- Feb 23, 2023
- 11
- 3
- Mendon, MA, USA
- C?ID=541800
For a 2013 Audi S6 I am looking to change out the Oil on the AFT side of the sport differential. However according to erwin after changing the fluid you need to go into module 22 "Four Wheel Electronics" and select function 22 "Adding ATF" apparently this fills the rear diff system and purges it from the air introduced in the draining and filling procedure. So how in VCDS after selecting Module 22 how you would go about performing the purging procedure on the ATF side of the sports diff?
Saturday,25,February,2023,18:54:06:37652
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4630.4
VIN: WAUJ2AFC5DN034396 License Plate:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 34 36 3B 3C 42 44
46 47 52 53 55 56 5F 62 6C 72 82 84 85 8B 8E 8F 90 A9 BA
VIN: WAUJ2AFC5DN034396 Mileage: 137554km-85472miles
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CEUC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 B HW: 4H0 906 014
Component: 4.0l V8TFSI / H56 0009
Revision: NCH56--- CVN: E762E91F
Coding: 0A2500326546000E1000
Shop #: WSC 39322 001 1048576
ASAM Dataset: EV_ECM40TFS0114G0906014B 001008
ROD: EV_ECM40TFS0114G0906014B.rod
VCID: 211FF6E88140DB43C4C-8074
VINID: 9D195A0915931547800C40C91852C5BA48
Part No SW: 4G1 927 156 S HW: 0B5 927 156 J
Component: 0B5 40TFSINAR H01 0009
Revision: --H01--- CVN: 0000D6A7
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL501021 001012
ROD: EV_TCMDL501021.rod
VCID: 3D272A981DF89FA3C04-8068
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 J HW: 4G0 907 379 J
Component: ESP PREMIUM H09 0361
Coding: 65B64F01A66DF2804B00
ASAM Dataset: EV_ESPPremiAU57X 004028
VCID: 38293B8C32DABA8B132-806C
Part No SW: 4H0 907 064 CR HW: 4H0 907 064 CR
Component: BCM2 2.0 H32 0421
Coding: 0D882006000000000000
VCID: 7BA3E48043EC5193BE0-802E
Serial number: 2312000149931012
Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
Component: KLIMA 4 ZONEN H13 0070
Serial number: 06071200040872
Coding: 688120B85D
ASAM Dataset: EV_AirCondiComfoUDS 002036
VCID: 629DB9E4C4C6805B9D6-8036
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001369424
Coding: 09072091073C9FE2A90008C7A0003800CF9CD308A20802218001085C7B00
VCID: 6FBBC0D007943D33028-803A
Component: WWS57X 120617 H36 0080
Serial number: 120625205252
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 20406172
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 H HW: 4G0 941 531 H
Component: E1 - LDS H07 0044
Serial number: 04 07 2012 00001298
Component: USHL4.2 H30 0030
Serial number: 0000002274555R280102
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000005071200010484
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000003071200010765
Coding: 110000
Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103815000001581914
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 97388A36000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0072
Revision: 11001001 Serial number: 61061219200013
Coding: A8E90A
Shop #: WSC 40623 210 01865
ASAM Dataset: EV_EPHVA18AU57X0000 003008
ROD: EV_EPHVA18AU57X0000_003.rod
VCID: 77ABF8B07F4475F3DA8-8022
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H17 0400
Coding: 7601010102
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
VCID: 2809EBCCE27A2A0B832-807C
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H32 0032
Revision: -------- Serial number: 003D80028SX9
Coding: 303234373131303030324A55304C34473053
VCID: 33330CA02BBC59D3260-8066
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H15 0045
Serial number: 6940000Y120000FZ3U0A
Serial number: 3575HRB40651EGVODOOM
Serial number: 3585HRB40631F0BA784G
Serial number: 3515JRB401E4UH24IPDV
Serial number: 3525JRB40124UH249HVL
Serial number: 3554VRB405V1AP62GHK8
Serial number: 3564VRB405V1AP62HGB0
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LFU000T8
Coding: 0004FC
VCID: 38293B8C325ABA8B132-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Component: E221 - MFL H08 0009
Serial number: 16 05 2012 D0071136
Part No SW: 4G0 920 981 M HW: 4G0 920 981 M
Component: TBenUsaAccNv H76 0515
Revision: 28460207 Serial number: 658120712596031
Coding: 0BCF09059F51D705020200
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU57.rod
VCID: 353732B825C847E3084-8060
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 AB HW: 4G0 907 468 AA
Component: J533--Gateway H10 0028
Revision: -------- Serial number: 00000000599587
Coding: 00E1034800
GVL: FDAFE8CCFEE26C0D5100
ASAM Dataset: EV_GatewPkoUDS 001013
VCID: 70B9C3AC1A2A22CB1B2-8024
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790798782
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H15 0013
Serial number: 000807120001014
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
VCID: 270BE8F0EF6425738A8-8072
Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
Component: KLIMA FOND H07 0070
Serial number: 10071200041189
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
VCID: 372B38B03FC4B5F31A8-8062
0025 - Motor for Rear Left Upper Body Vent
B10D3 22 [009] - Signal Amplitude Too High
Reset counter: 117
Mileage: 137554 km
Date: 2023.02.25
Time: 16:02:45
Voltage terminal 30: 11.91 V
Outside temperature: -5.0 °C
Left Rear Upper Body Vent Motor-Act.val.: 11701
Left Rear Upper Body Vent Motor-Target value: 11701
Left Rear Upper Body Vent Motor-Stop open: 11418
Left Rear Upper Body Vent Motor-Stop closed: 10000
