Resolved ABS Coding VW T5, code missing , pleas help
Resolved
seyyoshi
Sweden
C?ID=512480
Hello, I purchased a used ABS unit with the reference number 7H0907397S, the original unit that was installed on the car had the same oe number. I couldn't access previous code because the original unit was fried and could not be diagnosed. Here in Sweden this unit is almost impossible to get, cost me roughly 500 euros from Finland, could not find a single one in Sweden, and ebay was 800 euros+!
Now with the new used unit installed, I can access the unit with VCDS but it needs to be recoded for the car. I have no idea how to find this codes, but I am hoping one of you wizards might be able to help!
Please see auto-scan below. If someone could help I would really appreciate it!
lördag,25,Februari,2023,16:28:50:08760
VCDS -- Windows-baserad VAG/VAS-emulator Tändningen Windows 10 x64
VCDS version: AER 21.9.0.6  HEX-V2 CB: 0.4613.4
Dataversion: 20211220 DS330.0
www.vcds.se
VIN: WV3ZZZ7JZ8X014818   Reg.nr:
Chassityp: 7J (7J - VW Transporter Single/Double Cab (2003 > 2010))
Skanna: 01 02 03 08 09 0B 15 16 17 18 19 1C 22 37 45 46 47 56 6E 76
          77 7D
VIN: WV3ZZZ7JZ8X014818   Mätarställning: 188640km
Adress 01: Motor        Labels: AER\070-906-016-BPC.clb
   Artikelnr SW: 070 906 016 DS    HW: 070 906 016 DS
   Komponent: R5 2,5L EDC  000SG  1585
   Revision: --H06---    Serienummer: VWZ7Z0G6130311
   Kodning: 0001072
   Verkstad #: WSC 63549 001 1048576
   VCID: 6491A2DBB2499CAB23D-5184
   VINID: 9E60EAAAA1DAA88A0004420120036485E5
3 Funna fel:
000275 - Givare f�r insugningslufttemperatur (G42)
               P0113 - 000 - signalen �r f�r h�g - Intermittent fel
             frysta data:
                    Felstatus: 00100000
                    Felprioritet: 2
                    Felfrekvens: 1
                    Reset-räknare: 255
                    Mätarställning: 188649 km
                    Tidsindikering: 0
             frysta data:
                    Hastighet: 4.0 km/h
                    Belastning: 0.0 %
                    Spänning: 11.70 V
                    Temperatur: 133.2�C
                    Temperatur: 14.4�C
                    Temperatur: 11.7�C
005705 - Databussdrivning
               P1649 - 000 - meddelande saknas fr�n ABS-styrdonet - Intermittent fel
             frysta data:
                    Felstatus: 00100000
                    Felprioritet: 2
                    Felfrekvens: 5
                    Reset-räknare: 255
                    Tidsindikering: 0
             frysta data:
                    Hastighet: 4.0 km/h
                    Belastning: 0.0 %
                    Spänning: 11.70 V
                    Binära Bitar: 00000000
                    Vridmoment: 0.0 Nm
000568 - Givare f�r laddtryck (G31)
               P0238 - 000 - signalen �r f�r h�g - Intermittent fel
             frysta data:
                    Felstatus: 00100000
                    Felprioritet: 1
                    Felfrekvens: 1
                    Reset-räknare: 255
                    Tidsindikering: 0
             frysta data:
                    Hastighet: 4.0 km/h
                    Belastning: 0.0 %
                    Spänning: 11.70 V
                    Absoluttryck: 1336.2 mbar
