Terminal 15 fault Audi S6 C7
NotNormal
Lincoln, UK
C?ID=339865
Hello, today I replaced a piece of trim next to the steering column.
The car was totally issue free
I put back the lower trim under the steering wheel.
Then turn on the car, and I get all these faults - which I think might originate from the Terminal 15 issue
I have checked all the fuses, wiring and replaced and swapped the relays
here's the full scan :
Friday,24,March,2023,13:43:33:03442
VCDS Version: 23.3.0.0 (x64)  HEX-NET CB: 0.4631.4
VIN: WAUZZZ4G0JN078160   License Plate:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 20 22 28 30 34 36 3B 42 44 46
          47 52 53 55 5F 62 72 82 8F 90 A9 BA
VIN: WAUZZZ4G0JN078160   Mileage: 102567km-63732miles
03-ABS Brakes -- Status: Malfunction 0110
20-High Beam Assist. -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (------CTGE)       Labels: None
   Part No SW: 4G0 906 014 C    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H63 0006
   Revision: NCH63---    CVN: 82D74FA2
   Coding: 0A2500326526010B2800
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM40TFS0114G0906014C 001007
   ROD: EV_ECM40TFS0114G0906014C.rod
   VCID: 22081DE835C28383F5-8076
   VINID: 9D196AAAA11701A7801C804600653E06CD
          U1113 00 [039] - -
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:47
                    Engine RPM: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 47 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 11.544 V
                    Engine status: COENG_READY
          U1113 00 [039] - -
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:47
Readiness: 1110 1001
   Part No SW: 4G0 927 166 E    HW: 0B5 927 156 K
   Component: 0B5 40TFSIRdW H06 0014
   Revision: --H06---    CVN: 0000D20A
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001022
   ROD: EV_TCMDL501021.rod
   VCID: 2F2EE4DC76103EEB6A-807A
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 65B6DE41A66D7B829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41CAB264D084B89B8C-8014
224256 - Terminal 15
          U1405 00 [175] - Implausible signal
          [Klemmen_Status_Kl15_PlausiError]
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:45
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    Uz: 95
124416 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
          [Ldm_ApbFailureState]
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:45
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    Uz: 95
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0825
   Coding: 01B8704E000000000000
   VCID: 7CB40390FFE615739F-8028
   Serial number: 3217000250510008
   Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
   Serial number: 07121700040139
   Coding: 68211078310000
   VCID: 6A9835C88D729BC37D-803E
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 1502003S    Serial number: 00001847385102
   Coding: 0105801540349FE0E90140C3A0001800CF99C30A2F08020100000894E500170200400024030000
   VCID: 74A42BB0D7B65D33D7-8020
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 171104  H38 0080
   Serial number:         171117161012
   Coding: 0045F7
   Serial number: 21095789X81A955547A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
   Component: E1 - LDS  H07 0044
   Serial number: 08 12 2017  00001364
   Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: F6D19FD800PAG0MUFU03
01800 - Light Switch (E1)
                    Reset counter: 221
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:34:10
   Component: Airbag10.43   H83 0098
   Revision: --------    Serial number: 003P100FH6P6 Dataset Number: 4G0909602M  0003
   Coding: 30333130313730323737554A305234473053
   VCID: 3B36C08CB268D24BD6-806E
   Serial number: 3575HRB40185BPBI6OL.
   Serial number: 3585HRB40045BT7IDGHS
   Serial number: 3515JRB40125BT4UOH9Z
   Serial number: 3525JRB40085BSG880NB
   Serial number: 3554VRB406355ENK6OAY
   Serial number: 3564VRB405P556M669DL
1049600 - Databus
          U1121 00 [137] - Missing Message
          [CAN: 0x084 ESP_06 Timeout]
                    Reset counter: 180
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:46
          B13BC F2 [137] - No function
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:20:00
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372QL5000BL
   Coding: 000034
   VCID: 373EDCBC8640F62B32-8062
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 13 11 2017  A0021848
No Faults Found
   Part No SW: 4G0 920 982 P    HW: 4G0 920 982 P
   Component: TBenGb    Nv  H17 0225
   Revision: 18001312    Serial number: 658181117592010
   Coding: 23AF09019B412600010200
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   VCID: 393ADA84B854E05BC4-806C
   Part No SW: 4G5 907 468 K    HW: 4G0 907 468 AC
   Component: J533--Gateway H15 0110
   Revision: --------    Serial number: 00000002841252 Dataset Number: 4G0909515M  0026
   Coding: C0ED07481C
   GVL: FD83C9D8FC60680D11000000
   ASAM Dataset: EV_GatewPkoUDS 002011
   VCID: 3D32CE94AC7CDC7BE8-8068
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 3917556004
   Voltage stabilizer:
   Serial number: 17090700000000000043
4228 - No Communication with ABS Brake Control Module
          U0121 00 [009] - -
                    Reset counter: 180
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:44
                    Voltage terminal 30: 11.5 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 32 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: OFF
                    Datenfeld: 0
6221 - Control unit for information electronics 1
          U1054 00 [009] - No Communication
          [Steuergerät für Informationselektronik Keine Kommunikation]
                    Reset counter: 180
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:20:44
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
6227 - Digital sound System control module
          U106A 00 [009] - No Communication
          [Steuergerät für Digitales Soundpacket Keine Kommunikation]
                    Reset counter: 180
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:20:44
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0019 - Terminal 15
          U1405 00 [009] - Implausible signal
                    Reset counter: 180
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:45
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 220
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:44
