW: 8R2 035 764 J
   Component: H-BNT-RW      H50 0946
   Revision: --------    Serial number: 521D-0G7515644
   Coding: 1A0A01060205A9EF75808B4E000004035C0000000000000000
   VCID: 41DF4163A18EDB03C0D-8014
   Subsystem 1 - Part No: 8R0 060 884 DJ
   Component: ROW 2016  0806
   Component: DU7 High  H42 0104
   Serial number: A130DZ0G3561497
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000002513696
   Component: CD-Database  6890
   Component: TSG HL        H02 0510
   Revision:             Serial number: 0000195695296
   Coding: 010C13204001240004
   VCID: 46D5527F88A0FC3BF5F-8012
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
   Component: Anhaenger     H12 0100
   Revision: 1G001001    Serial number: 00000440290371
   Coding: 0300000000000000
   VCID: 353725B3E54667A36C5-8060
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H11---    Serial number: 525PA8-JB2A0T4
   Coding: 1030010
   VCID: 343118B7E23C7EAB5BB-8060
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D273D93DD76BFE3A45-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H02 0510
   Revision:             Serial number: 0000195695424
   Part No SW: 8R0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0007
   Serial number: 160308200481
   VCID: 79AFE983895E43C3C8D-802C
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 160910040
   ROD: EV_RDCMA00100.rod
   VCID: 2F3B17DB079A5D73269-807A
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 8R0 907 160 A    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H10 0008
   Serial number: 160402200198
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 323D1EAF14A8709B497-8066
End----------(Elapsed Time: 02:29, VBatt start/end: 12.2V/12.2V)-----------
Interesting how all of the speakers went "down" together. I think a wiring diagram would help trace the common wire that energizes the circuit; you wouldn't think one bad speaker would delete all sound, but I don't know how they are wired. You can check each front door speaker for corrosion or a "open" broken wire, but I think the problem maybe further up stream (amplifier??).
If you get to the back of the amp, and you can determine the speaker wire(s), you could place some temporary overlay wiring to the vehicles speaker(s) to test the amp and vehicle speaker circuits.
Let us all know what you ultimately find!
Reset counter: 212
Voltage: 12.30 V
Temperature: 28.0°C
Temperature: 29.0°C
Bin. Bits: 00000100
Reset counter: 212
Voltage: 12.30 V
Temperature: 28.0°C
Temperature: 29.0°C
Bin. Bits: 00000100
siLc
Tallinn, Estonia
C?ID=330192
Usually, in case of sound systems, there is no "common wire" for a set of speakers. All the speakers have a discrete connection (plus and minus wire) to the amp, with the exception of treble and midbass speakers which can be connected in parallel.
Since all the bass speakers went out at once, then an amp internal electrical fault can be suspected. But you can still inspect the wiring inside the wiring boots between the body and doors.
kats20t
Australia
C?ID=414983
Hugely late response but for people's curiosity both front speakers were blown and replaced.
I had checked the amp rear left for water damage prior to removing door cards.
The rears are intermittent according to VCDS so expect they will fail in future and need replacing.
Thanks Michael.
