P2015 Intake Manifold Flap Position Sensor (Bank 1): Implausible Signal
khaledabdulaziz
Israel
C?ID=394371
i have vw tiguan 2011 with 2.0L diesel engine
i keep getting the P2015 fault, i check the intake motor plug, 2 wires gives 12V, 1 wire gives 5V, the other two i dont know how to check them
i replaced 3 motors and keep getting same error
i tried to adapt them but keep getting PN inactive on the basic settings
auto-scan
on this scan, there are 5 errors because i was trying to do output test and see if the motor open and close but also nothing, always open and dont close maybe im doing something wrong, the car only have the p2015 error
anyone can help?
Sunday,19,March,2023,10:10:29:04619
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: WVGZZZ5NZ9W101384   License Plate:
Chassis Type: 5N-VW36 (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 37 42 44 46 47 4F 52 53
          55 56 62 6C 72 77
VIN: WVGZZZ5NZ9W101384   Mileage: 196450km-122068miles
37-Navigation -- Status: Cannot be reached 1100
56-Radio -- Status: Not registered 0011
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 997 016 H    HW: 03L 906 022 G
   Component: R4 2,0L EDC G000AG  4787
   Revision: 13H01---    Serial number: VWX7Z0I23NO0C3
   Coding: 0000175
   Shop #: WSC 45021 123 82482
   VCID: 372B2DE7F34CA4031A8-8062
   VINID: 9E65EAAAA15EA899C10010C810C73B3598
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 196176 km
                    Time: 21:58:47
                    RPM: 782 /min
                    Lambda: 0.0 %
                    Lambda: 0.0 %
                    Voltage: 0.228 V
                    Bin. Bits: 00000000
000256 - Mass Air Flow Sensor (G70)
               P0100 - 000 - Supply Voltage - Intermittent
                    Mileage: 196182 km
                    Time: 00:23:23
                    Voltage: 7.22 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 660.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
000258 - Mass Air Flow Sensor (G70)
               P0102 - 000 - Signal too Low - Intermittent
                    Mileage: 196182 km
                    Time: 00:23:26
                    Voltage: 5.70 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 610.0 mg/str
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
                    Voltage: 12.31 V
                    Voltage: 12.31 V
                    Voltage: 12.31 V
                    Voltage: 12.31 V
000290 - Throttle Position Sensor (G69)
               P0122 - 000 - Signal too Low - MIL ON
                    Mileage: 196459 km
                    Voltage: 11.78 V
                    Lambda: 99.4 %
                    Lambda: -0.8 %
                    Bin. Bits: 00000000
                    Voltage: 0.000 V
Readiness: 1 2 0 0 0
   Part No SW: 09G 927 750 FD    HW: 09G 927 750 FD
   Component: AQ 250 6F           1124
   Revision: 00H76000    Serial number:
   Coding: 0000328
   Shop #: WSC 01324 020 00200
   VCID: 78A9EEDBBED26B7BD32-802C
Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
   Part No SW: 5N0 614 517 N    HW: 5N0 614 517 N
   Component: J104    C2 450 V2   0008
   Revision: --H13---    Serial number: 00000001864287
   Coding: 0027938
   VCID: 392F2BDFC558B273ECC-806C
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 154
                    Mileage: 196318 km
                    Time: 15:17:46
                    Speed: 45.0 km/h
                    Hex Value: 0x0142
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 230
                    Hex Value: 0x0000
   Part No SW: 1K0 907 044 DA    HW: 1K0 907 044 DA
   Component: ClimatronicPQ35 133 1213
   Revision: 00133024    Serial number: 00000000000000
   VCID: 698FBB9FF578C2F35CC-803C
00710 - Defroster Flap Positioning Motor (V107)
