Touareg 7P Parasitic draw
pietpetoors
South Africa
C?ID=545045
I battle to find a parasitic draw draw on a 2012 Touareg 7P . It draws about 3.5 Amp all the time.
I unplugged fuses with no success in finding the culprit.
Searched for a tracking device and so far could not find any.
I hope that someone can see something in all the fault codes that can lead me in the right direction.
Everything on the car works. I see there are fault codes on doors, clusters, etc, but everything work.
There is a type of phone thing in the glove compartment, I unplugged it in my search for the draw. It did not make a difference
on the draw and the bluetooth phone is still working so I kept it unplugged.
Friday,24,March,2023,12:19:46:06875
VCDS Version: 23.3.0.0 (x64)  HEX-V2 CB: 0.4631.5
VIN: WVGZZZ7PZCD045107   License Plate:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 11 31 15 16 17 19 28 2E 34 36 42 46 52
          53 55 56 62 6D 72 77 A7
VIN: WVGZZZ7PZCD045107   Mileage: 89971km-55905miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Cannot be reached 0100
A7-Infotain. Interface -- Status: Malfunction 0010
Address 01: Engine (J623-CKDA)       Labels:. 057-907-409-V2.clb
   Part No SW: 7P0 907 409 D    HW: 7P0 907 409
   Component: 4.2TDI EDC17  H17 0001
   Revision: 52H17---    CVN: 7BD47759
   Coding: 292A0012432E00010000
   Shop #: WSC 04467 996 83643
   ASAM Dataset: EV_ECM42TDI1117P0907409D 001001
   ROD: EV_ECM42TDI1117P0907409D.rod
   VCID: 382DE5B8E2D2267AF73-806C
   VINID: 9E65EAAAA1E0A935001050401CB284B131
10585 - Door Control Module - Passenger's Door
          U0200 00 [032] - No Communications
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:27:52
                    Engine RPM: 683.00 /min
                    Normed load value: 31.8 %
                    Coolant temperature: 56 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 11.660 V
                    Unlearning counter according OBD: 31
                    CAN status - engine control module-Bits 0-7: 00000000
                    Cruise Control System (CCS): status-Bits 0-7: 00101111
                    CAN status - transmission control module-Bits 0-7: 00000000
                    CAN status - brake control module 1-Bits 0-7: 00000000
                    CAN status - brake control module 2-Bits 0-7: 00000000
                    selected gear-Bits 0-7: 00000000
10586 - Door Control Module - Rear Left
          U0201 00 [032] - No Communications
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:27:52
4715 - No Communication with Instrument Cluster
          U0155 00 [032] - -
          [Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:27:51
                    Engine RPM: 734.00 /min
                    Normed load value: 19.2 %
                    Voltage terminal 30: 11.580 V
4721 - Ride Level Control Module
          U0132 00 [032] - No Communications
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:27:51
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 K    HW: 0C8 927 750 K
   Component: AL1000 AISIN  001 1859
   Serial number:                CVN: 179D8FE8
   Coding: 001168
   Shop #: WSC 27673 004 1048576
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_VW52.rod
   VCID: 3435D188FEBAC21ADBB-8060
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 J    HW: 7P0 907 379 A
   Component: MK25A         H36 0433
   Revision: --------    Serial number: 403720010EC010 Dataset Number: 7P0012v____ 7P16
   Coding: 5B6B53C30B282558DAF5CA93D0D9A440F700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 44D58148AE1A729A6BB-8010
   Part No SW: 4H0 907 064 BM    HW: 4H0 907 064 BM
   Component: BCM2 2.0      H31 0333
   Coding: 05960000000000000000
   VCID: 75B32C8CB5C09B122C5-8020
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000262392012
                    Fault Status: 00101101
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 21:35:10
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 4 Zonen H20 1305
   Coding: 3826207AC0
   VCID: 7EA133A08076D84A7DF-802A
0249 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:27:54
0318 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:27:54
   Part No SW: 4H0 907 063 BL    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0111
   Revision: 15012002    Serial number: 00000001397441
   Coding: 26001011D1345D010021000300005D0C431D470803010241000000020000
   VCID: 73B71294BBB48522021-8026
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    111124  31  0020
   Serial number: 90243401120109150529
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10309841
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
   Serial number: 00000000001612110421
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0021
   Revision: --------    Serial number: 28261203001071
   Coding: 108501
   ASAM Dataset: EV_VW526ParkiAssis2 001011
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 42D98750B40E7CAA597-8016
Address 11: Engine II (J624)       Labels: None
   Revision: 52H17---    CVN: C3C46D47
   ASAM Dataset: EV_ECM42TDI2117P0907409D 001001
