Replace mib2
mattft86
C?ID=525197
Hey all at the moment my car has the mib2 I want to replace it with the mib3 for the wireless CarPlay. Can it be done or do they have component protection? Also would I need to replace the screen too?
downtime
Finland
C?ID=280813
Component protection, different screen, ethernet instead of MOST, fec codes etc.
Not plug’play, not even close. And if you manage to get it working, you would still need to get it hacked and afaik, not many people are capable of doing it.
  • Agree
mattft86
C?ID=525197
That’s what I thought thanks for the reply. I have an fec error now a friend tried to enable performance monitor but comes up with invalid and we can’t remove it.
downtime
Finland
C?ID=280813
Everything on MIB units is behind FeCs basically.
Tell your friend to undo the changes and you should be able to clear the error.
mattft86
C?ID=525197
He did try but he can’t remove it. I did a bit of reading and read the only way to do it is to install toolbox remove the code then remove toolbox.
downtime
Finland
C?ID=280813
Depends on the unit. Toolbox is not that useful for mib2 standard units. And on those I think for Delphi it was least useful.
It would be good if you would post an autoscan of that error active. I presume it is now complaining about software version being changed?
mattft86
C?ID=525197
I’ll post a scan today. It’s only showing an error when scanned other than that everything works as it should.
Cuzoe
C?ID=279487
The MIB Standard toolbox GitHub sees way more activity than the Disco Pro toolbox GitHub, which I suppose makes sense with how common each unit is out there. But Delphi... out of luck with that one.
mattft86
C?ID=525197
Hi sorry its taken me a while to post a scan. But here it is.
Sunday,19,March,2023,09:02:59:01631
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4630.4
VIN: TMBBE7NE9J0284947   License Plate:
Mileage: 79436km-49359mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 4B 52 5F A5 A9 D6 D7
VIN: TMBBE7NE9J0284947   Mileage: 79436km-49359miles
Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 P    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: FFE2AF15
   Coding: 0C1900122424010B0000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM20TFS0205G0906259P 001001
   ROD: EV_ECM20TFS0205G0906259P.rod
   VCID: 3B233A5D43E5C523FE0-806E
   VINID: 91D49254779525A0022042441CD661CF04
Readiness: 0010 0000
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 CS    HW: 5Q0 614 517 AF
   Component: ESC           H62 0973
   Revision: 00000000    Serial number: 60418000001167
   Coding: 24079391542821704080060440CA2924C92A8402600294762043F070C007430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
   ROD: EV_Brake1UDSContiMK100ESP_037.rod
   VCID: 045181A17E9B7ADBCFA-8050
   Part No SW: 5E0 907 044 AP    HW: 5E0 907 044 AP
   Component: Climatronic   H04 2002
   Revision: 00001K00
   Coding: 0111000400011001100500460010102A
   ASAM Dataset: EV_ACClimaBHBVW37X 006147
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 73B3D27D2B354D63E60-8026
   Air quality sensor:
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001803900033
   ROD: EV_BCMBOSCH_018.rod
   VCID: 094F909559B927B3BCC-805C
   Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 180120  051 0915
   Serial number: 887253F0401802000027
   Coding: 164DDD
   Component: RLHS  047 0105
   Serial number: TBY18M02D16H20M46S16
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY173132X07
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223973542629
0531 - Footwell Illumination
          B11FF 01 [009] - Electrical Failure
                    Reset counter: 29
                    Mileage: 79287 km
                    Date: 2023.03.13
                    Time: 18:26:23
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.1 V
                    Outside temperature: 10.5 °C
   Part No SW: 5QA 919 283 B    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0044
   Serial number: 000308419618039
   Coding: 0601050001
   ASAM Dataset: EV_EPHVA14AU3700000 009033
   ROD: EV_EPHVA14AU3700000_009_AU37.rod
   VCID: 49CF5095193967B37CC-801C
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W4P1DWN15
   Coding: 98CCC000000000005C5400CC008800000065
   Shop #: WSC 73430 790 00000
   VCID: 05579CA575A143D3D84-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 000 502 18
   Serial number: 3570000000080D84FB2X
   Subsystem 2 - Part No SW: -----------    HW: 454 000 402 18
   Serial number: 358000000001BA186C2O
   Subsystem 3 - Part No SW: -----------    HW: 454 800 102 18
   Serial number: 351009AEB5613000000P
