I have fitted a new OEM Swivelling Towbar to a 2022 Tiguan R but the release switch is not functioning, no power going to it, I have confirmed power going to the Trailer module and there are no fault codes being returned.
I reckon I am missing something in the coding.
I have a copy of a scan from another Tiguan owned by a family member which has the same OEM towbar but was retro-fitted by VW and coded with ODIS, this has allowed me to confirm a lot of the coding but I think there is still something I am missing?
This is what I have coded so far:
Scan from my car, ignore TPMS error - winter wheels are on with no sensors in yet
19 -Can Gateway | Install List | Enable 69-Trailer | |
09 -Central Elect | Adaptions | ENG122979-ENG141968 -- Networking - Anhaengeranschlussgeraet (set to installed) | |
01 -Engine | Long Code | Byte 5 - Bit 4 | Long Code string change confirmed by Dana (Ross-Tech) |
03 -ABS Brakes | Adaptions | Vehicle & Trailer Stabilisation to Activated | |
10 -Park /Steer Assist | Long Code | Byte 3 - Bit 1 = 01 Trailer Hitch Installed (manually operable) | Matches what was set by ODIS on another Tiguan |
13 -Auto dist reg | Long Code | Byte 3 - Bit 3 (control module for towing sensor) | Matches what was set by ODIS on another Tiguan |
69 -Trailer | Long Code | Byte 1 - Bit 0-7 = Country Code - set to ROW Byte 6 - Bit 0-2 = Set to 03 PlatformCoding, MQB | Matches what was set by ODIS on another Tiguan |
A5 -Frnt Sens.Drv.Assist | Long Code | Byte 5 - Bit 4 (AAG) | Matches what was set by ODIS on another Tiguan |
6D -Trunk Elect | Long Code | Byte 1 - Bit 7 (Trailer installed) | Matches what was set by ODIS on another Tiguan |
6C -Back up Cam | Long Code | Byte 4 - Bit 0 (equipment_ahk, installed) | |
3C -Lane Change Assist | Long Code | Byte 0 - Bit 4-5 = 20 ECU for draw bar, with ECU for draw bar" | Matches what was set by ODIS on another Tiguan |
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 2B 3C 42 44 47 4B 52 5F
65 69 6C 6D 75 A5 A9 D6 D7 8126 8127
VIN: WVGZZZ5NZNWxxxxxx Mileage: 8736km-5428miles
8126-Trq distrib RearL axle -- Status: OK 0000
8127-Trq distrib RearR axle -- Status: OK 0000
Address 01: Engine (J623-DNFG) Labels: None
Part No SW: 5NA 906 259 F HW: 06K 907 425 M
Component: R4 2.0l TFS H80 0002
CVN: B0713AA2
Coding: 092540322476050B30040000000000000000000000000000
ASAM Dataset: EV_ECM20TFS0205NA906259F 001004
ROD: EV_ECM20TFS020_VW37.rod
VCID: 49CF5B59993D36437CC-801C
VINID: 9E65EAAAA15EA9E9C50841082401514841
Readiness: 1110 0001
Part No SW: 0DL 300 014 C HW: 0GC 927 711 H
Component: GSG DQ500 H06 3703
Revision: 00H06V13 CVN: 23A43B29
ROD: EV_TCMDQ500021_001_VW36.rod
VCID: 2B0301D1338104536E0-807E
Part No SW: 5Q0 614 517 GS HW: 5Q0 614 517 BP
Component: ESC H35 0993
Revision: 00000000 Serial number: 63481000000351
Coding: 0AEE939AD0222370477B070862CC6950C90BC4E2E04696733842558852A8490800402844131A13114335351919323200
ASAM Dataset: EV_Brake1UDSContiMK100VWR 001005
ROD: EV_Brake1UDSContiMK100VWR.rod
VCID: 08499E5DC2B70F4BA32-805C
Part No SW: 3Q0 959 435 Q HW: 3Q0 959 435 Q
Component: VWKESSYMQB 037 1400
Revision: 00037000 Serial number: 0591328906
Coding: 132C2C0723
ASAM Dataset: EV_KessyHellaMQBAB 004055
ROD: EV_KessyHellaMQBAB.rod
VCID: 48C95E5D8237CF4B632-801C
Subsystem 1 - Part No SW: 3G0 962 243 D HW: 3G0 962 243 D
Component: GEB.F.Heckoef H17 0908
Serial number: 39198936
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NA 907 044 AJ HW: 5NA 907 044 AJ
Component: AC Automat H50 1301
Revision: 20K03000 Serial number: 00000A00344138
Coding: 06120104200114011105100C0050D436
ASAM Dataset: EV_ACTouchPrehVW37X 001010
ROD: EV_ACTouchPrehVW37X_VW37.rod
VCID: 074B9D61CFA90033AA8-8052
Air quality sensor:
Subsystem 1 - Part No SW: 5Q0 907 659 E HW: 5Q0 907 659 E
Component: G238 _AQS H32 0120
Serial number: 117996789
Rear air conditioning block 1:
Subsystem 2 - Part No SW: 11A 907 049 HW: 11A 907 049
Component: E265 KPH H02 0183
Serial number: G04S05.01.2200970972
Coding: FFFFFF
Part No SW: 5Q0 937 084 EC HW: 5Q0 937 084 EC
Component: BCM MQBAB H H44 0511
Serial number: 01102135401712
ASAM Dataset: EV_BCMMQB 022001
ROD: EV_BCMBOSCH_022_VW27.rod
VCID: 7DA7FF899D755AE3804-8028
