MIB 2 and the possibility of Retrofitting
Santos
golfi_vend
Tartu, Estonia
C?ID=195131
I have messing with this for few days now.
The politcally correct answer is from ODIS: "Wrong equipment installed" :) These have Component Protection which is not easy task. Seems like CP master is cluster. Even some older clusters have CP funcionality in them, at least 3aa 920 880 P. Because this cluster with 7n0...BC Gateway activated the CP on unit. On table test with BC gw didn't.
Also AN gw is able to communicate with 5F, but not in instalation list.
Extra. On new units there are many "Invalid Dataset faults" Odis or VCP should be able to resolve those.
It does look wicked.
Pics from another car:
Our testing:
https://goo.gl/photos/EZ9E9FA99ga8XWyS6
VWOA announced yesterday 2016 Models will have the MIB2 infotainment system.
http://www.androidpolice.com/2015/0...6-models-some-hitting-us-dealers-within-days/
We know many will want to retrofit this new system. We do not have all the answers and thought creating a post to collect information may assist the community.
Posting of Autoscans, Channel maps, and any other info from the 2016 models will help.
Santos: Great idea - my small contribution to helping the Americans is the latest spreadsheet that compares admaps from a bunch of MIBII from around the globe HERE
SHODAN
C?ID=253713
So, based on the above pictures it seems like a retrofit might be possible at some point. Will a cluster swap be necessary as well or will having a white MFD be enough?
golfi_vend
Tartu, Estonia
C?ID=195131
Well CP-master seems to be in cluster. So yes cluster is needed. But how does ODIS and motherVW take the situation where this is fitted in somewhere it doesn't belong. Car_net is out i guess. You have to insert VIN in carnet webpage and guess what happens if you insert 10 years old car VIN ;) :D
Golfi_vend: The extract below from the SSP displaying the network arrangement for CP on the mk 7 might be of interest.
PS: it's a great project which co-incidentally a forum colleague down her in the antipodes, just conpleted. You can find information (about the physical install) HERE
golfi_vend
Tartu, Estonia
C?ID=195131
Yes MK7 and B8 passats, but in CC MY16. It's just information I've collected.
On audis the CP-master is also GW... so you would guess in MY16 CC/Tiguan etc.. also, but rumors tell otherwise. :)
In the meantime...We should receive cluster back with SW updated to 1000+(previously 0703) and then check the possibility of removing CP. BUT...
I heard a story where there was discovery fitted in Jetta that had the Composition Media(i guess right name). Everything went OK, CP removed BUT nav still didn't get active. We guess that when it didn't have it originally, it cannot be retrofitted with dealer tools.
Svtweb
C?ID=11754
Going to chime in and see if there is any way that I can assist. I have a 2010 Jetta.. Mk5 body, Mk6 electronics. I have the US MIB2 PQ unit, 7N0 BC gateway, and a 2016 Tiguan 3D color instrument cluster. I have not as of yet placed anything in the vehicle. I do have several tools other than VCDS (sorry Uve, please forgive me) that will allow me to adapt the cluster to my ECU and any keys. They also allow me to poke around inside of other units. More than willing to share any information that I have that is relevant, just don't want to re-invent the wheel and step on the same landmines that others have already stepped on. Where should be start?
golfi_vend
Tartu, Estonia
C?ID=195131
Start with autoscan :) And for just for info(at least for me) with adaption map of 5F.
Spacewalker
Poland
C?ID=159607
No need org cluster , org ECU, if you car is not on server list to be "rebuild"
No matter of what cluster SW version you have.
Version SW100x give you a chance to enable it online, but if your VIN is not in a server (I believe is not) you will not jump to next step.
Everybody thinking..... " I need right cluster, right gateway, right radio" and bingo :thumbs:
I know only GW must be able to talk with 5F unit , and others is a trick with Component remove / hack.
Manufacture cars made 2016 , but only in RADIO, not RADIO + NAVI, can only enable RADIO in NAVI unit , because VIN of that car is design for RADIO only
So to fully enable radio, you must have donor CAR which was build with NAVI and hack radio .
Also - if you remove MIB radio from 2016 car, and place radio to older car , radio will LOCK component protection, and you are in deep sh****
and to fix it for future retrofit , you must REMOVE component Protection LOCK + match Component protection, so simple "try" will fu**** it up
If you remove radio from MIB car , and run it on the bench and radio still can be "hack"
Well done VW :cool:
Svtweb
C?ID=11754
So.. Theoretically speaking... If I were to change the VIN# in my Cluster and ECU to match that of a 2016 Jetta GLI SEL with MIB2 and NAV, I could theoretically thwart the VW minions from rendering the MIB unit into nothingness? *also realizing that I would have to re-code the ABS unit as it has the Vin embedded in the coding...
kamold
Australia
C?ID=241363
This could be an interesting retrofit, even without navigation, but only if Carplay/Android Auto could be enabled to allow Google/Apple maps to be run from a smartphone IMHO.
