Vehicle Communications are f**ked MK5 Golf GTI
MrFernze
C?ID=531186
So I have a MK5 Golf GTI, with a lot of modifications. Recently I have changed to a TTRS fuel pump but I doubt that is the issue. The vehicle cranks, starts and then dies like a second after.
I am having a nightmare with this car and I have built it in the summer only for it to be standstill after about a week of use, but never occurred to have any of these errors regarding the communications.
These were the engine codes when the vehicle was in working order, with some issue regarding the alarm and rear doors not working properly.
00821 - antenna 2 for radio R93 open circuit
01334 - door control module rear right no signal/communication
01135 - interior monitoring sensors no signal
01134 - Alarm horn no signal
00931 - locking module for central locking rear rigght
00930 - locking module for central locking rear left
01314 - engine control module no signal
01333 - ecu left rear door no signal
00883 ignition switch D electrical problem in circuit intermittent
01305 - databus for infotainment no signal
01320 - climatronic ecu no sigal
05634 - power supply voltage 30 p1602 lower limit reached
05635 - inter control module failed self
Since then, it has died and I purchased a VCDS. (Scan will be below) However, I asked one of the FB groups and said it was the BCM that may be faulty, changed this and it worked for a full 2 days. I understand that it is something to do with the communications but I do not understand what, and where to go from here. If anyone could possibly help me that would be wonderful. I just want to drive my car!
Tuesday,31,January,2023,17:23:19:02823
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: WVWZZZ1KZ6W022316   License Plate:
Chassis Type: 1K-VW35 (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ6W022316   Mileage: 224950km-139777miles
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
22-AWD -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine
Address 03: ABS Brakes
   Part No SW: 5K0 907 044 HA    HW: 5K0 907 044 HA
   Component: Climatronic   H19 1414
   Revision: 00001004
   Coding: 0010004003
   VCID: 71BFD998F129AAF314C-8024
12 Faults Found:
9472881 - Motor for Fresh Air / Recirculated Air Flap
          B108B 71 [024] - Actuator Stuck
                    Reset counter: 34
                    Mileage: 224957 km
                    Time: 00:01:27
          U1111 00 [009] - -
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Reset counter: 34
                    Mileage: 224957 km
                    Time: 00:01:26
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Bremsensteuergerät - kein Signal/Kommunikation]
                    Reset counter: 34
                    Mileage: 224957 km
                    Time: 00:01:26
13701424 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Bordnetz - kein Signal/Kommunikation]
                    Reset counter: 34
                    Mileage: 224957 km
                    Time: 00:01:26
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Reset counter: 34
                    Mileage: 224957 km
                    Time: 00:01:26
13701520 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Türsteuergerät hinten links - kein Signal/Kommunikation]
                    Reset counter: 34
                    Mileage: 224957 km
                    Time: 00:01:26
13701536 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Türsteuergerät hinten rechts - kein Signal/Kommunikation]
                    Reset counter: 34
                    Mileage: 224957 km
                    Time: 00:01:26
9481748 - High Pressure Sensor
          B10AE 14 [009] - Open or Short to Ground
                    Reset counter: 34
                    Mileage: 224957 km
                    Time: 00:01:26
9496597 - Sunlight Photo Sensor
          B10E8 15 [009] - Open or Short to Plus
                    Reset counter: 34
                    Mileage: 224957 km
                    Time: 00:01:26
9496613 - Sunlight Photo Sensor
                    Reset counter: 34
                    Mileage: 224957 km
                    Time: 00:01:26
9479189 - Signal Line for Air Quality Sensor
          B10A4 15 [008] - Open or Short to Plus
                    Reset counter: 74
                    Mileage: 224957 km
                    Time: 00:01:26
13701600 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Airbagsteuergerät - kein Signal/Kommunikation --> Fehlende Botschaft [ID] von Airbagsteuergerät]
                    Reset counter: 34
                    Mileage: 224957 km
                    Time: 00:01:26
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000001996961
   Coding: E78D8F2700041800001400001400000000087F075C
   Shop #: WSC 12345 785 00200
   VCID: 2B030BF01F0580236E0-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00207646
