Hi everyone. After a short year I have another audi project. Here is attached the log file of the car. I ve bought the car recently from somebody, who had it at a local shop, which stated the following "transmission needs to be changed, as the new mechatronic unit can not learn the shift points due to being to worn out."
I want to hear inputs, what s the problem and what are the steps to fix ? Also I have read, that audi might have a recall on these transmissions, since it s a common transmission problem with these cars. If true and they fix it for free, what are the steps ? Engine turns over sounds ok. Radio needs attention as well. Thank you veey much
Friday,03,February,2023,20:48:32:19722
VCDS Version: 22.10.0.1 (x64) HEX-NET2 CB: 0.4623.4
VIN: WAUCGAFH0CN000645 License Plate: AUDI S5 2012
Mileage: 232610km-144537mi Repair Order: 2
Chassis Type: FH-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 26 2E 36 42 46 47 52 53 55
56 62 72 77
VIN: WAUCGAFH0CN000645 Mileage: 232610km-144537miles
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine (J623-CCBA) Labels:. 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
Component: 3.0T SIMOS84 H07 0003
Revision: --H07--- CVN: BC966676
Coding: 011C000A240F0128
Shop #: WSC 99999 999 83333
ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
ROD: EV_ECM30TFS0218K0907551D.rod
VCID: 32367260D4ABB13B2D6-8066
VINID: 9D19535D1598013780000184142A80733A
6203 - EVAP Emission Control Sys
P0442 00 [039] - Small Leak
Mileage: 232618 km
Date: 2010.01.22
Time: 00:07:15
Engine RPM: 1001.00 /min
Normed load value: 11.8 %
Coolant temperature: 39 °C
Intake air temperature: 14 °C
Voltage terminal 30: 14.319 V
Height correction: 1008.2617 hPa
TIA_AM_SCHA: 14.25 °C
T_PER_MES_OBD_ENVD: 0.9 s
T_PER_MES_LEAK_ENVD: 0.0 s
T_AST_ENVD: 128.50 s
TAM_CAN: 9.0 °C
6506 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [047] - -
Mileage: 232619 km
Date: 2010.12.07
Time: 04:28:07
Normed load value: 10.6 %
Coolant temperature: 99 °C
Intake air temperature: 55 °C
Voltage terminal 30: 13.507 V
Engine speed: actual: 1248 /min
MAF_ENVD: 288.69411 mg/stroke
Coolant temperature (unfiltered): 11.3 °C
Engine: operating status: IS
Engine load: 14.843750 %
Vehicle speed: actual: 0 km/h
Readiness: 1110 0101
Part No SW: 8K2 927 156 S HW: 0B5 927 156 F
Component: 0B5 30TFSINAR H10 0001
Revision: --H10--- Serial number: 0000001676 CVN: 0000D9F8
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 46DE3EB048233D9B91E-8012
10 Faults Found:
7980 - RPM Signal from ECU
P0726 00 [047] - Implausible Signal
Mileage: 232619 km
Date: 2010.12.07
Time: 04:28:08
Engine RPM: 1002 /min
Transmission input speed: 1002 /min
Engine torque: 0 Nm
ATF temperature: 84 °C
Accelerator pedal position: 0.0 %
Clutch status: Beide Kupplungen offen
8024 - Valve 2 in Transmission Part 2
P174D 00 [167] - Electrical malfunction
Mileage: 232618 km
Date: 2010.01.22
Time: 00:04:52
Engine RPM: 1342 /min
Transmission input speed: 1342 /min
Engine torque: 8 Nm
ATF temperature: 13 °C
8025 - Valve 2 in Transmission Part 1
P173F 00 [167] - Electrical malfunction
Mileage: 232618 km
Date: 2010.01.22
Time: 00:04:52
Engine torque: 8 Nm
8026 - Valve 1 in Transmission Part 2
P174C 00 [167] - Electrical malfunction
Mileage: 232618 km
Date: 2010.01.22
Time: 00:04:52
Engine torque: 8 Nm
8027 - Valve 3 in Transmission Part 1
P174B 00 [167] - Electrical malfunction
Mileage: 232618 km
Date: 2010.01.22
Time: 00:04:52
Engine torque: 8 Nm
8028 - Valve 4 in Transmission Part 2
P174F 00 [167] - Electrical malfunction
Mileage: 232618 km
