2006 VW Rabbit MK5 - A/C troubleshooting
strichzwei
Austin, TX, USA
C?ID=44747
I inherited this well cared for vehicle with no-nop climatic (not climatronic) A/C, blower fans work, brand new pollen filter, all fuses are good but it just blows warm.
While I am somewhat mechanically inclined, A/C is a bit of black art to me 😉. I do not have A/C gauges and would not know how to use them, although willing to give this a try if there is a good tutorial somewhere. I have done a lot of research but did not understand everything I read about troubleshooting the A/C. Below is what I have done so far, if someone knowledgeable could give me some pointers, that would be much appreciated. Please see full auto scan below, along with some supporting images:
I have no A/C related fault codes
All fuses are good
The center bolt of the sanden (model U4568) compressor spins
I reset the basic settings
Compressor code: 0 (zero) with A/C running
Fans work but neither come on when A/C is turned on (not sure if that is supposed to trigger the fan?)
Thanks,
Scott
(For some reason I just cannot get my images to post, not sure what I am doing wrong, certainly user error! But I notice if you put the following url into your browser you can see the images or if you click it, it will link you to the IMGUR images.) There are images here of measuring blocks and the advanced measuring values:
https://imgur.com/a/e4PZP1A
Monday,13,February,2023,13:33:02:38585
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
VIN: WVWDR71K56W200765 License Plate:
Mileage: 96080km-59701mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWDR71K56W200765 Mileage: 96080km-59701miles
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 AQ HW: Hardware No
Component: 2.5l R5/4V G 6746
Revision: -------- Serial number: VWZ7Z0F3702817
Coding: 0000003
Shop #: WSC 01279 785 00200
VCID: 78A9E48BEEDA205BDF3-802C
VINID: 9E69D488705B1469C20001C614C4F1FF1E
000152 - Intake Air Temperature Sensor 2 (G299)
P0098 - 002 - Signal too Low - Intermittent
Mileage: 95671 km
Time: 04:01:03
Temperature: 86.0°C
Temperature: -40.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.938 V
000275 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High - Intermittent
Mileage: 95671 km
Time: 04:01:03
Temperature: 86.0°C
Voltage: 11.938 V
Part No SW: 09G 927 750 GJ HW: 09G 927 750 GJ
Component: AQ 250 6F 0833
Revision: 00H38000 Serial number:
Coding: 0000072
VCID: 7F5B0F97CBF417639E9-802A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Revision: 00H13001
Coding: 0021122
VCID: 71BFD9AF8DA0711318D-8024
Part No: 1K0 820 047 EC
Component: Climatic PQ35 090 0505
VCID: 698FB1CFA57089D350D-803C
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000225449
Coding: 10088F214004180000140000001400000028770B5C
Shop #: WSC 25152 444 54377
VCID: 2B030BC76F0C5BC3621-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 25152
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7F7047887
00003 - Control Module
014 - Defective
Fault Status: 01101110
Reset counter: 160
Mileage: 3521 km
Time: 03:43:27
02788 - Internal Communications Error
Fault Frequency: 11
Reset counter: 196
Mileage: 96050 km
Time: 02:27:46
Bin. Bits: 00000010
Bin. Bits: 00000000
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 5L AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD05VXU9
Coding: 0013644
Shop #: WSC 01269 785 00200
VCID: 392F218F9550F953E0D-806C
Subsystem 1 - Part No: 1K0 959 339 D
Component: BF-Gewichtsens. 006 0006
Subsystem 2 - Serial number: 6332MSME0E6215324
Subsystem 3 - Serial number: 6342MSME0E0B4604B
Subsystem 4 - Serial number: 6352QSME0E2F2127K
Subsystem 5 - Serial number: 6362QSME0C792E75Y
Subsystem 6 - Serial number: 63727SME0A171B6A6
Subsystem 7 - Serial number: 63827SME0A172040S
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0010022
Part No: 1K0 920 953 C
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0007203
Shop #: WSC 07228 444 53711
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 280010642511D7
Coding: 3F3F0360070002
VCID: 2A0D0EC360F642CB997-807E
Component: IMMO VDD 4312
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2373
Coding: 0001205
VCID: 36352AB3A44E162B0DF-8062
01552 - Motor for Central Locking; Drivers Door (V56); Lock
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 333313A7B73C03032A1-8066
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 13C803281B09058F880F048050CC
Shop #: WSC 00000 785 00200
VCID: 74B1D0BBF2B2443BF3B-8020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001205
VCID: 372B27B7A344EF23169-8062
Address 56: Radio Labels: 1K0-035-1xx-56.clb
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio PM6 016 0017
Revision: 00016000 Serial number: VWZ5Z7F2072215
Coding: 0040400
VCID: 2019ECEB16CA889BC73-8074
Reset counter: 156
Mileage: 96050 km
Time: 02:22:35
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2438
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
VCID: 343110BBB232043B33B-8060
End----------(Elapsed Time: 01:08, VBatt start/end: 13.5V/13.8V)-----------
EuroX
Northern NJ USA
C?ID=208579
Code wrap please. Based on the picture posted I would say compressor is coming on. The question is whether there is a charge in the system. I would check if there a charge in the system if not get it recharge with dye. If system has a charge check pressure on high and low side of system. If system pressure is even on both side with AC on your compressor is shot to shit.
strichzwei
Austin, TX, USA
C?ID=44747
EuroX, thanks for that feedback, I will get those readings.
Scott
Jef
HQ
General rule of thumb... no DTCs + no shutdown code = bad compressor. :(
  • Agree
Reactions: JMR
EuroX
Northern NJ USA
C?ID=208579
I never load the parts cannon I like to know for a fact.
MVB_
C?ID=164610
You only show 2bar /29psi in system.
MVB_
C?ID=164610
G65 sensor for high pressure on the high side. The only way to know if you have the correct charge is to have the system evacuated and charge it back by the correct weight.
