Resolved J519 Problem. Audi A5 2013
Resolved
equijano
Mexico City
C?ID=90020
Hi,
Can you help me to understand this problem code?. The HAVC system isn't working but , now I have these new codes.
there are others codes in the 08 HVAC module
But I want to trace one by one
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 20 36 42 44 46 47 52 53 56 5F
          62 72
VIN: WAU9FD8TXDA060635   Mileage: 129580km-80517miles
Address 01: Engine (DET-CDNC)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115     HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0005
   Revision: ECH09---    CVN: 69A6AE4A
   Coding: 1A250013242601022000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TFS0118K5907115 001007
   ROD: EV_ECM20TFS0118K5907115.rod
   VCID: 6FE98F3DB6C84BEB2A-803A
   VINID: 9D1949594224A1444018018314F4FA331E
Readiness: 1110 0101
   Part No SW: 8K2 927 156 G    HW: 0B5 927 156 J
   Component: 0B5 20TFSIRdW H01 0005
   Revision: --H01---    CVN: 0000D2DA
   Shop #: WSC 00078 790 12345
   ASAM Dataset: EV_TCMDL501021 001012
   ROD: EV_TCMDL501021.rod
   VCID: 3A7F6E69BD0ADE43CD-806E
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 095D0C
   Shop #: WSC 06325 000 00000
   VCID: 0403D091874E58B3E7-8050
   Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
   Component: BCM2 2.0      H12 0633
   Coding: 05A44040000000000000
   VCID: 010DD985985C4D9BCC-8054
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 S    HW: 8K1 820 043 S
   Revision: C0000000    Serial number: 01180220130339
   Coding: 643062C080
   Shop #: WSC 06325 123 12345
   VCID: 387B74618B06CC533B-806C
                    Fault Status: 01101000
                    Reset counter: 177
                    Mileage: 129585 km
                    Date: 2023.03.20
                    Time: 17:44:55
                    Temperature: 26.0°C
03063 - Voltage supply terminal 30 for actuators
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 177
                    Mileage: 129585 km
                    Date: 2023.03.20
                    Time: 17:44:52
                    Voltage: 13.10 V
                    Voltage: 13.00 V
                    Current: 5.700 A
                    Current: 5.700 A
                    Current: 5.725 A
                    Current: 5.725 A
                    Bin. Bits: 00000000
                    Count: 65534
                    Reset counter: 177
                    Mileage: 129585 km
                    Date: 2023.03.20
                    Time: 17:44:57
                    Temperature: 26.0°C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 177
                    Mileage: 129585 km
                    Date: 2023.03.20
                    Time: 17:44:52
                    Fault Status: 01100101
                    Reset counter: 177
                    Mileage: 129585 km
                    Date: 2023.03.20
                    Time: 17:44:52
                    Reset counter: 177
                    Mileage: 129585 km
                    Date: 2023.03.20
                    Time: 17:45:00
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000555632801
   Coding: 260000108074AFE00181408000001D0DCF9CD308AE090221000008000401030100000024000000
   VCID: 78FBB461CB860C53FB-802C
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 140213  H15 0080
   Serial number: SWF13020140055
   Coding: 00FD11
   Serial number: 20992368
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000802131468
03020 - Local databus 2
                    Fault Status: 01101100
                    Reset counter: 177
                    Mileage: 129585 km
                    Date: 2023.03.20
                    Time: 17:44:55
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD98B340   Dataset Number: 8T0909602M  0005
   Coding: 30513938363030303030554A304C38543053
   VCID: 489B04A1F3E6BCD34B-801C
   Serial number: 6334MSME78655A52L
   Serial number: 6344MSME7865567EW
   Serial number: 6352QSME122C0E4EQ
   Serial number: 6362QSME452C3B6CX
   Serial number: 63732SME7D281740+
   Serial number: 63832SME4C294F48F
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20130215000914
   Coding: 000036
   VCID: 4FA92FBD1E886BEB0A-801A
   Part No SW: 8T0 920 931 T    HW: 8T0 920 931 T
   Component: KOMBIINSTR.   H35 0556
   Revision: 00100000    Serial number: UUS44DG2E
   Coding: 13B731000301100C050001
   VCID: 489B04A1FBE6BCD34B-801C
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0055
