A vehicle identification number
jreve1990
Uruguay
C?ID=437460
hello forum. I need help with this supposed error, or whatever. When it appears, I click yes and it continues normally, but I don't know if it is letting me make basic adjustments to the car, since it doesn't allow me to do any. i need help
Tuesday,21,March,2023,12:21:00:18386
VCDS Version: 23.3.0.0 (x64)  HEX-NET2 CB: 0.4631.5
VIN: WAUZZZ8V1EA117974   License Plate: A3 DURAZNO FERREIRA
Mileage: 98658km-61303mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V1EA117974   Mileage: 98658km-61303miles
Address 01: Engine (J623-CJSA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 B    HW: 06K 907 425 A
   Component: 1.8l R4 TFSI  H09 0003
   Revision: --H09---    CVN: 3110891A
   Coding: 0A251032240400082000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM18TFS0218V0906264B 001003
   ROD: EV_ECM18TFS0218V0906264B.rod
   VCID: 3B285D47A3E1DDF21A1-806E
   VINID: 9D196AAAA226055441047247104F0EB92F
14866 - Camshaft Position Sensor (G40)
          P0340 00 [109] - Malfunction
                    Mileage: 92620 km
                    Date: 2022.09.02
                    Time: 00:00:44
                    Engine RPM: 1504.50 /min
                    Normed load value: 15.7 %
                    Coolant temperature: 11 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 11.484 V
                    Engine: operating status: IS
                    STATE_VCP: passive
                    TOIL: 10 °C
                    CAM_VCP[IN_1]: 0.000 °
                    CAM_SP_IND_VCP[IN_1]: 0.000 °
                    STATE_CRK_STST: CRK_STST_PAS
                    Time since engine start: 0.7 s
   Part No SW: 0CW 300 046 C    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5110
   Revision: 00043014    Serial number: CU501312017278 CVN: 00000FC3
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 3A265843ACDBE4FA017-806E
   Revision: 00000000    Serial number: 6339300000069D
   Coding: 12F16AA234210A730180060741C72948562C5080608294B4004100080608
   ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
   VCID: 7BA89D47E3611DF25A1-802E
0297 - Steering angle sensor
          B1168 16 [137] - Voltage Too Low
                    Reset counter: 227
                    Date: 2022.08.27
                    Time: 00:07:14
32928 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [IPB: Supply Voltage below undervoltage threshold]
                    Reset counter: 9
                    Mileage: 5 km
                    Date: 2014.01.24
                    Time: 15:41:30
Address 08: Auto HVAC (E87)       Labels:| 8V0-820-047.clb
   Part No SW: 8V0 820 047 D    HW: 8V0 820 047 D
   Component: AC Manuell el H11 0052
   Revision: 20021000    Serial number: 00000000036996
   Coding: 03000004100000000000000000000000
   ASAM Dataset: EV_AirCondiFrontManAU37X 008018
   ROD: EV_AirCondiFrontManAU37X.rod
   VCID: 372041779FC9F992FE9-8062
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011334301124 Dataset Number: 8V0909514H  0073
   Coding: 04141A42C041227D03844004B30C07000000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 131128  041 0580
   Serial number:         131203032215
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
   Component: G397_RLS  H06 0002
   Serial number: 20129092
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
   Serial number: 13 09 2013  00001651
   Serial number: 000000000ZY1330200D9
   Serial number: 00000000000028437725
   Sunroof control module:
   Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.009  H02 0007
   Serial number:     WOO25993136
   Coding: 901E00
721416 - Switch for Sunroof
          B13C4 29 [008] - Signal Implausible
                    Reset counter: 231
                    Mileage: 97597 km
                    Date: 2023.02.19
                    Time: 10:48:27
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 13.8 V
                    Outside temperature: 26.0 °C
721420 - Switch for Sunroof
          B13C4 01 [008] - Electrical Failure
                    Reset counter: 231
                    Mileage: 97597 km
                    Date: 2023.02.19
                    Time: 10:48:27
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 13.8 V
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831334400458 Dataset Number: 8V0909526C  0034
   Coding: 0000040011
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   VCID: 3822424B92D7F6EAF73-806C
1080340 - Parking Aid Speaker
          B107C 14 [009] - Open or Short to Ground
                    Reset counter: 109
                    Mileage: 88886 km
                    Date: 2022.05.21
                    Time: 00:02:02
13637426 - Databus