0033 - Motor for Rear Right Upper Body Vent
B10D4 22 [009] - Signal Amplitude Too High
Reset counter: 117
Mileage: 137554 km
Date: 2023.02.25
Time: 16:02:42
Right Rear Upper Body Vent Motor-Act.val.: 11701
Right Rear Upper Body Vent Motor-Target value: 11701
Right Rear Upper Body Vent Motor-Stop open: 11434
Right Rear Upper Body Vent Motor-Stop closed: 10000
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Coding: 008002
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E051DD4C09E743B49E-807A
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000034226775
Coding: 00581B0000002001000001010101102030303232203232
VCID: 77ABF8B07FC475F3DA8-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H02 0053
Revision: -------- Serial number: EJ1BPA7E002K71
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH01 0060
Revision: 00H01000 Serial number: 6PZ 010 287-03
Coding: 0000001
Shop #: WSC 41826 002 1048576
VCID: 303903ACD62A62CB5B2-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H01 0060
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F12.07.1200H01000AMS15799ÿ
Subsystem 4 - Serial number: S15799ÿ
Component: TSG FA H04 0506
Coding: 011F17005E00628002000013
VCID: 45D7427875A8D763984-8010
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0022673181
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D09A4D4A650DB2D6-8066
Revision: 00002001 Serial number: 0180424219
Coding: 0106023A00FA408583B00880020503000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000097555
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO17048633
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00001656328
Part No SW: 4G1 035 223 A HW: 4G1 035 223 A
Component: BOSE-G3C7-ANC H02 0540
Revision: CJ002700 Serial number: 00000000001894
Coding: 030000
VCID: 1C61C71CA6A2F6AB17A-8048
Component: TSG BF H03 0506
Coding: 011F17005E00628002000002
VCID: 46D5457448AEDC7B91E-8012
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000405961
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B0314C0F38C01136E0-807E
70912 - Left Parking Brake Motor Voltage Supply
C100D 13 [000] - Electrical Malfunction
71168 - Right Parking Brake Motor Voltage Supply
C100E 13 [000] - Electrical Malfunction
721152 - Brake Pad Replacement Mode Active
C1011 00 [000] - -
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 120711-0001-096
Coding: 12216F601002A400
ROD: EV_HeadlRegulBasic_AU21.rod
VCID: 2C0117DCF682062B67A-8078
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 156G/0C7613925
Coding: 020007010000000001
VCID: 211FF6E881C0DB43C4C-8074
Part No SW: 4G0 035 746 B HW: 4G0 035 746 B
Component: H-BNT-NA H49 0549
Revision: -------- Serial number: 194G10C7506845
Coding: 060200000203FDEF7D16CB1E00000003100001000000000000
VCID: 2615E5F4E8EE3C7BB1E-8072
Subsystem 1 - Part No: 8R0 060 884 GJ
Component: NAR 2019/2020 2001
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDC940232UL
Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q
Component: E380 BDT C7 H11 0204
Serial number: 90349LGC00118
Subsystem 4 - Part No: 8R0 060 961 D
Component: CD-Database 4353
Reset counter: 117
Mileage: 137554 km
Date: 2023.02.25
Time: 16:13:30
Text: DUA009,Front,M,0,0,6
Component: TSG HL H03 0506
Coding: 010F17004000628002000002
VCID: 49CF4E4859B033037CC-801C
Part No SW: 4H0 907 428 A HW: 7P6 907 441 D
Component: TopView H05 0111
Revision: 11001001 Serial number: 82330JF0050668
Coding: 0201000001010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
ROD: EV_CamerSysteTopViewAUDI_005.rod
9617993 - Proximity Camera
B145C 54 [009] - Missing Calibration / Basic Setting
Reset counter: 117
Mileage: 137554 km
Date: 2023.02.25
Time: 16:12:58
Voltage terminal 30: 11.5 V
Terminal 15 status: Terminal 15 on
Component: TSG HR H03 0506
Address 82: Head Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4G0 919 604 G HW: 4G0 919 604 G
Component: HeadUpDisplay 006 0106
Coding: D60000
ASAM Dataset: EV_HUDContiC7 001020
ROD: EV_HUDContiC7.rod
VCID: 2F3B00D0C7947D33428-807A
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 F HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0042
Serial number: 0K84AE40076794
Coding: 1311
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H08 0007
Serial number: 00000000001214400026
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H25 0038
Coding: EA060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2615E5F4E86E3C7BB1E-8072
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Coding: 7601010102
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000051607127
Coding: 04C19A1A0111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F06A8D1A06BC354C-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0010
Serial number: 120620201427
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H05 0006
Revision: 00001001 Serial number: 97804000454204
ASAM Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X_AU57.rod
VCID: 6695A5F428EEFC7B71E-8032
0554 - No Basic Setting
B2010 00 [009] - -
[FC_AssemblyCheck_NotDone]
Reset counter: 112
Mileage: 137481 km
Date: 2023.02.24
Time: 15:02:49
1632 - invalid data record
B2005 00 [009] - -
[FC_Dataset_Invalid]
Reset counter: 112
Mileage: 137481 km
Date: 2023.02.24
Time: 15:02:49
1295 - Drivetran Mounting
C1154 02 [009] - Signal Failure
Reset counter: 112
Mileage: 137481 km
Date: 2023.02.24
Time: 15:02:51
End----(Elapsed Time: 02:50, VBatt start/end: 11.4V/11.4V. VIgn 11.4V)-----
