Replaced cam tensioner on c5 2.8 AHA how to check timing with VCDS
Paperclips43
Verified VCDS-Lite User
Sedona, AZ, USA
C?ID=539036
I just finished up replacing the cam chain tensioner/adjuster on the passenger side (with cylinder 1,2,3) on my 99Audi A6 c5 2.8 30v AHA avant
How can I check timing with VCDS before turning the car on?
Also I want to prime the fuel system and do a throttle body adaptation since I also removed intake manifold and throttle body to look at my valves which all seemed in good condition. I scraped a minimal amount of carbon from them but the valves looked straight. This model has the drive by cable throttle.
I tried entering 035 in the engine section but I am a little lost on where to get better directions for using this.
Hi and welcome.
I rather doubt that a 1999 ECU has the ability to check cam timing, but please post an Auto-Scan so people can see exactly what ECU this car has.
Paperclips43
Sedona, AZ, USA
C?ID=539036
Apologies I told myself to remember to post the auto scan and it completely slipped my mind. Also this scan was taken prior to my repairs as I havent done another scan yet.
Address 01: Engine       Labels: 078-907-551-ACK.LBL
   Controller: 4D0 907 551 AH
   Component: 2.8L V6/5V  MOTR AT D03
   Coding: 06252
   Shop #: WSC 02325
   VCID: 6CABAC240F93
18010 -  Power Supply Terminal 30: Voltage too Low
            P1602 - 35-10 -   - - Intermittent
16795 -  Secondary Air Injection System: Incorrect Flow Detected
            P0411 - 35-00 -   -
Address 02: Auto Trans       Labels: 01V-927-156.LBL
   Controller: 4B0 927 156 G
   Component: AG5 01V 2.8l5V  USA 8509
   Coding: 00000
   VCID: 2B296F38CA1D
00526 -  Brake Light Switch-F
            27-00 -  Implausible Signal
Address 03: ABS Brakes       Labels: 8E0-614-111-ABS.LBL
   Controller: 8E0 614 111 A
   Component: ABS/EDS 5.3 QUATTRO D10
   Coding: 0273004284
   Shop #: BB 24334
   VCID: 1C4BBCE49FB3
Address 08: Auto HVAC       Labels: 4B0-820-043-MY1.LBL
   Controller: 4B0 820 043 Q
   Component: A6-Klimavollautomat D62
   Coding: 00160
   Shop #: WSC 02325
   VCID: 28239034DBEB
8 Faults Found:
01809 -  Actuating Motor for Temperature Flap; Left (V158)
            41-10 -  Blocked or No Voltage - Intermittent
00710 -  Defroster Flap Positioning Motor (V107)
01810 -  Actuating Motor for Temperature Flap; Right (V159)
01274 -  Air Flow Flap Positioning Motor (V71)
01842 -  Potentiometer/Actuator for Temperature Flap; Right (G221)
            30-10 -  Open or Short to Plus - Intermittent
00601 -  Potentiometer On Positioning Motor for Central Flap (G112)
00604 -  Potentiometer Positioning Motor for Air Flow Flap (G113)
01273 -  Fresh Air Blower (V2)
            17-10 -  Control Difference - Intermittent
Address 15: Airbags       Labels: 4B0-959-655-AI7.LBL
   Controller: 4B0 959 655 H
   Component: Airbag Front+Seite 0002
   Coding: 00106
   Shop #: WSC 02324
   VCID: 351D49401C59
00589 -  Airbag Igniter 1; Passenger Side (N131)
            32-10 -  Resistance too High - Intermittent
Address 17: Instruments       Labels: 4B0-919-xxx-17.LBL
   Controller: 4B0 919 930 R
   Component: C5-KOMBIINSTR. VDO D15
   Coding: 07262
   VCID: 370143480655
Address 35: Centr. Locks       Labels: 4B0-962-258.LBL
   Controller: 4B0 962 258 J
   Component: Central Lock/Alarm  D32
   Coding: 15885
   Shop #: WSC 02325
   VCID: 30137854E33B
8 Faults Found:
01366 -  Opened Due to Crash Signal
            35-00 -   -
01371 -  Alarm triggered by Door Contact Switch; Driver's Side
            35-00 -   -
01572 -  Alarm triggered by Door Contact Switch; Passenger Side
            35-00 -   -
01374 -  Alarm triggered by Terminal 15
            35-00 -   -
01370 -  Alarm triggered by Interior Monitoring
            35-00 -   -
00955 -  Key 1
            09-00 -  Adaptation Limit Surpassed
00956 -  Key 2
            09-10 -  Adaptation Limit Surpassed - Intermittent
01574 -  Alarm triggered by Door Contact Switch; Right Rear
            35-00 -   -
Address 36: Seat Mem. Drvr       Labels: None
   Controller: 4B0 959 760 A
   Component: Sitzmemory          D05
   VCID: 2B296F38CA1D
Address 45: Inter. Monitor       Labels: 4B0-951-173.LBL
   Controller: 4B0 951 173
   Component: Innenraumueberw.    D03
   Coding: 00002
   Shop #: WSC 02325
   VCID: E0B34814735B
01380 -  Alarm triggered by Anti-Theft Sensor; Rear Left
            35-00 -   -
01383 -  Alarm triggered by Anti-Theft Sensor; Front Right
            35-00 -   -
Address 56: Radio       Labels: 8D0-035-1xx-56.LBL
   Controller: 8N0 035 186 A