   Revision: 1Z100027    Serial number: 2741Z132058046
   Coding: 80CF07FF00
   VCID: 4C9338B1EF9E50F36F-8018
   Serial number: 0400630003
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 13040000482011200410
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 04019864747464545425363E00
   VCID: 7CF3A871FFBE20739F-8028
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000050754701
   Coding: 01581B00000000000000
   VCID: 3B716B6DBA30E74BD6-806E
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011F12625E00450005
   VCID: 56A7DAD921521A23C9-8002
   Part No SW: 8K0 909 144 R    HW: 8K0 909 144 B
   Component: RCEPS         H43 0511
   Revision: 00001000    Serial number: 0006785616
   Coding: 100000010001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 408B1C81DBD6849383-8014
   Revision: 00002001    Serial number: 0301033208
   Coding: 017E0E2020F9408581B004B68000000F
   Shop #: WSC 06324 123 12345
   Component: GTO BF  H01 0080
   Serial number: 00000000000000635149
   Subsystem 2 - Part No: 8K0 951 177
   Subsystem 4 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Revision: 00005001    Serial number: 94813010932802
   VCID: 2D555535744479FB58-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   Coding: 011F12225E00450005
   VCID: 55A5DDD53C54113BC0-8000
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 10000000170286
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 387B74618306CC533B-806C
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227B$0D7694290
   Coding: 050005010000000001
   VCID: 2647AA1951B24AA399-8072
   Part No SW: 8R1 035 664 K    HW: 8R1 035 664 B
   Component: H-BN-NA       H44 1040
   Revision: --------    Serial number: 203BW0D7516719
   Coding: 130200040106E1FD4502DF6E00000403F40000020000000202
   VCID: 3E776279A922F263F1-806A
   Subsystem 1 - Part No: 8R0 060 884 GB
   Component: NAR 2019  1901
   Component: DU7 High  H42 0104
   Serial number: A130BS0D2654268
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001415368
   Component: CD-Database  4949
03623 - Invalid Security/Release Code
                    Reset counter: 177
                    Mileage: 129585 km
                    Date: 2023.03.20
                    Time: 17:46:26
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0304
   Coding: 010C12224000450005
   VCID: 59BDD1E5504C355BE4-800C
   Component: TSG HR        H07 0304
End---------------------(Elapsed Time: 03:52, udsna)-----------------------
Can someone help me to understand the code
that means that there are local databus1?
EQ
Bruce
Near Philadelphia, PA, USA
I'm wondering if you have a blown fuse based on this fault and then several no communications faults:
Have you checked? You probably need a wiring diagram. See the "How To" at the top of the page for advice on getting wiring diagrams.
I don't have the reference details for your car. Maybe someone else will come along to help.
equijano
Mexico City
C?ID=90020
Thanks Bruce for your comments. Well I already have the wiring diagrams from AllData and ERWIN.
Can I share some pictures of them here? so i'll write down some doubts.
EuroX
Northern NJ USA
C?ID=208579
You either have a wiring problem or a sensor issue. If you have a faulty air quality sensor or pressure sensor for the ac the system will not work. I would test the sensors see if you have power ground and 5v reference, or any signal on the lin wire. IIRC both of those sensor are on the same LIN wire.
Bruce
A page or two can be shared... Best to limit the amount being shared. They are copyrighted materials and posting complete pages could be a violation. Better to post a snap shot of the area in question.
equijano
Mexico City
C?ID=90020
Thanks about the testing the Pressure sensor , I changed without testing the air quality sensor isn't tested. Sorry for this question but how I test it?. For example the Pressure sensor has 3 pins GND, LIN, 5V, I don't want to mess up for that reason I don't test it. so that means that I need to test voltage in the PIN 1 and 3 of both sensors, am I right?
equijano
Mexico City
C?ID=90020
Sure, I understand that , that was the reason for asking first.
The ERWIN
and ALLDATA
Thanks for your help.
Bruce
Yes. Check the power pins on the sensor. Do you have 5v? If not, you need to find out why not.
If yes, then check the LIN line with the positive probe on LIN and negative probe on ground. You should have a voltage less than 5v but higher than ground.
If good, go to the ECU pins and check it at that end. Do you get the same results? If not, there is a wiring problem.
equijano
Mexico City
C?ID=90020
Well, finally today I check both output sensors connectors
G657/G238 :thumbs:
G395 :thumbs:
How can I check the LIN line? Sorry, but I don't want to assume. You mentioned that I should check the LIN output for a voltage? Does this mean I should connect the positive cable of the multimeter to the sensor connector with the power supply and LIN cable? Could you please provide a picture or an image? My apologies, I am learning. Thank you in advance.
equijano
Mexico City
C?ID=90020
Well, here's a final update. I'm sharing this for those who like me, are just starting out and had a very productive day of learning today.
To begin with, the G238/G657 and G395 sensors receive current (+) from ST1/SC3 (Fuse 3 of Fuse holder 3) and ground (-) from G639, both at 12V. The G657/G238 sensor has the current input on PIN 1 and ground on PIN 2, with the LIN port on PIN 3. The G395 sensor receives current (+) from PIN 3 and ground from PIN 1, with the LIN port on PIN 2. The sensors are slaves and the J519 module (onboard supply control unit) is the master. The master ONLY sends requests if the line is enabled, for which the Slave sends the current signal to the master module using the LIN port. When the master module senses this current, it begins sending requests to the slave module. If it DOES NOT sense current, it will not request anything.
Finally, I attempted to measure current on the LIN port. I know it should be measured with an oscilloscope, but unfortunately, I don't have one at the moment. I tried measuring it with my multimeter by putting the ground on the chassis and the positive on the Slave LIN port, but I couldn't get anything. Perhaps I'm doing this procedure wrong, but that's what I tried. I also tried putting the positive on the LIN port and the negative on the negative port of the slave module to see if it received anything, but nothing. It could be that my low-cost multimeter is not suitable for this task, as we know it only gives averages and cannot capture the averages of what passes through the LIN line.
Things I learned: If the slave module has no power, it will NEVER be able to send the signal to the master that it is active, and therefore the master will NOT send anything.
The LIN signal is a one-wire communication protocol that is bidirectional (the master requests information or sends commands to the slave module, which sends information or receives orders). I understand that a good multimeter should be able to measure an average voltage (of the high and low currents of the communication between the modules). This is just theory and I need to put it into practice. (If anyone can contribute to improving this comment, I would appreciate it.);)
After understanding the operation of the LIN bus, I began to check the other error I had with the air conditioning actuators.
Some time ago, I bought another J255 air conditioning module (which I haven't changed yet because the serial number needs to be matched with the equipment, as far as I understand), and with the current J255 module, I measured the current of T16i port 2 (+) and T16i port 3 (-), but there was no voltage.
Then, I replaced the module with the other one that, although not activated, when connected, ports 2 and 3 send 12V voltage, which is what the actuators need to operate and activate Port 1 (LIN Bus). Therefore, although I couldn't solve the initial problem, it allowed me to determine that the my actual J255 has an output voltage problem, which is why VCDS showed me 12V output as zero in the J255.
It remains pending to check the port of the J519 module T16b Pin 4 (LIN port) to see if the slaves are sending current, because as they are in series, it can be misleading if one is sending and the other is not. But anyway, I believe and hope to be closer to finding a solution.
That's all for my 2 cents.
Bruce
I think the key point you have discovered is the fact that sensors are in series. When this is the case, the only way to find which may be causing the problem is to isolate - you have to unplug one, try the measurements on the one still plugged in. If it works, then you know the one unplugged is locking up the series connection.
If it does not work, don't assume the other sensor is the problem. Test it to be sure.
If neither work, then the problem lies elsewhere.
While I could argue nuances of your understanding of the LIN Bus, you have described it well enough for our purposes. It is a single wire bus that is bidirectional. That said, you should still be able to measure a switching voltage on it if communications are present. When devices on the bus are communicating, an average voltage of less than 12 but greater than 0 should be present. It does not matter which way you connect the multimeter leads. The lead connection will only effect the (+) or (-) sign of the value in this case.
equijano
Mexico City
C?ID=90020
Update:
Finally seems that I found the source of the problems seems to be the PORT A6 - C (16 PIN Port)
Connections of the Audi A5 central control unit for J519.
Connection order for the control device - J519."
