ABS esp parking break on
karl222y
Beirut, Lebanon
C?ID=506844
hello, i have an issue when driving the car, abs esp and parking break are getting on while driving
i have changed the brake pedal sensor but the issue remains
this is the vcds data
please if someone could help thank you
Saturday,11,March,2023,12:55:19:16360
VCDS Version: 23.3.0.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: WAUDK78T29A013503   License Plate:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 3C 42
          46 47 52 53 55 56 65 67 6C 77
VIN: WAUDK78T29A013503   Mileage: 213680km-132774miles
0E-Media Player 1 -- Status: Malfunction 0010
Address 01: Engine (J623-CALA)       Labels:| 06E-907-559-CAL.clb
   Part No SW: 8T0 907 559 G    HW: 8T0 907 559 B
   Component: 3.2 SIMOS8.2  H04 0002
   Revision: --------    CVN: 40586940
   Coding: 01140009190F0121
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM32FSI8T0907559G A01004
   ROD: EV_ECM32FSI8T0907559G.rod
   VCID: 46D55831F82413BA75F-8012
   VINID: 9D19546C72240894400431400C3393B5D8
6201 - Function Restriction due to Faults in Other Modules
          U1113 00 [108] - -
                    Fault Frequency: 11
                    Mileage: 213230 km
                    Date: 2023.03.01
                    Time: 13:19:29
                    Engine RPM: 1331.00 /min
                    Normed load value: 53.3 %
                    Coolant temperature: 87 °C
                    Intake air temperature: 33 °C
                    Ambient air pressure: 940 mbar
                    Voltage terminal 30: 11.984 V
                    Engine speed: actual: 1408 /min
                    MAF_ENVD: 234.22352 mg/stroke
                    Coolant temperature (unfiltered): 97.5 °C
                    Engine: operating status: IS
                    Engine load: 54.296875 %
                    Vehicle speed: actual: 0 km/h
6017 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [044] - -
                    Fault Frequency: 17
                    Mileage: 213230 km
                    Date: 2023.03.01
                    Time: 13:19:18
                    Engine RPM: 0.00 /min
                    Coolant temperature: 86 °C
                    Voltage terminal 30: 12.593 V
                    Engine speed: actual: 736 /min
                    MAF_ENVD: 152.51764 mg/stroke
                    Battery voltage: 12.289063 V
6134 - Function Restriction due to Faults in Other Modules
          U1113 00 [108] - -
                    Fault Frequency: 11
                    Mileage: 213230 km
                    Date: 2023.03.01
                    Time: 13:19:42
                    Engine RPM: 813.00 /min
                    Normed load value: 27.1 %
                    Vehicle speed: 1 km/h
                    Coolant temperature: 84 °C
                    Voltage terminal 30: 13.304 V
                    MAF_ENVD: 190.64705 mg/stroke
                    Coolant temperature (unfiltered): 93.8 °C
                    Engine load: 34.765625 %
                    Vehicle speed: actual: 1 km/h
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 D    HW: 0B6 927 156
   Component: 0B6 32 FSIUSA H04 0020
   Revision: --H04---
   Coding: 001002
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: 372B25F58FCE7A32FE9-8062
   Part No SW: 8K0 907 379 AB    HW: 8K0 907 379 AB
   Component: ESP8 quattro  H04 0060
   Coding: 0F0500
   VCID: 79AFE3CDF9DAAC4248D-802C
            008 - Implausible Signal - Intermittent - MIL ON
                    Fault Status: 10101000
                    Fault Frequency: 8
                    Reset counter: 238
                    Mileage: 213230 km
                    Date: 2023.03.01
                    Time: 13:18:10
                    Hex Value: 0x0080
                    Hex Value: 0x0224
                    Hex Value: 0x121B
                    Hex Value: 0x319F
                    Hex Value: 0x00FF
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 198
                    Mileage: 213230 km
                    Date: 2023.03.01
                    Time: 13:19:18
                    Hex Value: 0x0080
                    Hex Value: 0x0322
                    Hex Value: 0x0013
                    Hex Value: 0x029B
                    Hex Value: 0x00FF
                    Reset counter: 236
                    Mileage: 213344 km
                    Date: 2023.03.01
                    Time: 20:07:48
