Hi all!
Bahnstormer
C?ID=531517
Hi everyone, received my VCDS package at the weekend and have finally put it to use!
So, today I noticed that the DRL/sidelights on my 2012 Caddy van were behaving strangely (to me, at least).
When the light switch is off (engine running) the DRL's are on. When the switch is moved to the next position, the DRL's dim. All normal so far. However, when I move the switch to the final position, the main (H4) lights come on and the
DRL/sidelights switch off completely. It makes no difference whether the main lights are dipped or not. I've had the van since October last year, but I've never actually looked at the lights before - perhaps this is normal for VW?
I ran an autoscan and got the following. I noticed the DTC on the CAN gateway, although some (quick) Googling has suggested that the installation list could be wrong (note the second DTC for the Radio - my van doesn't have a VW head unit installed).
Any advice is greatly appreciated!
P.S, hope this is in the right place!
Wednesday,01,February,2023,17:43:05:36136
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: WV1ZZZ2KZDX032455   License Plate:
Mileage: 256790km-159561mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZDX032455   Mileage: 256790km-159561miles
56-Radio -- Status: Not registered 0011
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 TF    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9979
   Revision: --H43---    Serial number: 00000000000000 CVN: EF964091
   Coding: 00114014032500080000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM16TDI02103L906023TF 003003
   ROD: EV_ECM16TDI02103L997557L.rod
   VCID: 7DA7F587ED79BC63804-8028
   VINID: 9E606AAAA09BA94A000C210514CE927B2E
   Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
   Revision: 00H31001
   Coding: 633C400D092503FCC60F02E9901EC081300000
   VCID: 7CA1F883F6E3B56BB7A-8028
   Part No SW: 7N0 907 426 BN    HW: 7N0 907 426 BN
   Component: AC Manuell    H20 0505
   Revision: 00001018
   Coding: 0010004002
   Shop #: WSC 35110 790 50316
   VCID: 015F89779181D883E4C-8054
   Part No SW: 5K0 937 085 R    HW: 5K0 937 085 R
   Component: BCM PQ35 B+   021 0068
   Revision: BB021001
   Coding: 5F1A583A8037F12B08800082800000640381728852028020648000110040
   VCID: 42DD467BD487039BBD6-8016
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 24071  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 7N0 951 171 A
   Component: DWA-Sensor 00  002 0206
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 L    HW: 1K0 919 475 L
   Component: PARKHILFE     006 1806
   Revision: 00006000    Serial number: 0 263 004 450
   Coding: 108001
   Shop #: WSC 35110 377 00146
   VCID: 3B233B9FB36D7253FE0-806E
   Component: VW10Airbag02A H07 0013
   Revision: --------    Serial number: 003HL00D5CG1
   Coding: 000000000000000000000000000000003241
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 35372DA795C9A423084-8060
   Part No SW: 1K5 953 507 T    HW: 5K0 953 549 B
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90440MCJ0011F
   Coding: 008A140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 42DD467BD407039BBD6-8016
   Subsystem 1 - Part No SW: 3C8 959 537 B    HW: 3C8 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP  H4ÿ 0021
   Serial number: 00000000000000126985
   Coding: E20000
   Part No SW: 2K0 920 965 G    HW: 2K0 920 965 G
   Component: KOMBI         H05 0705
   Coding: 480A00
   VCID: 333313BF9BBDBA13260-8066
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 190712F1001594
   Coding: 357401
   VCID: 3FDB4F8FA7756E73D28-806A
                    Mileage: 256792 km
                    Date: 2017.06.24
                    Time: 17:37:28
   Component: IMMO          H05 0705
   VCID: 6A8DCEDB8CF73BDB556-803E
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 03 0174
   Coding: 0000000
   VCID: 76B5EAABC4CFEF3BC1E-8022
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 140    3305
   Revision: 00H22000
   VCID: 372B27AF834556331A8-8062
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Coding: 0000000
   VCID: 75B7EDA7D9C9E423C84-8020
Address 56: Radio
End----(Elapsed Time: 01:00, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Hi and welcome.
Yes, if you have an aftermarket head unit, you'll never get things completely free of faults.
As for the behavior of your lights, I can't say. We don't get Caddy vans here, and our lighting standards are rather different as well. Hopefully someone from the UK will chime in.
Zenerdiode
Newcastle, England
C?ID=24330
Go into Address 19: CAN Gateway > Installation List > then uncheck 56 - Radio. Save etc. The CAN Gateway is the only module complaining, so this should allow you to clear the fault code.
Are your DRLs filament lamps? If so, I think this is desired behaviour.
"Not Registered" means it's already not checked. If that gets reversed (checked), then there will be one or more "Can't be reached" faults. Like I said, there's no way to get things completely happy with an aftermarket head unit. The Gateway knows there's something there, but that something doesn't behave like a factory radio.
Bahnstormer
C?ID=531517
Thanks for the advice guys, much appreciated! I checked the installation list today and it is indeed already unchecked, clearly the previous owner was trying to clear all the DTC's too :).
I also spent the drive home from work looking for other Caddy vans coming the other way, so I could check their lights. They were all displaying the same behaviour as mine, so I'd say Zenerdiode is correct!