   ROD: EV_ECM42TDI2117P0907409D.rod
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:27:52
                    Normed load value: 23.5 %
                    Voltage terminal 30: 11.640 V
                    Cruise Control System (CCS): status-Bits 0-7: 00000000
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:27:52
          U0155 00 [032] - -
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:27:51
                    Normed load value: 18.4 %
                    Voltage terminal 30: 11.600 V
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:27:51
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag01P H05 0025
   Revision: --------    Serial number: 003L0001L3FL Dataset Number: 7P6003v____ 0967
   Coding: 000000000000000000000000000000003150
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 41DB885CB10867B240D-8014
   Serial number: 3575LRB405N12NLA6PRB
   Serial number: 3585LRB405512NLAB9UT
   Serial number: 3515RRB405713B6C6O4X
   Serial number: 3525RRB405513B6CL8K4
   Serial number: 3555NRB4069126SEIOV7
   Serial number: 3565NRB4069126SEI196
   Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
   Revision: --------    Serial number: 90815LAU000B9
   Coding: 000015
   VCID: 3631EB80E846D00AE5F-8062
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0148218
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 882     HW: 7P6 920 882
   Component: Kombi         H14 0253
   Revision: 12240067    Serial number: 658300112592042
   Coding: 333733003A000008000002
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 7AA93FB09C5EF46A417-802E
16776982 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Fahrwerk_05 keine Kommunikation]
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:27:53
   Part No SW: 7P6 907 530 B    HW: 7P6 907 530 B
   Component: Gateway-CAN-L H08 5202
   Revision: --------    Serial number: 00000000393246
   Coding: 0001037D00
   GVL: FB6E46C51E23810000
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 372FE684EFCC2902FE9-8062
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650826347
5072 - Door Control Module - Driver's Door
          U0199 00 [008] - No Communications
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:39:07
                    Voltage terminal 30: 11.7 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 11 °C
                    System status: Awake_Timer_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
5073 - Door Control Module - Passenger's Door
          U0200 00 [008] - No Communications
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 21:35:09
                    Voltage terminal 30: 11.9 V
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
5074 - Door Control Module - Rear Left
          U0201 00 [008] - No Communications
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 21:35:09
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
5075 - Door Control Module - Rear Right
          U0202 00 [008] - No Communications
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:39:07
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
66454 - Ride Level Control Module
          U0132 00 [008] - No Communications
          [Steuergerät für Niveauregulierung keine Kommunikation]
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:25:07
                    Control Module temperature: 31 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
5467 - Media player in position 3
          U1062 00 [009] - No Communication
          [Mediaplayer Position 3 keine Kommunikation]
                    Reset counter: 200
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 21:27:17
                    Voltage terminal 15: 11.9 V
                    Control Module temperature: 12 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 7P6 907 049 P    HW: 7P6 907 049 P
   Component: Klima Fond    H14 1305
   Coding: 0000000000
   ASAM Dataset: EV_AirCondiHeck 001007
   ROD: EV_AirCondiHeck.rod
   VCID: 4AC9AF708C3EA4EA917-801E
Address 2E: Media Player 3
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 K    HW: 7P0 907 553 K
   Component: PASM          H01 1110
   Revision: 00000000    Serial number: 00000120220480
   Coding: 14210000
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
   VCID: 3FDF8EA4C7FC1142369-806A
0628 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Fault Frequency: 240
                    Reset counter: 1
                    Mileage: 888576 km
                    Date: 2058.01.02
                    Time: 17:28:55
                    Default: 00
                    Default: 7D
                    Default: 00
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000022763294
   Coding: 00781B0000004001000001010101202020202121202020
   VCID: 3435D188FE3AC21ADBB-8060
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:39:07
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000123961837
   Coding: 011D1620DE01451005080002
   VCID: 44D58148AE9A729A6BB-8010
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 21:35:14