   Shop #: WSC 12345
10 Faults Found:
                    Fault Status: 00101100
                    Fault Frequency: 40
                    Reset counter: 74
                    Mileage: 171207 km
                    Voltage: 10.60 V
02498 - Left Low Beam Reflector Motor (V294)
                    Fault Status: 01111100
                    Reset counter: 34
                    Mileage: 150486 km
                    Voltage: 13.75 V
02499 - Right Low Beam Reflector Motor (V295)
                    Reset counter: 34
                    Mileage: 150486 km
                    Voltage: 13.75 V
01495 - Bulb for High-Beams; Left (M30)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 34
                    Mileage: 224957 km
                    Voltage: 12.15 V
                    Reset counter: 34
                    Mileage: 224957 km
                    Voltage: 12.15 V
                    Reset counter: 34
                    Mileage: 224957 km
                    Voltage: 12.35 V
                    Reset counter: 34
                    Mileage: 224957 km
                    Voltage: 12.35 V
                    Reset counter: 34
                    Mileage: 224957 km
                    Voltage: 12.25 V
                    Reset counter: 34
                    Mileage: 224957 km
                    Voltage: 12.25 V
00975 - Heated Rear Window (Z1)
                    Reset counter: 34
                    Mileage: 151744 km
                    Voltage: 13.35 V
Address 15: Airbags
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           634 0070
   Coding: 0012112
   Shop #: WSC 01279 785 00200
   VCID: 77ABE78093CDF4C3DA8-8022
   Component: E0221           007 0050
00002 - Transmission Control Unit
   Part No: 1K6 920 962
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0003403
   Shop #: WSC 00011 067 57207
   VCID: 6E85C2E4EC97B50B09E-803A
7 Faults Found:
00438 - Fuel Supply Sensor 2 (G169)
            015 - Cannot Be Tested at this Time
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0231
   Revision:   H16       Serial number: 4320K09A2501A2
   Coding: E9837F06000202002103
   Shop #: WSC 06314 000 00000
   VCID: 698FB1F8D57952335CC-803C
                    Reset counter: 34
                    Mileage: 224957 km
                    Reset counter: 34
                    Mileage: 224957 km
                    Reset counter: 74
                    Mileage: 224957 km
01304 - Radio
                    Reset counter: 74
                    Mileage: 224957 km
01312 - Powertrain Data Bus
                    Reset counter: 34
                    Mileage: 224957 km
Address 22: AWD
   Component: IMMO            VDD 1012
   Component: Tuer-SG         005 0972
   Coding: 0000692
   VCID: 382924BCDE533BBB132-806C
Address 44: Steering Assist
   Part No: 1K0 959 433 AK
   Coding: 01C802087F2D8405485FC69010CC
   Shop #: WSC 00000 785 00200
   VCID: 79AFE1B8A5D9E2B3ACC-802C
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
00323 - Vehicle Inclination Sensor (G384)
            013 - Check DTC Memory
   Coding: 0000692
   VCID: 392F21B8E55922B3ECC-806C
Address 55: Headlight Range
   Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
   Component: Radio RCD310  042 0082
   Revision: 01000001    Serial number: VWZ1Z2M4102409
   Coding: 01000400020001
   Shop #: WSC 31414 790 31414
   VCID: 33331390CB35D8E3260-8066
00625 - Vehicle Speed Signal
                    Reset counter: 34
                    Mileage: 224957 km
                    Time: 00:01:47
                    Reset counter: 34
                    Mileage: 224957 km
                    Time: 00:01:44
Address 62: Door, Rear Left
Address 72: Door, Rear Right
End----------(Elapsed Time: 00:50, VBatt start/end: 12.2V/12.2V)-----------
Hi and welcome.
Gateway complains about two different CAN buses. I'm not usually quick to fire the parts cannon, but if this were mine, I think I'd try swapping out the GW. They're pretty common/cheap.
MrFernze
C?ID=531186
Hi and welcome.
Hello Uwe, thank you for the reply.
I have just changed the original CAN gateway to 1K0 907 530 AD very recently, I should have included that into the main text of this post. Unless there is another that I am missing.
Regards,
Ryan
  • Informative
MrFernze
C?ID=531186
Is there any possibilities to check individual modules to check each are working with VCDS to take a closer look or what to look for when diagnosing which it could be? Bit of a newbie, but willing to learn!
Well, if the Gateway isn't the problem then I think you're going to need to attack this with a wiring diagram and a meter. Check power on the modules that "Cannot be reached". Check continuity of the CAN bus pair between those modules and the GW.
NZDubNurd
New Zealand
C?ID=230482
Your gateway isn't coded right... unless you really have 4WD. Check the other settings in there too.
Check the coding on that, and try unplugging the ABS module and then see if anything else comes back online.
I'm assuming the ECU has power, as the car starts, but stops because of no comms with the immo in the cluster.
When you say TTRS fuel pump, you mean the in-tank pump, run from the KM5 module?
And nothing else that coincided with the "sudden" failure to run?
MrFernze
C?ID=531186
Gateway coding may be something I'll have a look into. I thought it was weird that I have 4WD randomly. But I'll check the coding and unplug the ABS module when I have some time off tomorrow hopefully.
Your assumption for the ECU is correct, it starts but stops due to lack of comms.
The TTRS fuel pump is this one TTRS Fuel Pump, I had spoken to R-Tech performance and they previously said it was a straight swap, no need for coding or remap. I'll change this back to the standard fuel pump and reinstall the TTRS one later when I get my car sorted and ready for a remap.
My other worry was a mk6 climate control install, even though it has been installed correctly, I think the communicational error with the CAN gateway may be stopping it.
MrFernze
C?ID=531186
I'll have a look at the wiring diagram and use a meter to check everything.
MrFernze
C?ID=531186
Just to be thorough, is that on the ABS control module or the sensors on the hub centers. I'll first try the module, if nothing comes up, ill try diagnosing if any of the sensors are broken on the hubs. I've seen that the ABS control module is a common failure. I'll keep in the forum post if I find a fix.
NZDubNurd
New Zealand
C?ID=230482
Yeah, the module, as Dave clarified. In case it's taking out the CAN comms.
It might pay to look for signs of Rodents too, as you investigate things... just in case.
MrFernze
C?ID=531186
The module - the intent is to determine whether the ABS module is blocking the Powertrain CAN bus.
Thank you, ill try that tomorrow and keep this updated.
MrFernze
C?ID=531186
So I unplugged the ABS, and it didn't help at all. I was hoping that it was that due to so many suggestions. However, I moved my ECU around a little and tried starting the car. It didn't start but the fan went :ROFLMAO: "Hello bish, the car is hot af". So I unplugged the battery and moved the ECU again, it started but failed to communicate with other modules etc. So it's defiantly going to be a wire issue by the looks of things. So hopefully when I get some time away from Uni, that'll be perfect but I'm on my last year and my dissertation is due in soon. However, I will definitely keep this area updated!
EuroX
Northern NJ USA
C?ID=208579
Fans normally come on when the FCM looses comms with the ECU. Or sees a ECU thats not adapted to the vehicle. I would check Can communication via MVB or IDE channels see what its doing. I would also take a close look a J519 as they were notorious for failing in those vehicles however Checking fuses would be my first step and Verifying none of those modules are on the same circuit or on the cams can bus branch. If so dirty overlay and go from there.
I agree, sounds like a broken wire(s) ; reminds me of this video:
note: time ~1:50
MrFernze
C?ID=531186
I recently changed the engine from AXX to CDL just before winter in the UK, so it couldn't have been there unless it would have been hiding in the engine lmao
I'm going to download the wiring diagram and check all the connections again.
MrFernze
C?ID=531186
It may be this, but I'll need to test it out another day. University is killing most of my time but it's a start. Only just noticed this, as I'm pretty sure the wire harness is wrapped in plastic electrical tape rather than the standard cloth type. Unless its normally like that, not entirely sure.
MrFernze
C?ID=531186
She runs! So I believe that the J500 is faulty, does anyone have any more information regarding the continuation of a fix. Disconnected the power steering wire seen in the video, I believe that is the reason for the powertrain having communication issues. I still had the ABS module unplugged but I will plug this in tomorrow and rescan it. It starts every time now, but I want to be 100% before I drive it anywhere.
