Vw mk6 dtc
Rolotuning
Puerto Rico
C?ID=440
the first read
                Address 01: Engine       Labels: 06J-906-026-CCT.clb
Control Module Part Number: 1K0 907 115 AM    HW: 1K0 907 115 AA
  Component and/or Version: 2.0l R4/4V TFSI     0030
           Software Coding: 0403010A1C070160
            Work Shop Code: WSC 01357 011 00200
                      VCID: 71E9857668134FA9911-8024
001286 - Idle Control System
               P0506 - 000 - RPM Lower than Expected - Intermittent
                    Mileage: 68811 km
                    Date: 2003.14.17
                    Time: 06:55:30
                    RPM: 526 /min
                    Load: 29.8 %
                    Temperature: 75.0°C
                    Temperature: 48.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.954 V
               P0300 - 000 -
                    Fault Frequency: 11
                    Mileage: 69892 km
                    Date: 2003.14.29
                    Time: 22:20:22
                    RPM: 1158 /min
                    Load: 37.6 %
                    Temperature: 28.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.097 V
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - Intermittent
                    Mileage: 68869 km
                    Date: 2003.14.18
                    Time: 17:49:50
                    RPM: 1151 /min
                    Load: 34.5 %
                    Temperature: 41.0°C
                    Temperature: 30.0°C
                    Voltage: 14.097 V
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 11
                    Mileage: 69892 km
                    Date: 2003.14.29
                    Time: 22:20:49
                    RPM: 1196 /min
                    Load: 36.5 %
                    Temperature: 36.0°C
                    Temperature: 27.0°C
                    Voltage: 13.843 V
000135 - Fuel Rail/System Pressure
               P0087 - 000 - Too Low - Intermittent
                    Mileage: 69267 km
                    Date: 2003.14.21
                    Time: 05:26:18
                    RPM: 2363 /min
                    Load: 62.7 %
                    Speed: 12.0 km/h
                    Temperature: 80.0°C
                    Temperature: 55.0°C
                    Voltage: 13.462 V
004874 - Cylinder Disabling
               P130A - 000 -  - Intermittent
                    Mileage: 70604 km
                    Date: 2004.14.03
                    Time: 19:18:55
                    RPM: 1224 /min
                    Load: 33.3 %
                    Temperature: 39.0°C
                    Temperature: 26.0°C
                    Voltage: 14.224 V
I replace the 2 coil and the code return
               P0300 - 000 -
                    Mileage: 70644 km
                    Date: 2004.14.05
                    Time: 22:56:60
                    RPM: 1112 /min
                    Load: 39.6 %
                    Temperature: 34.0°C
                    Temperature: 34.0°C
                    Voltage: 13.843 V
000770 - Cylinder 2
                    Mileage: 70644 km
                    Date: 2004.14.05
                    Time: 22:57:04
                    RPM: 1119 /min
                    Load: 41.6 %
                    Temperature: 34.0°C
                    Temperature: 33.0°C
                    Voltage: 13.716 V
Readiness: 1110 0101
Apreciate any help !!
Rolotuning
Puerto Rico
C?ID=440
Gotcha!
2 bad injectors!!!
the first read
                    Mileage: 68811 km
                    Date: 2003.14.17
                    Time: 06:55:30
                    RPM: 526 /min
                    Load: 29.8 %
                    Temperature: 75.0°C
                    Temperature: 48.0°C
                    Voltage: 12.954 V
               P0300 - 000 -
                    Fault Frequency: 11
                    Mileage: 69892 km
                    Date: 2003.14.29
                    Time: 22:20:22
                    RPM: 1158 /min
                    Load: 37.6 %
                    Temperature: 28.0°C
                    Temperature: 27.0°C
                    Voltage: 14.097 V
000771 - Cylinder 3
                    Mileage: 68869 km
                    Date: 2003.14.18
                    Time: 17:49:50
                    RPM: 1151 /min
                    Load: 34.5 %
                    Temperature: 41.0°C
                    Temperature: 30.0°C
                    Voltage: 14.097 V
000770 - Cylinder 2
                    Fault Frequency: 11
                    Mileage: 69892 km
                    Date: 2003.14.29
                    Time: 22:20:49
                    RPM: 1196 /min
                    Load: 36.5 %
                    Temperature: 36.0°C
                    Temperature: 27.0°C
                    Voltage: 13.843 V
                    Mileage: 69267 km
                    Date: 2003.14.21
                    Time: 05:26:18
                    RPM: 2363 /min
                    Load: 62.7 %
                    Speed: 12.0 km/h
                    Temperature: 80.0°C
                    Temperature: 55.0°C
                    Voltage: 13.462 V
                    Mileage: 70604 km
                    Date: 2004.14.03
                    Time: 19:18:55
                    RPM: 1224 /min
                    Load: 33.3 %
                    Temperature: 39.0°C
                    Temperature: 26.0°C
                    Voltage: 14.224 V
               P0300 - 000 -
                    Mileage: 70644 km
                    Date: 2004.14.05
                    Time: 22:56:60
                    RPM: 1112 /min
                    Load: 39.6 %
                    Temperature: 34.0°C
                    Temperature: 34.0°C
                    Voltage: 13.843 V
000770 - Cylinder 2
                    Mileage: 70644 km
                    Date: 2004.14.05
                    Time: 22:57:04
                    RPM: 1119 /min
                    Load: 41.6 %
                    Temperature: 34.0°C
                    Temperature: 33.0°C
                    Voltage: 13.716 V