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 21:35:14
   Revision: 00002001    Serial number: 0169620563
   Coding: 011A1E2228B9108180200620010000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 21:35:10
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 21:35:10
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:39:07
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:39:07
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 209
                    Mileage: 89584 km
                    Date: 2023.03.22
                    Time: 11:38:02
02615 - Fuel Tank Cap; Lock
                    Reset counter: 209
                    Mileage: 89586 km
                    Date: 2023.03.22
                    Time: 11:44:02
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000123811062
   Coding: 011D1620DE01451005080000
   VCID: 3B27FAB4D3640D621A1-806E
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:39:12
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:39:12
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: A121270006A    Dataset Number:             A001
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 3631EB80E8C6D00AE5F-8062
   Slave 3:
0065 - Terminal 15
          U1405 00 [008] - Implausible signal
          [Steuergerät EPB - Zündungssignal unplausibel]
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:27:51
                    Voltage: 11.6 V
0016 - Indicator Lamp in Controls
          C1014 14 [008] - Short to Plus
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:27:53
                    Voltage: 11.0 V
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Revision: --------    Serial number: -------------- Dataset Number: 7P0036v____ 0009
   Coding: 012E00000F000200
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CA539A8966ACA5A53B-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
13705473 - Databus
          [Timeout Fahrwerk_01_FR]
                    Reset counter: 240
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 22:27:53
Address 56: Radio (J503)       Labels: None
   Part No SW: 7P6 035 195     HW: 7P6 035 195
   Component: RCD550        131 0208
   Revision: AA001001    Serial number: VWZ8Z3M87001J4
   Coding: 0100042004000000B0FCBD1300
   VCID: 74B51188BEBA821A1BB-8020
03272 - Control Module for Audio Interface
                    Reset counter: 200
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 21:27:45
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000124134044
   Coding: 011C16200001251005080000
   VCID: 3A29FFB0DC5E346A017-806E
   Part No SW: 7P6 959 107 A    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0620
   Revision: 22010001    Serial number: 026200164 Dataset Number: 7P6959107A  D043
   Coding: 0533314002
   ASAM Dataset: EV_HeckkTouar 202137
   ROD: EV_HeckkTouar.rod
   VCID: 3D23F4ACCDF00352245-8068
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000123115384
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B
   Component: Telefon       015 0723
   Revision: --------    Serial number: 35909603306654
   Coding: 020000000000000000000000
   ASAM Dataset: EV_UHVPremi A02003
   ROD: EV_UHVPremi_A02.rod
   VCID: 221927D0544E5CAA397-8076
9457939 - Telephone baseplate
          B1051 13 [009] - Open Circuit
          [Halterung für Handyhalter (Baseplate): Unterbrechung]
                    Reset counter: 200
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 21:27:46
9458193 - Control Module for Cellular Telephone
          B1052 14 [009] - Open or Short to Ground
          [Bedieneinheit für Handyvorbereitung (Drei Tasten Module): Unterbrechung/ Kurzschluss nach Masse]
                    Reset counter: 200
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 21:27:46
13636352 - Control module not coded
          U1013 00 [009] - -
                    Reset counter: 200
                    Mileage: 89487 km
                    Date: 2023.03.19
                    Time: 21:27:46
Address A7: Infotain. Interface (J885)       Labels:* None
   Part No SW: 7P6 907 540 A    HW: 1K0 907 951
   Component: IF CAN Infot. H27 0012
   Serial number: 110112F2000493
   Coding: 04052602000000001003
   ASAM Dataset: EV_InfotInterConti 001002
   ROD: EV_InfotInterConti.rod
4106 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Botschaftsausfall mMDI_1]
                    Reset counter: 198
                    Mileage: 89443 km
                    Date: 2023.03.17
                    Time: 12:35:13
End----------(Elapsed Time: 01:49, VBatt start/end: 14.1V/14.3V)-----------
pietpetoors
South Africa
C?ID=545045
Thank you Uwe
Can someone please check on your diagrams what fuses F8 and F23 are for? I refer to and used this diagram: https://fuse-box.info/volkswagen/volkswagen-touareg-2011-2018-fuses-and-relay
On that Diagram on left side fuse box F8 and F23 does not say what it is for. On this vehicle F8 has 5 Amp fuse and F23 has 7.5 Amp fuse. F8 draws 4.5 Amp and F23 Draws 5.4Amp
On right side fuse box fuse no 50 (Mobile phone) draws 1.75 Amp and Fuse 52 (Cluster) draws 6.5 Amp.