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 2
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 679E4CFC9660A6AB62-8032
02001 - Data-Bus Automatic Distance Regulation
                    Reset counter: 180
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:18:21
03455 - Function Restriction due to Faults in Other Modules
                    Reset counter: 180
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 12:33:02
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H19 0200
   Serial number: 002811170001001 Dataset Number: 4G0909104B  0023
   VCID: 281C0FC053FE69D3AB-807C
0377 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
          [ESP - Steuergerät nicht verfügbar DTC_FRAY_ESP_SYS_STATE]
                    Reset counter: 6
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:45
0408 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Motorsteuergerät Bitte Fehlerspeicher auslesen DTC_FRAY_MO_ACC_PEDAL]
                    Reset counter: 46
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:45
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 14121700041056
   Coding: 22
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H07 0030
   Revision: S0H07000    Serial number: 00000000004360
   Coding: 01010101000000000001000102
   VCID: 64845BF06756CDB347-8030
   Dataset Number: 4G0909553H  0037
   Coding: 008000
   ROD: EV_AirSuspe_VW51.rod
0648 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
                    Reset counter: 180
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:45
   Revision: AA000000    Serial number: 00000289838314
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77BE1CBCC6C0362BF2-8022
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E034V6G Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 373EDCBC8E40F62B32-8062
3801600 - Terminal 15
                    Reset counter: 180
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:45
                    DCU_Internal_DTC: 3A 02 00
                    Ignition Cycle Count: 24650
                    DCU Temperature: 33 °C
                    Voltage VBG 22: 2.5 V
                    Debug Data: 00 00 00 00 00 00 00 00
   Component: TSG FA        H03 0511
   Coding: 011F16015E21628002080002
   VCID: 47DEAC7CF6A086AB42-8012
   Component: RCevo         H55 0202
   Revision: 00000002    Serial number: 0000348462 Dataset Number: 4G0909852L  0038
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A38C588BD52EB43CD-806E
   Revision: 00002001    Serial number: 0464754161
   Coding: 011B062280B90880C330088408010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 B
   Component: Sensor, DWA  005 0002
   Subsystem 2 - Part No: 1K0 951 605 F
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00041545227
   Component: TSG BF        H03 0511
   VCID: 46C0A178F1AA9FA3B9-8012
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002382275 Dataset Number: 4G0909522G  0001
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3228EDA86522130305-8066
462592 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FC_SIGNAL_MO_FAHRPEDALROHWERT_01_ERROR_VALUE]
                    Reset counter: 220
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:45
                    Voltage terminal 30: 11.6 V
                    Internal Fault ID: 151
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
464128 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FC_SIGNAL_MO_QBIT_FAHRPEDALWERTE_01_QBIT]
                    Reset counter: 220
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:45
                    Internal Fault ID: 187
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Revision: --------    Serial number: -------------- Dataset Number: 4G0909865D  0019
   Coding: 04FE02102A600200
   VCID: 3424EBB09F361D3317-8060
   Coding: E01E00
   Coding: E01E00
   Component: TSG HL        H03 0511
   Coding: 010F14004021628002080002
   VCID: 49DAAA44E0B470DB54-801C
   Component: TSG HR        H03 0511
Address 82: Head Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 N    HW: 4G0 919 604 N
   Component: HeadUpDisplay H10 0306
   Coding: A20000
   ASAM Dataset: EV_HUDContiC7 001027
   ROD: EV_HUDContiC7.rod
   VCID: 3620D1B8894A0F2329-8062
   Component: RGS-VL        H16 0080
   Dataset Number: 4G0909614C  0001
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 312AE2A46024281B7C-8064
12584204 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Function limitation due to received error]
                    Reset counter: 220
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:45
   Component: RGS-VR        H16 0080
   Dataset Number: 4G0909615C  0001
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
          U1113 00 [008] - -
                    Reset counter: 220
                    Mileage: 102567 km
                    Date: 2023.03.24
                    Time: 13:19:45
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 171109200685
   VCID: 2C14F3D0470645F34F-8078
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813009188601 Dataset Number: 4G0909578B  0013
   ROD: EV_AEMLearAU64X.rod
End----------(Elapsed Time: 02:24, VBatt start/end: 14.5V/14.5V)-----------
Any pointers would be greatly appreciated
Many Thanks
Tom
Jef
HQ
Looks like fuse SB5 ST1 is a Terminal 15 signal to the ABS module. On the right front door, rip off the panel on the end of the dash to expose the chewy nugget and fuse panel B. The black row is ST1.
Do you have power on fuse position 5? For that matter, do you have power on any of them?
Also take look at SB7 ST2 (brown) and verify that fuse is good and accounted for.
NotNormal
Lincoln, UK
C?ID=339865
@jeff …. Thank you ….. I checked them, I swear, but yes, it was blown …. 5amp fuse !
Replaced, faults cleared
But I’m getting anther terminal 15 fault …. But no issues on the dash
Fault is :
Fault Found:
0019 - Terminal 15
U1405 00 009] - Implausible signal
Reset counter: 183
Mileage: 102618 km
Date: 2023.03.25
Time: 08:56:11
Voltage terminal 30: 14.6 V
Control Module temperature: 28 °C
IN ESP _standstill flag: standstill detected
Engine running: On
IN ZAS Te X: On
Datenfeld: 0
Any further pointers where to go to clear this off
I also need to find what caused that fuse to blow in the first instance
Thank you Jeff, appreciate you input (my heads a rubbish place the past few weeks, my car playing up isn’t helping)
Tom