                    Hex Value: 0x4180
                    Hex Value: 0x4006
                    Hex Value: 0x1206
                    Hex Value: 0x90AA
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 AG    HW: 8K0 907 064 AG
   Component: BCM2 1.1      H71 0134
   Coding: 0D0000
   VCID: 75B7EFFDD5C2C8222C5-8020
   Component: ELVAUDIB8  H36 0041
   Serial number: 0208000040833016
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-BFS       H09 0043
   Revision: AA000000    Serial number: 00001001121194
   Coding: 08017025002400001000
   Shop #: WSC 39910 001 1048576
   VCID: 42DD4421D48C2F9A597-8016
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 M    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 340GW087509467
   Coding: 0005003
   VCID: 43D34125C7962692521-8016
   Subsystem 1 - Part No: 8T0 919 609 D
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000122160
   Subsystem 3 - Serial number: 0125.07.080000000100010365ÿ
   Subsystem 4 - Serial number: 010365ÿ
                    Reset counter: 193
                    Mileage: 213225 km
                    Date: 2023.02.28
                    Time: 13:20:24
                    Bin. Bits: 00000001 00000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0140
   Revision: C1000000    Serial number: 0131.07.080987
   Coding: 46022000
   VCID: 72BDD4E1A4ACDF1A097-8026
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000095979
   Coding: 26001091843CAF010020080300003D003F1C528820010161000000
   Shop #: WSC 06325 123 12345
   VCID: 30391EE96A20AD0ABF3-8064
   Subsystem 1 - Part No SW: 8T1 955 119 C    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 280708  H13 0040
   Serial number: SWFBIE 0000461
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10217319
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 J    HW: 8K0 941 531 J
   Component: E1 - LDS  H07 0070
   Serial number: 00000000002507080960
   Subsystem 4 - Part No SW: 8K0 907 410 A    HW: 8K0 907 410 A
   Component: UGDO HL US  H04 0060
03187 - Rear Footwell Lights
                    Fault Status: 01101100
                    Reset counter: 193
                    Mileage: 213209 km
                    Date: 2023.02.27
                    Time: 10:58:00
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H43 0390
   Revision: 00043003    Serial number: AUZ5ZBH8514661
   VCID: 2A0D0C8140FCD7DA717-807E
02261 - Data Medium
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 193
                    Mileage: 213209 km
                    Date: 2023.02.27
                    Time: 10:59:27
                    Text: 00000000
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7H0382718
   Coding: 0000100
   VCID: 313F1BED6D2AA402B0D-8064
                    Reset counter: 193
                    Mileage: 213209 km
                    Date: 2023.02.27
                    Time: 10:58:49
   Part No SW: 8K0 919 475 D    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0020
   Revision: 11001001    Serial number: 52930821204704
   Coding: 200101
   VCID: 3A2D3CC1BC5C675A017-806E
   Part No SW: 8K0 959 655 C    HW: 8K0 959 655 C
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0039GD12CNPI   Dataset Number: 8T0909602B  0021
   Coding: 303333333730303030304A55304C38543053
   VCID: 3D2737DDADF25062245-8068
   Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
   Component: BF-Gewichtss.  H01 0050
   Serial number: 5810000R0800000ZYG
   Serial number: 6334MSME38720B47F
   Serial number: 6344MSME22560433%
   Serial number: 6352QSME78033819G
   Serial number: 6362QSME7F31533FU
   Serial number: 63732SME6E693D69M
   Serial number: 63832SME6E6150672
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90304HH30009G
   Coding: 000036
   VCID: 3D2737DDAD725062245-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8T0 920 981 D    HW: 8T0 920 981 D
   Component: KOMBIINSTR.   H30 0224
   Revision: 00000000    Serial number: 9D458U588
   Coding: 831701000B00D705020001
   Part No SW: 8T0 907 468 L    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0092
   Revision: FB402044    Serial number: 4400F0871580EF
   Coding: 000303
   VCID: 4ACD6C01ECBCF7DA917-801E
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 1803370B180708
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H15 0850
   Revision: 00000000
   Coding: 020000
   VCID: 2B0309854306CED28A1-807E
   Component: MEM-FS        H09 0043
   Revision: AA000000    Serial number: 00001001120848
