Lost coding for 34 level control Audi S8 2016
m23ney
Ireland
V2-2H
Vehicle came into me today after having lower RHF control arm replaced. Customer complaint regarding warning light on dash for vehicle level / air suspension fault . All level sensors ok . Air suspension inop.
C/o reset of adaptions in basic setting
Will not take relearning procedure, due to loss of coding in control unit .
Faults logged :
ride height not learned c1044
Control module not coded u1013
No end of line programming b2013
Looking to retrieve original coding or help on this matter .
Kind regards
Craig
Bruce
Near Philadelphia, PA, USA
To give the help you seek, we need to know the control module details. These are provided us through an autoscan from the car. Don't "How To" post an autoscan, see the drop down menu in the blue bar at the top of the page.
Once we have the autoscan, we may have some help for you.
Dealer (or independent with ODIS and Audi server access) needed to re-load the parameters.
m23ney
Ireland
V2-2H
Wednesday,22,March,2023,09:01:47:33524
VCDS Version: 23.3.0.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: WAUZZZ4H7FN025827   License Plate:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 1B 22 28 34 36 3B
          3C 42 44 46 47 52 53 55 56 57 5F 62 6C 6D 6F 72 81 85 88 89
          8B 8E 8F 90 A9 BA
VIN: WAUZZZ4H7FN025827   Mileage: 67458km-41916miles
85-On Board Cam. -- Status: Malfunction 0010
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CTFA)       Labels:. 079-907-560-CFS2.clb
   Part No SW: 4H0 907 557 C    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H62 0006
   Revision: NCH62---    CVN: 71ACC120
   Coding: 022A00326546010B3000
   Shop #: WSC 64595 001 1048576
   ASAM Dataset: EV_ECM40TFS0114H0907557C 001007
   ROD: EV_ECM40TFS0114H0907557C.rod
   VCID: 303915B5FAAB7CCABF3-8064
   VINID: 9D196AAAA1181D67800852021C0E150BEF
7780 - Engine Off Timer Performance
          P150A 00 [032] - -
                    Mileage: 67458 km
                    Date: 2023.03.21
                    Time: 03:19:06
                    Engine RPM: 1687.00 /min
                    Normed load value: 17.3 %
                    Coolant temperature: 65 °C
                    Intake air temperature: 57 °C
                    Voltage terminal 30: 10.130 V
                    Engine status: COENG_RUNNING
Readiness: 0010 0001
   Part No SW: 4H1 927 158 CE    HW: 0BK 927 156 AD
   Component: 0BK 40TFSIRdW H19 1004
   Revision: --H19---    CVN: 630A0E2C
   VCID: 75B7E4A1454919E22C5-8020
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 AA    HW: 4H0 907 379 AA
   Component: ESP PREMIUM   H10 0665
   Coding: D2FDA3004BBFC500E300
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005024
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 71BFD0B1312135C2F0D-8024
0396 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ComScl_PDU_Fahrwerk_02_Timeout]
                    Reset counter: 126
                    Mileage: 67456 km
                    Date: 2023.03.20
                    Time: 22:45:30
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 02
                    Bit Info 4: 12
                    F-Path: 39
                    F-Type: 92
                    Uz: B6
0440 - Steering angle sensor
          B1168 29 [136] - Signal Implausible
                    Reset counter: 113
                    Mileage: 67311 km
                    Date: 2023.03.13
                    Time: 01:46:55
                    VzRef: 68
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 06
                    Bit Info 4: 12
                    F-Path: 1C
                    F-Type: 31
                    Uz: B4
0679 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Net_QSP_02_QSP_Ist_Moment]
                    Fault Frequency: 15
                    Reset counter: 121
                    Mileage: 67279 km
                    Date: 2023.03.10
                    Time: 22:40:01
                    VzRef: 3D
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 06
                    Bit Info 4: 12
                    F-Path: 2C
                    F-Type: 2E
                    Uz: B4
   Part No SW: 4H0 907 064 FD    HW: 4H0 907 064 ED
   Component: BCM2 2.0      H36 0560
   Coding: 05B76F0E000000000000
   VCID: 70B9D5B53AAB3CCAFF3-8024
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000122895442
   Coding: C038320085047201010001010101112131313333283333
   VCID: 353724A1054959E2EC5-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 P    HW: 4H0 820 043 P
   Component: Klima 4 Zonen H20 0210
   Coding: 68A160B83C0000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2D070CC1ED991122945-8078
0129 - Motor for  Left Side Window Defrost Flap