Sunday,05,March,2023,19:15:49:02823
VCDS Version: 23.3.0.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: WVWZZZ1KZ6W022316   License Plate: GK55OXD
Mileage: 224950km-139777mi   Repair Order:
Chassis Type: 1K (1K0)
   Part No SW: 1K0 907 115 A    HW: 1K0 907 115 A
   Component: 2.0l R4/4V TFSI  00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2321880
   Coding: 040300031C070060
   VCID: 2411E0CC72DB4F5A4BB-8070
   VINID: 9E69EAAAA05BA869C00820C11898CAA7C1
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage
                    Mileage: 224927 km
                    Time: 00:40:56
                    Temperature: 60.0°C
                    Temperature: 35.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.954 V
005635 - Internal Control Module
               P1603 - 004 - Failed Self-Test - Intermittent
                    Temperature: 60.0°C
                    Temperature: 35.0°C
                    Voltage: 12.827 V
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
008214 - Intake Manifold Flap Position Sensor (Bank 1)
               P2016 - 002 - Short to Ground
                    Fault Status: 01100010
                    Temperature: 60.0°C
                    Temperature: 35.0°C
                    Voltage: 12.954 V
012691 - Intake Manifold Runner Control
               P3193 - 002 - Open Stop outside of Valid Range
                    Temperature: 60.0°C
                    Temperature: 35.0°C
                    Voltage: 12.954 V
049441 - No Communication with ABS Brake Control Module
               U0121 - 008 -
                    Fault Status: 01101000
                    Temperature: 60.0°C
                    Temperature: 35.0°C
                    Voltage: 12.954 V
Readiness: 0110 0100
   Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
   Component: GSG DSG         070 1111
   Revision: 04507000    Serial number: 00000601111214
   VCID: 1471B00CA27B3FDABBB-8040
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller
                    Fault Frequency: 255
                    Mileage: 224957 km
   Revision: 00H37000    Serial number: 00000001950675
   Coding: E58D0F2700041800001400001400000000087F075C
   VCID: 2B030BF01F0580228A1-807E
   Coding: 00065493
   Shop #: WSC 01279
   Coding: 00207646
   Shop #: WSC 01279
7 Faults Found:
00984 - Left Tail Light (M4)
                    Reset counter: 39
                    Mileage: 224957 km
                    Voltage: 12.90 V
                    Reset counter: 39
                    Mileage: 224957 km
                    Voltage: 12.90 V
                    Reset counter: 39
                    Mileage: 224957 km
                    Voltage: 12.90 V
                    Reset counter: 39
                    Mileage: 224957 km
                    Voltage: 12.85 V
                    Reset counter: 39
                    Mileage: 224957 km
                    Voltage: 12.85 V
                    Reset counter: 39
                    Mileage: 224957 km
                    Voltage: 12.90 V
                    Reset counter: 39
                    Mileage: 224957 km
                    Voltage: 12.90 V
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 2F AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0G7CH4
   Coding: 0012870
   VCID: 372B2780D34D34C2FE9-8062
   Subsystem 1 - Serial number: 6332MSME0F3C7A41N
   Subsystem 2 - Serial number: 6342MSME12106670
   Subsystem 3 - Serial number: 6351HSME075C47709
   Subsystem 4 - Serial number: 6361HSME075E4C0FP
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
   Coding: 0012112
   VCID: 77ABE78093CDF4C23E9-8022
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001056200B15
   Coding: 3F3F0340070003
   VCID: 2A0D0EF410FF992A717-807E
                    Reset counter: 39
                    Mileage: 224957 km
                    Time: 00:51:09
                    Reset counter: 39
                    Mileage: 224957 km
                    Time: 00:51:09
                    Reset counter: 39
                    Mileage: 224957 km
                    Time: 00:51:09
                    Reset counter: 39
                    Mileage: 224957 km
                    Time: 00:51:10
                    Reset counter: 39
                    Mileage: 224957 km
                    Time: 00:51:10
   VCID: 6E85C2E4EC97B50AEDF-803A
   Coding: 0000692
   VCID: 382924BCDE533BBAF73-806C
   VCID: 79AFE1B8A5D9E2B248D-802C
   Coding: 0000692
   VCID: 392F21B8E55922B208D-806C
   VCID: 33331390CB35D8E2C21-8066
                    Reset counter: 39
                    Mileage: 224957 km
                    Time: 00:51:31
                    Reset counter: 39
                    Mileage: 224957 km
                    Time: 00:51:27
End----------(Elapsed Time: 00:51, VBatt start/end: 12.9V/12.9V)-----------
MrFernze
C?ID=531186
I had a little break from university course work to reconnect the ABS control module and test if the car would start again which it did thankfully. So I printed off a wiring diagram for the power steering control module and investigated the resistance for CAN HI/LOW. Unfortunately the resistance shows that the control module is fuck*d (video of resistance, nothing exciting) , thankfully I am planning to do a anti-roll bar performance upgrade soon. Am I correct in answering if I were to get the Gen 3 steering rack and loom. I would be able to code it in quite easily?
