2012 Seat Ibiza DPF light doesn't clear
FStech
Moray, UK
C?ID=518341
So my daughter has returned home with yet another problems that requires assistance from Dad's garage :). This time it's the DPF light that won't clear. I have carried out a complete scan but I'm not getting any error codes.
The only code I am getting is Mode 03 Missions related fault code, 7E8 when I carry an OBD2 scan and I an unable to clear this.
Sunday,19,March,2023,17:12:30:41739
VCDS Version: 23.3.0.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: VSSZZZ6JZDR044623   License Plate:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZDR044623   Mileage: 136300km-84692miles
   Part No SW: 03L 906 023 LE    HW: 03L 906 023 Q
   Component: R4 1.6l TDI   H33 9978
   Revision: --H33---    Serial number:                CVN: A20C3AD5
   Coding: 00114016000500080000
   ASAM Dataset: EV_ECM16TDI02103L906023LE 003011
   ROD: EV_ECM16TDI02103L906023LC_SE25.rod
   VCID: 74B1D2388E311F1A1BB-8020
   VINID: 9A38EAAAA19AA948801041820CDC00B8F4
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6R0 907 379 AD    HW: 6R0 907 379 AB
   Component: ABS8.2 front  H03 0001
   Revision: --------
   Coding: 100200DB007100B6082B00E400D400000000
   Shop #: WSC 04941 000 00000
   VCID: 00598EE8CA4933BA0F3-8054
Address 08: Auto HVAC        Labels: 6J0-820-045.clb
   Part No SW: 6J0 820 045 A    HW: 6J0 820 045 A
   Component: J301  Klimaanlage   0330
   Revision: 00 26 08    Serial number: 0000002497733-
   Shop #: WSC 06402 785 00200
   VCID: 2411E27872D1CF9A4BB-8070
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0254
   Revision: BF046001    Serial number: 0434 125120537
   Coding: 24882BE888612500922008F06E0B0CC80000422F608C0000200000000000
   Shop #: WSC 64564 324 38760
   VCID: 45D75FFC95ABD6927C5-8010
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3110
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3110
   Coding: 020000
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 5 - Part No: 1K8 951 171 A
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagA0D H10 0020
   Revision: --------    Serial number: 003GX017MW2U Dataset Number: s00303416J0 0009
   Coding: 003044
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250_VW25.rod
   VCID: 4ACD6CC0BC3539EA917-801E
   Serial number: 3495RRB405P17NPAE8QJ
   Serial number: 3505RRB405318U1C50M/
   Part No SW: 6J0 920 904 L    HW: 6J0 920 904 L
   Component: KOMBI         H03 0507
   Coding: 410A00
   VCID: 34311238CEB15F1ADBB-8060
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0254
   Revision: BF046001
   Coding: 022300
   VCID: 70B9DE28FAA9233AFF3-8024
   Component: IMMO          H03 0507
   VCID: 6A8DCC40DCF5D9EAB17-803E
   Part No: 6R0 423 156 B
   Coding: 11251
   Shop #: WSC 00046
   VCID: 2F3B1D542E577CC2A69-807A
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441
   Component: MF-Modul       0007 0001
   Coding: 0000001
   Shop #: WSC 77005 000 00000
   VCID: 70B9DE28F6A9233AFF3-8024
Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
   Part No SW: 6J2 035 153 G    HW: 6J2 035 153 G
   Component: Radio         H15 0204
   Revision: R0000000    Serial number: SEZAZ2M1967219
   Coding: 0503020002
   VCID: 2A0D0C401CF519EA717-807E
                    Fault Status: 00101011
                    Reset counter: 123
                    Mileage: 136289 km
                    Date: 2017.08.07
                    Time: 09:32:26
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 83
                    Mileage: 136289 km
                    Date: 2017.08.06
                    Time: 09:33:57
End----------(Elapsed Time: 01:28, VBatt start/end: 14.3V/14.2V)-----------
I have tried to carry out a static DPF regen but this isn't available, only regen whilst driving. I have read various posts here which say that if if the ash is above 40g then this isn't possible and requires the DPF cleaning. See below
Sunday,19,March,2023,17:01:20:41739
VIN:    License Plate: YR62KWZ
Mode 03: Emission related fault codes
Address 7E8: No fault code found.
Address 01: DTCs cleared
                Address 01: Engine  (03L 906 023 LE)
17:08:07
  IDE00196-ENG100000   Engine oil temperature-TOIL 43 °C
  IDE00427-ENG101722   Particle filter: difference pressure-DIP_PF 6.55 hPa
  IDE00428-ENG100917   DPF: offset for differential pressure-DIP_PF_AD[0] 0.00 hPa
  IDE00430-ENG102682   Particle filter: field regeneration request status-STATE_RGN_PF 0
  IDE00433-ENG103279   Particle filter: oil ash volume-MASS_ASH_PF 42.4234900 g
  IDE00434-ENG102050   Particle filter: soot mass calculated-MASS_SOOT_SIM_PF 12.30 g
  IDE00435-ENG101197   Particle filter: soot mass measured-MASS_SOOT_PHY_PF 8.34 g
  IDE00556   Outside temperature 8 °C
  IDE01360-ENG103054   Service regeneration: Release conditions 3-FRF_STATE_RGN 9
  IDE04263-ENG102014   Sensor for particle filter differential press: raw value-DIP_PF_RAW[0] 7.30 hPa
  IDE04650-ENG111633   Particle filter: differential pressure: dynamic offset-DIP_PF_DYN_AD_VALUE[0] 0 hPa
Hmm.. DPF light on with no fault codes is quite strange. Incidentally, "7E8" is not a fault code. It's the address that responded to the generic OBD-II query.
Ash mass over 40 gram, remove DPF and have it professionally cleaned, refit and carry out service regeneration
Good catch.
But I'm still surprised there isn't a DTC to reflect this.
VWT6
Finland
C?ID=295527
No, not the ash. If the SOOT mass is above 40 grams, ECU won't allow DPF regen.
Ash is residual of burned soot, burned oil deposits, etc. The ash capacity of the DPF is probably somewhere at 80 grams. For the exact number there should be a parameter "Particulate filter ash limit" .
Did you trigger the regen whilst driving? Did you actually drive the car? Long enough (30 minutes)?
What I have observed (on different engines though) the triggering turns on the DPF light (without fault codes) and you need to finish the full cycle before the light turns off. The soot mass values (12.30g, 8.34g) possibly indicate that the DPF regen has not finished yet.
Please post engine's full blockmap data - it should contain information at what phase (of DPF regen) the engine is - preferably hot engine idling.
VCDS > Applications > Controller channel map > [Controller 01, Measuring values, CSV file]
FStech
Moray, UK
C?ID=518341
The DPF light was on when my daughter left home and drove 200 miles to our home, but the light didn't extinguish. She has had this problem on and off for the past 18 months and knows how to manage it, to get it to regen with long drive and rpm > 1500. She does regular 1hr+ journeys.
She has had it looked at by a garage, they inserted an plate at the EGR valve and changed some coding, not sure what was changed.
VWT6 - Can you please explain how to obtain full blockmap data, thanks
VWT6
Finland
C?ID=295527
From VCDS main menu select Applications - then select Controller Channel Map
Fill fields/tick boxes:
Single Controller Address - 01​
Login or security access code - leave blank​
Function - tick Measuring values​
(Repeats - 0)​
Output - CSV file​
Click on Go​
When finished click Done, the logged file blockmap-01-... will be in folder C:\Ross-Tech\VCDS\Logs\...