          B10D7 22 [009] - Signal Amplitude Too High
                    Fault Frequency: 35
                    Reset counter: 86
                    Mileage: 67278 km
                    Date: 2023.03.10
                    Time: 22:37:07
   Part No SW: 4H0 907 063 DG    HW: 4H0 907 063 AG
   Component: BCM1 2.0      H20 0311
   Revision: 14020001    Serial number: 00000921059501
   Coding: 0105000040309FF2F90140C4A0001800009DC3082F080201800008946101170000400009090000
   Subsystem 1 - Part No SW: 4H2 955 119 C    HW: 4H2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 140603  H36 0090
   Serial number:         140617224844
   Coding: 0045F7
   Serial number: 23404503
   Coding: 02004E
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Serial number: 25 08 2014  00000925
   Component: EVLS-SG  H08 0300
   Serial number: WA109325000009951491
   Coding: 020300
   Serial number: A5780957000000000001
03455 - Function Restriction due to Faults in Other Modules
                    Fault Frequency: 17
                    Reset counter: 86
                    Mileage: 67299 km
                    Date: 2023.03.13
                    Time: 01:31:39
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 F    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0200
   Revision: AA001001
   VCID: 2313EAF9BBDDD752321-8076
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 G    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0070
   Revision: --------    Serial number: 56261430800846
   Coding: B83B06
   ASAM Dataset: EV_EPHVA2CAU64X0000 001011
   ROD: EV_EPHVA2CAU64X0000.rod
   VCID: 353724A105C959E2EC5-8060
13637413 - Databus
          [Bremsensteuergerät - ESP_01.ESP_Systemstatus - Fehlerspeicher auslesen]
                    Reset counter: 113
                    Mileage: 67311 km
                    Date: 2023.03.13
                    Time: 01:46:55
   Part No SW: 4H0 907 561 C    HW: 4H0 907 561
   Component: ACC3          H21 0032
   Serial number: 00000000000000 Dataset Number: 4H0909863E  0036
   Coding: 7E02010101
   ASAM Dataset: EV_AdaptCruisContrAU64X 002024
   ROD: EV_AdaptCruisContrAU64X_002.rod
   VCID: 2B0302D9D38D1F128A1-807E
105472 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_VDC_FAIL]
                    Reset counter: 113
                    Mileage: 67311 km
                    Date: 2023.03.13
                    Time: 01:46:55
                    Control Module temperature: 17 °C
                    Voltage terminal 15: 14.403 V
                    Velocity_vehicle_reference: 29.58 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.22 m/s²
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Fault Frequency: 27
                    Reset counter: 86
                    Mileage: 67299 km
                    Date: 2023.03.13
                    Time: 01:31:35
                    Control Module temperature: 22 °C
                    Voltage terminal 15: 14.550 V
                    Velocity_vehicle_reference: 25.55 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.34 m/s²
154112 - Steering angle sensor
          B1168 F3 [008] - Offset too high
                    Reset counter: 114
                    Mileage: 67308 km
                    Date: 2023.03.13
                    Time: 01:45:10
                    Control Module temperature: 19 °C
                    Voltage terminal 15: 14.321 V
                    Velocity_vehicle_reference: 28.12 m/s
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P100266WW Dataset Number: 4H0909602J  0016
   Coding: 30333045323130323134554A305234483053
   VCID: 3B23329923ED8F921A1-806E
   Serial number: 3575HRB405F2R8PA6OH3
   Serial number: 3585HRB40692OJSO0P8A
   Serial number: 3515JRB406332020P8VQ
   Serial number: 3525JRB4063320206G6Y
   Serial number: 3554VRB405V32L402OS
   Serial number: 3564VRB405332IIG6P0F
   Serial number: 2284VRB401852P5071AO
   Serial number: 2294VRB405T31BAMMGRL
   Serial number: 2304VRB401A52P50OH43
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 01335NK700056
   Coding: 0004FC
   VCID: 38292D95125BA48AF73-806C
   Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
   Serial number: 27 10 2014  F0081170
   Part No SW: 4H0 920 840 B    HW: 4H0 920 840 B
   Component: TBenRDWACCNV- H53 0707
   Revision: 37081202    Serial number: 658231014592019
   Coding: 33870802BF51000C0F0100
   ASAM Dataset: EV_RBD4K 004050
   ROD: EV_RBD4K_AU64.rod
   VCID: 2517F4E1B56929625C5-8070
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 P    HW: 4H0 919 204 P
   Component: Analoguhr D4  H05 0225
   Serial number: 2140925000095
   Part No SW: 4H0 907 468 AF    HW: 4H0 907 468 AC
   Revision: --------    Serial number: 00000001616695 Dataset Number: 4H0909515L  0087
   Coding: C0ED07480C
