Tiguan R towbar coding, no power to switch
Ads17
C?ID=396935
I have fitted a new OEM Swivelling Towbar to a 2022 Tiguan R but the release switch is not functioning, no power going to it, I have confirmed power going to the Trailer module and there are no fault codes being returned.
I reckon I am missing something in the coding.
I have a copy of a scan from another Tiguan owned by a family member which has the same OEM towbar but was retro-fitted by VW and coded with ODIS, this has allowed me to confirm a lot of the coding but I think there is still something I am missing?
This is what I have coded so far:
19 -Can GatewayInstall ListEnable 69-Trailer
09 -Central ElectAdaptionsENG122979-ENG141968 -- Networking - Anhaengeranschlussgeraet (set to installed)
01 -EngineLong CodeByte 5 - Bit 4Long Code string change confirmed by Dana (Ross-Tech)
03 -ABS BrakesAdaptionsVehicle & Trailer Stabilisation to Activated
10 -Park /Steer AssistLong CodeByte 3 - Bit 1 = 01 Trailer Hitch Installed (manually operable)Matches what was set by ODIS on another Tiguan
13 -Auto dist regLong CodeByte 3 - Bit 3 (control module for towing sensor)Matches what was set by ODIS on another Tiguan
69 -TrailerLong CodeByte 1 - Bit 0-7 = Country Code - set to ROW
Byte 6 - Bit 0-2 = Set to 03 PlatformCoding, MQB
A5 -Frnt Sens.Drv.AssistLong CodeByte 5 - Bit 4 (AAG)Matches what was set by ODIS on another Tiguan
6D -Trunk ElectLong CodeByte 1 - Bit 7 (Trailer installed)Matches what was set by ODIS on another Tiguan
6C -Back up CamLong CodeByte 4 - Bit 0 (equipment_ahk, installed)
3C -Lane Change AssistLong CodeByte 0 - Bit 4-5 = 20 ECU for draw bar, with ECU for draw bar"Matches what was set by ODIS on another Tiguan
Scan from my car, ignore TPMS error - winter wheels are on with no sensors in yet
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 2B 3C 42 44 47 4B 52 5F
          65 69 6C 6D 75 A5 A9 D6 D7 8126 8127
VIN: WVGZZZ5NZNWxxxxxx   Mileage: 8736km-5428miles
8126-Trq distrib RearL axle -- Status: OK 0000
8127-Trq distrib RearR axle -- Status: OK 0000
Address 01: Engine (J623-DNFG)       Labels: None
   Part No SW: 5NA 906 259 F    HW: 06K 907 425 M
   Component: R4 2.0l TFS   H80 0002
   CVN: B0713AA2
   Coding: 092540322476050B30040000000000000000000000000000
   ASAM Dataset: EV_ECM20TFS0205NA906259F 001004
   ROD: EV_ECM20TFS020_VW37.rod
   VCID: 49CF5B59993D36437CC-801C
   VINID: 9E65EAAAA15EA9E9C50841082401514841
Readiness: 1110 0001
   Part No SW: 0DL 300 014 C    HW: 0GC 927 711 H
   Component: GSG DQ500     H06 3703
   Revision: 00H06V13    CVN: 23A43B29
   VCID: 2B0301D1338104536E0-807E
   Part No SW: 5Q0 614 517 GS    HW: 5Q0 614 517 BP
   Component: ESC           H35 0993
   Revision: 00000000    Serial number: 63481000000351
   Coding: 0AEE939AD0222370477B070862CC6950C90BC4E2E04696733842558852A8490800402844131A13114335351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100VWR 001005
   ROD: EV_Brake1UDSContiMK100VWR.rod
   VCID: 08499E5DC2B70F4BA32-805C
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0591328906
   Coding: 132C2C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 48C95E5D8237CF4B632-801C
   Subsystem 1 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 39198936
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 AJ    HW: 5NA 907 044 AJ
   Component: AC Automat    H50 1301
   Revision: 20K03000    Serial number: 00000A00344138
   Coding: 06120104200114011105100C0050D436
   ASAM Dataset: EV_ACTouchPrehVW37X 001010
   ROD: EV_ACTouchPrehVW37X_VW37.rod
   VCID: 074B9D61CFA90033AA8-8052
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 E    HW: 5Q0 907 659 E
   Component: G238 _AQS  H32 0120
   Serial number: 117996789
   Subsystem 2 - Part No SW: 11A 907 049     HW: 11A 907 049
   Component: E265 KPH  H02 0183
   Serial number: G04S05.01.2200970972
   Coding: FFFFFF
   Part No SW: 5Q0 937 084 EC    HW: 5Q0 937 084 EC
   Component: BCM MQBAB H   H44 0511
   Serial number: 01102135401712
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 7DA7FF899D755AE3804-8028
   Subsystem 1 - Part No SW: 5NC 955 119 B    HW: 5NC 955 119 A  Labels: 1KX-955-119.CLB
   Component: 326 RL 141021  034 0373
   Serial number: 00000002110110302852
   Subsystem 2 - Part No SW: 81D 955 555 A    HW: 81D 955 555
   Component: G397_RLFSS  H06 0004
   Serial number: 40386553X81D955555A0
   Coding: 0000DE
   Subsystem 3 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  005 0403
   Serial number: 000000000ZL22045X8BB
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000001972843
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 521 KS    HW: 5Q1 953 569 K
   Component: Lenks.Modul  H24 0190
   Serial number: 0100160220220C201466
   Part No SW: 3Q0 919 298 F    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0055
   Serial number: 000601229448092
   Coding: 0331567951
   ASAM Dataset: EV_EPHBO2CVW3260000 010019
   ROD: EV_EPHBO2CVW3260000_VW37.rod
   VCID: 40D9467DAA07F70BAB2-8014
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H09 0396
   Coding: 32055FDB5CFF8728749F812481408780000000000000000024
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: 73B3D9B1AB311C93E60-8026
   Serial number: 03022241350043
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38292E9DF2D7BFCB132-806C
   Part No SW: 5Q0 959 655 CG    HW: 5Q0 959 655 CG
   Component: AirbagVW21    010 0421
   Serial number: 003J9R82435.