                    Reset counter: 227
                    Mileage: 98658 km
                    Date: 2023.03.19
                    Time: 00:02:11
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R04C8H9 Dataset Number: 8V0909602C  0009
   Coding: 98CCC000000000005C540000004800000065
   VCID: 4BC80D87F3416D72AA1-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 002 711 13
   Serial number: 35767000000C90DC4E06
   Subsystem 2 - Part No SW: -----------    HW: 480 002 711 13
   Serial number: 35867000000D16DC4E06
   Subsystem 3 - Part No SW: -----------    HW: 480 400 612 13
   Serial number: 3516502A5122056292AX
   Subsystem 4 - Part No SW: -----------    HW: 480 400 612 13
   Serial number: 3526502AD1220563026U
   Subsystem 5 - Part No SW: -----------    HW: 480 401 211 13
   Serial number: 3556502C51050642401N
   Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 08121304401505
   Coding: 8418
   ROD: EV_SMLSKLOMQB_017.rod
   VCID: 065EFCB3A8A3501A35F-8052
617752 - Selector Lever Park Position Lock Switch
          B1162 29 [024] - Signal Implausible
                    Fault Frequency: 55
                    Reset counter: 9
                    Mileage: 93032 km
                    Date: 2022.09.09
                    Time: 17:15:33
                    Operating time: 195820 min
                    Terminal 30 power supply: 14.4 V
                    Vehicle speed: 10 km/h
                    Voltage at switch: 4.98 V
                    Terminal 15 status: active
                    System status: 30
   Part No SW: 8V0 920 860 E    HW: 8V0 920 860 E
   Component: KOMBI         H02 2220
   Coding: 078409082A8000080500A800100000
   VCID: 3C2A5E5BA6EFDACA13B-8068
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001335996 Dataset Number: 8V0909515D  0049
   Coding: 0101000820085A005B000208180B00000001000000000000000000000000
   GVL: 01543C0000000000400C10000000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010.rod
   VCID: 3FD02957B7F9C1D2369-806A
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 B    HW: 8U0 951 528 B
   Serial number: 18 11 2013  A1297385
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 20111302090565 Dataset Number: 8V0909872E  0030
   Coding: 001C0E204100040000001002
   VCID: 3E2E5453B0F3C8DA3DF-806A
   Component: EPS_MQB_ZFLS  122 1043
   Dataset Number: 8V0909852G  0017
   Coding: 0102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41D42FAFC10DB72240D-8014
16135 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Motor status: 00
                    Supply voltage: 9.75 V
                    Temperature: 26.0 °C
                    KFC: 3F
                    KFA: 00 07
                    Freeze frame conditions: 21
                    uioUdNotFilt_xdu16: 9.34 V
                    uAdSensI_SwitchedKl30_xdu16: 9.35 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 17111304080758 Dataset Number: 8V0909873E  0029
   Coding: 001C06204100040000001002
   VCID: 3D2C535FBDF5D3C2245-8068
   Revision: --------    Serial number: -------------- Dataset Number: 8V0909865G  0033
   Coding: 011A000001000000
   VCID: 75BC8B7FC5454B822C5-8020
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
   Component: MU-S--ER      040 0420
   Serial number: A3E00912131756 Dataset Number: 8V1909545C  0036
   Coding: 01730300FF0A000021220001001A00002F0001440100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 343A767B8EBF128ADBB-8060
   Multimedia System 1:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H48 0013
   Serial number: AUZ8Z9DY3006UU
   Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000005101300010275
   Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0025
   Serial number: 30111304081162 Dataset Number: 8V0909897C  0017
   Coding: 000C06204000040000001002
   VCID: 40D22AABCA07BE2A4F3-8014
   Component: TSG HBFS      020 0025
   Serial number: 30111306071162 Dataset Number: 8V0909896C  0017
End----(Elapsed Time: 01:36, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
It does that, just ignore it as I did earlier on an A4.
jreve1990
Uruguay
C?ID=437460
Fine, I'll do that. What surprises me is that this message did not appear before, and I think I had already scanned one of those cars.
Yesterday the first time I went in it was fine and the second time that message came up but it had no impact on what I was doing.
jreve1990
Uruguay
C?ID=437460
When in doubt, do an Auto-Scan first.
What exactly are you trying to do?
I have a camshaft sensor failure, and I want, among other things, to do a basic adjustment. But it also happened to me in another Audi A4 with a CNCD engine, which has a throttle body failure, and I want to do a basic adjustment of it and it won't let me.