   GVL: FFEFECCCFFE3E0CDD1000000
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 51295G39511911964535
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 14302003421021200410
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Revision: 52001005    Serial number: --------------
   Coding: 090100
   VCID: 392F28912951BD8208D-806C
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   Serial number: 002710140001003 Dataset Number: 4H0909104C  0031
   VCID: 2809FDD5C27B340A673-807C
0181 - Steering angle sensor
          B1168 29 [008] - Signal Implausible
                    Fault Frequency: 16
                    Reset counter: 41
                    Mileage: 67279 km
                    Date: 2023.03.10
                    Time: 22:40:01
0377 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [ESP - Steuergerät nicht verfügbar DTC_FRAY_ESP_SYS_STATE]
                    Reset counter: 41
                    Mileage: 67311 km
                    Date: 2023.03.13
                    Time: 01:46:55
0305 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [ESP - Steuergerät Bitte Fehlerspeicher auslesen DTC_FRAY_ESP_09_TORQ_REQ]
                    Reset counter: 41
                    Mileage: 67357 km
                    Date: 2023.03.13
                    Time: 22:23:46
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H17 0200
   Coding: 2800000000
   ASAM Dataset: EV_AirCondiHeck 002001
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: 38292D9512DBA48AF73-806C
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3B16C9E7956332A69-807A
367877 - Ride Height Not Learned
          C1044 00 [009] - -
                    Reset counter: 86
266752 - Control module not coded
          U1013 00 [009] - -
                    Reset counter: 86
38144 - No End-of-Line Programming
          B2013 00 [009] - -
          [keine Bandendeprogrammierung erfolgt (Auslieferungszustand)]
                    Reset counter: 86
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000122895350
   Coding: C0383B0085057201010001010101112131313333203333
   Part No SW: 4H0 907 637 L    HW: 4H0 907 637 G
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7100L3D$
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4H0 907 566 F    HW: 4H0 907 566 F
   Component: SWA Master    H06 0030
   Serial number: 0349644270 Dataset Number: 4H0909535D  0016
   Coding: 040312
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 33331AB90BBD47D2C21-8066
   Subsystem 1 - Part No SW: 4H0 907 568 F    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0030
   Serial number: 0348219586
   Coding: 040312
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H07 0280
   Revision: --------    Serial number: 0000124351451
   Coding: 011F1E005E0162C202083017
   VCID: 48C95D5562BBD40A873-801C
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0024131574 Dataset Number: 4H0909852J  0023
   Coding: 011101010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0351001039
   Coding: 011A0E2080B93185F330C7C40E0316470000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.030  H08 0006
   Serial number:     WOO3299634A
   Coding: 901F00
   Subsystem 4 - Part No SW: 4H0 947 135 G    HW: 4H0 947 135 G
   Component: Dachelektroni  H13 0080
   Serial number: A2014000000000823982
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS014  H06 0005
   Serial number:     WOO10007NOT
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93357706
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 86
                    Mileage: 67392 km
                    Date: 2023.03.14
                    Time: 05:01:20
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000013889
   Coding: 030000
   VCID: 1C61D10586A3E8AAF3B-8048
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H07 0280
   Revision: --------    Serial number: 0000124358980
   Coding: 011F1E005E0162C202083006
   VCID: 3C213185266388AA13B-8068
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000002135460 Dataset Number: 4H0909522E  0001
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 313F10B1F1A175C2B0D-8064
   Part No SW: 4H4 907 357 B    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0049
   Revision: --------    Serial number: -------------- Dataset Number: 4H0909865C  0018
   Coding: 02F60A2022100200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
   ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
   Subsystem 1 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7540
   Coding: E00300
   Subsystem 2 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7540
   Coding: E00300
   Power module 1 for left matrix headlamp:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0030
   Coding: E00300
