Injector help
mattft86
C?ID=525197
Hi again all, Could anyone point me in the right direction please.
I cannot find the injectors in the engine control under adaptations, i'm thinking of putting bigger injectors in but i need to adjust how much fuel is injected.
Friday,30,December,2022,18:22:25:01631
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: TMBBE7NE9J0284947   License Plate:
Mileage: 77464km-48133mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 4B 52 5F A5 A9 D6 D7
VIN: TMBBE7NE9J0284947   Mileage: 77464km-48133miles
Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 P    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: D35B8655
   Coding: 0C1900122424010B0000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM20TFS0205G0906259P 001001
   ROD: EV_ECM20TFS0205G0906259P.rod
   VCID: 3B233A5D43E5C523FE0-806E
   VINID: 91D49254779525A0022042441CD661CF04
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 CS    HW: 5Q0 614 517 AF
   Component: ESC           H62 0973
   Revision: 00000000    Serial number: 60418000001167
   Coding: 24079391542821704080060440CA2924C92A8402600294762043F070C005430B00000012121212B835351919323200
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
   ROD: EV_Brake1UDSContiMK100ESP_037.rod
   VCID: 045181A17E9B7ADBCFA-8050
   Part No SW: 5E0 907 044 AP    HW: 5E0 907 044 AP
   Component: Climatronic   H04 2002
   Revision: 00001K00
   Coding: 0111000400011001100500460010102A
   ASAM Dataset: EV_ACClimaBHBVW37X 006147
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 73B3D27D2B354D63E60-8026
   Air quality sensor:
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001803900033
   Shop #: WSC 73430 790 00000
   ROD: EV_BCMBOSCH_018.rod
   VCID: 094F909559B927B3BCC-805C
   Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 180120  051 0915
   Serial number: 887253F0401802000027
   Coding: 164DDD
   Component: RLHS  047 0105
   Serial number: TBY18M02D16H20M46S16
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY173132X07
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223973542629
   Part No SW: 5QA 919 283 B    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0044
   Serial number: 000308419618039
   Coding: 0601050001
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_EPHVA14AU3700000 009033
   ROD: EV_EPHVA14AU3700000_009_AU37.rod
   VCID: 49CF5095193967B37CC-801C
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W4P1DWN15
   Coding: 98CCC000000000005C5400CC008800000065
   VCID: 05579CA575A143D3D84-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 000 502 18
   Serial number: 3570000000080D84FB2X
   Subsystem 2 - Part No SW: -----------    HW: 454 000 402 18
   Serial number: 358000000001BA186C2O
   Subsystem 3 - Part No SW: -----------    HW: 454 800 102 18
   Serial number: 351009AEB5613000000P
   Subsystem 4 - Part No SW: -----------    HW: 454 803 101 18
   Serial number: 352005FC06513000000E
   Subsystem 5 - Part No SW: -----------    HW: 454 802 101 18
   Serial number: 35500AF851C13000000P
   Part No SW: 5Q0 953 507 GD    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 17021804400858
   Coding: 1400
   VCID: 7EA5F3491077100B99E-802A
   Part No SW: 5E0 920 956 E    HW: 5E0 920 956 E
   Component: KOMBI         303 0310
   Coding: 27AD010069848600010A6B021001000000000000
   VCID: 2E0503098097208B49E-807A
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007427193
   Coding: 030100047F085900FB00026B080F00010001070000000000000000000000
   GVL: 01563C1000000000408C00000000480000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   VCID: 3829255172D3EE3B132-806C
   Generator:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Serial number: 000000000A2892090218
   Serial number: 758860000018021525FE
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Serial number: 0000304536789
   Coding: 001C00208001040000001100
   VCID: 45D75CA5352183D3984-8010
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Serial number: 00000000000019301939
   Coding: 1D0200
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 91170000
   ROD: EV_SteerAssisMQB_015.rod
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 10021810802742
   Coding: 000000070100046E00003D01010000000000000000000000000000000000
   VCID: 72BDD779542F446BED6-8026
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Serial number: 0000304027152
   VCID: 44D141A13E1BBADB8FA-8010
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Serial number: 00000000000019346783
   Coding: 050200
   Part No SW: 5Q0 035 874 C    HW: 5Q0 035 874 C
   Component: MU-S-ND-ER    H41 0480
   Serial number: SKZAZ2U0432698
   Coding: 03735101FF00000041111201008800002F0209C601200500CF
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 343111616EBB0A5B3FA-8060
   Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: SKZ6ZHV0482961
   Subsystem 2 - Part No SW: V03 959 820 F    HW: -----------
   Component: ECE1 2023  --- 1910
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 1272
   Serial number: 09011841K11269
   Coding: 0203070100000401000213408150A80094000E200020
   VCID: 0849959142B35EBBA32-805C
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 180120204166
   VCID: 698FB01579F987B35CC-803C
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   ROD: EV_LEDPLUSRightKEBODVW416.rod
End----------(Elapsed Time: 01:29, VBatt start/end: 12.2V/12.1V)-----------
The only way to do that is via re-mapping.
mattft86
C?ID=525197
Gremling
Norway, Nordland
C?ID=319714
Re-map as Uwe said, adaptations is used, as far as I understand, for telling ECU status of injectors («new» installed or installing brand new ones). In newer cars (started in 2005 I think) these data is used for ECU to compensate for injector wear, and with some tools one can do an adaptation if ECU has compensatet to much/little.
Using this function after installing bigger injections will not do it, ad there are so many orher parameters used for calculating fuel injection time and amount.
Also, have you checked if you need new/different air filter(air supply system to engine) a different fuel pump, pressure regulator?
If not already done, not explained in case, I recon there is a quite hp rise you are targeting, sinse a «normal» re-map and maybe a bigger turbo has not been evaluated (or is this done once already?). Normally std injectors easily can take a 10-15% increase, maybe even more.
Changing intercooler can easily give you 2-5+ % increas in power.
A cool/funny and fancy mod of installing water spray system in front of intercooler will also help, although short term term as water supply and weight can remove benefit😂🤣.
Regards
Gremling
That's on CR diesels, not gasoline/petrol engines, which this is.
Gremling
Norway, Nordland
C?ID=319714
Know, he copyed text prior to me specifying/updating text. He should do it again