   Coding: 08197B25002400001000
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H51 1100
   Revision: 00000000    Serial number: 341GH087511305
   Shop #: WSC 40901 444 83871
   VCID: 382926C98E50754AF73-806C
   Part No SW: 8K0 907 566 B    HW: 4L0 907 566 B
   Revision: 00H01000    Serial number: 6PZ 009 014-13
   Coding: 0000004
   VCID: 363528F18444833AE5F-8062
   Subsystem 1 - Part No: 8K0 907 568 B
   Subsystem 2 - Serial number: 6PZ 009 014-33
   Subsystem 3 - Serial number: 5F15.11.0800H010003CD10542ÿ
   Subsystem 4 - Serial number: D10542ÿ
02850 - Control Module 2 for Lane Change Assistance (J770)
            014 - Defective
                    Reset counter: 193
                    Mileage: 213209 km
                    Date: 2023.02.27
                    Time: 10:58:38
   Part No SW: 8K0 959 793     HW: 8K0 959 793
   Component: TSG FA        H09 0149
   Revision:             Serial number: #‡Q
   Coding: 011C13224E002201
   VCID: 7DA7F7DDEDF29062645-8028
   Revision: 00002001    Serial number: 0112745414
   Coding: 0106169A007A440501B000
   Component: GTO BF  H06 0040
   Serial number: 00000000000000053342
   Subsystem 3 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
02771 - Bulb for Left Brake / Turn Signal / Tail Lamp (M69)
                    Fault Status: 11101100
                    Reset counter: 193
                    Mileage: 213209 km
                    Date: 2023.02.27
                    Time: 10:58:38
02615 - Fuel Tank Cap; Lock
                    Fault Status: 00101001
                    Reset counter: 238
                    Mileage: 213225 km
                    Date: 2023.02.27
                    Time: 11:31:00
02616 - Fuel Tank Cap; Unlock
                    Fault Status: 01101001
                    Reset counter: 198
                    Mileage: 213225 km
                    Date: 2023.02.27
                    Time: 11:31:53
02901 - Lamp for Brake / Blink / Parking 2; Left (M72)
                    Fault Status: 00101100
                    Reset counter: 236
                    Mileage: 213334 km
                    Date: 2023.03.01
                    Time: 19:19:32
   Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
   Component: DSP Prem      H14 0400
   Revision: 00H14003    Serial number: 34871000669703
   Coding: 030101
   Shop #: WSC 12336 024 394758
   VCID: 3FDB4DD5A77E4272369-806A
00003 - Control Module
            014 - Defective
                    Voltage: 13.70 V
                    Temperature: 39.0°C
                    Temperature: 45.0°C
                    Bin. Bits: 00000100
                    Bin. Bits: 01000000
                    Bin. Bits: 00000000
   Part No SW: 8K0 959 792     HW: 8K0 959 792
   Component: TSG BF        H09 0149
   Revision:             Serial number: aG
   VCID: 7CA1FAD9F6E8996A53B-8028
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 00000000187810
   VCID: 313F1BED612AA402B0D-8064
                    Fault Status: 00101101
                    Fault Frequency: 8
                    Reset counter: 238
                    Mileage: 213230 km
                    Date: 2023.03.01
                    Time: 13:19:18
                    Voltage: 12.60 V
                    Count: 62
                    Hex Value: 0x0263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 A    HW: 8H0 907 357
   Coding: 0000017
   Shop #: WSC 06324 000 00000
   VCID: 30391EE96620AD0ABF3-8064
   Component: AFS-Modul links H06 0002
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 357GW087507227
   Coding: 0000002
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13140781499844
   Coding: 0CD154
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000807220120
   VCID: 343112F99238912ADBB-8060
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J8791OL
   Coding: 1000008
   VCID: 372B25F5834E7A32FE9-8062
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005053648
   Coding: 0010900
   VCID: 2809F6895EF0E5CA673-807C
End----------(Elapsed Time: 02:10, VBatt start/end: 12.2V/12.2V)-----------
karl222y
Beirut, Lebanon
C?ID=506844
The brake pressure in advanced measuring values is reading 272.44 bar , wont change even if i press the pedal
The brake is working properly but this is the reading
davisev5225
C?ID=263265
Your ABS controller needs repair or replacement. The pressure sensor is integrated, and this is not a user-serviceable part.
  • Agree