Well, definitely quite a challenge then. Possibly the blockmap still can tell what the engine is doing. E.g. time/distance since last regen etc.
FStech
Moray, UK
C?ID=518341
Full blockmap data attached
;SW:03L-906-023-LE   HW:03L-906-023-Q ---  Engine
;Component:R4 1.6l TDI   H33 9978     Coding:00114016000500080000
;EV_ECM16TDI02103L906023LE    3011    EV_ECM16TDI02103L906023LC_SE25.rod
;Monday    20    March    2023    14:14:48:41739
;VCDS Version: Release 23.3.0 (x64)  Data version: 20230228 DS346.1
;VCID: 74B1D2388E311F1A1BB-8020
Group    Description    Actual
IDE00018-ENG99300    Voltage terminal 15-V_IGK    12.2     V
IDE00019    Voltage terminal 30    12.198     V
IDE00021    Engine RPM    0     /min
IDE00025    Coolant temperature    8     °C
IDE00030    Status of actuator test    not active
IDE00075    Vehicle speed    0     km/h
IDE00076    Status of initial fuel filling    Default
IDE00078    Time since engine start    0     s
IDE00083    Throttle valve position (absolute)    88.6     %
IDE00084    Absolute load value    0     %
IDE00085    Normed load value    0     %
IDE00086    Accelerator pedal position    14.1     %
IDE00090-ENG100708    selected gear-DRI    0
IDE00097    OBD - requirements for which this vehicle is designed    Euro-OBD
IDE00100-ENG101842    Engine torque-TQI_SP    0     Nm
IDE00102-ENG103182    Control Module temperature-TECU    17     °C
IDE00167    Exhaust temperature 1 bank 1    20     °C
IDE00169    Exhaust temperature 2 bank 1    20     °C
IDE00172-ENG99317    A/C compressor torque-TQ_LOSS_ACC    0     Nm
IDE00173-ENG102035    Cruise Control System: specified speed-Vehicle speed: specified    0     km/h
IDE00182-ENG103031    Camshaft adaptation intake bank 1: phase position-Camshaft adjustment: inlet phase: bank 1    0.375     °
IDE00188-ENG102817    Fuel high-pressure: actual value-FUP_FIL    0     MPa
IDE00190-ENG100128    Charge air pressure: specified value-MAP_SP_MMV    200     hPa
IDE00191-ENG103684    Charge air pressure: actual value-MAP_MMV    200     hPa
IDE00192-ENG99381    Coolant temperature at radiator outlet: actual value-TCO_2    8     °C
IDE00196-ENG100000    Engine oil temperature-TOIL    0     °C
IDE00198-ENG111631    Refrigerant pressure-ACP_MES    4.5     bar
IDE00201-ENG102664    High fuel pressure: specified value-FUP_SP_KPA    0     kPa
IDE00304-ENG101210    Fuel level-FTL_CAN    31     l
IDE00322-ENG100540    Status of basic setting-Basic Settings Status    was not yet started
IDE00347    Air mass: actual value:    1.88     g/s
IDE00348    Intake air temperature    10     °C
IDE00349    Throttle valve position: normed    96.1     %
IDE00350-ENG99082    Air mass: specified value-MAF_SP_MMV    239.95     mg/stroke
IDE00351-ENG100251    Main injection: start of activation-SOI_MAIN_SP    0     °
IDE00352-ENG99257    Main injection: duration of activation-TI_MAIN_BAS    0     ms
IDE00353-ENG102974    Engine start: start quantity-TQI_ST    161.41     Nm
IDE00354-ENG102395    Engine start: start synchronization-LV_SYN_VLD    0
IDE00355-ENG103498    Cruise Control System (CCS): status-Binary 8 Bit    10000000
IDE00356-ENG102448    Cruise Control System (CCS): switch position-STATE_CRU_SWI_POS    10
IDE00357-ENG99842    Fuel temperature-TFU    11     °C
IDE00358-ENG100184    Limitation: torque-TQI_LIM_MIN    1023.97     Nm
IDE00359-ENG102866    Limitation: smoke-TQI_SLM    1023.97     Nm
IDE00361-ENG99319    Ambient air pressure-Ambient pressure    1002.8     hPa
IDE00362-ENG100099    Charge Pressure Actuator: activation-ANG_SP_BPA[0]    20     %
IDE00363-ENG102107    Glow status-STATE_GLOW    80
IDE00364-ENG102834    Pre-glow time-T_GL_ES    1.5     s
IDE00365-ENG99400    Injection quantity deviation cylinder 1-FAC_CYL_BAL1    0.0002     mg/stroke
IDE00366-ENG101187    Injection quantity deviation cylinder 2-FAC_CYL_BAL2    0.0002     mg/stroke
IDE00367-ENG101684    Injection quantity deviation cylinder 3-FAC_CYL_BAL3    0.0002     mg/stroke
IDE00368-ENG103465    Injection quantity deviation cylinder 4-FAC_CYL_BAL4    0.0002     mg/stroke
IDE00371-ENG100275    Fuel consumption-FCO_T    0     ml/s
IDE00373-ENG99620    Electric auxiliary heater: shut-off conditions-Binary 16 Bit    00000000 01011101
IDE00374-ENG100674    Electric auxiliary heater: relay activation-COUNT_ACT_HEAT_ELEMS    0
IDE00375-ENG103823    Generator: load signal-ALTPWM    100     %
IDE00380-ENG102782    Coolant fan 1: activation-Radiator fan 1: activation    9.8     %
IDE00381-ENG101514    Coolant fan 2: activation-Radiator fan 2: activation    9.8     %
IDE00383-ENG104210    Pre-injection 1: activation start-SOI_PREV_SP[0]    0     °
IDE00384-ENG101378    Pre-injection 1: activation duration-TI_PREV_BAS[0]    0     ms
IDE00385-ENG99181    Pre-injection 2: activation start-SOI_PREV_SP[1]    0     °
IDE00386-ENG99911    Pre-injection 2: activation duration-TI_PREV_BAS[1]    0     ms
IDE00387-ENG99235    Post-injection 1: activation start-SOI_POST_SP[0]    0     °
IDE00388-ENG102772    Post-injection 1: activation duration-TI_POST_BAS[0]    0     ms
IDE00389-ENG103789    Post-injection 2: activation start-SOI_POST_SP[1]    0     °
IDE00390-ENG102792    Post-injection 2: activation duration-TI_POST_BAS[1]    0     ms
IDE00392-ENG100739    Accelerator pedal: sensor voltage 1-V_PVS_1_BAS    0.723     V
IDE00393-ENG102348    Accelerator pedal: sensor voltage 2-V_PVS_2_BAS    0.376     V
IDE00396-ENG103408    Charge air pressure actuator: acknowledgment-ANG_BPA[0]    10.217     %
IDE00400-ENG99245    Intake manifold Runner Control (IMRC): activation-ANG_SP_PORT[0]    14.999     %
IDE00401-ENG102947    Intake manifold Runner Control (IMRC): acknowledgment-ANG_PORT[0]    99.811     %