   Component:  Radio              D03
   Coding: 00117
   Shop #: WSC 02325
   VCID: 2E2F662CF90F
End   --------------------------------------------------------------------------------------------------
Paperclips43
Sedona, AZ, USA
C?ID=539036
VCDS-Lite Version: Release 1.2
Monday, 09 January 2023, 14:40:34:60311
Control Module Part Number: 4D0 907 551 AH
Component and/or Version: 2.8L V6/5V MOTR AT D03
Software Coding: 06252
Work Shop Code: WSC 02325
VCID: 6CABAC240F93
P0411 - 35-00 - -
Monday, 09 January 2023, 14:52:28:60311
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,06,08,15,16,17,18,22,34,35,36,37,45,55,56,57,65,67,75,76,77
Paperclips43
Sedona, AZ, USA
C?ID=539036
Thank you for the welcome and the info about my ECU. Yeah I realize its an old car now basically historic haha. Ok well as soon as you think its ok to try and start up from being taken apart that far let me know. I am looking forward to firing her up and getting her out of my friends garage who has so patiently let me keep inside while I work. Potentially just a fuel prime and a throttle body adaptation and I should be good to start it? Ive read about throttle body adaptations by keeping the key to on position for 3 minutes. Though id like to be sure I have primed it correctly so I can rule out that as any issues if I have a less than perfect process when I turn her over.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
That car has chain only to run second camshaft, Main thing is Timing belt.
Now did you count 16 pins from one mark to other mark , this is most important when you installing cam chain?
Pay tension on right side of picture which pin you start , I have seen people start counting straight up from cam mark and end up with 15 pins and car will have long crank and get DTC for Camshaft sensor .
Coding: 06252
Shop #: WSC 02325
VCID: 6CABAC240F93
As I expected -- very much old-school. No cam timing data to be had from that ECU.
Paperclips43
Sedona, AZ, USA
C?ID=539036
My deepest apologies for such a late reply that is not usually like me but I was inconvenienced with a possible destroyed engine although thankfully not! I ended up running a test on VCDS that tested my fuel injectors and a few other parts and I heard my fuel pump turn on. I know I probably shouldnt have been messing around pressing buttons without clear guidance but I figured since I could hear the fueld pump turn on and prime everything I was ok. I quickly skipped through the rest of the testing procedure and figured I was good to go and thats when the nightmare began.
Im sure it was unrelated to the injector testing but I went to start the car and it started instantly which I felt was a good sign as I had both valve covers off and the intake manifold off and throttle body apart for a couple weeks. One second after starting an extremely loud knock sound occurred and I quickly shut the car off. I ended up trying again once more while filming so I have a video if anyone wants me to post it. A couple people guessed I had rod knock which i looked up and wrongfully believed I did as well.
I decided coincidence is just a word used when you cant see levers and pulleys and since one CCT had failed the other is likely to have failed as well. I pulled it and replaced the drivers side this time Bank2 and went to start to the car and things were good. All good. Lifters were a little loud at first but went away in a second which had a sound that gave me a fright but I knew was much quieter that what I heard when CCT failed and wow that sure was scary.
Paperclips43
Sedona, AZ, USA
C?ID=539036
This probably the best diagram to use as reference that I have seen so thank you very much. And actually im not sure what happened but I did end up with a link less on top that was noticed when I went to lock cams with cam lock bar. The cam washer was pointing about 30 degrees or so of center which i had never had happen to me so I pried off the valve cover and was able to get it right and then everything went normal when i buttoned her up.
I posted my question on an Audi forum but if anyone here has any experience or advice on replacement tensioners to use i am on the market. I have cheap chinese ones in there right now but i dont want to drive it much if at all until i get something better. I think i paid 40 bucks each for those and im not willing to spend the 1000 plus dollars for OEM. I have budgeted 500 dollars for the whole kit including gaskets so any recomendations would be really helpful as there is no shortage of alternate manufacturer options.