M4Py1wg1lhlsAthnDLeftGaW0dF5PLUA6BXQAY0HH3a7cnE6SnxblfxcqirnxjPygWYbgFzFxlpsC7hFpHssgoOQMwMtEoy4t6z8eZixjLz3zODeykzgQY0Pg9m8Y4KODP55uOgtwImm7VYWpMfhjh0
Conector A (32-pin) - A5​
Pin 8: Warning lights button -E229
Pin 9: Redundancy contact, light switch
Pin 13: Valet parking button -E536
Pin 14: Rear roller blind switch -E149
Pin 17: Footwell lights, front -L151 / -L152
Pin 18: LIN 1 (light switch -E1)
Pin 26: Enable electric steering column lock
Pin 27: Valet parking button warning lamp -K159
Pin 28: Hazard warning light system warning lamp -K6
Pin 31: Switch search illumination terminal 58s
Conector B (32-pin) - A7​
Pin 1: Switch search illumination terminal 58st
Pin 3: Bonnet contact switch -F266
Pin 5: Oil pressure switch for reduced oil pressure -F378
Pin 6: Brake fluid level warning contact -F34
Pin 9: Brake lining wear sender, front left -G34
Pin 10: Ambient temperature sensor -G17
Pin 13: Gear recognition switch -F208 (forward gear)
Pin 14: Front left seat temperature sender -G344 (not if seat ventilation fitted)
Pin 16: Terminal 15
Pin 17: Switch search illumination terminal 58s
Pin 19: Front right seat temperature sender -G345 (not if seat ventilation fitted)
Pin 21: Gear recognition switch -F208 (reverse gear)
Pin 25: General signal earth
Pin 27: Coolant shortage indicator sender -G32
Pin 28: Windscreen washer fluid level sender -G33
Pin 29: Horn relay -J413
Conector C (16-pin) - A6​
Pin 2: LIN 1 (wiper motor control unit -J400, rain and light sensor -G397)
Pin 4: LIN 2 (Charisma switch module -E592, air quality sensor -G395, refrigerant pressure and temperature sender -G238, garage door opener control unit -J530, front left seat ventilation control unit -J799, front right seat ventilation control unit -J800)
Pin 14: CAN-Low
Pin 15: CAN-High
Conector D (17-pin) - A1​
Pin 1: Servotronic solenoid valve -N119 (activation)
Pin 3: Windscreen washer pump -V5 (activation 2)
Pin 4: Windscreen washer pump -V5 (activation 1)
Pin 6: Headlight washer system pump -V11
Pin 8: AC compressor regulating valve -N280 (activation)
Pin 9: Interior light dimming
Pin 10: AC compressor regulating valve -N280 (earth)
Pin 12: Servotronic solenoid valve -N119 (earth)
Pin 14: Footwell lights, rear -W45/-W46
Pin 15: Terminal 30 - 2
Pin 16: Terminal 30 - 1
Pin 17: Terminal 30g - supply (interior light supply)
Conector E (17-pin) - A2​
Pin 2: Daytime running lights and side lights bulb, left -L186 (halogen headlights) / Supply LED module, left, for daytime running lights and side lights -L176 (xenon headlights)
Pin 3: Dipped beam screen, left -V294 (xenon headlights)
Pin 4: Front right side marker light bulb -M34
Pin 5: Turn signal light bulb, front left -M5
Pin 6: Front left side marker light bulb -M33
Pin 8: Fog light bulb, left -L22
Pin 12: Main beam headlight bulb, left -M30 (halogen headlights) / Activation, LED module, left, for daytime running lights and side lights -L176 (xenon headlights)
Pin 15: Dipped beam headlight bulb, left -M29 (halogen headlights) / Left side gas-discharge lamp control unit -J343 (xenon headlights)
Pin 16: Terminal 30 left
Pin 17: Terminal 31 - 2
Conector F (17-pin) - A3​
Pin 2: Main beam headlight bulb, right -M32 (halogen headlights) / Activation, LED module, right, for daytime running lights and side lights -L177 (xenon headlights)
Pin 7: Daylight driving light bulb, left -L174 (halogen headlights)
Pin 8: Fog light bulb, right -L23
Pin 9: Dipped beam screen, right -V295 (xenon headlights)
Pin 10: Turn signal light bulb, front right -M7
Pin 12: Daytime running lights and side lights bulb, right -L188 (halogen headlights) / Supply LED module, right, for daytime running lights and side lights -L177 (xenon headlights)
Pin 14: Daylight driving light bulb, front right -L175 (halogen headlights)
Pin 15: Dipped beam headlight bulb, right -M31 (halogen headlights) / Right side gas-discharge lamp control unit -J344 (xenon headlights)
Pin 16: Terminal 30 right
Pin 17: Terminal 31 - 1
Conector G (6-pin) - A4​
Pin 1: Seat heating front left (heated driver's seat -Z6, heated driver's seat backrest -Z7); not if seat ventilation fitted)
Pin 3: Terminal 30 - 3
Pin 6: Seat heating front right (heated front passenger seat -Z8, heated front passenger seat backrest -Z9); not if seat ventilation fitted)
As we can see the port C has 2 LIN ports 1 and 2
and the error in the Scan is:
Reset counter: 177
Mileage: 129585 km
Date: 2023.03.20
Time: 17:44:55
The PIN 4 has all this sensors attached
Puf85mPPdcQ2QyUgqE45BNy3fo3dCgY-in6yG7QmoSiE5pin-pnFX7QyPHTSqAMEZthrAQdEJ4ZJah37_ZB6P0n6gUwaRsiHnCCd50QfQGPPYnIoPOi7QHkeyCJU0-W0IWB9xuK9XsfRzUPQXaRQjA4
I check the garage open door module and doesn’t work too but there isn’t any DTC. it's normal?
