Is it possible to disable checking of LED lights ? Or suppress MFD bulb out warnings?
revhead
Australia
C?ID=247818
G'day. I've fitted LED DRLs and LED Reverse Lamps to my MY12 VW Passat CC.
The MFD displays 4 x warnings constantly (or you clear them with 'OK') til the next drive. VCDS scan shows the 09 - Central Electronics error as "bulb out or short to ground" for each of these LEDs.
Whilst I know I can fit heatsinked resistors across each of them, it sort of defeats the purpose of LED efficiency. Plus, the resistors get real hot, and are a waste of electric power. Additionally, I believe the circuits may be current limited, so the resistors could then reduce the light output of the LEDs.?? :confused:
Instead, I've been researching & experimenting with VCDS Long Coding but have not been able to disable checking of the Daytime Running Lights check, nor the Backup bulb check.
Is there a way to code to prevent CANBUS checking these specific bulbs; or prevent displaying of light out errors on the MFD?
Cheers,
SM
Please post an Auto-Scan so people can see exactly what BCM is installed in this car and how it's configured.
revhead
Australia
C?ID=247818
I've performed a full Autoscan to hopefully help get this issue sorted for me and I'm sure, countless others who are retrofitting LEDs in their late model cars
THANKS IN ADVANCE
Sunday,09,August,2015,19:19:04:41437
VCDS Version: 15.7.0.1
Data version: 20150729
Dealer/Shop Name: Elmura
VIN: WVWZZZ3CZCE528483   License Plate: MY - CC
Mileage: 31150km   Repair Order:
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 2E 36 37 42 44 46 4F
          52 53 55 56 61 62 65 69 72 77
VIN: WVWZZZ3CZCE528483   Mileage: 31150km-19355miles
Address 01: Engine (0-32-BWS_)       Labels: None
   Part No SW: 03H 906 023 L    HW: 03H 907 309 A
   Component: 3,6 FSI EU5   H03 1159
   Revision: MFH03---    Serial number: 00000000000000
   Coding: 001D0012242600000000
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_ECM36FSI01103H906023L 002008
   ROD: EV_ECM36FSI01103H906023L.rod
   VCID: 2B554C4042A4ED66D3-807E
   Part No SW: 02E 300 013 R    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2703
   Revision: 05351113    Serial number: 00001106200193
   Shop #: WSC 44551 111 44551
   VCID: 204FAB6CF3623E3E76-8074
   Part No SW: 3AA 614 109 AB    HW: 3AA 614 109 AB
   Component: J104   C2 450M V4FE 0022
   Revision: --H07---    Serial number: 00000004402710
   Coding: 0000932
   Shop #: WSC 05311 000 00000
   VCID: 6DD18258743023568D-8038
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001003
   Coding: 0000004002
   VCID: 000FCBEC9BA2DE3E56-8054
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 D    HW: 3AA 937 087 D
   Component: BCM PQ47 H    413 0455
   Revision: BB413001
   Coding: 00000000000000203F180210950009E44575008860208D60008846240041
   Shop #: WSC 05311 000 08193
   VCID: 3B757C00BAC47DE643-806E
   Subsystem 1 - Part No SW: 3C8 955 119 E    HW: 3C8 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 23061  10  0603
   Coding: 00BFB5
   Component: RLS 120711 05  54  0403
   Coding: 07302A
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 12
                    Reset counter: 254
                    Mileage: 30746 km
                    Date: 2015.08.03
                    Time: 16:13:19
                    Voltage: 12.20 V
                    Fault Frequency: 18
                    Reset counter: 254
                    Mileage: 30746 km
                    Date: 2015.08.03
                    Time: 16:13:19
                    Voltage: 12.20 V
                    Reset counter: 254
                    Mileage: 30746 km
                    Date: 2015.08.03
                    Time: 16:08:11
                    Voltage: 12.25 V
                    Reset counter: 254
                    Mileage: 30746 km
                    Date: 2015.08.03
                    Time: 16:08:11
                    Voltage: 12.25 V
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 G    HW: 3AA 919 475 G
   Component: PARKHILFE PLA H05 0010
   Revision: --------    Serial number: 29501118800040
   Coding: 109107
   ASAM Dataset: EV_EPHVA2C000000000 001006
   ROD: EV_EPHVA2C000000000_SE36.rod
   VCID: 3F8D0810A6DC61C66F-806A
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 05071102770001
   Coding: 010180
   Shop #: WSC 05314 000 00000
   VCID: 275DB070564CC90637-8072
   Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
   Component: J234__311 VW10 HI   1918
   Revision: 22014000    Serial number: 003JZPDDQ3W/
   Coding: 0012593
   VCID: 4B952CC02A64CD66F3-801E
   Subsystem 1 - Serial number: 6332MTS671621731
   Subsystem 2 - Serial number: 6342MTS648401691
   Subsystem 3 - Serial number: 6351HTS6Q50T6AKJ
   Subsystem 4 - Serial number: 6361HTS60TO07AKJ
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20110704100002
   Coding: 099A230000
   VCID: 6BD58C4082242D6693-803E
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Coding: 830000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C8 920 870 K    HW: 3C8 920 870 K
   Component: KOMBI         H04 0607
   Coding: 140F00
   Shop #: WSC 05314 115 00000
   VCID: 336554209A94B5A69B-8066
   Part No SW: 7N0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway H41 1620
   Revision:   H41       Serial number: 280611F1000185
   Coding: 469007
   VCID: 39796608B0F84FF651-806C
   Part No SW: 0BS 907 554 C    HW: 0BS 907 554 C
   Component: Haldex 4Motion      4016
   Coding: 0000005
   VCID: 46831DF43106300E2C-8012
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 20071 959 98314
   VCID: 76E3AD340166E08E7C-8022
   Revision: A1001003    Serial number: 7660383858
   VCID: 2959B6484058FF7621-807C
03138 - Input AUX IN
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 254
                    Mileage: 31150 km
                    Date: 2015.08.09
                    Time: 19:13:10
   Part No SW: 3C8 959 760 A    HW: 3C8 959 760 A
   Component: Sitzmemory    H05 2301
   Revision: 00H05000
   Coding: 000039
   VCID: 336554209294B5A69B-8066
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 D
   Component: RNS-MID       H55 5238
   Revision: AB001001    Serial number: VWZ6Z7L7178009
   Coding: 04000402040000A0000F
   VCID: 377D603086EC5986A7-8062
   Subsystem 1 - Part No: 7L6 919 859 G