Cluster do have some error. Each time I get in car the fuel consumption option is back to "since started" and range. I always set it to "Since refueled" and average. But it keeps on going back to the other setting.
The scan above also showed a communication lost error with cluster.
Note in first post I said I unplugged the mobile phone thingy in glove box. After reading the draw on the fuse I plugged it back in and draw remained the same.
I used the method described in the video Uwe posted.
BY THE WAY: The video you posted, the link to voltage drop table does not exist no more. I found another table at
Jef
HQ
Looks like your steering wheel is on the wrong side of the car, right side... I suspect you are talking about the fuse box on the right side of the dash. If so...
SB8 = 5A, TPMS (J502), SCLM (J527)
SB23 = 7.5A, OBDII port, Ignition/start switch (D), CAN Gateway (J533), CAN Info Bus (J885), Electronic SCLM (J764).
---- side note, fuse box identification logic... SB23
S = fuse in wiring diagrams
B = fuse block B
23 = position 23.
Fuse box on "drivers" side is fuse block SB. Then you should have another panel on the passenger side of the dash, that will be SC. So "F23" is open ended because what fuse box are we talking about? SB23 or SC23? SC23 can be for a rear lid (J605). And then you've got SD block under the seat... but there aren't 23 positions there so I think we can rule that one out.
pietpetoors
South Africa
C?ID=545045
Thank you Jef. I refer to the left and right of the vehicle.
The unknown fuses are on the left of the dash.
It is always confusing when people refer to driver side and passenger side of a Touareg. Like they will say battery is under driver seat, but in fact my battery is under passenger seat.
Most other vehicles refer to left and right of vehicle but a Touareg is different, everyone talks about driver side and passenger side.
pietpetoors
South Africa
C?ID=545045
Last night I pulled all 4 fuses on which I measured a voltage drop.
During the night the battery went from 12 volt where I left it after yesterday's work to 9.6 volt this morning and that was without those 4 fuses.
I still have to measure the fuses in the engine compartment, will do that today.
pietpetoors
South Africa
C?ID=545045
Jef
HQ
Taking a close look at the info I have... often times there is different data for left hand VS right hand drive cars, but I'm not finding that here, and all the drawings show a left hand drive car. So yeah, looks like fuse panel SB on the left, SC on the right. The info on what items are on SB23 still checks out as good though.
pietpetoors
South Africa
C?ID=545045
If Fusebox on right = A then :
I narrowed it down to
SA52 = 5A, Control unit in dash panel insert -J285-
With my clamp meter on, when I pull both these fuses the parasitic draw falls to 0.8Amps down from 3.6Amps.
Does the cluster have a separate control module or is it built into the cluster?
pietpetoors
South Africa
C?ID=545045
Jef, if panel SB is on the left, SC on the right, what is the panel under the seat? SA?
I took another angle on finding the culprit.
The fusebox under the seat with blade fuses. I marked all the wires and then removed them all.
After I removed all of them I still had 0.2A draw.
I then started putting them back and noted the increase of amps with my clamp meter.
Pin number 2 under the seat is my biggest problem. Adaptive suspension control unit -J197
Pin number 9 gives a small 0.3 amp increase, thus I am not concerned about it.
If I put all the wires back and leave only Pin 2 off, we get down to 0.5Amps.
The moment I put No 2 back we first spike to about 8 Amps and then after a couple of seconds it falls to about 3.5 Amps and stay there.
What I do find strange, if I pull SC2 which is also marked Adaptive suspension control unit -J197- it has absolutely no influence in the amps. It does not even give a spike.
Where do I search from here? The control unit or the compressor?
davisev5225
C?ID=263265
Always start with the control unit and work out from there. I suspect, however, that your compressor is likely the culprit. The motor windings on them can sometimes shed a winding and cause excess current consumption even when not in-use. (These are sometimes erroneously referred to as a "flat spot".) The same thing can (rarely) happen to alternators.
pietpetoors
South Africa
C?ID=545045
Thank you.
Some feedback:
I kept wire number 2 off last night. at 17h00 - 13.1 volt, this morning at 07h30 it was 12.98 volt. Thus most definitely wire no 2 is problem.
I disconnected all wires from compressor and the parasitic draw is still there. Presume then it can only be the controller then.