Date: 2010.01.22
Time: 00:04:52
Engine torque: 8 Nm
8029 - Main Pressure Valve
P179C 00 [175] - Electrical Malfunction
Mileage: 232619 km
Date: 2010.12.07
Time: 04:28:07
Engine RPM: 998 /min
Transmission input speed: 998 /min
Engine torque: 0 Nm
8030 - Cooling Oil Valve
P179D 00 [167] - Electrical Malfunction
Mileage: 232618 km
Date: 2010.01.22
Time: 00:04:52
Engine torque: 8 Nm
8031 - Clutch Temperature Monitoring
P1740 00 [175] - -
Mileage: 232619 km
Date: 2010.12.07
Time: 04:28:08
Engine RPM: 1000 /min
Transmission input speed: 1000 /min
Engine torque: 0 Nm
8053 - Selector Lever Sensor
P179E 00 [038] - Electrical Malfunction
Mileage: 232618 km
Date: 2010.01.22
Time: 00:00:22
Engine RPM: 0 /min
Transmission input speed: 0 /min
Engine torque: -40 Nm
ATF temperature: 50 °C
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Coding: 290D18
Shop #: WSC 02391 823 56573
VCID: 0256E2A0240BC1BBFD6-8056
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 242
Mileage: 232618 km
Date: 2010.01.22
Time: 00:04:52
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0027
Hex Value: 0x238F
Hex Value: 0x00FF
Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
Component: BCM2 2.0 H05 0435
Coding: 090300
Shop #: WSC 02399 823 56573
VCID: 76BE8E7078C3ED1BC1E-8022
Subsystem 1 - Part No SW: 8T0 959 754 M HW: 8T0 959 754 M
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0811000073916012
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 2311000119323007
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 D HW: 8T0 959 760 D
Component: MEM-BFS H10 0074
Revision: AA000000 Serial number: 00000006112913
Coding: C80170250D2400001000
VCID: 44DA24B87E9F0F8B8FA-8010
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AL HW: 8T1 820 043 AL
Revision: C3000000 Serial number: 01240520111206
Coding: 6603200E
VCID: 7BA89F4443E1B073BE0-802E
Fault Status: 01101000
Reset counter: 242
Mileage: 232618 km
Date: 2010.01.22
Time: 00:00:21
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000927894
Coding: 26001091063CAF010000080000003D3D0F1C528802010161000003
VCID: 3C2A5C58066F774BF7A-8068
Subsystem 1 - Part No SW: 8F1 955 119 HW: 8K1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 200511 H07 0021
Serial number: SWF11050205302
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11471563
Coding: 02562A
Subsystem 3 - Part No SW: 8K0 941 531 BA HW: 8K0 941 531 BA
Component: E1 - LDS H03 0031
Serial number: 00000000002004111891
Reset counter: 242
Mileage: 232619 km
Date: 2010.12.07
Time: 04:28:00
02258 - Door Opener Transmitter
Reset counter: 242
Mileage: 232619 km
Date: 2010.12.07
Time: 04:28:00
Address 15: Airbags (J234) Labels:| 8F0-959-655.clb
Part No SW: 8F0 959 655 A HW: 8F0 959 655 A
Component: AirbagVW-AU10 H11 0430
Serial number: 003A5D7029NT
Coding: 303737353631303030304A55304C38463053
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaECUVWAUDI010.rod
VCID: 363E4E7038C3AD1B01E-8062
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R1100002UGS
Serial number: 6334MSME60045108/
Serial number: 6344MSME60127A7FM
Serial number: 6352QSME3C1D0272H
Serial number: 6362QSME7E2E4D54+
Serial number: 63732SME400B3D74+
Serial number: 63832SME400B3E7EA
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KEM00050
Coding: 000036
VCID: 3D2C515C1D757E43C04-8068
Component: E221 - MFL H02 0010
Part No SW: 8T0 920 983 D HW: 8T0 920 983 D
Component: KOMBIINSTR. H42 0258
Revision: 00000000 Serial number: EI130CW5C
Coding: 8B1719000300D705020000
VCID: 3FD02B5417796C53D28-806A
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G1152880B6
