vw golf mk 5 diesel none start
Shafo
South Africa
C?ID=163752
VCDS Version: Release 14.10.2 (x64)
Data version: 20150311
Thursday,30,July,2015,11:21:01:48700
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: AAVZZZ1KZ4U006046   Mileage: 165340km-102737miles
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 ET    HW: 028 101 184 3
   Component: R4 2,0L EDC G000SG  5803
   Revision: 12345678    Serial number: VWZ7Z0D9513502
   Coding: 0000032
   Shop #: WSC 01120 512 00000
   VCID: 79FF556330676EE9291-802C
18080 - Coolant Fan Control 1
            P1672 - 000 - Open or Short to Ground
                    Torque: 168.0 Nm
                    Voltage: 12.24 V
                    Bin. Bits: 00001100
                    Temperature: 5.4°C
                    Duty Cycle: 9.6 %
19559 - Motor for Intake Manifold Flap (V157)
            P3103 - 000 - Malfunction
                    Torque: 168.0 Nm
                    Voltage: 12.24 V
                    Bin. Bits: 00001100
                    Torque: 0.0 Nm
                    Torque: 354.0 Nm
16486 - Mass Air Flow Sensor (G70)
            P0102 - 000 - Signal too Low
                    RPM: 126 /min
                    Torque: 168.0 Nm
                    Voltage: 9.20 V
                    Bin. Bits: 00001100
                    Mass Air / Rev.: 850.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
18072 - Control Circuit for PD Injectors
            P1664 - 000 - Electrical Malfunction
                    RPM: 126 /min
                    Torque: 206.0 Nm
                    Voltage: 8.74 V
                    Bin. Bits: 00001100
                    Temperature: 12.6°C
                    Bin. Bits: 01010000
Readiness: 0 0 1 1 1
   Part No: 1K0 907 379 N
   Component: ASR FRONT MK70      0103
   Coding: 0017025
   Shop #: WSC 00046 412 00000
   VCID: 3D77817364CF92C9459-8068
   Part No: 1K0 820 047 CR
   Component: Climatic PQ35   081 0404
   VCID: 76E55E5F01790191443-8023
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000760779
   Coding: E4890F0600041800001400001400000000
   Shop #: WSC 05449 996 13005
   VCID: 3F8BFB7B6EC380D9575-806A
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00049109
   Shop #: WSC 05449
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 05449
00906 - Horn (H1)
            009 - Open or Short to Ground
   Part No SW: 1K0 909 605 D    HW: 1K0 909 605 D
   Component: 02 AIRBAG VW8   022 0600
   Revision: 05022000    Serial number: 0033JD0BP2KA
   Coding: 0012338
   VCID: 2D57B133B4AF0249F59-8078
   Subsystem 1 - Serial number: 6332MSME54095B02
   Subsystem 2 - Serial number: 6342MSME453D4402
   Subsystem 3 - Serial number: 6351HSME49032502
   Subsystem 4 - Serial number: 6361HSME23042602
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000042
   VCID: 3069A847A39D6FA1DEF-8065
   Part No: 1K0 920 860 L
   Component: KOMBIINSTRUMENT VDD 3354
   Coding: 0001101
   Shop #: WSC 80093 222 69422
   VCID: 316FAD43A89766A9D11-8064
00003 - Control Module
            014 - Defective
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 21001043319547
   Coding: 3D3F0340070003
   VCID: 275B431B965328190F5-8072
   Component: IMMO                3354
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0148
   Coding: 0000052
   Part No: 1K2 909 144 F
   Component: EPS_ZFLS Kl.0       1301
   VCID: 2F6BAB3BBEA37059C75-807A
            000 -  -
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 19C802087F2D8F0F485FC69010
   Shop #: WSC 05449 996 83277
   VCID: 7BF34F6B3A5B5CF93BD-802E
   Subsystem 1 - Part No: 1K0 951 605 A
   Component: LIN BACKUP HORN H01 1201
   Subsystem 2 - Part No: 1K0 907 719
   Component: Neigungssensor  003 0003
   Subsystem 3 - Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   Part No: 1K0 035 186 J
   Component: Radio BNO           0016
   Coding: 0040402
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0202
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
   Shop #: WSC 00046 000 00000
End-------------------------(Elapsed Time: 01:37)--------------------------
hi guys
this vehicle came in none starting..im assuming the injector fault is the reason for the none start..ive checked the resistance on each injector and all are 0.3 ohm...guys seem to have loads of issues with the harness running inside the head to injectors, but I get proper resistance on injectors till ecu plug...ive already tried another ecu but same fault codes..