Wiper motor control module:
Subsystem 1 - Part No SW: 5NC 955 119 B HW: 5NC 955 119 A Labels: 1KX-955-119.CLB
Component: 326 RL 141021 034 0373
Serial number: 00000002110110302852
Subsystem 2 - Part No SW: 81D 955 555 A HW: 81D 955 555
Component: G397_RLFSS H06 0004
Serial number: 40386553X81D955555A0
Coding: 0000DE
Subsystem 3 - Part No SW: 5Q0 951 172 A HW: 5Q0 951 172 B
Component: Sensor, DWA 005 0403
Serial number: 000000000ZL22045X8BB
Subsystem 4 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000001972843
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 521 KS HW: 5Q1 953 569 K
Component: Lenks.Modul H24 0190
Serial number: 0100160220220C201466
Part No SW: 3Q0 919 298 F HW: 3Q0 919 298
Component: PLA 3.0 12K H09 0055
Serial number: 000601229448092
Coding: 0331567951
ASAM Dataset: EV_EPHBO2CVW3260000 010019
ROD: EV_EPHBO2CVW3260000_VW37.rod
VCID: 40D9467DAA07F70BAB2-8014
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 AA HW: 2Q0 907 572 D
Component: ACCCONTIMQB H09 0396
Coding: 32055FDB5CFF8728749F812481408780000000000000000024
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 73B3D9B1AB311C93E60-8026
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 03022241350043
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 38292E9DF2D7BFCB132-806C
Part No SW: 5Q0 959 655 CG HW: 5Q0 959 655 CG
Component: AirbagVW21 010 0421
Serial number: 003J9R82435.
Coding: 98CCC0C0000000005C5400CF00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1062
Serial number: 5NC857705D0050W00718
Coding: 802006
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1062
Serial number: 5NC857706D0054W00336
Coding: 802006
Subsystem 3 - Part No SW: ----------- HW: 480 002 801 22
Serial number: 35700000000DAA586D5%
Subsystem 4 - Part No SW: ----------- HW: 480 002 801 22
Serial number: 35800000000657D8695W
Subsystem 5 - Part No SW: ----------- HW: 480 400 302 22
Component: SideSensor_Dr 003 6149
Serial number: 3510001BD07487D416FD
Subsystem 6 - Part No SW: ----------- HW: 480 400 302 22
Component: SideSensor_Pr 005 6149
Serial number: 35200019EC739A2533BD
Subsystem 7 - Part No SW: ----------- HW: 480 401 802 22
Component: FrontSensor_D 005 6149
Serial number: 3550001A8C79AA63928M
Part No SW: 3G0 920 320 C HW: 3G0 920 320 C
Component: KOMBI 524 6170
Coding: 20AC2098FE8C06000188724F1001000800601106
ASAM Dataset: EV_DashBoardVDDMQBA0 001046
ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
VCID: 1D67DF097D35FAE3E04-8048
Part No SW: 3Q0 907 530 AL HW: 3Q0 907 530 E
Component: GW MQB High 524 5463
Serial number: 26012210801054
Coding: 0B0D00047F085B00FB17AAFE9A0F00010001070000000000000000000000
GVL: 014E3C1008000600C0CC80008082CC0000000000000200000030000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 79AFEB99895D66C3ACC-802C
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 1EA 959 442 F HW: 1EA 959 442 F
Component: MFL H03 0219
Serial number: 17038315080142202925
Coding: 2F2B00
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Component: J367-BDMHella H11 9070
Serial number: 6621078805
Inverter for electrical outlet:
Subsystem 4 - Part No SW: 5Q0 907 155 F HW: 5Q0 907 155 F
Component: U13DCAC H27 0810
Serial number: 6174195
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H07 0020
Serial number: 22000013135010
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 333319B1EBB15C93260-8066
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H07 0150
Serial number: 00000591798368
Coding: A2A54640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
VCID: 392F2B99C9DDA6C3ECC-806C
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H07 0150
Serial number: 00000591778923
Part No SW: 5Q4 959 593 P HW: 5Q4 959 593 P
Component: TSG FS 011 0912
Serial number: 0000460463250
Coding: 003D1A20D001048000001000
VCID: 52FD7C35746B759B0D6-8006
Subsystem 1 - Part No SW: 5Q0 959 408 E HW: 5Q0 959 164 C
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000056638541
Coding: 2D0000
Part No SW: 5QF 909 144 B HW: 5QF 909 144 A
Component: EPS_MQB_ZFLS 507 5582
Coding: 931F0000
ROD: EV_SteerAssisMQB_015.rod
Part No SW: 3G0 035 466 D HW: 3G0 035 466 D
Component: AMPeth16C H03 3831