   Subsystem 4 - Part No SW: -----------    HW: 454 803 101 18
   Serial number: 352005FC06513000000E
   Subsystem 5 - Part No SW: -----------    HW: 454 802 101 18
   Serial number: 35500AF851C13000000P
   Part No SW: 5Q0 953 507 GD    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 17021804400858
   Coding: 1400
   VCID: 7EA5F3491077100B99E-802A
   Part No SW: 5E0 920 956 E    HW: 5E0 920 956 E
   Component: KOMBI         303 0310
   Coding: 27AD010069848E00010A6B021001000000000000
   VCID: 2E0503098097208B49E-807A
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007427193
   Coding: 030100047F085900FB00026B080F00010001070000000000000000000000
   GVL: 01563C1000000000408C00000000480000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   VCID: 3829255172D3EE3B132-806C
   Generator:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Serial number: 000000000A2892090218
   Serial number: 758860000018021525FE
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000113427163
   Coding: 00150020D001040000001100
   Shop #: WSC 73430 790 00123
   VCID: 44D141A13E1BBADB8FA-8010
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Serial number: 00000000000019301939
   Coding: 1D0200
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 91170000
   ROD: EV_SteerAssisMQB_015.rod
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 10021810802742
   Coding: 000000070100046E00003D01010000000000000000000000000000000000
   Shop #: WSC 73430 790 00063
   VCID: 72BDD779542F446BED6-8026
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000112829126
   VCID: 43D342BD3B15BDE3B60-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Serial number: 00000000000019346783
   Coding: 050200
   Part No SW: 5Q0 035 874 C    HW: 5Q0 035 874 C
   Component: MU-S-ND-ER    H41 0480
   Serial number: SKZAZ2U0432698
   Coding: 03735101FF00000041111201008800002F0209C601200500CF
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 343111616EBB0A5B3FA-8060
   Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: SKZ6ZHV0482961
   Subsystem 2 - Part No SW: V03 959 820 F    HW: -----------
   Component: ECE1 2023  --- 1910
1604 - Authentication of a Function
          B2018 00 [008] - Failed
          [Function authentication failed]
                    Reset counter: 69
                    Mileage: 79287 km
                    Date: 2023.03.13
                    Time: 20:07:50
                    Voltage terminal 30: 12.1 V
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 1272
   Serial number: 09011841K11269
   Coding: 0203070100000401000213408150A80094000E200020
   VCID: 0849959142B35EBBA32-805C
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 180120204166
   VCID: 698FB01579F987B35CC-803C
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   ROD: EV_LEDPLUSRightKEBODVW416.rod
End----(Elapsed Time: 01:28, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
downtime
Finland
C?ID=280813
Ok so you're friend probably inserted the swap code already and it is now in the mib. You would need to clear it.
You can do that by inserting this SWAP code in developer mode and the run basic setting "Activate SWaP". This SWAP clears illegal FeCs from the unit.
1102FFFFFFFD03ABCDEF12345756575A5A5A41555A475031323334353600640F2D1C0000000000000000003B0FC769BFFF15ECD445B8196D2203D6D56BD8F22748B37D68F863DAC57E23C90A5FEEF0C06394C8D48A2EAA4F0FB658557400E66441DDC7D5AC3610AA4D45056C0C6E17C7E4B60C40E52FFA891938AF186ED20AE83A99EB10F3088479E6CBD2770C1563B5AE235B440BEF16EBE696576E108F2F9F897D963DEFBAD3ABDF2FFE
mattft86
C?ID=525197
Hiya I’m sure I tried that but I will try again today when I get some free time.
mattft86
C?ID=525197
Right i just tried it with obdeleven and it didn't work. Would i have more luck trying with vcds? if so how would i do it i had a quick look but couldn't find where to do it.
downtime
Finland
C?ID=280813
You need to contact @Uwe for the developer session details for VCDS. Not publicly given information.
Did you change the session in obdeleven before inserting the SWaP?
mattft86
C?ID=525197
Yes I did it said it had done it but when I checked on the radio it still had the invalid code.
downtime
Finland
C?ID=280813
And it did accept it? The basic setting said activated succesfully?
mattft86
C?ID=525197
downtime
Finland
C?ID=280813
Long press MIB menu button to get to red menu, from there installed codes, check if there's a code that says invalid
mattft86
C?ID=525197
Yes I get an invalid code error.
downtime
Finland
C?ID=280813
Can you please be more specific, what code(s) is/are invalid? One or more?