                    Absoluttryck: 2182.8 mbar
Readiness: 0 3 0 0 1
Adress 03: Bromselektronik        Labels:. AER\7H0-907-37x-ABS.clb
   Artikelnr SW: 7H0 907 379 S    HW: 7H0 907 379 S
   Komponent: (M)ABS MK25E        0103
   Revision: 00H21001
   Kodning: 0000552
   Verkstad #: WSC 02736 790 00000
   VCID: 45D75F5F19B3C5A3D43-5160
1 fel funnet:
01044 - Styrdonet �r felaktigt kodat
            003 - Mekaniskt fel
             frysta data:
                    Felstatus: 01100011
                    Felprioritet: 2
                    Felfrekvens: 2
                    Reset-räknare: 40
                    Tidsindikering: 0
             frysta data:
                    Räkna: 128
                    Räkna: 13057
                    Räkna: 199
                    Räkna: 0
Adress 08: Klimatanläggning        Labels: AER\7Hx-820-045.clb
   Artikelnr: 7H0 820 045 AM
   Komponent: CLIMA/AC            0303
   Verkstad #: WSC 00000 000 00000
   VCID: 70B9DE8B76B1300B575-5160
1 fel funnet:
01299 - Diagnosinterface f�r databuss (J533)
            013 - Kontrollera  DTC-minne - Intermittent fel
Adress 09: Elektron. elcentral        Labels:. AER\7H0-937-049.lbl
   Artikelnr: 7H0 937 049 AD
   Komponent: BORDNETZ SGVER 1.0  2101
   Kodning: 0000103
   Verkstad #: WSC 35110 377 00159
   VCID: 74B1D29B02A90C2BB3D-5160
1 fel funnet:
01598 - Sp�nning k�rbatteri
            002 - Undre gr�ns �verskriden
Adress 15: Krockkuddar        Labels: AER\6Q0-909-605-VW5.lbl
   Artikelnr: 1C0 909 605 A
   Komponent: 3G AIRBAG VW51      0010
   Kodning: 13127
   VCID: 221DE4C3EDDDD29B911-5160
Ingen felkod funnen.
Adress 17: Instrument        Labels: AER\7Hx-920-xxx-17.lbl
   Artikelnr: 7H0 920 851 R
   Komponent: KOMBI+WEGFAHRSP VDO V02
   Kodning: 00113
   Verkstad #: WSC 00186
   VCID: 3A2D3CA3654DBA5BA91-5160
   WV3ZZZ7JZ8X014818     VWZ7Z0G6130311
1 fel funnet:
01316 - Bromsstyrdon
            49-10 - Ingen kommunikation - Intermittent fel
Adress 18: Extra/p-värmare        Labels: AER\7H0-819-008.lbl
   Artikelnr: 7H0 815 071 F
   Komponent: Standheizung        0209
   VCID: 2B0309E79F1713D3227-5160
1 fel funnet:
00664 - Br�nslem�tare
Adress 19: CAN Gateway        Labels: AER\6N0-909-901-19.lbl
   Artikelnr: 6N0 909 901
   Komponent: Gateway K<->CAN    0001
   Kodning: 00006
   VCID: 70B9DE8B73B1300B575-5160
1 fel funnet:
Adress 46: Komfortcentral        Labels: AER\7H0-959-433.lbl
   Artikelnr: 7H0 959 433 B
   Komponent: CX6 Komfortger�t     0004
   Kodning: 00031
   VCID: 323D1483BD3D421B611-4B1E
Adress 56: Radio        Labels: AER\1K0-035-1xx-56.lbl
   Artikelnr SW: 7H0 035 152 H    HW: 7H0 035 152 H
   Komponent: Radio DE2           0007
   Revision: 00005000    Serienummer: VWZ4Z4G5040550
   Kodning: 0010200
   Verkstad #: WSC 35110 377 09999
   VCID: 270BF5D783FF37B3C6F-5160
Slut-(Förfluten tid: 04:52, Vbatt start/stopp: 11.9V/11.6V. VIgn 11.7V)---
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Once you access the coding function for the ABS, VCDS will provide you with a coding table via the coding assist.
Based on the VIN (PR-1CL+K4G++0ZN+TM7) your coding should be 0000551.
seyyoshi
Sweden
C?ID=512480
Thank you so much Sebastian, the code was correct and abs works perfect! :)
