MK7 transmission shifts wrong at gear 5th
khaledabdulaziz
Israel
C?ID=394371
hello all
I have mk7 came to me with steering light on
I did the basic settings and everything went fine, steering light went off
so after that no faults came on but the auto-transmission doesn't go to the 5th gear
what could be possibly wrong, some mechanic friends told me to do update for transmission software
could anyone advice me what to do?
Monday,13,February,2023,22:04:53:04619
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: WVWZZZAUZFW225183   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZFW225183   Mileage: 180049km-111877miles
Address 01: Engine (J623-CXSA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 DF    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H10 7775
   Revision: WAH10---    CVN: 22D4EEAE
   Coding: 01250012230411082000
   ASAM Dataset: EV_ECM14TFS01104E906016DF 002006
   ROD: EV_ECM14TFS01104E906016DF.rod
   VCID: 698FBB9FF9F8C2F35CC-803C
   VINID: 9E69EAAAA465A969C20850480CAED414F6
Readiness: 0110 0001
   Part No SW: 0CW 300 047 D    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5220
   Revision: 00043014    Serial number: CU501412167622 CVN: 0000C97B
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 3C2132CBC6EA875BF7A-8068
   Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
   Component: ESC           H42 0609
   Revision: 00000000    Serial number: 63524000000113
   Coding: 01FA6AA1242211710778060841C62980562488E0608294F300220028C202
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   VCID: 3D273FCFDDF08E53C04-8068
   Part No SW: 5G0 907 044 BC    HW: 5G0 907 044 BC
   Revision: 00001K08
   Coding: 00020014200100001005000012101400
   Air quality sensor:
   Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
   Component: BCM MQBAB M   H18 0137
   Serial number: 01011500500406
   Coding: 00101842C24100DB4BE44000000403081000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7DA7FFCF9D704E53804-8028
   Component: WWS    141207  043 0551
   Serial number:         141212100249
   Sunroof control module:
   Subsystem 2 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.403  H02 0003
   Serial number: 0000FST0002DAVK00000
   Coding: 181801
   Humidity sensor: interior:
   Subsystem 3 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 20958236
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R0EPYRM
   VCID: 41DF433FA108EAB3A4C-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 002 407 14
   Serial number: 3576700000001868901I
   Subsystem 2 - Part No SW: -----------    HW: 480 001 812 14
   Serial number: 358670000009AB10421O
   Subsystem 3 - Part No SW: -----------    HW: 480 401 612 14
   Serial number: 35165029F196FF61E1C/
   Subsystem 4 - Part No SW: -----------    HW: 480 401 212 14
   Serial number: 3526502AF1811B92539C
   Subsystem 5 - Part No SW: -----------    HW: 480 401 612 14
   Serial number: 35565029B188FBF2D22.
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141217400762
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FDB45C7D7FC9C43D28-806A
   Part No SW: 5G1 920 740     HW: 5G1 920 740
   Component: KOMBI         203 5297
   Coding: 07A4190823800008000808001400000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009003
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: 6393A9B71BD498A3960-8036
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 E
   Component: GW MQB Mid    127 1204
   Revision: --------    Serial number: 0002869930
   Coding: 030100042F085700EF0002481C0F00010001050000000000000000000000
   GVL: 01503C0000000000400C00000000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 71BFD3FFD1283A3314C-8024
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 H    HW: 5G0 959 442 H  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0038
   Serial number: 29140002877510105012
   Coding: 24FFFF
   Serial number: 3685755203
   Component: TSG FS        010 0031
   Serial number: 0000155538904
   Coding: 00310320D000020000001000
   Shop #: WSC 00028 028 00023
   VCID: 47CB5D278F2CD4836A8-8012
   Serial number: 00000000000004847382
   Coding: 110000
                    Reset counter: 20
                    Mileage: 180047 km
                    Date: 2023.02.10
                    Time: 00:43:24
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 0103
   Shop #: WSC 73430 790 00103
   ROD: EV_SteerAssisMQB_010.rod
   Component: TSG BFS       010 0031
   Serial number: 0000156173419
   Coding: 00310120DE00020000801000
   VCID: 46D550238826CD8B91E-8012
   Serial number: 00000000000004802926
   Coding: 090000
   Part No SW: 3Q0 035 840 C    HW: 3Q0 035 840 C
   Component: MU-S--ER      724 0891
   Coding: 02731000FF00000051110001000938001F0500F40120000006
   Shop #: WSC 00046 000 00000
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2B030197338410E36E0-807E
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJT2545559
          U1014 00 [009] - -
                    Reset counter: 20
                    Mileage: 180047 km
                    Date: 2023.02.10
                    Time: 00:43:34
                    Voltage terminal 30: 12.3 V
          B201A 00 [009] - -
                    Reset counter: 20
                    Mileage: 180047 km
                    Date: 2023.02.10
                    Time: 00:43:34
                    Status_Software_Version_Management-module_name: C
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [009] - Open Circuit
                    Reset counter: 20
                    Mileage: 180047 km
                    Date: 2023.02.10
                    Time: 00:43:35
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 14 dB�V
6698 - Optical data bus
          U1049 00 [009] - Open circuit
          [Optical data bus: open circuit: wakeup]
                    Reset counter: 20
                    Mileage: 180047 km
                    Date: 2023.02.10
                    Time: 00:43:39
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 20
                    Mileage: 180047 km
                    Date: 2023.02.10
                    Time: 00:43:37
                    BAP-BAP_Function_ID: 02
End----------(Elapsed Time: 01:28, VBatt start/end: 12.3V/12.3V)-----------
Spacewalker
Poland
C?ID=159607
DSG do gear up/ down depend of conditiosn send from ECU
1- when you swich to manual , you see Gear recommendation to up or down /?
1st to 2nd will always shift , but then next gears should show arrow (up)
khaledabdulaziz
Israel
C?ID=394371
goes up
yes but the gear itself dont pass gear 4
anyhow, i told the customer to update the transmission software, he didnt return to me
thanks for helping
siLc
Tallinn, Estonia
C?ID=330192
1.4 TSI CXSA engine should have DQ200 box with part number ending in 047 T or S, not 047 D. This software is probably for the 1.2 TSI CJZA engine. Go and have the correct software installed.
There are a few measurement channels in the TCU, which can help identify the transmission:
IDE02862-ENG104019 Production data transmission-Getriebekennbuchstabe QES
IDE80305-ENG125922 Parameter set description-Data set name 0CW300046G_5206_LgDP
First one is the gearbox code, the other is the software part number, software version and software identifier. If the gearbox code doesn't match with the one in the vehicle data sticker, then it is clear as day that something is very off. Then the software identifier is also expected to be off from what is documented here -> https://docs.google.com/spreadsheet...6O1naA4P7dwHLfSW5d7P0nnAw/edit#gid=1999272625
Spacewalker
Poland
C?ID=159607
hello all
to 5th not, but how easy is going from 2nd to 3rd, ....3rd to 4th ?
if you manually swich to 5th or 6th ..and swich on to Automatic, it will reduce to 4th ?
when you drive on 5th in Tiptronic, you see gear recommendation to reduce to 4th ?