Coding: 00C303
VCID: 0154EDAC210DDAA3E4C-8054
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 1101ECEF170511
02078 - Media Player Position 3 (R120)
Reset counter: 242
Mileage: 232619 km
Date: 2010.12.07
Time: 04:28:12
Bin. Bits: 11111
Voltage: 13.40 V
Count: 6
Bin. Bits: 10000
Reset counter: 242
Mileage: 232618 km
Date: 2010.01.22
Time: 00:04:52
Bin. Bits: 11111
Voltage: 11.40 V
Count: 6
Text: FF33756C80A20000
Inj. Quantity: -9.18 mg/str
Address 26: Auto Roof (J256) Labels:* 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H11 0190
Coding: 030000
ASAM Dataset: EV_ElectRoofContr 001008
ROD: EV_ElectRoofContr.rod
VCID: 71B4BD6C112DCA2314C-8024
Address 2E: Media Player 3
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0074
Revision: AA000000 Serial number: 00000006112906
Coding: C81973250D2400001000
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1501
Coding: 011C43724E08332C03
VCID: 53F817E48BF19833060-8006
Revision: 00002001 Serial number: 0150901814
Coding: 010602BA00FA442080B0033200000000
014 - Defective
Fault Status: 01101110
Reset counter: 242
Mileage: 232619 km
Date: 2010.12.07
Time: 04:28:10
03233 - Controls for Garage Door Opener (E284)
Reset counter: 242
Mileage: 232619 km
Date: 2010.12.07
Time: 04:28:11
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AH HW: 8T0 035 223
Component: DSP STD H07 0230
Revision: S2200000
Coding: 0203010102
VCID: 74BAB4786EBFFF0BFFA-8020
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
Reset counter: 242
Mileage: 232618 km
Date: 2010.01.22
Time: 00:04:52
Voltage: 11.60 V
Temperature: 10.0°C
Bin. Bits: 00000001
00417 - Left Front DSP Mid-Bass Speaker (R101)
Reset counter: 242
Mileage: 232618 km
Date: 2010.01.22
Time: 00:04:52
Voltage: 11.60 V
Temperature: 10.0°C
Bin. Bits: 00000001
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
Reset counter: 242
Mileage: 232618 km
Date: 2010.01.22
Time: 00:04:52
Voltage: 11.60 V
Temperature: 10.0°C
Bin. Bits: 00000001
00418 - Front Right DSP Mid-Bass Speaker (R102)
Reset counter: 242
Mileage: 232618 km
Date: 2010.01.22
Time: 00:04:52
Voltage: 11.60 V
Temperature: 10.0°C
Bin. Bits: 00000001
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
Coding: 011C43324E08332C03
VCID: 52F612E0B4EB913B0D6-8006
00379 - Terminal 58s
Fault Status: 00101100
Reset counter: 242
Mileage: 232619 km
Date: 2010.12.07
Time: 04:28:59
Fault Status: 01101100
Reset counter: 242
Mileage: 232618 km
Date: 2010.01.22
Time: 00:04:53
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000953143
VCID: 343A74782E3FBF0B3FA-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
Coding: 0000002
VCID: 3924454C055D4263ECC-806C
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H06 0351
Revision: 00000008 Serial number: AUZ5Z6J1351292
Coding: 05020000010305004159070000
VCID: 46DE3EB048A33D9B91E-8012
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Reset counter: 242
Mileage: 232619 km
Date: 2010.12.07
Time: 04:28:06
03138 - Input AUX IN
Reset counter: 242
Mileage: 232618 km
Date: 2010.01.22
Time: 00:13:22
Part No SW: 8T0 959 795 L HW: 8T0 959 795 C
Component: TSG HL H07 1501
Coding: 010C03324008372C03
VCID: 54FA14F88EFF9F0B1FA-8000
Reset counter: 242
Mileage: 232619 km
Date: 2010.12.07
Time: 04:28:07
Component: TSG HR H07 1501
Part No SW: 8T0 862 336 F HW: 8T0 862 336 E
Component: FSE_256x BT H45 0660
Revision: 00000000 Serial number: 00000005230054
Coding: 0010300
Shop #: WSC 02335 785 00200
VCID: 3E2E56501C73655BD9E-806A
End----------(Elapsed Time: 01:39, VBatt start/end: 14.3V/14.7V)-----------
