Oddities in experimental LBLs
etz2k
C?ID=69430
Why do VCDS show settings where you must insert a number so strange, so that it's nearly useless.
Here is 1 example of many, how ODIS and how VCDS shows it.
Why is there no field to insert a number like in ODIS, if there is no description for the different settings/values ? This would be much better than always showing "!! None found".
Why do LCode show sometimes "Bit 0" for a pulldown menue which i can activate and not for example "Bit 0-3" :confused: (seems like the problem only occurs if pd-menue is line 1 and there is a second one)
I think it's the same problem i already descriped here: https://forums.ross-tech.com/index.php?threads/20117/post-269160
Come on RT-guys i believe you can do this better:D
JMR
Romania
C?ID=432218
:popcorn:
NEtech
Denmark
C?ID=56995
I am not an RT employe, but example Byte 5:
There are no exp data available to show (like the other examples), and the value 08 is showed, just as odis show that.
That is what I/we define in made label files, if it is known.
Yes not showing the text Bit 0-3 on line is maybe a bug in lcode, but it shows the pulldown as is should!
etz2k
C?ID=69430
Thanks for your response @NEtech
I know that there is no exp data to show, but can LCode not show the Hex-value of the bit-range (here bit 0-3) in a field like ODIS, if there is no exp data?
LCode show the value of bit 0-7 in the hex-field and "None found", but i think this is not so helpfull in such cases.
Maybe LCode can show it more like this (don't worry i only modified the screenshot not LCode:))
Sebastian
Magdeburg, Germany
HN0-nnnnnn
What's wrong with using the non-experimental coding chart? Based on a brief check, all your cases should be covered there.
Feel free to attach a full scan, so I can double check your case.
etz2k
C?ID=69430
Thanks @Sebastian,
I think you understand me wrong, i don't know if there is something wrong with your "non-experimental coding charts", this is not my request.
I only like to use also the so called "experimental coding chart", because it uses the asam data from the modules and so it may sometimes fit better, for different module (sw) variants.
My question is, if it's on the "RT to do list" to display this information more concrete/correct like in ODIS or not?
here is the autoscan:
Wednesday,03,August,2022,23:22:43:02752
VCDS Version: 22.3.1.4 (x64)
VIN: VSSZZZ6JZGR110769   License Plate:
Chassis Type: 6J-SE26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 55 5F 69
VIN: VSSZZZ6JZGR110769   Mileage: 40280km-25028miles
Address 01: Engine (J623-CHZC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 Q    HW: 04C 907 309 AE
   Component: R3 1.0l TFS   H25 2307
   Revision: W1H25---    CVN: CEA868A2
   Coding: 01190032232411080000
   Shop #: WSC 00049 770 00242
   ASAM Dataset: EV_ECM10TFS01104C906026Q 001005
   ROD: EV_ECM10TFS01104C906026AH_001.rod
   VCID: 2F550D3876178CF766-807A
   VINID: 9A38EAAAA19AA978810401C6246D489F4C
Address 03: ABS Brakes (J104)       Labels:. User\6R0-907-37x-ESP90.lbl
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08508432160303
   Coding: 11DD487D492433C0091B106F005A881292CC9008000DE7098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 374535588E4744373E-8062
Address 08: Auto HVAC (J255)       Labels:| 6C0-907-044.clb
   Part No SW: 6P0 907 044 B    HW: 6P0 907 044 B
   Component: Climatronic   H02 0202
   Serial number:  1602242A-1443
   Coding: 000000001001000001
   ASAM Dataset: EV_ACClimaValeoPQ26 003001
   ROD: EV_ACClimaValeoPQ26.rod
   VCID: 30570E446B29930F7F-8064
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 C    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0087
   Serial number: 006098014993
   Coding: 08020A4042132AFB43804000402F07480000690053010000000000000000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005.rod
   Subsystem 1 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S3Y16M03D16H06M21S26
   Coding: 00984D
   Driver door control module:
   Subsystem 2 - Part No SW: 6R0 959 801 DT    HW: 6R0 959 801 DT  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 0630
   Serial number: KU0KU015031660754654
   Coding: 1400A5
   Front passenger door control module:
   Subsystem 3 - Part No SW: 6R0 959 802 EE    HW: 6R0 959 802 EE  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 0630
   Serial number: KU0KU015031660751993
   Coding: 0400A5
   Humidity sensor: interior:
11274 - Bulb for Center Brake Light
          B12C6 15 [008] - Open or Short to Plus
                    Fault Frequency: 181
                    Reset counter: 204
                    Mileage: 38523 km
                    Date: 2022.05.07
                    Time: 13:03:44
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Stoerschutzzaehler: 19
                    Voltage: 14.7 V