IDE00404-ENG102559    Throttle valve: activation-PWM_HBR_THR[0]    0     %
IDE00405-ENG98787    Crankshaft speed (RPM)-N    0     /min
IDE00406-ENG102227    Camshaft RPM-N_CAM    0     /min
IDE00407-ENG101894    Rail pressure regulation: status-LV_VCV_CTL    0
IDE00413-ENG100922    Starter control: Interlock- or P/N-signal-LV_CLU_SWI_2_PN    0
IDE00414-ENG100800    Starter control: relay 1-Starter: start relay 1    0
IDE00415-ENG99979    Starter control: relay 2-Starter: start relay 2    0
IDE00420-ENG101443    Service regeneration: current duration-T_RGN_ACT_PF    0     s
IDE00423-ENG103230    Service regeneration: Release conditions 2-Binary 32 Bit    01011001 01111110 11111111 11011111
IDE00425-ENG102682    Service regeneration: phase-STATE_RGN_PF    0
IDE00427-ENG101722    Particle filter: difference pressure-DIP_PF    0     hPa
IDE00428-ENG100917    DPF: offset for differential pressure-DIP_PF_AD[0]    0     hPa
IDE00431-ENG102952    Particle filter: field regeneration lock status-LV_STATE_TEST_RGN_PF_INH_HLD    0
IDE00432-ENG103847    Particle filter: time since last regeneration-T_WOUT_RGN    89249     s
IDE00433-ENG103279    Particle filter: oil ash volume-MASS_ASH_PF    42.4237176     g
IDE00434-ENG102050    Particle filter: soot mass calculated-MASS_SOOT_SIM_PF    12.32     g
IDE00436-ENG102397    Particle filter: kilometers since last regeneration-DIST_RGN    1259.4     km
IDE00437-ENG99390    Injector valve 1: capacity-CAPA_INJ_MAIN[0]    0     µF
IDE00438-ENG103101    Injector valve 2: capacity-CAPA_INJ_MAIN[1]    0     µF
IDE00439-ENG102776    Injector valve 3: capacity-CAPA_INJ_MAIN[2]    0     µF
IDE00440-ENG104221    Injector valve 4: capacity-CAPA_INJ_MAIN[3]    0     µF
IDE00445    Unlearning counter according OBD    255
IDE00450    Operating instruction    ---
IDE00451    Currently running routine    Unknown (0)
IDE00472-ENG99569    Mean injection quantity-MF_INJ_SUM    0     mg/stroke
IDE00473-ENG102104    EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]    0     %
IDE00474    Ambient air pressure    100     kPa abs
IDE00475-ENG99518    Fuel Pressure Regulator Valve-PCV    0     %
IDE00476-ENG104101    Fuel Metering Valve-VCV    0     %
IDE00477-ENG99523    Torque request: sum of auxiliary aggregate-TQ_LOSS_ADD    0     Nm
IDE00478-ENG104104    Engine-drag torque-TQFR_BAS    -30.81     Nm
IDE00481-ENG103062    Limitation: status of clutch protection-LV_TQI_LIM_CLU_PROT_ACT    1
IDE00482-ENG101051    Limitation: torque of clutch protection-TQI_LIM_CLU_PROT    1023.97     Nm
IDE00495-ENG99873    Calculated oil temperature-TOIL_MDL    7     °C
IDE00541-ENG103835    Acceleration-AC_VEH_CLC    0     m/s²
IDE00545-ENG102287    maximum permissible engine torque-TQI_TQL    1023.97     Nm
IDE00556    Outside temperature    11     °C
IDE00558    Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor)    0.505 Lambda / 0.000 V
IDE00581    EGR specified value    0     %
IDE00583    Throttle valve specified value    95.7     %
IDE00584    Distance driven since erasing DTC memory    1     km
IDE00585    Dist. driven with exh. Malfunction Indicator Lamp activated    0     km
IDE00586    Deviation of exh.gas recirc. rate    99.2     %
IDE00589    Fuel pressure    0     kPa rel
IDE00594    Absolute intake pressure    100     kPa abs
IDE00595    Allocation of oxygen sensors    B1S1
IDE00600    Conversion factors    Max eq. ratio 32  / Max V O2s 0 V
IDE00601    Monitoring status since erasing DTC memory
IDE00602    Monitoring status in current driving cycle
IDE00603    Number of driving cycles since erasing DTC memory    0
IDE00606    Oper. time with exh. Malfunction Indicator Lamp activated    0     min
IDE00607    Time since erasing DTC memory    14     min
IDE00608    Fuel type    Diesel
IDE00611    Malfunction that has caused the ambient data to be stored    00 00
IDE00727    Test steps still to be performed    0
IDE00787    Cause for cancellation    0
IDE00973-ENG103910    Outside temperature-Ambient temperature    10.5     °C
IDE01259-ENG101906    EGR Solen.val.: actual value-ANG_EGRV[0]    99.997     %
IDE01260-ENG99807    Generator performance-GEN_LOAD_CAN    99.2     %
IDE01361-ENG102606    exh.gas recirc. (EGR) cooler pump: specified value-PWM_EGRCP[0]    95.001     %
IDE01362-ENG99381    Cooler for exh.gas recirc.: temperature-TCO_2    8     °C
IDE01366-ENG101906    Exhaust flap: actual value-ANG_EGRV[0]    99.997     %
IDE01367-ENG99571    Turbocharger boost control: offset closed-V_BPA_TOL[0]    4.351     V
IDE01368-ENG100522    Turbocharger boost control: offset open-V_BPA_BOL[0]    0.498     V
IDE01369-ENG100116    Intake manifold runner control (IMRC): offset closed-V_PORT_TOL[0]    4.58     V
IDE01370-ENG99995    Intake manifold runner control (IMRC): offset open-V_PORT_BOL[0]    0.332     V
IDE01373-ENG102590    EGR valve: offset closed-V_EGRV_BOL[0]    1.001     V
IDE01374-ENG103179    EGR valve: offset open-V_EGRV_TOL[0]    3.999     V
IDE01375-ENG101848    Throttle valve adapter: offset closed-V_THR_BOL[0]    0.693     V
IDE01376-ENG103692    Throttle valve adapter: offset open-V_THR_TOL[0]    4.6     V
IDE01377-ENG100929    Throttle valve adapter: actual value-ANG_THR[0]    95.996     %
IDE01378-ENG100595    Fuel high pressure: control deviation-PFU_DIF    0     MPa
IDE01380-ENG103961    Pre-injection 3: activation start-SOI_PREV_SP[2]    0     °
IDE01381-ENG99178    Pre-injection 3: activation duration-TI_PREV_BAS[2]    0     ms
IDE01382-ENG103886    Post-injection 3: activation start-SOI_POST_SP[2]    0     °
IDE01383-ENG100997    Post-injection 3: activation duration-TI_POST_BAS[2]    0     ms
IDE01385-ENG101283    Wear index-WEAR_EQU_TMP_SRV_INTL    0     m
IDE01405-ENG102759    Starter activation: status-FRF_ST_RL    1
IDE01406-ENG99620    Service regeneration: status-Binary 16 Bit    00000001 00001110
IDE01407-ENG100958    Particle filter: fuel consumption since last regeneration-FCO_SUM_RGN    68.04     l
IDE01409-ENG102169    Charge limit for service regeneration-Ash Mass Diag    40     g
IDE01410-ENG102169    Charge limit over-charge-Ash Mass Diag    50     g
IDE01671-ENG100919    Starter control: clutch switch-Starter control: interlock switch    0
IDE01673-ENG101111    Starter control: readiness bits-LV_STA_RLS    1
IDE01834    Battery voltage    12.2     V
IDE01877-ENG102109    Operating condition of idle speed control-LV_REQ_IS_CTL    0
IDE01880    Accelerator pedal position 2    14.5     %
IDE01881-ENG101073    Adaptation of kick-down shifting point-LV_KD_AD_OK    0
IDE02228-ENG100386    Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL    0
IDE02229-ENG102154    Exhaust gas temperature sensor 1-TEG_MES[0]    19.98     °C
IDE02234-ENG102117    Exhaust gas temperature sensor 3-TEG_MES[1]    10.48     °C
IDE02236-ENG102786    Exhaust gas temperature sensor 4-TEG_MES[2]    10.91     °C
IDE02609-ENG102086    Coding in the engine control module-FRF_VARCOD    1
IDE03015-ENG100927    Compression test cylinder 1-N_CMP_TEST[0]    0     /min
IDE03016-ENG100124    Compression test cylinder 2-N_CMP_TEST[1]    0     /min
IDE03017-ENG103600    Compression test cylinder 3-N_CMP_TEST[2]    0     /min
IDE03018-ENG102802    Compression test cylinder 4-N_CMP_TEST[3]    0     /min
IDE03270-ENG111636    Exh.gas temp.sen 1: unconditioned voltage-VP_TEG[0]    3.2886     V
IDE03273-ENG111637    Exh.gas temp.sen 3: unconditioned voltage-VP_TEG[1]    0.5704     V
IDE03275-ENG111638    Exh.gas temp.sen 4: unconditioned voltage-VP_TEG[2]    0.5704     V
IDE03361-ENG103541    Driver intention torque-TQI_DRIV_SUB    0     Nm
IDE03362-ENG103557    Requested transmission torque-TQI_REQ_ETCU    1023.97     Nm
IDE03712-ENG103230    Engine diagnostic status in curr driving cycle (end-of-line)-Binary 32 Bit    00000000 00000001 00001010 00000000
IDE03767-ENG99531    Engine status-SF_ENG_STATE    ES
IDE03892-ENG102868    Fuel high pressure sensor: unconditioned voltage-VP_PFU    0.498     V
IDE03893-ENG101196    Injection valve 1: voltage-V_INJ_MAIN[0]    0     V
IDE03894-ENG104143    Injection valve 2: voltage-V_INJ_MAIN[1]    0     V
IDE03895-ENG101536    Injection valve 3: voltage-V_INJ_MAIN[2]    0     V
IDE03896-ENG102925    Injection valve 4: voltage-V_INJ_MAIN[3]    0     V
IDE03949-ENG102262    Air mass: actual value (mg/stroke)-MAF_MES    0     mg/stroke
IDE03998-ENG101893    Clutch Position Sensor-Starter control: clutch switch    0
IDE04005-ENG103719    Accelerator position: normalized-Accelerator position    0     %
IDE04105-ENG124676    Freeze frame conditions-TQI_MSR_REQ_MON    0     Nm
IDE04105-ENG124673    Freeze frame conditions-TQI_GS_REQ_MON    0     Nm
IDE04105-ENG124668    Freeze frame conditions-N_SP_IS_ETCU_CAN_MON    0     /min
IDE04105-ENG124666    Freeze frame conditions-LV_CRASH    0
IDE04105-ENG124681    Freeze frame conditions-VS_AC    0     m/s²
IDE04105-ENG124675    Freeze frame conditions-TQI_LIM_CTL_SECU    0     Nm
IDE04105-ENG112089    Freeze frame conditions-VS_RAW_CAN_AC_MON    0     km/h
IDE04105-ENG112086    Freeze frame conditions-LV_ERR_N_SP_XSC_MON    0
IDE04105-ENG124672    Freeze frame conditions-TQI_EGS_SUB    0     Nm
IDE04105-ENG124669    Freeze frame conditions-PREV_STATE_IV    0
IDE04105-ENG102360    Freeze frame conditions-TQ_LOSS_ALTER    0     Nm
IDE04105-ENG124671    Freeze frame conditions-TQFR_ADD_ENV    -18.81     Nm
IDE04105-ENG124657    Freeze frame conditions-DCC_AC    3.01     m/s²
IDE04105-ENG124674    Freeze frame conditions-TQI_I_IS_CTL    0     Nm
IDE04105-ENG124667    Freeze frame conditions-LV_TQI_MON_ACT_MON    1
IDE04105-ENG124677    Freeze frame conditions-TQI_REQ_CAN_ETCU    1023.96875     Nm
IDE04105-ENG112087    Freeze frame conditions-LV_VS_RAW_CAN_VLD_AC_MON    1
IDE04105-ENG124678    Freeze frame conditions-TQ_LOSS_TCU1    0     Nm
IDE04105-ENG124682    Freeze frame conditions-VS_MON    0     km/h
IDE04105-ENG102494    Freeze frame conditions-Engine speed: actual    0     /min
IDE04105-ENG124663    Freeze frame conditions-LF_TQI_N_MAX_MON_1_ENVD    0
IDE04105-ENG124658    Freeze frame conditions-LF_CAN_MON_1_ENVD    2
IDE04105-ENG100863    Freeze frame conditions-FAC_COR_SLOP_CHA_CAL[0]    1
IDE04105-ENG103478    Freeze frame conditions-PFU    0     MPa
IDE04105-ENG124664    Freeze frame conditions-LF_TQ_LOSS_MON_1_ENVD_0    0
IDE04105-ENG124659    Freeze frame conditions-LF_CRU_MON_1_ENVD    0
IDE04105-ENG124679    Freeze frame conditions-VP_MC_AN_DIG_MON    0.376     V
IDE04105-ENG124680    Freeze frame conditions-VP_MU_AN_DIG_MON    0.3711     V
IDE04105-ENG124665    Freeze frame conditions-LF_TQ_LOSS_MON_1_ENVD_1    0
IDE04105-ENG124662    Freeze frame conditions-LF_TI_MON_1_ENVD    0
IDE04105-ENG124661    Freeze frame conditions-LF_PVS_MON_1_ENVD    0
IDE04105-ENG124660    Freeze frame conditions-LF_FCUT_MON_1_ENVD    0
IDE04257-ENG100212    High pressure EGR actuator: activation-PWM_HBR_EGRV[0]    0     %
IDE04258-ENG100888    Actuator for high pressure EGR: status-LF_STATE_EGRV_DISP[0]    0
IDE04259-ENG99492    High press EGR actuator: actual unconditioned volt val-V_EGRV[0]    4.995     V
IDE04263-ENG102014    Sensor for particle filter differential press: raw value-DIP_PF_RAW[0]    -1.33     hPa
IDE04264-ENG99088    Throttle valve adapter: status-LF_STATE_THR_DISP[0]    0