   Power module 1 for right matrix headlamp:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0030
   Coding: E00300
13705473 - Databus
          [Timeout CAN-Message Fahrwerk_01_FR (0x108)]
                    Reset counter: 126
                    Mileage: 67456 km
                    Date: 2023.03.20
                    Time: 22:45:30
13705988 - Databus
          [Empfangener Fehlerwert im Signal FA_Hoehenwert_VL_00: CAN Message Fahrwerk_01_FR]
                    Reset counter: 126
                    Mileage: 67299 km
                    Date: 2023.03.13
                    Time: 01:31:35
13706039 - Databus
          [Empfangener Initwert im Signal FA_Hoehenwert_VL_00: CAN Message Fahrwerk_01_FR]
                    Reset counter: 86
                    Mileage: 67456 km
                    Date: 2023.03.20
                    Time: 22:45:36
13705989 - Databus
          [Empfangener Fehlerwert im Signal FA_Hoehenwert_HL_00: CAN Message Fahrwerk_01_FR]
                    Reset counter: 125
                    Mileage: 67299 km
                    Date: 2023.03.13
                    Time: 01:31:35
13706041 - Databus
          [Empfangener Initwert im Signal FA_Hoehenwert_HL_00: CAN Message Fahrwerk_01_FR]
                    Reset counter: 86
                    Mileage: 67456 km
                    Date: 2023.03.20
                    Time: 22:45:36
13705999 - Databus
          [Empfangener Fehlerwert im Signal Kamera_FDD_Funktionsstatus: CAN Message Kamera_Status]
                    Fault Frequency: 17
                    Reset counter: 86
                    Mileage: 67299 km
                    Date: 2023.03.13
                    Time: 01:31:35
   Part No SW: 4G0 035 083     HW: 4G0 035 083
   Component: Radio U JP    H50 0055
   Revision: AB001007    Serial number: 448KD0E7669822
   Coding: 000005010000000001
   Shop #: WSC 12345 123 61029
   VCID: 5EE59B0DD03FBABA5DF-800A
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4G1 919 129 C    HW: 4G1 919 129
   Component: NGTV-JP       H03 0430
   Revision: R0030000    Serial number: 07001100107201
   Coding: 10000000
   VCID: 2E050BCDE01F6A3AADF-807A
   Part No SW: 4H0 035 678 K    HW: 4H0 035 678 G
   Component: H-BN-JP       H22 0642
   Revision: --------    Serial number: K5FAN1AWAXBY2
   Coding: 03060100020BF9EF7D90CB0E00000003FC0001020000000000
   VCID: 343119A50E3340EADBB-8060
   Subsystem 1 - Part No: 8R0 060 884 CQ
   Component: JPN-25.06.14.  7810
   Subsystem 2 - Part No SW: 4F0 035 503 E    HW: 4F0 035 503 E
   Component: ETC-VICS-Ant.  H04 0020
   Subsystem 3 - Part No SW: 4F0 919 813 E    HW: 4F0 919 813 E
   Component: Card reader  H03 0110
   Serial number: 381312301656
   Subsystem 4 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
   Component: DU8 D4 SV NB  H48 0021
   Serial number: AUZ8ZDEN1007EU5
   Subsystem 5 - Part No SW: 4H2 919 600 M    HW: 4H2 919 600 A
   Component: E380 BDT D4  H11 0110
   Serial number: 00000000174588
   Subsystem 6 - Part No: 8R0 060 961 G
   Component: CD-Database  5950
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H07 0280
   Revision: --------    Serial number: 0000124155973
   Coding: 010F1E00400062C202083006
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JG0009794
   Coding: 020F000101000000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   VCID: 2E050BCDE09F6A3AADF-807A
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 307401077 Dataset Number: 4H0909541F  0008
   Coding: 021004C020
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FBBD6C927152332E69-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000168876 Dataset Number: 4F0000000__ U001
   Coding: 220000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6393AAF9FBDD9752721-8036
   Component: TSG HR        H07 0280
   Revision: --------    Serial number: 0000124155972
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
   Component: GSM-RL        H09 0083
   Revision: 0R0D5015    Serial number: SN141001  0031
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 2C0101C5D683182A83B-8078
   Component: DPC-SG        H27 0081
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4H0909547F  0046
   Coding: EA160000
   ROD: EV_OnBoardCamerDPC.rod
0708 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [EGD_Fahrwerk_01_Signal_Error]
                    Reset counter: 126
                    Mileage: 67299 km
                    Date: 2023.03.13
                    Time: 01:31:35
                    Outside temperature: -44.0 °C
                    Voltage terminal 15: 14.4 V
                    Control Module temperature: 37.0 °C
0706 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [EGD_Timeout]
                    Reset counter: 126
                    Mileage: 67456 km