                    Outside temperature: 18.5 °C
   Revision: --------    Serial number: 39391606304869
   Coding: 0031051101
   ROD: EV_EPHVA18AU3700000_SE26.rod
   VCID: 43BD5188CA9F189792-8016
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 J    HW: 6C0 959 655 J
   Component: VW20Airbag002 002 0380
   Revision: --------    Serial number: 003TH003Y123
   Coding: 88C0C000000000005C0000CA000800000000
   Shop #: WSC 00049 770 00109
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3A432C6CBD55595FC1-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 272 302 16
   Component: SideSensor_Df  15B 0148
   Serial number: 3495R002829544B2C35T
   Subsystem 2 - Part No SW: -----------    HW: 410 272 302 16
   Component: SideSensor_Pf  15B 0148
   Serial number: 3505R002429544B491DM
   Part No SW: 6P0 920 740 A    HW: 6P0 920 740 A
   Component: KOMBI         208 1424
   Coding: 072411002980000800082A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_SE26.rod
   VCID: 2D6917307C1BFEE754-8078
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H08 0087
   Revision: --------    Serial number: 006098014993
   Coding: 030100046F08560070000000000000010001000000000000000000000000
   GVL: 01443C0000000000C00010000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_VW26.rod
   VCID: 65F9AF10646B06A75C-8030
   Subsystem 1 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B  Labels: 3C8-959-537.CLB
   Serial number: 000000000B0048220216
   Coding: 002000
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 53078M02382821730751
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serial number: CG3G1413
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6DE9D730BC9B3EE714-8038
   Coding: 058A000003000000
   Shop #: WSC 00049 770 00143
   VCID: 40B75E84DB89038F8F-8014
   Subsystem 1 - Part No SW: 7L6 941 329 C    HW: 7L6 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 290000
   Subsystem 2 - Part No SW: 7L6 941 329 C    HW: 7L6 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 290000
5275648 - Left/Right Driving Switch-Over Active
          C1080 00 [009] - -
                    Reset counter: 156
                    Mileage: 40098 km
                    Date: 2022.07.19
                    Time: 17:05:53
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 5QA 035 824     HW: 5QA 035 824
   Component: MU-S--ER      H24 0245
   Serial number: SEZAZ2S0019750
   Coding: 04520300960A000011110001000808002F0200C40120010002
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SE26.rod
   VCID: 7DC9E770ECFBAE67A4-8028
   Subsystem 1 - Part No SW: 5F0 919 604     HW: 5F0 919 604
   Component: ABTm_Std2  H44 1031
   Serial number: SEZ8Z9SLL00HVE
   Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
   Component: ConWysTrailer H14 0137
   Serial number: 00000181563668
   Coding: 0100000200000000
   ROD: EV_TrailFunctGener2Hella_SE26.rod
   VCID: 39413360B8535247C8-806C
End-------------------------(Elapsed Time: 02:37)--------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Ideally we want people not to use the experimental coding at all, otherwise we could could stop our efforts which go into curating our control module documentation. So while I see your point, that the experimental data ought to be on par with ODIS, our primary concern must be the curated data.
Thanks for the scan, I'll do a walk-through later to make sure everything is covered as it should be.
etz2k
C?ID=69430
Hi @NEtech,
nice done with the number behind the pull-down menu.
I do some testing with the new 2.0.21 in #5F and found some small glitches:
1. if there is exp data it only shows line one of the pull-down menu (for example "no brand"), even if another ("brand,Seat") is coded.
2. if i make another selection in the pull-down menu, it still displays the first line of the menu (but the bit setting is OK)
3. if i open the pull-down menu and close it, without making a new selection it sets the Bits to 00 (zero)
4. it shows a blank line after every menu point in the pull-down menu, but only the first pull-down menu for a byte, the 2nd, 3rd etc is ok.
etz2k
C?ID=69430
Hi @NEtech,
very nice done, you fixed the glitches i found.
I do some testing with the new version and found some new/other small glitches, maybe you can/will fix it. :D
1. if i open a pull-down menu w/o exp data and close it without making anything, it sets the Bits to 00
2. In the gateway (#19) i get this error for byte 6,7,18,22 (this error seems to be new in the last version and only for the gateway and only if pull-down menu w/o exp data?):confused:
etz2k
C?ID=69430
Seems like you fixed the most glitches,:thumbs: but i still found one :)
If i click (open&close) here the pull down menu 1 or 2, always the hex value of the 2nd menu will be set to zero (in both cases):confused:
