2006 Audi A4 Ecu Swap, How to get pin? Is that Possible?
GuntherE30
Walla Walla, WA, USA
C?ID=259062
I have a buddy's 2006 Audi A4 here with the BWT Engine.
It sat for about 3-4 years before it got around to getting fixed due to the rear chain snapping and valves getting to meet the pistons....
We got it all done and now it won't start, found that we don't have the proper voltage hitting the injectors. Do to reading, phone calls etc it seems that the dc to dc converter in the ECU has died? Or the driver circuits have died?
Got a used ecu and rather then just cranking over and over the car actually starts, runs then shuts down from the immobilizer.
I'm told I need the security pin? out of both ecu's to make the "new" one run in this car?
Can someone help me do this or is there a shop in the Pacific Northwest that can do this on a bench if I send them both Ecu's?
Any help would be appreciated.
Thanks in advance!!
Trevor
Below are the full auto scans from the old ecu first, and then the new ecu if that somehow helps
Friday,24,March,2023,09:33:22:59922
VCDS Version: 23.3.0.0 (x64)  HEX-NET2 CB: 0.4631.5
VIN: WAUKF78E67A013515   License Plate:
Mileage: 256010km-159077mi   Repair Order: audi old
          67 69 75 76 77
VIN: WAUKF78E67A013515   Mileage: 256010km-159077miles
   Part No SW: 8E0 910 115 P    HW: 8E0 907 115 D
   Revision: 5EH13---    Serial number:
   Coding: 010C010A190F0120
   Shop #: WSC 26203 444 57325
   VCID: 2E0E6187AC19E45AADF-807A
   VINID: 9D195B58721518744004314114D90B165B
005491 - Left Engine Mount Solenoid Valve (N144)
               P1573 - 004 - Open Circuit
                    Mileage: 256018 km
                    RPM: 864 /min
                    Load: 58.8 %
                    Temperature: 16.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 11.430 V
000513 - Injector: Cylinder 1 (N30)
               P0201 - 004 - Circuit Malfunction
                    Mileage: 256018 km
                    RPM: 864 /min
                    Load: 44.7 %
                    Temperature: 16.0°C
                    Temperature: 18.0°C
                    Voltage: 11.430 V
000515 - Injector: Cylinder 3 (N32)
               P0203 - 004 - Circuit Malfunction
                    Mileage: 256018 km
                    RPM: 864 /min
                    Load: 44.7 %
                    Temperature: 16.0°C
                    Temperature: 18.0°C
                    Voltage: 11.430 V
000516 - Injector: Cylinder 4 (N33)
               P0204 - 004 - Circuit Malfunction
                    Mileage: 256018 km
                    RPM: 864 /min
                    Load: 44.7 %
                    Temperature: 16.0°C
                    Temperature: 18.0°C
                    Voltage: 11.430 V
000514 - Injector: Cylinder 2 (N31)
               P0202 - 004 - Circuit Malfunction
                    Mileage: 256018 km
                    RPM: 864 /min
                    Load: 44.7 %
                    Temperature: 16.0°C
                    Temperature: 18.0°C
                    Voltage: 11.430 V
Readiness: 0110 0101
   Part No SW: 8E1 910 156 K    HW: 09L 927 156 B
   Component: AG6 09L 2.0TFSI USA 0030
   Revision: --H01---    Serial number:        4191852
   Coding: 0000002
   Shop #: WSC 06335 000 00000
   VCID: 2F307C83AB13ED52A69-807A
009783 - Torque Management Feedback Signal A
               P2637 - 000 -  - Intermittent
                    Mileage: 256018 km
                    (no units): 31.0
                    (no units): 12.0
                    Temperature: 7.0°C
                    T.B. Angle: 0.0°
049408 - No Communication with Engine Control Module (SAE ECM/PCM)
               U0100 - 000 -  - Intermittent
                    Mileage: 256018 km
049412 - No Communication with Cruise Control Module
               U0104 - 000 -  - Intermittent
                    Mileage: 256018 km
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004528
                    Reset counter: 39
                    Hex Value: 0x20C0
                    Hex Value: 0x5302
                    Hex Value: 0x0003
                    Hex Value: 0x1667
                    Hex Value: 0x0001
                    Hex Value: 0x0000
                    Hex Value: 0x4202
                    Hex Value: 0x0024
                    Hex Value: 0x0199
                    Hex Value: 0x0001
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
                    Reset counter: 39
                    Hex Value: 0x0000
                    Hex Value: 0x6202
                    Hex Value: 0x0028
                    Hex Value: 0x017E
                    Hex Value: 0x0001
                    Reset counter: 39
                    Hex Value: 0x0080
                    Hex Value: 0x0702
                    Hex Value: 0x0013
                    Hex Value: 0x85A2
                    Hex Value: 0x0001
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 11023
   Shop #: WSC 65536
   VCID: 3D2C56CB746F0FC2245-4AA4
            30-00 - Open or Short to Plus
   Part No SW: 8E0 035 593 F    HW: 8E0 035 593 F
   Component: SDAR SIRIUS         0120
   Serial number: AUZ4Z7F5025805
   VCID: 2C0A6B8F9A25964A83B-5160
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H12 3840
   Revision: 91H12384    Serial number: 0036N001ZWES
   Coding: 0032607
   VCID: 3C2A5BCF6A6506CA13B-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 36V2A
   Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB40338CC22Pÿ†63
   Subsystem 5 - Serial number: 8CC22Pÿ†6342DRB40362900DHÿ†63
   Subsystem 6 - Serial number: 2900DHÿ†6352ARB40148B0D7Qÿ†63
   Subsystem 7 - Serial number: 8B0D7Qÿ†6362ARB40148BFE81ÿ†63
   Subsystem 8 - Serial number: 8BFE81ÿ†63729RB40158BD1CYÿ†63
   Subsystem 9 - Serial number: 8BD1CYÿ†63829RB40158BCA3Yÿ
   Subsystem 10 - Serial number: 8BCA3Yÿ
                    Reset counter: 39
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0701
   Coding: 04042
   Shop #: WSC 06335
   VCID: 41D42A3B08976B2240D-4AA4
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.clb
   Part No SW: 8E0 920 951 G    HW: 8E0 920 951 G
   Component: KOMBI+WFS 4     H14 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0023261
   Shop #: WSC 12345 444 109186
   VCID: 2E0E6187AC09E45AADF-50F4
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.clb
   Coding: 0023261
   Part No: 8E0 959 433 CG
   Component: Komfortgerát T7B    4135
   Coding: 12076
   Shop #: WSC 06335
   VCID: 78A287DF1BCDEAEA373-4AA4
   Subsystem 1 - Part No: 8E1959801G
   Component: Tõrsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 0706
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
00956 - Key 2
            35-10 - - - Intermittent
   Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
   Coding: 0000019
   VCID: 2802979F8EFDBA6A673-807C
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H03 0010
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH03 0010
                    Reset counter: 25
   Part No SW: 8E0 035 195 AC    HW: 8E0 035 195 AC
   Component: R Symphony2+    H02 0060
   Revision: 00H02000    Serial number: AUZ1Z4F1828704
   Coding: 0650102
   VCID: 6882D79F4E5D7A6AA73-5160
                    Time Indication: 15
                    Reset counter: 4
                    Time Indication: 15
   Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
   Component: FSE_255x BT     H21 0290
   Revision: 00000001    Serial number: 00000000470192
   Coding: 0001677
   VCID: 3D2C56CB716F0FC2245-50D0
                    Reset counter: 161
                    Time Indication: 15
End----------(Elapsed Time: 05:51, VBatt start/end: 12.2V/12.2V)-----------
Here is the scan from the "New" used one
Friday,24,March,2023,09:52:09:59922
VIN: WAUDF78E57A063492   License Plate:
Mileage: 256010km-159077mi   Repair Order: "new" Ecu
          67 69 75 76 77
VIN: WAUDF78E57A063492   Mileage: 256010km-159077miles
   Coding: 0104010A190F0120
   Shop #: WSC 23190 444 54694
   VINID: 9D19545872151474401831090822D3DC75
   Coding: 0000002
                    Mileage: 256018 km
                    (no units): 31.0
                    (no units): 12.0
                    Temperature: 7.0°C
                    T.B. Angle: 0.0°
                    Mileage: 256018 km
                    Mileage: 256018 km
   Coding: 0004528
                    Reset counter: 39
                    Hex Value: 0x20C0
                    Hex Value: 0x5302
                    Hex Value: 0x0003
                    Hex Value: 0x1667
                    Hex Value: 0x0001
                    Fault Frequency: 11
                    Hex Value: 0x0000
                    Hex Value: 0x4202
                    Hex Value: 0x0024
                    Hex Value: 0x0199
                    Hex Value: 0x0001
18265 - Load Signal
                    Reset counter: 39
                    Hex Value: 0x0000
                    Hex Value: 0x6202
                    Hex Value: 0x0028
                    Hex Value: 0x017E
                    Hex Value: 0x0001
                    Reset counter: 39
                    Hex Value: 0x0080
                    Hex Value: 0x0702
                    Hex Value: 0x0013
                    Hex Value: 0x85A2
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2833
   Coding: 00000
   VCID: 6D8CA68B648F5F42D45-50D0
01273 - Fresh Air Blower (V2)
   Coding: 11023
   Shop #: WSC 65536
   Coding: 0032607
                    Reset counter: 39
   Coding: 04042
   Shop #: WSC 06335
   Coding: 0023261
02241 - Engine Control Module; Immobilizer Data not Adapted
   Coding: 0023261
   Coding: 12076
   Shop #: WSC 06335
00956 - Key 2
   Coding: 0000019
                    Reset counter: 24
   Coding: 0650102
                    Time Indication: 15
                    Reset counter: 4
                    Time Indication: 15
   Coding: 0001677
                    Reset counter: 161
                    Time Indication: 15
End----------(Elapsed Time: 05:52, VBatt start/end: 12.2V/12.2V)-----------
EuroX
Northern NJ USA
C?ID=208579
This car is WFS4 you cannot adapt ecm using pin IIRC. Pin is present but means nothing. This system is ODIS online connection or some specialized tools to do the swap. I order to perform this swap you need ecm dash and all keys then it can be done on bench with some expensive tools. PM ME if you want to send it all in im on the east coast.
  • Agree
I concur. PINs won't cut it for that car.
equijano
Mexico City
C?ID=90020
Hi, I'm interested in learning about module swap coding with ODIS and other tools. Could you recommend some reading materials? Also, what tools are needed for this? I'm interested in learning more
EuroX
Northern NJ USA
C?ID=208579
I'm afraid there isn't much reading materials in terms of ODIS or a howto really as that's factory software used at the dealer level or authorized workshop. Not to mention the cost of hardware and software along with license, certificate and geko id just to have access is not worth it unless your doing alot of those jobs for personal vehicle it's not worth it. Hardware wise at best your looking at 1000-5000$usd for hardware then license cost, cert cost and login cost your talking another $1500 give of take and that's just for access to audi brand and nothing else. If your having an issue with your q7 feel free to pm me I will see if I can assist at a distance.