IDE04265-ENG104156    Throttle valve adapter: uncond voltage actual value-V_THR[0]    4.438     V
IDE04266-ENG104017    High press turbocharger actuator: activation-CTL_LIM_BPA[0]    95.001     %
IDE04267-ENG100274    High press turbocharger actuator: status-LF_STATE_BPA_DISP[0]    0
IDE04268-ENG102598    High press turbocharger actuator: actual uncond volt value-V_BPA[0]    1.68     V
IDE04269-ENG103982    Intake manifold runner actuator: activation-PWM_HBR_PORT[0]    0     %
IDE04271-ENG100727    Intake manif runner actuator: uncond volt actual value-V_PORT[0]    4.995     V
IDE04272-ENG100854    Counter for regeneration time of particulate filter-T_INT_RGN_ACT_INI_PF_ENVD_H    12596.0189     s
IDE04551-ENG103251    Exh gas press sensor 1: uncond voltage value-PRS_EX_PCAT_UP    1002.8     hPa
IDE04557-ENG99620    ECM system status-Binary 16 Bit    00000000 00000000
IDE04673-ENG103030    O2 sensor 1 bank 1: duty cycle O2 heater-LSHPWM_UP[1]    0     %
IDE04678-ENG102558    Oxygen sensor 1 Bank 1: Status Calibration O2-Signal-LV_LSL_AD_STATE    1
IDE04680-ENG99353    Oxygen sensor 1 bank 1: voltage raw value O2 signal-Lambda probe voltage: bank 1: probe 1 (broadband probe)    2.017     V
IDE04682-ENG99526    Allowed number of injections-LV_INJ_MON_ENA_AC_MON    0
IDE04683-ENG99537    Injection release status-LF_INJ_AD_ACT    0
IDE04684-ENG104138    Desired injection characteristic-PFU_SP_INJ_AD    0     MPa
IDE04689-ENG99620    Starter control: Start interruption status-Binary 16 Bit    00011001 00000000
IDE04695    Immobilizer snapshot A    FF FF
IDE04696    Immobilizer snapshot B    FF FF
IDE04706-ENG101896    Activation condition ACC interface-STATE_DT_MNG_CDN_1    0
IDE04707-ENG103676    Status of reversible shut-off conditions ACC 2-STATE_DT_MNG_CDN_2    0
IDE04708-ENG99795    Status of reversible shut-off conditions ACC 3-STATE_DT_MNG_CDN_3    0
IDE04709-ENG101874    Status of ACC/CCS acceleration interface-STATE_CRU_AC    0
IDE04710-ENG101150    ACC control module: received status-STATE_AD_DIST_CTL    4
IDE04711-ENG102746    Next Status ACC/Cruise status machine-STATE_CRU_PLAUS    3
IDE04712-ENG102726    Active brake system error status-STATE_ERR_BRAKE    0
IDE04713-ENG100230    Active brake system status-STATE_BRAKE_ACT    0
IDE04937-ENG102996    Sensor for engine block temperature: raw value-Coolant temperature    7     °C
IDE04938-ENG102512    Sensor for temp after charge air cooler: raw value-TBA_MES    10     °C
IDE05134-ENG100869    ACC specified acceleration-AC_SP_CRU_EXT    3.0098     m/s²
IDE05139-ENG101726    Shut-off timer: last ECM after-run time-T_ES_FCT_DIAG    0     s
IDE05466-ENG103340    Oxy sensor 1 bank 1 offset spec value-VLS_OFS_LSL[1]    0     V
IDE05468-ENG102329    Oxygen sensor 1 bank 1 ceramic temp-TTIP_MES_LS_UP[1]    0     °C
IDE05632-ENG101485    Fuel pressure regulator valve actual value-CFB_PCV_MES    0.076     A
IDE05633-ENG100012    Valve for fuel metering: feedback value measured-CFB_VCV_MES    0.076     A
IDE05634-ENG103637    Voltage load of main injection cylinder 1-CHR_INJ_MAIN[0]    0     µAs
IDE05635-ENG99789    Voltage load of main injection cylinder 2-CHR_INJ_MAIN[1]    0     µAs
IDE05636-ENG103475    Voltage load of main injection cylinder 3-CHR_INJ_MAIN[2]    0     µAs
IDE05637-ENG101402    Voltage load of main injection cylinder 4-CHR_INJ_MAIN[3]    0     µAs
IDE05638-ENG100023    Oxygen sensor interface: counter for failed write cycles-CTR_ERR_LSL_IF_SPI_WR[1]    0
IDE05639-ENG100771    Number of resets of main unit-CTR_RST_MC    0
IDE05640-ENG104219    Number of resets of monitoring unit-CTR_RST_MU    0
IDE05642-ENG100743    Rule deviation of energy control cylinder 1-EGY_INJ_CTL_DIF[0]    0     mJ
IDE05643-ENG101114    Rule deviation of energy control cylinder 2-EGY_INJ_CTL_DIF[1]    0     mJ
IDE05644-ENG103009    Rule deviation of energy control cylinder 3-EGY_INJ_CTL_DIF[2]    0     mJ
IDE05645-ENG102758    Rule deviation of energy control cylinder 4-EGY_INJ_CTL_DIF[3]    0     mJ
IDE05646-ENG101723    Measured energy of main injection cylinder 1-EGY_INJ_MAIN[0]    0     mJ
IDE05647-ENG101584    Measured energy of main injection cylinder 2-EGY_INJ_MAIN[1]    0     mJ
IDE05648-ENG103761    Measured energy of main injection cylinder 3-EGY_INJ_MAIN[2]    0     mJ
IDE05649-ENG100583    Measured energy of main injection cylinder 4-EGY_INJ_MAIN[3]    0     mJ
IDE05650-ENG102923    Energy control injector 1 specified value-EGY_INJ_SP[0]    68.595     mJ
IDE05651-ENG101270    Energy control injector 2 specified value-EGY_INJ_SP[1]    68.595     mJ
IDE05652-ENG100278    Energy control injector 3 specified value-EGY_INJ_SP[2]    68.595     mJ
IDE05653-ENG101718    Energy control injector 4 specified value-EGY_INJ_SP[3]    68.595     mJ
IDE05654-ENG100606    Oxygen sensor enhancement adaptation factor-FAC_LSL_GAIN_AD[1]    0.99722
IDE05655-ENG101493    Air mass proportion filtered-FAC_MAF_CYL_KGH_RATIO_FIL    1
IDE05656-ENG99849    CAN controller status byte-FRF_CAN_CTR    0
IDE05657-ENG100224    EEPROM malfunction status-FRF_EEPROM    0
IDE05658-ENG101840    Hardware monitoring of EEPROM status-FRF_HWMT_EEPROM    0
IDE05659    Departure lock Snapshot C    FF FF
IDE05660-ENG102585    Energy control cylinder 1: integral part-I_CTL_EGY[0]    0     %
IDE05661-ENG99987    Energy control cylinder 2: integral part-I_CTL_EGY[1]    0     %
IDE05662-ENG104135    Energy control cylinder 3: integral part-I_CTL_EGY[2]    0     %
IDE05663-ENG103697    Energy control cylinder 4: integral part-I_CTL_EGY[3]    0     %
IDE05664-ENG101228    Smallest amount calibration: current adaptation value-IDX_TI_OFS_CMB_AD    0
IDE05665-ENG103851    Oxygen value calculated-LAMB_EXT_CLC_FIL    31.999
IDE05666-ENG101688    Error information regarding selected piezo output stage-LF_STATE_PPS_SPI[0]    0
IDE05667-ENG101827    Brake status monitoring level-LV_BRAKE_MON    0
IDE05668-ENG103061    Transmission control module torque request-LV_ETCU_INC_40    0
IDE05669-ENG99348    ASR-torque request-LV_TCS_INC_40    0
IDE05670-ENG103153    Cruise control torque intervention-LV_TQ_CRU_ACT    0
IDE05671-ENG103889    Cruise Control System torque request-LV_TQ_CRU_ACT_40    0
IDE05672-ENG103337    Fuel mass deviation of the last adapted specified value-MF_DE_AD_LST_CMB_AD    0     mg/stroke
IDE05673-ENG101139    RPM monitoring level-N_32_MON    0     /min
IDE05674-ENG101163    Transm. control module RPM specified value monit. level-N_SP_ETCU_MON    0     /min
IDE05675-ENG103796    Short trip RPM specified value-N_SP_IS_EOL    850     /min
IDE05676-ENG103974    Idle regulator RPM value-N_SP_IS_FIL    0     /min
IDE05677-ENG102856    Idle regulator RPM value monitoring level-N_SP_IS_MON    1248     /min
IDE05678-ENG102371    Pre-control for regulating valve for fuel pressure-PCV_PCTL    15.468     %
IDE05679-ENG101916    Accelerator monitoring level-PV_AV_MON    0     %
IDE05680-ENG99397    OBD-1 error status-STATE_ERR_EL_LSL_UP[1]    NO_FAULT
IDE05681-ENG100704    Oxygen sensor controller register-STATE_LSL_IF_SPI_RD[1]    192
IDE05682-ENG103046    Oxygen sensor plausibility status-STATE_SYM_DIAG_PUC_LSL_UP[1]    VLS_OK
IDE05683-ENG99980    Oxygen sensor diagnosis status-STATE_SYM_OBD_LSL_LSH_UP[1]    NO_SYM
IDE05684-ENG100115    Timer offset oxygen sensor adaptation active-T_DIAG_ACT_OFS[1]    0     s
IDE05685-ENG100166    Time too low oxygen sensor voltage-T_VLS_UP_MIN_DIAG_OC_LSL_UP[1]    0     s
IDE05686-ENG100966    Null amount calibration current adaptation value-TI_OFS_UPD_CMB_AD    0     ms
IDE05687-ENG99851    Torque losses-TQ_LOSS    -30.81     Nm
IDE05688-ENG103834    Torque filtered-TQI_DT1_IS_CTL    0     Nm
IDE05689-ENG101315    Torque at idle-TQI_IS    161.41     Nm
IDE05690-ENG103219    ESP torque intervention-TQI_MSR_REQ    0     Nm
IDE05691-ENG100034    Supply voltage of analog output 1-VCC_1    5     V
IDE05692-ENG102036    Supply voltage of analog output 2-VCC_2    5     V
IDE05693-ENG102409    Volume intervention of valve for fuel metering-VFF_VCV_PCTL    0     ml/min
IDE05694-ENG102432    Environmental pressure sensor gross voltage-VP_AMP    4.043     V
IDE05695-ENG101654    Voltage equiv. current of regulating valve for fuel pressure-VP_CFB_PCV    3.2877     V
IDE05696-ENG101599    Voltage equivalent of valve for fuel metering-VP_CFB_VCV    3.2875     V
IDE05697-ENG103427    Cruise control: main switch position-LV_PIN_CRU_OFF_MON    1
IDE06059-ENG103279    Particulate filter: oil ash mass-MASS_ASH_PF    42.4237176     g
IDE06060-ENG111632    Particulate filter ash load limit-C_MASS_ASH_PF_LIM_TEST    70     g
IDE07085-ENG113811    Learning cycle counter of min. deviation quant. of injectors-CTR_AD_TOT_CMB_AD[0]    201
IDE08288-ENG99620    Minimum deviation quantity: adapted points adaptation limit-Binary 16 Bit    00000000 00000000
IDE08289-ENG99620    Minimum deviation quantity: adapted points-Binary 16 Bit    00000000 00000000
IDE08750-ENG124670    Adaptation freq. ratio per thousand kilometers-RATIO_DIST_CYC_OK_CMB_AD    1.3     1/1000 km
ENG103226    Accelerator pedal sender 1: voltage ratio    0.723     V
ENG103029    Accelerator pedal sender 2: voltage ratio    0.376     V
ENG99612    AEB_PWM    10     %
ENG99746    BYTE_A_OBD    0
ENG101194    BYTE_B_OBD    14
ENG103896    BYTE_C_OBD    232
ENG99936    BYTE_D_OBD    104
ENG103825    CTR_EOL    0
ENG102980    CTR_EOL_MAF    0
ENG100462    CTR_RGN_PF_PTL    0
ENG101500    CTR_RGN_PF_PTL_HLD    255
ENG102921    CTR_RGN_PF_SUC_SUM    160
ENG101140    CTR_RGN_PF_SUM    255
ENG103437    CTR_SECU_ERR    0
ENG100764    CTR_SUM_SRV_INTL    0
ENG103065    CUR_MES_STB_PWL_LOCK_CDN    0
ENG102309    ECTPWM    0     %
ENG106081-ENG101789    EGR_control_deviation_lower_limit-EGR_DIF_MIN_DIAG    0     %
ENG106082-ENG102398    EGR_control_deviation_upper_limit-EGR_DIF_MAX_DIAG    0     %
ENG106083-ENG102565    EGR_deviation-EGR_DIF    -23.993     %
ENG101084    EGRCP_TEMP    8     °C
ENG101205    EGY_INJ_POST[0.0]    0     mJ
ENG102922    EGY_INJ_POST[1.0]    0     mJ
ENG103643    EGY_INJ_POST[2.0]    0     mJ
ENG100653    EGY_INJ_POST[3.0]    0     mJ
ENG103089    EGY_INJ_PREV[0.0]    0     mJ
ENG104162    EGY_INJ_PREV[1.0]    0     mJ
ENG100215    EGY_INJ_PREV[2.0]    0     mJ
ENG100587    EGY_INJ_PREV[3.0]    0     mJ
ENG99118    EMV_DCC_CAN    0
ENG103947    EMV_EILU_CAN    0
ENG101678    EMV_SMLS_CAN    0
ENG104178    EMV_VECU_CAN    0
ENG102855    ESI (extended service intervals) oil level    58.25     mm
ENG101942    ESI (extended service intervals) oil warning threshold    48     mm
ENG102595    FAC_CTL_TEG_PF_DOWN    0
ENG102816    FAC_MASS_ASH_PF    0.95
ENG102671    FAC_MF_POST_1_COR_PF_DOWN_CTL    0.99998
ENG102577    FAC_MF_POST_2_COR_PF_DOWN_CTL    0.99998
ENG102402    FAC_PI_VALUE_TEG_PF_UP_CTL    0
ENG103715    FAC_PI_VALUE_TEG_TUR_UP_CTL    0
ENG102041    FCO_T_RAW    0     ml/s
ENG106675-ENG100872    Freeze_Frame_1_for_processor_monitoring_error-ENVD_MON_3__1    0
ENG106676-ENG104249    Freeze_Frame_2_for_processor_monitoring_error-ENVD_MON_3__2    0
ENG111634    FRF_E2P_READ    0
ENG111635    FRF_E2P_WRITE    0
ENG106693-ENG101000    Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD    0     kPa
ENG99728    LF_STATE_ACC    3
ENG104069    LF_TEMP_GLP_DR_READY_CAN    0
