MOST issue
Dippy
C?ID=10790
This is on a 2015 S5 sportback which is under warranty so whilst I'll get this checked out sometime I am interested and hence this post. If anyone has seen similar I'd love to hear about it so that I can better understand it.
The car was just over 1 month old and I hadn't had my HEX-NET for long when I captured these:
               Address 19: CAN Gateway       Labels: 8T0-907-468.clb
Control Module Part Number: 8R0 907 468 P    HW: 8R0 907 468 D
  Component and/or Version: GW-BEM 5CAN-M H11 0060
           Software Coding: 80CF07FF00
            Work Shop Code: WSC 06325 000 00000
                      VCID: CCD4325C6F8BCA41427-8099
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 50
                    Mileage: 166 km
                    Date: 2015.04.19
                    Time: 14:54:02
                    Bin. Bits:    10000
                    Voltage: 12.50 V
                    Count: 9
                    Bin. Bits:    00000
                Address 5F: Information Electr.       Labels: 4E0-035-6xx-5F.clb
Control Module Part Number: 8R2 035 670 J    HW: 8R2 035 670 J
  Component and/or Version: H-BNT-EU      H49 0897
           Software Coding: 140101040206A9EF7D82CB5E00000403040000000000000000
                      VCID: BB3661803A257DF9FBD-80EE
02067 - Optical Databus; Unpermitted Wake-Up Request
            000 -  -  - Intermittent
                    Reset counter: 50
                    Mileage: 166 km
                    Date: 2015.04.19
                    Time: 14:52:51
                    Voltage: 12.60 V
They cleared and didn't reappear over several scans so I forgot about them. However yesterday they reappeared:
                    Reset counter: 124
                    Mileage: 1538 km
                    Date: 2015.07.06
                    Time: 16:39:33
                    Bin. Bits:    10000
                    Voltage: 12.10 V
                    Count: 9
                    Bin. Bits:    00000
                    Reset counter: 124
                    Mileage: 1538 km
                    Date: 2015.07.06
                    Time: 16:39:01
                    Voltage: 12.10 V
So I ran the optical bus diag and got:
Optical Bus Diagnostic : Standard
Controller          	Electrical          	Optical
19-CAN Gateway      	OK                  	OK
47-Sound System     	OK                  	OK
56-Radio            	OK                  	OK
I thought that there should be more modules on that list so I re-ran with the 3dB option. This hung and caused VCDS to crash but I still got a result:
56-Radio            	ERROR               	ERROR
Now I had more modules with DTCs:
                    Reset counter: 148
                    Mileage: 2173 km
                    Date: 2015.07.29
                    Time: 14:11:35
                    Bin. Bits:    10111
                    Voltage: 12.00 V
                    Count: 6
                    Bin. Bits:    10000
                Address 47: Sound System       Labels: 8T0-035-223-BOM.clb
Control Module Part Number: 8T1 035 223 A    HW: 8T1 035 223 A
  Component and/or Version: DSP Prem      H05 0030
           Software Coding:
            Work Shop Code:
                      VCID: AD125FD8F451E349759-80F8
                    Reset counter: 148
                    Voltage: 12.00 V
                    Temperature: 31.0°C
                    Temperature: 32.0°C
                    Bin. Bits: 00000100
                    Bin. Bits: 00001000
                    Bin. Bits: 00000000
                Address 56: Radio       Labels: Redir Fail!
Control Module Part Number: 4G0 035 061 Q    HW: 4G0 035 061
  Component and/or Version: Radio U DAB   H60 0150
           Software Coding: 010103010000000001
                      VCID: AB1651C0CA45ED796BD-80FE
                    Reset counter: 148
                    Mileage: 2173 km
                    Date: 2015.07.29
                    Time: 14:09:01
                    Bin. Bits: 00000000 00101100
                    Fault Frequency: 19
                    Reset counter: 148
                    Mileage: 2173 km
                    Date: 2015.07.29
                    Time: 14:09:01
                    Bin. Bits: 10111110 10100010
                    Bin. Bits: 00001110 10011111
                    Bin. Bits: 00000000 00000100
                    Bin. Bits: 00000000 00000000
                    Reset counter: 148
                    Mileage: 2173 km
                    Date: 2015.07.29
                    Time: 14:09:01
                    Bin. Bits: 00000001 00010000
                    Bin. Bits: 00000000 00001010
I cleared all DTC and then ran an autoscan which was fault-free. I have no symptoms of any problem - I only know about these through using VCDS. Any ideas?
If I were to venture a guess, I'd say you've got dodgy MOST bus connection somewhere. That's going to be a bugger to find unless/until you catch it in the act.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The Optical Check in all Versions up to 14.10 is flawed, please make sure to update to Beta 15.6.1 or newer. Once you have that, run the Test again and post the new results. As far as the original DTCs go, they are more likely to be related to the unexpected wakeup. Unless you see this happening again in future, I wouldn't give too much about it. What bothers me more is the fact that you get errors when you damp the output - that should NOT happen. Was there anything retrofitted or repaired in let's say the tail area of the vehicle?
Dippy
C?ID=10790
Thanks for that info Seb, I have just got 15.7.0 so I'll try again. Nothing has been done to the car - its only 15 weeks old from new so I wasn't expecting DTCs but indeed I am not too worried about it as I know that comms is never 100% reliable and all the systems in the car seem to be working. I am painfully aware of Uwe's point about it being a bugger to find so I am reluctant to have one of Audi's highly trained and very careful (?) technician crawling over the car this soon!
Jef
HQ
I'm intrigued Sebastian, are you able to elaborate?
Long and short of it, it may not show all items on the MOST bus. A friend of mine with a 2015 A5, the old version only showed 2 modules on the Optic Bus. Beta (now a standard release) shows all of the modules.
Dippy
C?ID=10790
I tried again with VCDS 15.7.0 and the latest FW update for HEX-NET. I ran an autoscan and there were no faults. So then I ran optical bus diag and got this:
5F-Information Electr. ERROR ERROR
So I now get 5F included and it has an error. As before it now had '03157 - Functionality limited due to Communications Disruption' and '03278 - Functionality Limited due to Missing Messages'. Module 56 also had 03278.
I cleared all faults and ran the optical diag again and it hung. I cancelled out and then decided to re-run the diag without clearing module faults. I got this:
5F-Information Electr.(High/D3) OK OK
56-Radio OK OK
I cleared all faults and tried it again but it hung and in fact VCDS crashed altogether. So I restarted it and had all the usual faults, however now the ones on module 5F come back after clearing:
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R2 035 670 J HW: 8R2 035 670 J
Component: H-BNT-EU H49 0897
Revision: -------- Serial number: 517BX0F7501572
Shop #: WSC 06325 000 00000
VCID: BB3661803A257DE6C3-80EE
Subsystem 1 - Part No: 8R0 060 884 CH
Component: EUR 2014 2004
Component: DU7 High H42 0104
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: CD-Database 5950
Fault Frequency: 19
Reset counter: 110
Mileage: 2200 km
Date: 2015.08.06
Time: 15:56:13
Reset counter: 110
Mileage: 2200 km
Date: 2015.08.06
Time: 15:55:53
Bin. Bits: 00000000 00010000
I guess this implies that the source of the failure is at 5F. I think I shall e-mail this to the service manager at my local dealer and see if I get a useful response (I cynically doubt it but its worth a try). The crazy thing is that there is nothing obviously wrong with anything in the car so if there is a genuine fault it's only symptom seems to be the diagnostic fault codes and nothing more!
Dippy
C?ID=10790
Sorry I have been an idiot. I have relied on my flawed memory rather than check my notes. I had thought that the first appearance of the comms fault in 5F coincided with some errors in the homelink part of module 46 because I had been trying to set it up and seemed to cause it to crash (it was lost in MMI) since my garage door opener is incompatible. Anyway I was wrong, and I now realise that the first appearance was when I did some simple re-coding! So I have re-read my handwritten notes and believe that events were as follows:
1) I got the car on 4/15 and took autoscans on 4/16 and 4/17 (first use of HEX-NET) and there were no faults.
2) On 4/25 I decided to try re-coding.
2a) I started by adding the lap timer to DIS, so setting bit 3 of byte 1 in module 7 instruments.
2b) On my first attempts I got a re-code invalid error message. So I then tried the default code and it worked.
2c) I then checked for faults and got the ones on modules 19 and 5F. I cleared them and they did not return.
2d) I then did the 'locking chirp' mod of setting bit 2 of byte 1 in module 46 central conv.
3) I the ran an autoscan which was clear.
Before I 'undo' these mods to see if it fixes the fault, is it possible that the problem is in the 'way' I made the changes rather than the changes themselves?
Data:
1 - clear autoscan
Friday,17,April,2015,18:26:30:16477
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
Chassis Type: 8T (8R0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 1B 20 22 30 36 3C 42 44
          46 47 52 53 56 5C 5F 62 6C 72 A9
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CREC)       Labels: None
   Part No SW: 8K2 907 551 A    HW: 4H2 907 551 A
   Component: 3.0l V6 TFSI  H10 0004
   Revision: --H10---
   Coding: 1A2500340447010B3800
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K2907551A 002004
   ROD: EV_ECM30TFS0218K2907551.rod
   VCID: B12A43A8E06987A9511-80E4
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 8K0 927 166     HW: 0B5 927 156 K
   Component: 0B5 30TFSIRdW H03 0004
   Revision: --H03---
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: F2A88CA425EFFCB1E8B-80A7
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 296DCE01
   VCID: 895ACB4820799F69B91-80DC
   Part No SW: 8K0 907 064 KF    HW: 8K0 907 064 KF
   Component: BCM2 2.0      H15 0711
   Coding: 05B44040000000000000
   VCID: FEB0A89469B7A8D19C3-80AB
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01260220152196
   Coding: 6624028080
   VCID: F8BCBE8C4B9396E1D6F-80AD
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00001012316901
   Coding: 260000108074AFF2398140C300001D0D0F9DC30AA7090221000008004400070200020034000000
   VCID: FAB8A484759F84F1A0B-80AF
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 130215  H13 0080
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Subsystem 4 - Part No SW: 4G0 907 410     HW: 4H0 907 410
   Component: EHL2 V07.03  H30 0030
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561 B    HW: 8K0 907 561 B
   Component: ACC3          H11 0100
   Coding: 003352
   VCID: B12A43A8E86987A9511-80E4
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 C    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0054
   Revision: 00000000    Serial number: 27011500720002
   Coding: 070181
   VCID: BA386484351F44F1E0B-80EF
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KFDC652TJ
   Coding: 30543938363030303030554A305238543053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: C8DC0E4C73F3266166F-809D
   Serial number: 6334MSME4E592E74W
   Serial number: 6344MSME4C3B4B47U
   Serial number: 6352QSME60524574A
   Serial number: 6362QSME69524868Q
   Serial number: 63732SME4C52435A1
   Serial number: 63832SME7C520644/
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372OBR0004C
   Coding: 0000FE
   VCID: C4C41A7C47DB02018A7-8091
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 984 D    HW: 8T0 920 984 D
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 5U-34GX1G
   Coding: 33E73100FF012600010000
   VCID: C0CC166C53C31E21AEF-8095
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z152230201
   Coding: 80CF07FF00
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Revision: 52001005    Serial number: --------------
   Coding: 040100
   VCID: B93A7B8830194FE9E91-80EC
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02029864747464545425363E00
   VCID: FCB4A29C7FABBAC1B27-80A9
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H15 0100
   Serial number: 002201150001008
   VCID: AF2E45D0F65D9159475-80FA
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0020
   Revision: S0H04000    Serial number: 00000000120087
   Coding: 01010101000000000001000102
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000135130040
   Coding: 01781B00000000000000
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0360483383
   Coding: 010312
   Shop #: WSC 06324 000 00000
   ROD: EV_LaneChangAssis.rod
   VCID: BFCE1590263D61D9D75-80EA
   Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H10 0305
   Coding: 011C12625E21450005
   VCID: D6E0D034A1478091E43-8083
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0031154924
   Coding: 010001010001
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X.rod
   VCID: B83C7E8C031356E116F-80ED
   Revision: 00002001    Serial number: 0361279341
   Coding: 013B0E22A0B948818330043680000047
   Component: GTO BF  H01 0080
   Subsystem 2 - Part No: 8K0 951 177
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Revision: 00005001    Serial number: 94813040965506
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H10 0305
   Coding: 011C12225E21450005
   VCID: D5E2D738BC418B89ED9-8080
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 00000001624494
   ROD: EV_ParkiBrake_AU48.rod
   VCID: BA3864843D1F44F1E0B-80EF
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109BP0F8018050
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 600215226000E7
   Coding: 0033205
   VCID: B73E7DB0C60D59991F5-80E2
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H08 0305
   Coding: 010C12224021450005
   VCID: D9FADB08D059AFE9C91-808C
   Revision: --H09---    Serial number: 525PA8-J4Z92OK
   Coding: 1021006
   VCID: B83C7E8CCB1356E116F-80ED
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Component: TSG HR        H08 0305
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0006
   Serial number: 150207200574
2 - VCDS diag log
Address 17:8T0 920 984 D recoded (Long Coding) from 33E73100FF012600010000 to 33EF3100FF012600010000  (06325/000/00000)  Saturday,25,April,2015,15:59:52:16477
Address 17:8T0 920 984 D recoded (Long Coding) from 33E73100FF012600010000 to 33EF3100FF012600010000  (06325/000/00000)  Saturday,25,April,2015,16:00:21:16477
Address 17:8T0 920 984 D recoded (Long Coding) from 33E73100FF012600010000 to 33EF3100FF012600010000  (06325/000/00000)  Saturday,25,April,2015,16:14:56:16477
Address 46:8K0 907 064 KF recoded (Long Coding) from 013B0E22A0B948818330043680000047 to 013F0E22A0B948818330043680000047  (06324/000/00000)  Saturday,25,April,2015,16:19:48:16477
2c - faults
Saturday,25,April,2015,16:04:16:16477
                    Reset counter: 50
                    Mileage: 166 km
                    Date: 2015.04.19
                    Time: 14:54:02
                    Bin. Bits:    10000
                    Voltage: 12.50 V
                    Count: 9
                    Bin. Bits:    00000
Saturday,25,April,2015,16:07:25:16477
                    Reset counter: 50
                    Mileage: 166 km
                    Date: 2015.04.19
                    Time: 14:52:51
                    Voltage: 12.60 V
3 - clear autoscan
Saturday,25,April,2015,16:29:18:16477
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 1B 20 22 30 36 3C 42 46
VIN: WAUZZZ8T1FA050745   Mileage: 240km-149miles
   Revision: --H10---
   Revision: --H03---
   Coding: 296DCE01
   Coding: 6624028080
   Coding: 00FD11
   Coding: 02005D
H01 0031
H01 0031
   Coding: 003352
   Coding: 070181
   Coding: 0000FE
   Coding: 33EF3100FF012600010000
   Shop #: WSC 06325 123 12345
   Coding: 80CF07FF00
   Coding: 040100
   Revision: AA001002
   Coding: 010312
   Coding: 013F0E22A0B948818330043680000047
   Shop #: WSC 06324 123 12345
   Coding: 0033205
   Coding: 1021006