any advice?
under actual values for injector condition I get "128" something to do with fault at start of injection?
thanx
shafo
Shafo
South Africa
C?ID=163752
hmmm starter is pulling excessive current...I can only imagine how much they've been cranking this car..lol...will do starter over and report
Shafo
South Africa
C?ID=163752
starter done over...strong battery...swinging perfectly now but I still keep on getting the same fault codes...
PPP
Sketchy
Cambodia
C?ID=242293
Have you checked the speed of engine crankshaft while cranking?
Gone But Not Forgotten
Okay now it's time to verify supply to the PD harness + consumers via WD starting with fuses.
Get manual and trace the tracks.
Take a strong look at supply relay and power plausibility for terminal 15 during cranking........ verifying the ignition switch.
Shafo
South Africa
C?ID=163752
Jack do these injectors get a 12v supply from the ecu?
Affirmative, however it is the power to the controller you must trace and track using WD.
Start with FP relay.....and terminal 50 to J519
Don't forget grounds back to controller and from controller to chassis.
Shafo
South Africa
C?ID=163752
so I got an audi in with the exact same engine...also none start...but 0 errors...I took the audis control unit out and tried it in the golf v and my car starts and cuts out(immo)... I do believe the second computer I tested with in my golf v was also faulty...
fault on my car seems to be ecu .
I do however worry that the audis ecu part number was slighty different ..
can anybody confirm that these two ecus are interchangeable -
audi- 0281 011 364
vw-0281 011 843
Why are you doing this........?
Install the correct part #
You are gonna have a bad time...... if the PC doesn't match up even if the Immo gets aligned.
Shafo
South Africa
C?ID=163752
i think you misunderstood me....i want to know is if it is fine that i tested my car with the audi ecu? it started my car...so do you think that i can thus confirm that my ecu is the issue?
Is it fine........no it's not the correct part.
The fact that it ran though and if the other doesn't, would be an indication that you might need an ecu.
Have you verified both ecu's share all the same power conditions for supply in WD? I would before I bought an ecu!
golfi_vend
Tartu, Estonia
C?ID=195131
Both are EDC16U1 ecus so yeah, they share same power patch.
Find same p/n ecu and match immo or swap eeprom.
Beware that swapping the eeprom may not work and give you a really bad time if this ecu is PC specific.......... because the PC is stored in Flash/MPC not eeprom.......
Also this ecu supports a redundant virtual eeprom within the flash/MPC.
It is advised that valid backups are made!
Simple swap over could really be a bad time!
I bet I could help you do that transfer if interested.......... if the hardware is an exact match.
Shafo
South Africa
C?ID=163752
I did confirm that wiring for the two are EXACTLY the same ...both cars have the SAME engine code bkd... again i just swopped ecu for testing purposes ( i HATE making wrong diagnosis, im sure everyone does) so now that i can confirm the ecu is in fact my problem i will source the same ecu as was in my car (original 1)
How much effort is it to program a used ecu?i do have a supervag3 to pull security codes and vcds obviously.
If that hardware is the same you could send me both ecu's for a real authorized data transfer.
The unit was in need of a serious firmware update as well........so we could handle that to while in custody.
Shafo
South Africa
C?ID=163752
Bud im faarrrrrrrrr from you!!! South africa :)
I do this for the whole world...........
Let me know.....
Shafo
South Africa
C?ID=163752
Update on this situation. ..customer brought me a edc16u34 ecu from a golf v tdi (i assume a later/earlier model)
He brought a cluster key and ecu
I advised him against it but he pushed me to fit.
Car started fine a drove away
So original ecu was edc16u1 and swopped with edc16u34
Did you do an auto-scan of the controller and did it contain any faults even though it ran?
Doesn't surprise me that it ran..........