Perhaps as an academic exercise just the upgrade to the newer style media player could be worthwhile, or as an upgrade from an RCD. For me the loss of Nav functionality would render the upgrade from RNS - MIB2 invalid.
Third party solutions might better fit the bill there...
An MIB2 double DIN unit, with CP removed, and AA/Caplay active would suit me very well if I could get it going in my B6.
IMO, having Google Maps/Nav from the phone via Carplay makes on-board nav rather redundant.
kamold
Australia
C?ID=241363
I largely agree, however the MFD integration of OEM NAV is a factor for some (I would happily give it up for Google Maps also :)
vystrcil
DFW Texas
C?ID=275774
I just got my cable today. I have a 2016 Jetta GLI SEL with all the bells and whistles. Not trying to brag, just meaning that I will post my auto scan so everyone can have it :)
Great! The best place would be in the Reference Scan section. :)
golfi_vend
Tartu, Estonia
C?ID=195131
In the meantime
DzOlZMRHemcYIUYzvpf6pgF6_TTup_Jfzu55YjKT7RqLWqXt_YLFGU6HhBvmtzym-iiJ2ZbY7wQ_=w1118-h629-no
P76A-k_eGeImSELtc34h6u4EK9KsTGs9Q2bQmWvnZYLTc-Is7AKhySHIPNY5yIZ1An5Phn9PgPrq=w1118-h629-no
v0TyBNbsMaNdniIKx59ZVaOR4d2pS1ZC4L_1kQUl9RdUslZdk7zVUVuYwdNZUbaQQwqpB-J4LDof=w1118-h629-no
1IOjWXSZv1mN2AstKfCtkQ4SOuLI2R6_87gnPTeu_WLuEgUBYXbrPrEBVT7zgFfWegjDT22zxbSe=w1118-h629-no
GE16Df4RepONLLNjl3a1496qXf8pk3SuH959m0L4TDtI5tODrtJwlsEMsRMV7cBDCYmigl9r6aGz=w1118-h629-no
I79KapTOKQ6B64wlOMcQtQrmJV72ykAMYmr6FPdL6LUK14lq0pxRyIzLDUcAk8XJ0if5TnHjZaGx=w880-h660-no
Wednesday,20,April,2016,17:00:33:01666
VCDS Version: 16.3.0.2 (x64)
Data version: 20160325
Dealer/Shop Name:
VIN: WVWZZZ3CZ7Pxxxxxx   License Plate: VOLKAR DISCOVERY
Mileage: 173950km-108087mi   Repair Order:
Chassis Type: 3C (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 3C 42 44 46 4F 52 53 5F 61
          62 65 69 72
VIN: WVWZZZ3CZ7Pxxxxxx   Mileage: 173950km-108087miles
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 021 LR    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000SG  9248
   Revision: --H06---    Serial number: VWZCZ000000000
   Coding: 0000071
   Shop #: WSC 00028 028 00001
   VCID: 7AFB00AD35D9DBECE3-802E
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --025---    Serial number: 00000795617532
   Coding: 0002305
   Shop #: WSC 12345 123 21345
   VCID: 62CB58CDBD49332CDB-8036
   Part No SW: 3AA 907 044 AJ    HW: 3AA 907 044 AJ
   Component: Climatronic   H03 0404
   Revision: 00001K02
   Coding: 0009004804
   Shop #: WSC 00070 000 00000
   VCID: 78FF1AA5C3D5C9FC95-802C
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 B    HW: 3AA 937 087 B
   Component: BCM PQ47 H+   413 0452
   Revision: BC413001
   Coding: 0008000000000000009800808500028C47F0008855200100FF0820200001
   VCID: 3979DFA1B05F10F4AA-806C
   Subsystem 1 - Part No SW: 3C1 955 419 A    HW: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 28110  03  0205
   Coding: 00BF95
   Component: RLS 110213 05  54  0403
   Coding: 8F9028
                    Reset counter: 34
                    Mileage: 173932 km
                    Date: 2016.04.18
                    Time: 16:17:39
                    Voltage: 14.30 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 12
                    Reset counter: 36
                    Mileage: 173932 km
                    Date: 2016.04.18
                    Time: 16:17:39
                    Voltage: 14.30 V
                    Fault Status: 00101010
                    Fault Frequency: 146
                    Reset counter: 76
                    Mileage: 173932 km
                    Date: 2016.04.20
                    Time: 07:32:56
                    Voltage: 14.60 V
Address 10: Park/Steer Assist (J446)       Labels: 1Q0-919-475.clb
   Part No SW: 56D 919 475 A    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0006
   Revision: --------    Serial number: 35831413600268
   Coding: 318001
   ASAM Dataset: EV_EPHVA18VW4110000 001007
   ROD: EV_EPHVA18VW4110000.rod
   VCID: 3365ED899A33EAA460-8066
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 0B AIRBAG VW8   031 2522
   Revision: 11031000    Serial number: 003B1P160ZJF
   Coding: 0012354
   VCID: 306FE285A325D1BC1D-8064
   Subsystem 1 - Serial number: 6332MSME15315C29
   Subsystem 2 - Serial number: 6342MSME16386566
   Subsystem 3 - Serial number: 6351HTS6GIE0EA77
   Subsystem 4 - Serial number: 6361HTS6GIEKAJ77
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AH    HW: 3C0 953 549 AH
   Component: J0527               0030
   Revision: 00035000    Serial number: 3C0953507
   Coding: 0200711
   VCID: 72EB288D6DA9A3ACAB-8026
   Subsystem 1 - Part No: 3C8 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   H1˙ 0020
   Coding: 00000227
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C8 920 880 T    HW: 3C8 920 880 T
   Component: KOMBI         X02 X002
   Coding: 160F010000
   Shop #: WSC 00001 001 1048576
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 3D71CBB1AC772CD486-8068
12851456 - Implausible Data Received from Steering Effort Control Module
          U0419 00 [009] - -
                    Reset counter: 36
                    Mileage: 173954 km
                    Date: 2016.04.20
                    Time: 16:53:26
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 5K0 963 272 A
   Component: Standheizer     043 4707
   Revision: 00043000    Serial number: 09016748000000
   Coding: 0021012
   VCID: 2E53FCFDB911C74C0F-807A
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1663
   Revision:   H56       Serial number: 270314F2002662
   Coding: 461006
   VCID: 72EB288DADA9A3ACAB-8026
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         042 0399
   Shop #: WSC 00857 461 999999
   VCID: 76E3149D01C1BF8C87-8022
   Part No SW: 3AA 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0030
   Revision: 00H02000    Serial number: 6PZ 010 316-09
   Coding: 0010171
   Shop #: WSC 12345 123 45725
   VCID: 3A7BC0AD75591BECA3-806E
   Subsystem 1 - Part No: 3AA 907 568 D
   Component: J770  SWA Slave H02 0030
   Subsystem 2 - Serial number: 6PZ 010 316-29
   Subsystem 3 - Serial number: 5F24.03.1400H02000AMS15170˙
   Subsystem 4 - Serial number: S15170˙
02849 - Control Module for Lane Change Assistance (J769)
                    Fault Status: 01100101
                    Reset counter: 36
                    Mileage: 173932 km
                    Date: 2013.01.01
02850 - Control Module 2 for Lane Change Assistance (J770)
                    Reset counter: 36
                    Mileage: 173932 km
                    Date: 2013.01.01
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0002932146
   Coding: 0011F7
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 3561D3919447F4944E-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388__TSG-HL  006 1118
   Serial number: 00000001227586
   Coding: 0000D0
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.134 H07 1806
   VCID: 3467EE95573DED9C79-8060
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 042 0631
   Coding: 18910A000186403F0002951570088F0B607C40
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1663
   Coding: 00000008
   VCID: 6FED21F9BE9B8E4444-803A
   Subsystem 1 - Part No SW: 3AD 919 204 A    HW: 3AD 919 204 A
   Component: Analoguhr  003 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0002929027
   Coding: 0011F6
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 3663D49D8941FF8C47-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389__TSG-HR  006 1118
   Serial number: 00000001266367
   Coding: 000050
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   010       Serial number: 00000000248059
   Coding: 0000057
   VCID: 2C57F6F58F0DB55C21-8078
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 5C0 035 680 B    HW: 5C0 035 680 B
   Component: MU-S-N-ER     H22 0245
   Serial number: VWZAZ2S8218590
   Coding: 02740401FF00000011110001000808001F0100D4002001004F
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 204F12C53BC5613C8D-8074
   Subsystem 1 - Part No SW: 3G0 919 866 M    HW: -----------
   Component: ECE 2016  --- 0521
1637 - Interface for External Media
          U11B8 00 [009] - No Communications
                    Reset counter: 36
                    Mileage: 173954 km
                    Date: 2016.04.20
                    Time: 16:50:59
   Component: Batt.regelung H56 1663
   Coding: 020E185A
   VCID: 71E92781A8AF98B452-8024
   Component: J367-BDM  H07 0180
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000179043
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_VW36.rod
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0050
   Revision: 3A002002    Serial number: 00000113173491
   Coding: 0100000100000000
   Shop #: WSC 01316 785 00200
   VCID: 2F6DE1F97E1BCE4404-807A
End-------------------------(Elapsed Time: 03:10)--------------------------
GaSelle
Denmark
C?ID=266649
So, you´ve fitted a B7 dash and a B8 radio into a T5? :D
supremo
Italy
C?ID=245837
let me understand. . . . is it possible to install discover mib2( 5C0035680B ) on a tiguan 2015 TDI BLUMOTION ? which retrofit must be performed?
