mk4 jetta 2.0 abs module bleeding
smee
C?ID=245673
Hello all,
I have ran the brake reservoir dry while changing all of the calipers and rotors/pads. After doing 10 cycles of the abs module bleeding procedure with vcds (foot on the brake, pump cycles, open two front bleeders, pump 10 times, close bleeders, repeat), and a power bleed of the four corners, the brakes are very soft and it takes a lot of travel to stop the car. Not sure what else to try. Any suggestions would be appreciated. Thanks!