I’ll check the weekend all the others sensors.
Just a question
1.- If it is possible to fuse a LIN bus PIN?, There is any chance to repair? or I must to change the J519 Module?
2.- If I change the J519 module , I need to code it with ODIS and gecko pair system?.
Since there are so many things connected to that LIN bus, I would try disconnecting them one at a time to see if any of them are responsible for the fault rather than the J519 module itself. You should also check that there are no wiring faults on that bus (like a short to some other wire).
LIN bus is normally quite fault tolerant; a hard short to either GND or +12 should not damage it, so I'm not sure what benefit a fuse would bring.
I am not sure whether J519 is part of the Component Protection scheme in that car.
equijano
Mexico City
C?ID=90020
Another Update:
Well, I check the following items.
  1. Charisma switch module -E592,:thumbs:
  2. air quality sensor -G395 :thumbs:
  3. refrigerant pressure and temperature sender -G238, :thumbs:
  4. garage door opener control unit -J530 :banghead:
  5. front left seat ventilation control unit -J799 & front right seat ventilation control unit -J800) N/A
the J530 it has corrosion blue in the terminals , I cleaned all the pins of all the devices attached to T16b /4 LIN databus 2
and this error is gone
Reset counter: 177
Mileage: 129585 km
Date: 2023.03.20
Time: 17:44:55
and all this error gone too
Reset counter: 177
Mileage: 129585 km
Date: 2023.03.20
Time: 17:44:55
Temperature: 26.0°C
Reset counter: 177
Mileage: 129585 km
Date: 2023.03.20
Time: 17:44:57
Temperature: 26.0°C
Reset counter: 177
Mileage: 129585 km
Date: 2023.03.20
Time: 17:44:52
Reset counter: 177
Mileage: 129585 km
Date: 2023.03.20
Time: 17:45:00
and about this notice
Reset counter: 177
Mileage: 129585 km
Date: 2023.03.20
Time: 17:44:52
Voltage: 13.10 V
Voltage: 13.00 V
Current: 5.700 A
Current: 5.700 A
Current: 5.725 A
Current: 5.725 A
Bin. Bits: 00000000
Count: 65534
Finally I test the J255 module and the pinz T16i /1 (LIN), T16i /2 (Current) , T16i /3 (Ground) there is not any voltage output!:banghead: as we know now, if there is not current there is no way to send data link using LIN BUS in the T16i /1 port.
I just purchase today a VAS 5054a module to do some test and hire to someone to do the coding of the J255 Module and attach to the system.
There is any chance to learn more about Coding, ODIS and other stuff?.
Regards
EQ
equijano
Mexico City
C?ID=90020
SOLVED
Well, I finally swap my J255 all the LIN actuators are working now, the G395 was faulty and crashing all the LIN Communication change was need as usal , no J519 change , swap or modification thanks @Uwe for your suggestions, and the garage door opener control unit -J530 has some terminal corrosion. thanks @Bruce for all the comments and assistance .
EuroX
Northern NJ USA
C?ID=208579
Glad you got it sorted out.
