2013 S4 Sport differential "prime pump" after changing the "ATF / Transfer box oil"
Cameron
Hawaii, USA
C?ID=402537
I did this service yesterday: https://www.audizine.com/forum/show...ervice-DIY?p=12114623&viewfull=1#post12114623
But when I tried to do this part, the option to "prime pump" wasn't present in my VCDS
To prime your sport diff pump:
With the sport diff filled to overflowing, and the fill plug in, connect VCDS to the car.
Power your car but do not start the engine.
Select Control Module
Select 22-AWD
Select Security Access. Hover over the access key field and VCDS should prompt you to enter the value shown. I used 20103, as shown. Select Do It!
Select Basic Settings.
From the drop down list, select Prime Pump. When you activate this, you will hear the pump run for a moment and stop. I repeated this twice.
Back out of VCDS, shut off the car, remove the fill plug and fill the sport diff to capacity.
Should I be looking in a different area to prime this pump?
Please post an Auto-Scan so we can see how your car is equipped and configured.
Cameron
Hawaii, USA
C?ID=402537
Apologies for forgetting about the auto scan info. Here it is:
Saturday,18,March,2023,10:24:12:29712
VCDS Version: 23.3.0.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: WAUBGAFL9DA076177   License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2E 36 42 44 46 47 52 53 56
          62 72 77 A9
VIN: WAUBGAFL9DA076177   Mileage: 116560km-72427miles
Address 01: Engine (J623-CGXC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0004
   Revision: --H07---    CVN: 624D2E02
   Coding: 0A250014052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
   ROD: EV_ECM30TFS0218K5907551E.rod
   VCID: 38292DED92D4CACAF73-806C
   VINID: 9D19525D159C2544401C60471CA0FEB8BF
   Part No SW: 8K2 927 156 M    HW: 0B5 927 156 J
   Component: 0B5 30TFSINAR H01 0012
   Revision: --H01---    CVN: 00008AA5
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001025
   ROD: EV_TCMDL501021.rod
   VCID: 40D9450DCA04820A4F3-8014
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 291D1A
   Shop #: WSC 06324 000 00000
   VCID: 0451891D9E1C5E2A2BB-8050
                    Reset counter: 180
                    Mileage: 114935 km
                    Date: 2022.10.13
                    Time: 17:04:41
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0015
                    Hex Value: 0x1094
                    Hex Value: 0x0000
03991 - Tire pressure monitor function limited System availability
                    Fault Frequency: 15
                    Reset counter: 182
                    Mileage: 112211 km
                    Date: 2021.06.07
                    Time: 18:06:07
                    Hex Value: 0x00C0
                    Hex Value: 0x4006
                    Hex Value: 0x1221
                    Hex Value: 0x36AE
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
   Component: BCM2 2.0      H11 0621
   Coding: 0D814000000000000000
   VCID: 015F8009810E4B0200D-8054
   Serial number: 2312000102435005
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
   Component: KLIMA 3 ZONEN H04 0036
   Revision: C1000000    Serial number: 01250520120641
   Coding: 6600228000
   VCID: 33331AC18B322992C21-8066
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000425381302
   Coding: 260000918634AFE0210048C300003D0D0F1CD20822090221000008004000030100000000000000
   Shop #: WSC 06325 123 12345
   VCID: 76B5E3D5D8C07CBA25F-8022
   Component: WWS 230512  H07 0070
   Serial number: SWF12050237126
   Coding: 00FD11
   Serial number: 20299279
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001405121152
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R1S2L02
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: BB688D26000000000001
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD90971    Dataset Number: 8K0909602VA 0001
   Coding: 303844354730303030304A55304C384B3053
   Shop #: WSC 60571 001 1048576
   VCID: 4ACD6725FC38485A917-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1200008TSE
   Serial number: 6334MSME681347204
   Serial number: 6344MSME68142C75J
   Serial number: 6352QSME37150E5CO
   Serial number: 6362QSME1315325EC
   Serial number: 63732SME26165142Q
   Serial number: 63832SME3E163D489
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20120521000921
   Coding: 000036
   VCID: 51FF704911EE7B82D0D-8004
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 982 M    HW: 8K0 920 982 M
   Component: KOMBIINSTR.   H10 0553
   Revision: 00300000    Serial number: RBF54WT5D
   Coding: 839709008301D705020000
   VCID: 3E253BF5B070F4FA3DF-806A
   Part No SW: 8R0 907 468 F    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0051
   Revision: 1V060024    Serial number: 2441V1242880A5
   Coding: 80C303FF00
   VCID: 42DD4F05C488901A597-8016
   Serial number: 5697267501
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H13 0100
   Serial number: 001805120001028 Dataset Number: 8K0909104D  0025
   VCID: 2F3B16B1679A0D72A69-807A
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: 392F28E9A95ED3C208D-806C
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000029815088
   Coding: 00581B00000000000000
   VCID: 3B2332E1A362E1D21A1-806E
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011C13204E00410001
   VCID: 56F5835538001CBA05F-8002
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0005561018 Dataset Number: 8K0909852H  0023
   Coding: 000000010001
   Shop #: WSC 06324 123 12345
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 343119DD8EBC2EAADBB-8060
   Revision: 00002001    Serial number: 0177106721
   Coding: 0106023A00FA40058030013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000525801
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
   Part No SW: 8T1 035 223     HW: 8T1 035 223
   Component: DSP Prem      H04 0040
   Revision: 00004001    Serial number: 94804003437601
   Coding: 0203010302
   VCID: 6C81C1BD968CB66AC3B-8038
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   VCID: 55F78459250617A20C5-8000
   Part No SW: 8K0 907 801 K    HW: 8K0 907 801 J
   Component: EPB-4         H01 0002
   Revision: --------    Serial number: 00000000064464
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 372B2ED19FCAC5B2FE9-8062
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 186 H    HW: 8R1 035 186 H
   Component: Con3 Sirius   H08 0461
   Revision: 00000001    Serial number: AUZ5Z6L1746768
   Coding: 040300020101850043D9070804
   VCID: 3A2D37E5AC58D8DA017-806E
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0304
   Coding: 010C13204000210001
   VCID: 59EF8869491E33C228D-800C
   Component: TSG HR        H07 0304
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005267309
   Coding: 0010370
   VCID: 3E253BF5BC70F4FA3DF-806A
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 120503200874
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: 72BDDFC5B428609A097-8026
End----------(Elapsed Time: 01:49, VBatt start/end: 12.4V/12.4V)-----------
It would seem that procedure does not apply to this car because there is no "Prime Pump" Basic Setting defined for that module.
It is not Basic Setting, but Output Test-03.
Nothing there for "prime". But it does look like it is possible to run the pump there:
IDE02059-ENG167462 -- All wheel drive pump
and also:
IDE03345-ENG167462 -- Fill pressure lines
IDE03439-ENG167462 -- Bleed pressure lines
Cameron
Hawaii, USA
C?ID=402537
You guys are absolute Chads! Thank you, I will try this tonight
Cameron
Hawaii, USA
C?ID=402537
I tried the All wheel drive pump but got the error: "Refused by control module" -- Message 7f 2f 13
I tried with engine on and off, same error...
NEtech
Denmark
C?ID=56995
Maybe from 4) shown here.
Hm link was not saved.
Click link now.
Cameron
Hawaii, USA
C?ID=402537
Click link now.
The link works now. I tried it and it sounded like the pump in the diff was activating. I'll get it up on jack stands soon and top it off. Thank you!