ENG107396-ENG102158    Load_class_for_particulate_filter-LOAD_PF_CLAS    3
ENG102236    LOAD_PF_BAS    327.67     %
ENG101747    LOIL_DYN    0     mm
ENG102180    LOIL_DYN_TMP    0     mm
ENG103837    LOIL_MAX_SRV_INTL    0     mm
ENG102184    LOIL_MIN_SRV_INTL    0     mm
ENG101445    LV_ACT_EOL    0
ENG104064    LV_CMD_EGR_COOL    1
ENG101399    LV_EGR_COOL_OFF    1
ENG103560    LV_KD_SWI_DISP    0
ENG103290    LV_LAMB_LS_UP_VLD[1]    0
ENG100044    LV_LOIL_L_WARN    0
ENG103908    LV_LOIL_L_WARN_TMP    0
ENG101737    LV_LSL_AD    1
ENG103479    LV_LSL_FIRST_GAIN_AD[1]    0
ENG103152    LV_STA_STOP    0
ENG102161    M_TUR_KGH    0     kg/h
ENG103084    MAF_CYL_KGH_OBD    0     kg/h
ENG102795    MAF_SP_COR_TEG_PF_DOWN_CTL    0     mg/stroke
ENG101783    MAF_SP_COR_TEG_TUR_UP_CTL    0     mg/stroke
ENG103125    MASS_SOOT_EQU_TOT_FIL_PHY_PF    9     g
ENG101922    MF_MAIN_SP    0     mg/stroke
ENG99843    MF_POST_COR_PHY_PF_UP_CTL    0     mg/stroke
ENG104252    MF_POST_COR_PHY_TUR_UP_CTL    0     mg/stroke
ENG103624    MF_POST_INJ_SUM    0     mg/stroke
ENG101033    MF_PREV_INJ_SUM    0     mg/stroke
ENG102904    MF_TOT    0     mg/stroke
ENG100340    MPF_SOOT_DEC_HEAT_PF    0     g/s
ENG101244    MPF_SOOT_DEC_NOX_PF    0     g/s
ENG100561    MPF_SOOT_EMI_PF    0     g/s
ENG100865    N_SP_IS_ADD_SAVE_EXT_ADJ    0     /min
ENG108161-ENG103220    Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H    869     km
ENG99137    PV_AV_2    0     %
ENG100560    PWM_EGRCP_RAW    95.001     %
ENG100435    PWM_EGRCP_SP    0     %
ENG101432    R_IT_ADJ_CLC[0]    75     Ohm
ENG103027    STATE_ADD_HEAT    0
ENG109084-ENG101970    State_boost_pressure_control-STATE_BPA_CTL    0
ENG101776    STATE_CMP_TEST    10110010
ENG103861    STATE_CRU_SWI_2    0
ENG101028    STATE_CRU_SWI_3    0
ENG99491    STATE_DCC_CAN    0
ENG104046    STATE_DCC_MVB    0
ENG103504    STATE_ECU_1    0
ENG100335    STATE_ECU_CAN    0
ENG99653    STATE_ECU_ERR_1    0
ENG101505    STATE_ECU_ERR_2    0
ENG101745    STATE_ECU_ERR_VCC_MAX    0
ENG101853    STATE_ECU_ERR_VCC_MIN    0
ENG101677    STATE_EGR_COOL_CDN    56
ENG103882    STATE_EGR_COOL_DIS    0
ENG101430    STATE_EGR_CTL_DIAG    0
ENG102424    STATE_INJ_DEAC    10
ENG100900    STATE_LAMB_ERR    0
ENG101468    STATE_LSH    1
ENG99651    STATE_LSL_IF_SPI    11000000
ENG99845    STATE_MAF_DIAG    0
ENG102508    STATE_PF_RGN_CDN    0
ENG102701    STATE_PVS    1000
ENG103011    STATE_TCS_DIAG    0
ENG100504    STATE_TCS_DIAG_2    100
ENG102191    STATE_TCU    1000000
ENG101441    STATE_VS_CTL    11
ENG104148    T_COOL_LOIL    611     ms
ENG101325    T_TEMP_SIG_LOIL    38.1     ms
ENG99126    T_VS_TOL_LOCK    0     min
ENG102431    TCE    7     °C
ENG101250    TEG_DYN_LS_UP[0]    0.475     °C
ENG102857    TEG_PF_UP_SP    592.73     °C
ENG103349    TEMP_HEAT_TOL_ACT    10     °C
ENG130724-ENG112088    Tester_communication_activ-LV_XSC_MSG_OK_MON    1
ENG109429-ENG102608    Throttle_actuator_commanded_value-ANG_SP_THR[0]    96.001     %
ENG103853    TI_MAIN_TUN[0]    0     ms
ENG103104    TI_MAIN_TUN[1]    0     ms
ENG101104    TI_MAIN_TUN[2]    0     ms
ENG103756    TI_MAIN_TUN[3]    0     ms
ENG103540    TI_POST_TUN[0.0]    0     ms
ENG103688    TI_POST_TUN[0.1]    0     ms
ENG102269    TI_POST_TUN[1.0]    0     ms
ENG104129    TI_POST_TUN[1.1]    0     ms
ENG100726    TI_POST_TUN[2.0]    0     ms
ENG102673    TI_POST_TUN[2.1]    0     ms
ENG100955    TI_POST_TUN[3.0]    0     ms
ENG103058    TI_POST_TUN[3.1]    0     ms
ENG99903    TI_PREV_TUN[0.0]    0     ms
ENG104263    TI_PREV_TUN[0.1]    0     ms
ENG99420    TI_PREV_TUN[1.0]    0     ms
ENG99442    TI_PREV_TUN[1.1]    0     ms
ENG102563    TI_PREV_TUN[2.0]    0     ms
ENG99966    TI_PREV_TUN[2.1]    0     ms
ENG100993    TI_PREV_TUN[3.0]    0     ms
ENG104083    TI_PREV_TUN[3.1]    0     ms
ENG99994    TQ_DRIV_ADD_WHL    -378     Nm
ENG102784    TQ_LIM_GB_PROT    1023.97     Nm
ENG99846    TQ_REQ_BRAKE_CRU_CTL    0     Nm
ENG102534    TQ_SUM_WHL    2084     Nm
ENG102961    TQI_ASR_REQ_SLOW    297.66     Nm
ENG102009    TQI_CRU_REQ    -993.1875     Nm
ENG100822    TQI_N_MAX    1023.97     Nm
ENG101322    V_KD_AD_MAX    0     V
ENG99611    V_TEMP_LS_UP[1]    0.19     V
ENG102561    VLS_OFS_LSL_L_GAIN[1]    0     V
ENG110143-ENG100688    X_Acceleration_slip_regulation_desired_torque-TQI_ASR_SLOW    1023.97     Nm
ENG110145-ENG101310    X_Air_condition_pressure_sensor_pressure_actual_value-ACP_CAN    4.6     bar
ENG110153-ENG101887    X_Cruise_control_brake_torque-TQ_REQ_BRAKE_CAN    0     Nm
ENG110154-ENG101690    X_Cruise_control_irreversible_disable_conditions-STATE_CRU_DEAC_IRV    4
ENG110155-ENG102010    X_Cruise_control_operation_status-STATE_CRU_SWI_1    11000000
ENG110157-ENG101921    X_Cruise_control_reversible_disable_conditions-STATE_CRU_DEAC_RV    0
ENG110162-ENG104134    X_ECU_TYPE-LV_SWMD_ISSAMPLEMODE    production
ENG110175-ENG103404    X_Engine torque at the wheel requested by cruise control-TQDR_REQ_CRU    -65536     Nm
ENG110176-ENG99273    X_Engine_calculated_value_ecu_idle_speed_commanded_value_absolute-Engine speed: specified    980     /min
ENG110177-ENG100690    X_Engine_drag_torque_control_desired_torque-TQI_MSR_SLOW    0     Nm
ENG110178-ENG99147    X_Engine_torque_limitation_mechanical-TQI_MAX    1023.97     Nm
ENG110181-ENG103059    X_Exhaust Gas Recirculation Actuator Duty Factor Set Value-CTL_LIM_EGRV[0]    0     %
ENG110193-ENG100210    X_Exhaust_gas_temperature_control_state-LF_STATE_TEG_CTL    384
ENG110194-ENG103099    X_Exhaust_gas_temperature_upstream_atl:_commanded_value-TEG_TUR_UP_SP    574.54     °C
ENG110195-ENG99504    X_Filtered vehicle speed for cruise control-VS_FIL_CRU    0     km/h
