Help needed on MK6 ABS module replacement
I love error codes
Australia
uC-2H
I'm using a friends system so might not get registered with my email. I'm having an issue with the ABC control module I believe. I've already replaced the speed sensor - right rear, and the rear wheel hubs and I figure this is all that's left. I guess the hubs are okay as it didn't start showing up an error for the left rear after they were replaced.
Thought it's best to come here before I replace any more components that might not be causing the problem.
I've posted the read out below
I've looked at a heap of posts, but I'm having trouble finding a how to guide to replace the abs pump and module. I have bought one second hand to replace that I've been told was working fine. it has the codes 1KO 907 379 BL/ 1KO 614 517 DR L2+
My unit on the car has 1KO 614 517 DP L2+
Will there be an issue from the DR changing to DP?
Do I need to swap the whole abs unit over or just the module? I'd prefer to keep them together if possible.
VIN: WVWZZZ1KZEK003588   License Plate: EHX
Mileage: 127770km-79392mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 26 2E 37 42 44 46 52 56 62
          72 77
VIN: WVWZZZ1KZEK003588   Mileage: 127770km-79392miles
Address 01: Engine (J623-CTHD)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 026 AB    HW: 03C 907 309 Q
   Component: 1.4l R4 TSI   H02 3731
   Revision: LMH02---    Serial number: 00000000000000 CVN: 4817EA93
   Coding: 00250012002400000000
   Shop #: WSC 00040 040 00019
   ASAM Dataset: EV_ECM14TSI01103C906026AB 001003
   ROD: EV_ECM14TSI01103C906026AB.rod
   VCID: 60E154107B212E93A3-8034
   VINID: 9E69EAAAA05BA956C0003148209E027CDC
4674 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [047] - -
                    Fault Frequency: 15
                    Mileage: 127498 km
                    Date: 2023.02.20
                    Time: 22:43:55
                    Engine RPM: 702.00 /min
                    Normed load value: 18.4 %
                    Coolant temperature: 88 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 13.735 V
                    Cruise Control System (CCS): status-Bits 0-7: 00101100
                    Cruise Control System: specified speed: 0.00 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 00000000
                    Cruise control switch-off: reversible-Bits 0-7: 11111111
                    Cruise control switch-off: irreversible-Bits 0-7: 11111111
                    Acceleration: 0.000 m/s²
4675 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [032] - -
                    Fault Frequency: 14
                    Mileage: 127774 km
                    Date: 2023.03.17
                    Time: 21:59:07
                    Engine RPM: 2124.00 /min
                    Normed load value: 36.9 %
                    Vehicle speed: 14 km/h
                    Coolant temperature: 39 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 14.065 V
                Address 03: ABS Brakes       Labels: 1K0-907-379-60EC1F.CLB
Control Module Part Number: 1K0 907 379 BL    HW: 1K0 907 379 BL
  Component and/or Version: ESP MK60EC1   H31 0152
           Software Coding: 163B600D212200FD681006EC84210080311050
            Work Shop Code: WSC 00040 040 00001
                      VCID: 7DDF0D64E493E37BA8-8028
                    Reset counter: 89
                    Mileage: 127500 km
                    Date: 2017.07.14
                    Time: 22:04:39
                    Count: 7
                    Count: 15
                    Count: 12800
                    Count: 128
                    Count: 37888
                    Count: 3072
                    Count: 263
                    Count: 60
                    Fault Status: 00100011
                    Fault Frequency: 11
                    Reset counter: 93
                    Mileage: 127502 km
                    Date: 2017.07.14
                    Time: 22:13:50
                    Count: 4096
                    Count: 83
                    Count: 50945
                    Count: 63477
                    Count: 64767
                    Count: 51
03842 - RPM Sensor Rear Right: Incorrect Signal
                    Fault Frequency: 13
                    Reset counter: 53
                    Mileage: 127498 km
                    Date: 2017.07.14
                    Time: 01:35:10
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 87
                    Count: 50432
                    Count: 260
                    Count: 48
etz2k
C?ID=69430
No
Both is possible
I see no real reason to replace the ABS, i don't think the WSS fault is a ABS unit problem. Maybe you used a wrong WSS, because you need a WHT003856 with index -A,-B or -C (for PLA).
I love error codes
Australia
uC-2H
You could be right, I did buy this one from Ebay, it has reference OE Number 1k0927808/WHT 003 858 / V10 -72-1058 / 1K0-827 808/1K0-927-808
ALS468/5S10452 5S11412
Would this be the correct WSS?
The WHT 003 858 is different to your number of 856, would this cause it to not work?
etz2k
C?ID=69430
Yes, you need the wht003858A/B, the ...856... is front or rear (if AWD car), sorry.
I would not buy very cheap wss, because bought some cheap from ebay that were garbage.
I love error codes
Australia
uC-2H
I just checked out the one I bought cheap off ebay, and my year isn't even listed on the ad lol I stuffed up.
I'll find another one and try this out.
etz2k
C?ID=69430
You can use this LBL and check in MVB 113-114 if the rear wss work.
I love error codes
Australia
uC-2H
Guys, I owe you beers and pizza!!
It was the wheel sensor in the end, I put in the Bosch part and it fixed it right away. I can't thank you all enough!! I can't blame the Ebay part though, as upon further investigation, I had purchased the wrong one that just looked identical.
So, does anyone need a ABS unit listed above, before I list it on ebay for $50?
etz2k
C?ID=69430
