I forgot to mention, the green rubber bumper is present between board and solenoids, at every electrical connection points. The boards are the same shape as the original, identical, only looks cheaper made, not being original Audi, or reputable brand, rather a no name. Is the serial number on the mech unit TCU surface or where should I look for ? The 2 tubes are inside in the transmission and some cases are metal, in this case is black plastic. Likely you missed my previous post, where I answered some of the questions regarding to the fluid used before, I have photos of the inside of the transmission, the container of the fluid, what was used and what I intend to use. Please check that, I try to find a way, if I can to bring your attention to that post. I take some photo of the seral number. I know the transmission was changed for this car around 3 years ago (112000 miles) the plates not sure if ever were changed or can be changed several times ?Compare to the original board. But I will assume there is not solenoid there as the board is probably used in a few different configurations. Do the boards have the rubber bumper installed between the board and solenoid pins? there should be some green colored rubber bumpers. Finally why dont you post a picture of the serial number from the unit so we can determine correct finger height. Also are the 2 metal pressure tubes for the mech in the transmission? Please take pictures of inside of transmission so I can see if pressure tubes are present or not.