ENG110196-ENG102930    X_Fuel_mass_correction_of_exhaust_gas_temperature_control_post_1-MF_ADD_TEG_CTL[0]    0     mg/stroke
ENG110197-ENG103680    X_Fuel_mass_correction_of_exhaust_gas_temperature_control_post_2-MF_ADD_TEG_CTL[1]    0     mg/stroke
ENG110198-ENG103001    X_Fuel_mass_correction_value_based_on_empirical_calculation_-MF_POST_COR_IPT_PF_UP_CTL    0     mg/stroke
ENG110199-ENG99408    X_Fuel_mass_correction_value_based_on_empirical_calculation_-MF_POST_COR_IPT_TUR_UP_CTL    0     mg/stroke
ENG110203-ENG101465    X_Fuel_Mean_Value_Adaptation_Learning_Index-CTR_MF_DIF_AD_LAMB    15
ENG110205-ENG101442    X_Fuel_Mean_Value_Adaptation_Value 1-MF_DIF_AD_LAMB_MES_0    0     mg/stroke
ENG110206-ENG101195    X_Fuel_Mean_Value_Adaptation_Value 2-MF_DIF_AD_LAMB_MES_1    0     mg/stroke
ENG110231-ENG100304    X_Intermediate_basic_regeneration_level_for_the_particulate_filter-STATE_LEVEL_RGN_PF_INTER    0
ENG110236-ENG102138    X_Maximal_allowed_fuel_mass_quantity_of_the_post_1_injection-MF_POST_1_MAX_LAMB_MIN    0     mg/stroke
ENG110237-ENG100754    X_Maximal_allowed_fuel_mass_quantity_of_the_post_2_injection-MF_POST_2_MAX_LAMB_MIN    0     mg/stroke
ENG110242-ENG104261    X_Particulate_filter_load_class_determined_by_soot_load-LOAD_PF_CLAS_SOOT    3
ENG110243-ENG99978    X_Particulate_filter_load_class_determined_distance:_time_and_consumption-LOAD_PF_CLAS_RGL_END    0
ENG110244-ENG99556    X_Particulate_filter_regeneration_state_level-STATE_LEVEL_RGN_PF    0
ENG110245-ENG101979    X_Particulate_filter_state_regeneration_successful-LF_STATE_RGN_PF_SUC    0
ENG110246-ENG101284    X_Precontrol_correction_for_exhaust_gas_temperature_upstream_particulate_filter_control-MF_POST_TEG_PF_UP_PCTL_COR    0     mg/stroke
ENG110247-ENG101460    X_Precontrol_correction_for_exhaust_gas_temperature_upstream_turbocharger_turbine_control-MF_POST_TEG_TUR_UP_PCTL_COR    0     mg/stroke
ENG110251-ENG102356    X_Received_acceleration_setpoint_from_distance_cruise_contro-LV_DCC_AC_SP_CAN_DFT    0
ENG110254-ENG103435    X_Regeneration_interlock_is_active-LV_RGN_LOCK    0
ENG110255-ENG99110    X_Regeneration_of_particulate_filter_active_interrupt_conditions-LF_INTR_RGN_PF    528
ENG110256-ENG102620    X_Regeneration_timer_locked_state-T_RGN_LOCK_PF    6.5536     s
ENG110257-ENG99193    X_Required_regeneration_level_for_particulate_filter-STATE_RGN_PF_REQ    0
ENG110258-ENG99928    X_Soot_equivalent_of_ash_mass-MASS_SOOT_EQU_ASH_PF    0.69     g
ENG110259-ENG99255    X_Soot_in_the_particulate_filter_is_dry-LV_STATE_SOOT_PF_DRY    0
ENG110260-ENG100801    X_Soot_mass_state_of_calculation-LF_STATE_MASS_SOOT_CLC_PF    183
ENG110292-ENG102321    X_Variable Swirl Actuator Duty Factor Set Value-CTL_LIM_PORT[0]    0     %
Elapsed Time: 00:40
VWT6
Finland
C?ID=295527
Quite a long time since last regen. All the values seem to match with each others (fuel, time, distance)
VW has mentioned in their training material (SSP 514) that maximum distance would be 750 km between regens.
Wondering if this discrepancy has triggered the DPF light.
I believe the charge limits should actually refer to SOOT mass, not ash mass.
Anyways, 12.32 grams of calculated soot is very low in relation to distance travelled since last regen.
Still approx. 100.000 km before DPF ash load limit is reached.
Just a bunch of remaining measuring values which refer to "regen". No good ideas what they tell.
Anyways, perhaps the garage - which blanked the EGR - could tell what else besides the EGR might have affected?
Just curious if the DPF light is seen in blockmap data of controller 17-Instrument - something similar to
IDE00484-MAS00572Status of text/acoustics 1-Engine: particulate filternot active
FStech
Moray, UK
C?ID=518341
The reason for this is possibly that the last 320km was done with the DPF light ON and in limp home mode. Since I posted the blockmap scan, I have managed to carry out a regen whilst driving and the lamp extinguished itself after a lengthy drive and all seems to be good in the world again.
My daughters driving is a mixture of short journeys around town at the weekends, followed by 2 long trips during the week, in which she is able to put her foot down and get the DPF up to temp (Not that she needs a excuse to put her foot down :) ). It just seems that the regen may not complete and DPF light comes on. Is there anyway that the frequency of the regen could be increased?
Something I found during my initial investigation was 'failed or incomplete' on the following:
Secondary air system monitoring
Oxygen sensor monitoring
Oxygen sensor heater monitoring.
There were times when they would pass, but the majority of the time they failed. On this I replaced the oxygen sensor but the same failures occurred with the new one. Any reason why they should show as failing?
Mode 01 - PID 01 : Readiness -- Address 7E8
Number of DTCs stored: 0 -- MIL Status: MIL OFF
Misfire monitoring: Not installed.
Fuel System: Passed
Comprehensive Components: Passed
Catalyst monitoring: Not installed.
Heated catalyst monitoring: Not installed.
Evaporative system monitoring: Not installed.
Secondary air system monitoring: Failed or Incomplete
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring: Failed or Incomplete
Oxygen sensor heater monitoring: Failed or Incomplete
Exhaust Gas Recirculation: Passed
Westbury, UK
IIRC there are some other conditions too - more 1/4 tank of fuel and engine rpm high enough (can't remember the details as I've never owned a diesel with a DPF) - so there needs to be sufficient diesel in the tank and a fast cruise in a high gear might not trigger a regen as the engine rpm could be too low.