                    Date: 2023.03.20
                    Time: 22:45:30
                    Outside temperature: -41.0 °C
                    Control Module temperature: 45.0 °C
0793 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [EGD_Fahrwerk_01_Permanent_Error]
                    Reset counter: 86
                    Mileage: 67456 km
                    Date: 2023.03.20
                    Time: 22:45:38
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00018467044802 Dataset Number: 4H0909880D  0019
   Coding: 776FF2
   ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00018593121202 Dataset Number: 4H0909881D  0019
   Coding: 376FF2
   Part No SW: 4H0 907 541 C    HW: 4H0 907 541
   Coding: 7E02010101
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002021
   ROD: EV_AdaptCruisContr2AU64X_002.rod
   VCID: 290FF8D1D9710D0278D-807C
8 Faults Found:
38400 - Function Restricted due to Missing Message(s)
          U1111 00 [016] - -
          [FAULT_CIM_TIMEOUT_AAG]
          Intermittent - Not Confirmed - Not Tested Since Memory Clear
57600 - Function Restriction due to Implausible Message(s)
          U1112 00 [016] - -
          [FAULT_CIM_ALVAAG_FAIL]
99584 - Function Restriction due to Implausible Message(s)
          U1112 00 [016] - -
          [FAULT_CIS_AAG_STOPLIGHTS_PLAUS_FAIL]
          U1113 00 [008] - -
                    Reset counter: 113
                    Mileage: 67311 km
                    Date: 2023.03.13
                    Time: 01:46:55
                    Control Module temperature: 18 °C
                    Voltage terminal 15: 14.419 V
                    Velocity_vehicle_reference: 28.93 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.14 m/s²
141056 - Function Restriction due to Faults in Other Modules
          U1113 00 [016] - -
          [FAULT_CIS_RTA_INVALID]
144640 - Function Restriction due to Faults in Other Modules
          U1113 00 [016] - -
          [FAULT_CIS_STPL_AAG_FAIL]
156672 - Internal Control Module Memory Check Sum Error
          B2000 00 [016] - -
          [FAULT_EDC_ECU_DEFECT]
                    Reset counter: 114
                    Mileage: 67309 km
                    Date: 2023.03.13
                    Time: 01:45:29
                    Voltage terminal 15: 14.402 V
                    Velocity_vehicle_reference: 26.43 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.28 m/s²
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000622410147 Dataset Number: 4H0909548K  0035
   Coding: 01C31A030111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0028 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [ESP_ESP_01_Signal_Error]
                    Reset counter: 113
                    Mileage: 67311 km
                    Date: 2023.03.13
                    Time: 01:46:56
                    Outside temperature: 11.0 °C
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 28.0 °C
0165 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [QSP_Signal_Error]
                    Fault Frequency: 17
                    Reset counter: 121
                    Mileage: 67279 km
                    Date: 2023.03.10
                    Time: 22:40:01
                    Outside temperature: 7.0 °C
                    Control Module temperature: 17.0 °C
0091 - Function Limitation due to Missing Video Data
          C1108 00 [009] - -
          [DPC_SystemError]
                    Fault Frequency: 27
                    Reset counter: 86
                    Mileage: 67299 km
                    Date: 2023.03.13
                    Time: 01:31:35
                    Outside temperature: 12.0 °C
                    Voltage terminal 15: 14.7 V
                    Control Module temperature: 23.0 °C
   Dataset Number: 4H0909614C  0003
   Coding: 0066F609031F0376070308004240C0010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   Dataset Number: 4H0909615C  0003
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323D1FBDF4A74EDAC97-8066
   Part No SW: 4H0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0003
   Serial number: 140821200536
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H09 0008
   Revision: 00001001    Serial number: 97811004392901 Dataset Number: 4H0909578B  0014
   ROD: EV_AEMLearAU64X.rod
1294 - Actuator 1 for Drivetrain Mounts
          C1131 07 [009] - Mechanical Failure
                    Reset counter: 71
                    Mileage: 67278 km
                    Date: 2023.03.10
                    Time: 22:37:51
End----------(Elapsed Time: 03:21, VBatt start/end: 14.3V/14.4V)-----------
Bruce
Uwe caught something I missed and has told you what you need.. ODIS and Audi server access to re-load parameters. Can't be done with VCDS.
