Cannot access Measuring Blocks
Huntsman
C?ID=531355
Hi all,
I cannot access CAN Gateway 19 Measuring Blocks 08, the option is grayed out. Also the same with 61 Battery Regul. Measuring Block 08.
What is wrong?
Very frustrating as I have just watched a video of a chap doing the above.
New VCDS Hex V2 Registered.
Golf Match Edition Mk7 2016 1.0 Litre TSI 115PS 6 speed Manual 5 door
Huntsman
C?ID=531355
Thank you for the fast response.
So Advanced Measuring Values has nothing to do with Advanced Functions?
I will have a look at how to find and use Advanced Measuring Values using your link
I find it odd that I have watched a video where the chap just clicked on the grayed out (in my case) button.
Should have asked:- do I post my scan dump in my first message?
Huntsman
C?ID=531355
Ok, Just read about the Adv Meas Values; it seems a bit of a kludge, but it seems that VAG have move the goal posts on you :(
People must be making list of popular selections? is there collection the most use anywhere to get people started.
See:
I'm not upset, sigh; Just confused when I see a video of how to use a tool and then I find it does not work that way.
You have explained that. I have said I sort of understand that.
How you use the tool depends on the car & control module.
In another video I have seen the guy says the naming may not match your idea of what you are looking for!
The naming of things isn't ours, it's VAG's.
In the help docs, there is an example of how to create a list to interrogate the system and save the list. So I wondered if you or others had sample list. For the sake of an example, show all the values relevant to the charging system.
Please post an Auto-Scan so we can see how the car is equipped. I expect on an Mk.7, the CAN Gateway will be in control of the charging system, but before I can tell you exactly what to look at, I'd need to see the details of that module.
Huntsman
C?ID=531355
Hope this is correct.
VIN: WVWZZZAUZHW0
Address 01: Engine (J623-CHZD)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 AB    HW: 04C 907 309 AE
   Component: R3 1.0l TFS   H25 2993
   Revision: W1H25---    CVN: 2861C7C5
   Coding: 0119003223241D086000
   ASAM Dataset: EV_ECM10TFS01104C906026AB 002005
   ROD: EV_ECM10TFS01104C906026AB_002.rod
   VCID: 619FA9ED81C1EB1384C-8034
   VINID: 9E69EAAAA465A989C004600420C5065629
   Part No SW: 5Q0 614 517 CC    HW: 5Q0 614 517 AG
   Component: ESC           H62 0637
   Revision: 00000000    Serial number: 91566000000164
   Coding: 01FA8AA1142119724777060441CB2580512898E26082A47300200078C00203
   VCID: 74B1D0B92E336EBBFFA-8020
   Part No SW: 5G0 907 426 AK    HW: 5G0 907 426 AK
   Component: AC Manuell    H03 1601
   Revision: 00001K06
   Coding: 00120003200110001000000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004132
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Serial number: 01061615901783
   Coding: 03000846C241027B0BA44080B11C07081000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 045180797E935E3BCFA-8050
   Component: WWS    160515  042 0551
   Serial number:         160530100449
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y16M06D06H22M38S16
   Coding: 90A8DD
   Serial number: 000000000ZY161170ASY
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000065813026
   Revision: --------    Serial number: 39331616103145
   Coding: 0031051001
   VCID: 43D343653B1D9903B60-8016
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    015 0388
   Serial number: 003MLR1U6NCG
   VCID: 7F5B0F9517753DE3928-802A
   Left seat belt tensioner:
   Serial number: 34169677D07061651423
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676D08061680731
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 406 16
   Serial number: 35767000000A8A09DB14
   Subsystem 4 - Part No SW: -----------    HW: 480 000 306 16
   Serial number: 358670000008B869DB1A
   Subsystem 5 - Part No SW: -----------    HW: 480 400 306 16
   Serial number: 3516502AF205729330C4
   Subsystem 6 - Part No SW: -----------    HW: 480 400 306 16
   Serial number: 3526502AB2057292722$
   Subsystem 7 - Part No SW: -----------    HW: 480 403 105 16
   Serial number: 35565029F209EA03309E
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 05061604221052
   Coding: 0400
   VCID: 0D47A55D2DD91F73904-8058
   Part No SW: 5G1 920 940 B    HW: 5G1 920 940 B
   Component: KOMBI         202 9630
   Coding: 27A41A002380260001086A001400000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009007
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: 270BF7F5AF6555238A8-8072
   Part No SW: 5Q0 907 530 AL    HW: 5Q0 907 530 E
   Component: GW MQB Mid    127 1265
   Revision: --------    Serial number: 0004917148
   Coding: 030100043F085700FB00004C080F00010001050000000000000000000000
   GVL: 01543C0000000000400C00000000480000000000000000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7BA3FB85036D21C3BE0-802E
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29160001034040026207
   Coding: 28FFFF
   Serial number: 0497290304
   Serial number: 240516EEM17469
   Coding: 00310220D001048000001000
   Serial number: 00000000000010370909
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 0107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D75D7D3529A733984-8010
   Serial number: 080416ED723414
   Coding: 00310020DE01048000801000
   VCID: 42DD46612407900BBD6-8016
   Serial number: 00000000000010424830
   Coding: 150000
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0757
   Coding: 02730001FF00000051110101008808001F0100C601200100CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 313F19AD91A11B9354C-8064
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9SJU01T5T
   Subsystem 2 - Part No SW: 3G0 919 866 S    HW: -----------
   Component: ECE1 2016/17  --- 0635
0512 - Rear Right Bass Speaker
          B1067 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 1: Unterbrechung (DC-Diagnose)]
                    Reset counter: 99
                    Mileage: 62974 km
                    Date: 2023.02.02
                    Time: 10:36:40
                    Voltage terminal 30: 12.2 V
Thank you.
Huntsman
C?ID=531355
I've created a couple of list...
I would attach them, but I cannot see how.
You mean lists of measuring values? They're just text. Open With Notepad. Copy & paste the contents here.
Huntsman
C?ID=531355
Hmm, never thought of 'generator' I did find Alternator.
Yes, saw they were text, just wanted to upload the file.
BatteryAndAlternator-prefs.u19
IDE00019
IDE01834
IDE01836
IDE01839
IDE01841
IDE01842
IDE07681-MAS06086
IDE08794-MAS07707
ENG106123
ENG106124
ENG118437
ENG106154
StopStart-prefs.u19
IDE03011-MAS01478
IDE03011-MAS04055
IDE03011-MAS04056
IDE03011-MAS04058
IDE03011-MAS05999
IDE07473-MAS06306
IDE07616
IDE07619-IDE07621
IDE07640-MAS06344
IDE07640-MAS06345
IDE07640-MAS11065
IDE12135-MAS14367