   Component: AUNZ V8  8207
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0502
   Revision: 12110009    Serial number: 0003157211
   Coding: 0013B7
   Shop #: WSC 05311 115 00000
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 6DD18258BC3023568D-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 704 C    HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000002309458
   Coding: 000090
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 210    3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 3467573C579AB29E82-8060
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 043 0634
   Coding: 19910A0001860E76000294157008DFCE105801
   Component: Neigungssensor  004 0611
   Component: EZE_2         H41 1620
   Coding: 00000008
   VCID: 6FED9850BE3CD146BF-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0502
   Revision: 14110009    Serial number: 0003160512
   Coding: 0013B6
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 6ED38554B136D84EB4-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 703 C    HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000002312034
   Coding: 000090
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000097593
   Coding: 0022157
   VCID: 35616A385CE0AB96B5-8060
   Coding: 3526088
   Subsystem 1 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0008
   Coding: 00000053
   Subsystem 2 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0008
   Coding: 00000053
   Component: Batt.regelung H41 1620
   Coding: 03220172
   VCID: 71E99E28A808C7B6A9-8024
   Subsystem 1 - Part No SW: 3AA 915 181     HW: 3AA 915 181
   Component: J367-BDM  H07 0150
   Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
   Component: RDKBERU30     H08 0008
   Serial number: 10000000050324
   ASAM Dataset: EV_RDKBERU30 003010
   ROD: EV_RDKBERU30_VW36.rod
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Revision: 3A001001    Serial number: 00000150341828
   Coding: 4100000100000000
   VCID: 306F5B2C63828EBEE6-8064
   Part No SW: 7P6 035 730 E    HW: 7P6 035 730 E
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660345271
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA A01015
   ROD: EV_UHVNA.rod
   VCID: 3467573C9F9AB29E82-8060
End-------------------------(Elapsed Time: 04:30)--------------------------
revhead
Australia
C?ID=247818
I was hoping that there was a solution to this. It's really distracting getting pop up errors frequently on dashboard display while you drive.
To further the collective knowledge - I ran a test of brightness with and without resistors across the LEDs and they are slightly dimmer with the resistors in place. They also get very hot very quick and are a drain of electric power (and fuel).
My research since posting this has found that the potential solution is in Byte 18 of Central Electronics. However, deciphering that is tricky. Truth is, I don't know if there is a code that suits the configuration of LED driving lights (at the minimum) with Bi-Xenon headlights and foglights.
However, what would be great is the ability to stop the error from popping up while you drive all the time.
revhead: hi. I don't know the answer to your substantive question, but I'll have-a-stab at commenting on your observation above
As to the first part: LEDs are really efficient devices and they only need a small amount of electrical current to produce a high amount of light. This is why you are getting the error message - because the car's monitoring ciruit thinks that there is an incandescent lamp and the small current is being seen as an open filament fault). Adding the resistor means that you place a relatively high electrical load in parallel with the LED. As a result, the additional load from the resistor causes Volt-Drop (sometimes abbreviated to VD - not to be confused with the other same acronym for the sexually transmitted disease!) at the point in the wiring loom where the LED is connected. The reduced voltage from VD means that the available current to energise the LED drops slightly. Since LEDs are constant current devices (not Voltage devices) and because the light output of an LED is highly sensitive to current, the amount of lumens from the LED drops a little. Hence your observation!
As to the second part: The observed heating comes from the relatively high energy that is dissipated by the resistor (it's sometimes called I^2R losses). The job of the resistor is to simulate the minimum current that would normally flow from the filament of an incandescent lamp. However, unlike a normal lamp where some of the supplied energy is transformed to light and some to heat, in the resistor, all the energy becomes heat - hence your observation.
I apologise if you already know this stuff!
revhead
Australia
C?ID=247818
After months of trial & error (and no solution offered here) I came up with a solution! However, it's not 100% so hence another question. PS - this is after trialling higher resistances (around 60 Ohm) to reduce the power loss but still have current which reduced the frequency of the errors.
I disabled DRL on the dash MFD, then disabled most DRL options using VCDS. I disconnected the LED from the DRL connection. I then soldered long cables to a bus-bar (aluminium plate) mounted on the fuse box. This gets 12V from the accessory fuse inside the car by feeding a cable from this bus bar to the back of the fuse next to the driver's footwell. Advantage are that the DRL is on day or night; there's no power wastage; the LEDs are brighter; and the error doesn't appear whilst driving. Disadvantage: Can't disable DRL if want to; error still shows up when starting car; bulb warning light in dash remains lit
Now this is odd. Why am I still getting a bulb out error for Left & Right DRL when I have disabled them. In fact, for a week before finalising the setup, the LED DRLs were not connected to anything and the DRL option was disabled, yet I still got the error on startup.
How can I stop this error as I have now disabled DrL so the ECU shouldn't be checking the circuit for current. The DRL wires terminate to an open circuit (brown & yellow wires feeding the DRL location are not connected to anything). I'm guessing this is a VCDS issue. Unless the brown or yellow wires are supposed to connect to something else?