            014 - Defective
   Revision: 00H54000    Serial number: 00000009495531
   Coding: EF8A8FA300041C004719000014000000000BFF475C400125420000000000
   VCID: 333319F7E7344823260-8066
   Subsystem 1 - Part No: 5N1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 010409  012 0203
   Coding: 00038805
   Shop #: WSC 01324
   Component: RLS     300309 046  0204
   Coding: 00208933
   Shop #: WSC 01324
                    Fault Status: 01101100
                    Reset counter: 157
                    Voltage: 12.15 V
01502 - Bulb for Rear Fog; Left (L46)
                    Reset counter: 157
                    Voltage: 12.15 V
                    Reset counter: 157
                    Voltage: 12.15 V
                    Reset counter: 157
                    Voltage: 12.15 V
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 1T0 919 475 C    HW: 1T0 919 475
   Component: PARKHILFE PLA H07 0009
   Revision: --------    Serial number: 61730908702588
   Coding: 300103
   VCID: 3B2331D7C3648063FE0-806E
                    Reset counter: 190
                    Mileage: 196182 km
                    Time: 00:25:30
                    Temperature: 18.0�C
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__200 VW10 HI   1916
   Revision: 20013000    Serial number: 003E2P66YVF7
   Coding: 0012336
   VCID: 44D14A2BB29AFF9B8FA-8010
   Subsystem 1 - Serial number: 6332MTS639700719
   Subsystem 2 - Serial number: 6342MTS656150779
   Subsystem 3 - Serial number: 6351HTS6UAA306KR
   Subsystem 4 - Serial number: 6361HTS6G84QV5KJ
                    Reset counter: 190
                    Mileage: 196182 km
                    Time: 00:24:05
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Component: J0527           855 0111
   Coding: 0001432
   VCID: 7AADF4D380DE796BA56-802E
   Component: E0221           002 0030
   Part No SW: 5N0 920 870 D    HW: 5N0 920 870 D
   Component: KOMBIINSTRUMENT VDD 2420
   Revision: V0005000    Serial number: VWX7Z0I23NO0C3
   Coding: 0007104
   Shop #: WSC 01286 386 08256
   VCID: 313F13FF1D287A3354C-8064
                    Reset counter: 190
                    Mileage: 196182 km
                    Time: 00:23:21
   Part No SW: 1K0 907 530 T    HW: 1K0 907 951
   Component: J533  Gateway   H06 0071
   Revision:   H06 01    Serial number: 190309F2000128
   Coding: FDA37F06504403006002
   VCID: 38292EDBFE52AB7B132-806C
                    Reset counter: 150
                    Mileage: 196166 km
                    Time: 19:57:19
                    Fault Frequency: 156
                    Mileage: 196166 km
                    Time: 19:57:15
   Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
   Component: Haldex 4Motion      0041
   Coding: 0000005
   VCID: 4BC361179FC430E34E0-801E
   Component: IMMO            VDD 2420
   Shop #: WSC 00137 211 56823
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 87637 km
                    Time: 13:57:28
Address 37: Navigation
   Part No SW: 5N0 959 701 C    HW: 5N0 959 701 C
   Component: Tuer-SG         008 2005
   Coding: 0004286
   VCID: 353727EFE9405613084-8060
00912 - Window Regulator Switch; Front Left (E40)
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.098 0503
   Revision: 1AH02267    Serial number: 00083450372802
   Coding: 0000258
01288 - Terminal 30; Steering Assist
                    Fault Status: 00101011
                    Fault Priority: 9
                    Reset counter: 190
                    (no units): 2.0
                    Voltage: 8.20 V
                    Reset counter: 190
                    Voltage: 0.20 V
                    Voltage: 4.60 V
                    Voltage: 3.40 V
                        Not Occup.
                        Not Occup.
   Component:    KSG PQ35 G2  020 0205
   Coding: 80800A0052830C7F3F04840570084FCEF0FC00
   Shop #: WSC 12345 726 12345
   VCID: 03538937F71438A3F60-8056
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
                    Reset counter: 150
                    Mileage: 196166 km
                    Time: 20:02:46
00323 - Vehicle Inclination Sensor (G384)
                    Reset counter: 150
                    Mileage: 196166 km
                    Time: 20:02:46
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 101
                    Reset counter: 154
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0316
   Revision: --------    Serial number: BP218198596167
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1_VW12.rod
   VCID: 678BBDA7EFECF4834A8-8032
9461523 - Front Left Bass Speaker
          B105F 13 [009] - Open Circuit
          [Tiefton Lautsprecher vorne links: Unterbrechung]
                    Reset counter: 150
                    Mileage: 196166 km
                    Time: 19:57:16
9463059 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
                    Reset counter: 150
                    Mileage: 196166 km
                    Time: 19:57:16
9462035 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
          [Hochton Lautsprecher vorne links: Unterbrechung]
                    Reset counter: 150
                    Mileage: 196166 km
                    Time: 19:57:16
9462803 - Front Right Treble Speaker
          B1064 13 [009] - Open Circuit
          [Hochton Lautsprecher vorne rechts: Unterbrechung]
                    Reset counter: 150
                    Mileage: 196166 km
                    Time: 19:57:16
9463315 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
                    Reset counter: 150
                    Mileage: 196166 km
                    Time: 19:57:16
Address 4F: Centr. Electr. II (J533)       Labels:. 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Coding: 050B0500
   VCID: 6695B0A3E866ED8B71E-8032
   Subsystem 1 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
   Subsystem 2 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J394EE16SKB10  H01 0180
   Part No SW: 5N0 959 702 C    HW: 5N0 959 702 C
   Coding: 0004286
   VCID: 363520E3F4465D0B01E-8062
   Part No SW: 5N0 907 801 B    HW: 5N0 907 801 D
   Component: J540 EPB3  VW-09384 0005
   Revision:   H10       Serial number: 00000000014416
   Coding: 0000057
   VCID: 2E0508830C1665CB49E-807A
                    Reset counter: 190
                    Mileage: 196182 km
                    Voltage: 7.80 V
                    Count: 52
                    Hex Value: 0x12E1
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 55: Headlight Range        Labels: 5M0-907-357-V2.clb
   Component: AFS-Steuergeraet    0142
   Coding: 1361094
   VCID: 34311AEBE23A4F1B3FA-8060
   Coding: 00000020
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000020
02235 - Stationary Cornering Lamp (Left) (M51)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Fault Frequency: 9
                    Reset counter: 155
                    Mileage: 196172 km
                    Time: 20:38:37
                    Voltage: 13.49 V
                    Speed: 7.8 km/h
                        ABS 1
02236 - Stationary Right Cornering Lamp (Right) (M52)
                    Fault Frequency: 12
                    Reset counter: 155
                    Mileage: 196172 km
                    Time: 20:38:39
                    Voltage: 12.78 V
                    Speed: 5.2 km/h
                        ABS 1
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3H3374662
   Coding: 0500040004
   Shop #: WSC 01324 785 00200
   VCID: 6597B7AF1560E693784-8030
                    Reset counter: 190
                    Mileage: 196182 km
                    Time: 00:23:57
                    Reset counter: 150
                    Mileage: 196166 km
                    Time: 19:57:16
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 150
                    Mileage: 196166 km
                    Time: 19:57:16
                    Reset counter: 150
                    Mileage: 196166 km
                    Time: 19:57:16
   Part No SW: 5N0 959 703 B    HW: 5N0 959 703 B
   Component: Tuer-SG         007 2001
   Coding: 0000144
   Shop #: WSC 01324 020 1012552
00934 - Electric Window Motor; Rear Left (V26)
   Part No SW: 5N0 907 441     HW: 5N0 907 441
   Component: J772__Rearview      0021
   Revision: 00H05000    Serial number:    PA8 J931899
   Coding: 0020010
   VCID: 6C81C28BFA8AD7DB27A-8038
02203 - Audio / Video Input 1
                    Reset counter: 197
                    Mileage: 196174 km
                        Reverse OFF
                    Count: 3
                    Reset counter: 190
                    Mileage: 196182 km
                        Reverse OFF
                    Count: 3
   Part No SW: 5N0 959 704 B    HW: 5N0 959 704 B
   Coding: 0000144
Address 77: Telephone        Labels: 3C0-035-730.lbl
   Part No SW: 5N0 035 730 A    HW: 5N0 035 730 A
   Component: J412                4100
   Revision: 00015000    Serial number: 0000B7A061528
   Coding: 0020145
   VCID: 2615F0A324E62D8BB1E-8072
                    Reset counter: 190
                    Mileage: 196182 km
                    Time: 00:23:27
00992 - Consumption Cut-Off Active
                    Reset counter: 190
                    Mileage: 196172 km
                    Time: 21:04:47
End----(Elapsed Time: 01:50, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
measuring
basic settings
output test
Westbury, UK
There are multiple faults in multiplre modules reporting low battery voltage and the voltage is shown as 11.6/11.7V so I suggest charging the battery then clearing all faults and posting the result of a new Auto-Scan.
khaledabdulaziz
Israel
C?ID=394371
you are right, but the error stays on even when battery is good, also it wont accept doing basic settings, what would cause that?
khaledabdulaziz
Israel
C?ID=394371
here the new auto-scan
Tuesday,21,March,2023,12:04:00:04619
VCDS Version: 23.3.0.0 (x64)  HEX-V2 CB: 0.4631.4
          55 56 62 6C 72 77
VIN: WVGZZZ5NZ9W101384   Mileage: 196740km-122248miles
56-Radio -- Status: Not registered 0001
   Coding: 0000175
   VCID: 372B2DE7F34CA402FE9-8062
                    Mileage: 196742 km
                    Time: 17:36:27
                    RPM: 782 /min
                    Lambda: 0.0 %
                    Lambda: 0.0 %
                    Voltage: 0.228 V
                    Bin. Bits: 00000000
   Coding: 0000328
   VCID: 78A9EEDBBED26B7A373-802C
   Coding: 0027938
   VCID: 392F2BDFC558B27208D-806C
                    Reset counter: 161
                    Mileage: 196742 km
                    Time: 17:32:50
                    Hex Value: 0x0000
                    Voltage: 13.50 V
                    Bin. Bits: 00011111
                    Count: 230
                    Hex Value: 0x0000
   VCID: 698FBB9FF578C2F2B8D-803C
   VCID: 333319F7E7344822C21-8066
   Coding: 00038805
   Shop #: WSC 01324
   Coding: 00208933
   Shop #: WSC 01324
                    Reset counter: 161
                    Mileage: 196742 km
                    Voltage: 13.40 V
   Coding: 300103
   VCID: 3B2331D7C36480621A1-806E
   Coding: 0012336
   VCID: 44D14A2BB29AFF9A6BB-8010
   Coding: 0001432
   VCID: 7AADF4D380DE796A417-802E
   Coding: 0007104
   VCID: 313F13FF1D287A32B0D-8064
   VCID: 38292EDBFE52AB7AF73-806C
                    Reset counter: 161
                    Mileage: 196742 km
                    Time: 17:32:56
                    Mileage: 196742 km
                    Time: 17:32:51
   Coding: 0000005
   VCID: 4BC361179FC430E2AA1-801E
            014 - Defective
                    Mileage: 87637 km
                    Time: 13:57:28
   Coding: 0004286
   VCID: 353727EFE9405612EC5-8060
   Coding: 0000258
   VCID: 03538937F71438A2121-8056
                    Reset counter: 161
                    Mileage: 196742 km
                    Time: 17:34:12
                    Reset counter: 161
                    Mileage: 196742 km
                    Time: 17:34:12
   Revision: --------    Serial number: BP218198596167 Dataset Number: 1K8050v____ 5N03
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: 678BBDA7EFECF482AE9-8032
   Coding: 050B0500
   VCID: 6695B0A3E866ED8A95F-8032
   Coding: 0004286
   VCID: 363520E3F4465D0AE5F-8062
   Coding: 0000057
   VCID: 2E0508830C1665CAADF-807A
   Coding: 1361094
   VCID: 34311AEBE23A4F1ADBB-8060
   Coding: 00000020
   Coding: 00000020
   Coding: 0500040004
   VCID: 6597B7AF1560E6929C5-8030
   Coding: 0000144
   Coding: 0020010
   VCID: 6C81C28BFA8AD7DAC3B-8038
   Coding: 0000144
   Coding: 0020145
   VCID: 2615F0A324E62D8A55F-8072
01524 - Antenna for Telephone
                    Reset counter: 161
                    Mileage: 196742 km
                    Time: 17:32:54
End----------(Elapsed Time: 01:44, VBatt start/end: 13.4V/13.7V)-----------
Westbury, UK
                    Mileage: 196742 km
                    Time: 17:36:27
                    RPM: 782 /min
                    Lambda: 0.0 %
                    Lambda: 0.0 %
                    Voltage: 0.228 V
                    Bin. Bits: 00000000
Time for a wiring diagram and some old fashioned fault finding of the wiring I suspect.
khaledabdulaziz
Israel
C?ID=394371
I thought someone could have it already since I never dealt with erwin
Westbury, UK
Time to acquaint yourself with them then?
It's not complicated - create an account, login, pay a fee to get access for a short amount of time, enter the VIn and then download everything offerd as PDF files onto local to you storage. Then you have the data forever with no further cost.