Serial number: A1130J00052181
Coding: 24040000000000000000000000000000000000000000000000
ASAM Dataset: EV_AMPEthMQB 001005
ROD: EV_AMPEthMQB_VW27.rod
VCID: 2615F0E52863393BB1E-8072
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 G HW: 3Q0 907 338 K
Component: FCM MQB Low 005 0382
Serial number: 23022211601358
Coding: 00000007090010D607102F100A0000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 004006
ROD: EV_MultiModulContiVW48X_004_VW37.rod
Part No SW: 5Q4 959 592 P HW: 5Q4 959 592 P
Component: TSG BFS 011 0912
Serial number: 0000460727279
Coding: 003D1020DC01048000001000
VCID: 51FF7339716D0E8334C-8004
Subsystem 1 - Part No SW: 5Q0 959 407 E HW: 5Q0 959 163 C
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000056614356
Coding: 250000
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 3G5 035 820 H HW: 3G5 035 820 H
Component: MU-O-ND-EU H22 0306
Serial number: VWZAZ2A0366131
Coding: 23260008000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001001
ROD: EV_MUOIMQB_001_VW27.rod
VCID: 290FFBD9397D16439CC-807C
Subsystem 1 - Part No SW: 5NN 919 605 B HW: 5NN 919 605 B
Component: ABT_Std-2_Nav 381 8304
Serial number: VWZ6ZHA0580208
Data carrier:
Subsystem 2 - Part No: V03 959 809 TP
Component: EUR 2022 6053
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H06 0011
Serial number: 30000000623709
ROD: EV_RDKBERU30_006_VW37.rod
8397058 - Front Left TPMS Sensor
C1050 31 [009] - No Signal
Reset counter: 126
Mileage: 7004 km
Date: 2022.12.04
Time: 13:50:06
Vehicle speed: 54 km/h
Outside temperature: 4.5 °C
Reception level antenna 1: 440 mV
Offset level antenna 1: 230 mV
8397314 - Front Right TPMS Sensor
C1051 31 [009] - No Signal
Reset counter: 126
Mileage: 7004 km
Date: 2022.12.04
Time: 13:50:06
Reception level antenna 1: 470 mV
8397570 - Rear Left TPMS Sensor
C1052 31 [009] - No Signal
Reset counter: 126
Mileage: 7004 km
Date: 2022.12.04
Time: 13:50:06
Reception level antenna 1: 460 mV
8397826 - Rear Right TPMS Sensor
C1053 31 [009] - No Signal
Reset counter: 126
Mileage: 7004 km
Date: 2022.12.04
Time: 13:50:06
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 5H2 907 383 HW: 5H2 907 383
Component: Anhaenger H09 0040
Serial number: 000000000005853
Coding: 0100000202001300
ASAM Dataset: EV_TrailFunctGener3Hella 001009
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 6D87CFC9CD15CA63304-8038
Component: RVC Compact H18 0231
Coding: 0123060123002017000040
ROD: EV_CamSysRVRVCPANAMQBAB.rod
Part No SW: 5WC 959 107 HW: 5WC 959 107
Component: HDSG-Modul H04 0430
Revision: -------- Serial number: A2-C767-1160-5
Coding: 0A88
ASAM Dataset: EV_DeckLidCONTIAU536 001001
ROD: EV_DeckLidCONTIAU536_VW27.rod
VCID: 0E45A845A0D3517B69E-805A
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 284 E HW: 5WA 035 284 B
Component: OCUGen3High H20 0139
Serial number: 0000000107VIUQ9
Coding: 023760001968A8209025460161102607
ASAM Dataset: EV_OCUGen3High 003007
ROD: EV_OCUGen3High_003_VW37.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 2Q0 980 653 C HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1302
Serial number: E80320004220470
Coding: 00000908117EC020089F10001030008000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
ROD: EV_MFK3ValeoMQB_007_VW27.rod
VCID: 353727A9E5C542A3084-8060
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 5NA 907 159 B HW: 4K0 907 159
Component: SAS-GEN 2.5 H08 0001
Serial number: 220210292357
VCID: 45D75769B525D223984-8010
Part No SW: 992 941 572 CE HW: 992 941 572 C
Component: LED1L H08 9202
ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
ROD: EV_LLPGen3LKEBODPO68X_001_VW37.rod
VCID: 6889BEDDE2F7EF4B432-803C
Component: LED1R H08 9202
ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
Address 8126: Trq distrib RearL axle (J492) Labels: None
Part No SW: 08E 907 554 G HW: 08E 525 130
Component: 4Motion H05 0124
Serial number: 010UITN
Coding: 00010100
ASAM Dataset: EV_TorquSplitLeftMAGNA 001005
ROD: EV_TorquSplitLeftMAGNA_001_VW48.rod
VCID: 323D1CB514AB559B2D6-8066
Address 8127: Trq distrib RearR axle (J492) Labels: None
Serial number: 010UISE
Coding: 00010100
ASAM Dataset: EV_TorquSplitRightMAGNA 001005
ROD: EV_TorquSplitRightMAGNA_001_VW48.rod