   Coding: 98CCC0C0000000005C5400CF00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
   Left seat belt tensioner:
   Component: BeltPretRevFL  106 1062
   Serial number: 5NC857705D0050W00718
   Coding: 802006
   Right seat belt tensioner:
   Component: BeltPretRevFR  106 1062
   Serial number: 5NC857706D0054W00336
   Coding: 802006
   Subsystem 3 - Part No SW: -----------    HW: 480 002 801 22
   Serial number: 35700000000DAA586D5%
   Subsystem 4 - Part No SW: -----------    HW: 480 002 801 22
   Serial number: 35800000000657D8695W
   Subsystem 5 - Part No SW: -----------    HW: 480 400 302 22
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001BD07487D416FD
   Subsystem 6 - Part No SW: -----------    HW: 480 400 302 22
   Component: SideSensor_Pr  005 6149
   Serial number: 35200019EC739A2533BD
   Subsystem 7 - Part No SW: -----------    HW: 480 401 802 22
   Component: FrontSensor_D  005 6149
   Serial number: 3550001A8C79AA63928M
   Part No SW: 3G0 920 320 C    HW: 3G0 920 320 C
   Component: KOMBI         524 6170
   Coding: 20AC2098FE8C06000188724F1001000800601106
   ASAM Dataset: EV_DashBoardVDDMQBA0 001046
   ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
   VCID: 1D67DF097D35FAE3E04-8048
   Part No SW: 3Q0 907 530 AL    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5463
   Serial number: 26012210801054
   Coding: 0B0D00047F085B00FB17AAFE9A0F00010001070000000000000000000000
   GVL: 014E3C1008000600C0CC80008082CC0000000000000200000030000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 79AFEB99895D66C3ACC-802C
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 1EA 959 442 F    HW: 1EA 959 442 F
   Component: MFL  H03 0219
   Serial number: 17038315080142202925
   Coding: 2F2B00
   Component: J367-BDMHella  H11 9070
   Serial number: 6621078805
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 F    HW: 5Q0 907 155 F
   Component: U13DCAC  H27 0810
   Serial number: 6174195
   Component: ELV-MQBB      H07 0020
   Serial number: 22000013135010
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 333319B1EBB15C93260-8066
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 00000591798368
   Coding: A2A54640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   VCID: 392F2B99C9DDA6C3ECC-806C
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 00000591778923
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000460463250
   Coding: 003D1A20D001048000001000
   VCID: 52FD7C35746B759B0D6-8006
   Subsystem 1 - Part No SW: 5Q0 959 408 E    HW: 5Q0 959 164 C
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000056638541
   Coding: 2D0000
   Part No SW: 5QF 909 144 B    HW: 5QF 909 144 A
   Component: EPS_MQB_ZFLS  507 5582
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   Part No SW: 3G0 035 466 D    HW: 3G0 035 466 D
   Component: AMPeth16C     H03 3831
   Serial number: A1130J00052181
   Coding: 24040000000000000000000000000000000000000000000000
   ASAM Dataset: EV_AMPEthMQB 001005
   ROD: EV_AMPEthMQB_VW27.rod
   VCID: 2615F0E52863393BB1E-8072
   Part No SW: 3Q0 907 338 G    HW: 3Q0 907 338 K
   Component: FCM MQB Low   005 0382
   Serial number: 23022211601358
   Coding: 00000007090010D607102F100A0000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 004006
   ROD: EV_MultiModulContiVW48X_004_VW37.rod
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000460727279
   Coding: 003D1020DC01048000001000
   VCID: 51FF7339716D0E8334C-8004
   Subsystem 1 - Part No SW: 5Q0 959 407 E    HW: 5Q0 959 163 C
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000056614356
   Coding: 250000
   Part No SW: 3G5 035 820 H    HW: 3G5 035 820 H
   Component: MU-O-ND-EU    H22 0306
   Serial number: VWZAZ2A0366131
   Coding: 23260008000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_001_VW27.rod
   VCID: 290FFBD9397D16439CC-807C
   Subsystem 1 - Part No SW: 5NN 919 605 B    HW: 5NN 919 605 B
   Component: ABT_Std-2_Nav  381 8304
   Serial number: VWZ6ZHA0580208
   Subsystem 2 - Part No: V03 959 809 TP
   Component: EUR 2022       6053
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Component: RDKBERU30     H06 0011
   Serial number: 30000000623709
   ROD: EV_RDKBERU30_006_VW37.rod
8397058 - Front Left TPMS Sensor
          C1050 31 [009] - No Signal
                    Reset counter: 126
                    Mileage: 7004 km
                    Date: 2022.12.04
                    Time: 13:50:06
                    Vehicle speed: 54 km/h
                    Outside temperature: 4.5 °C
                    Reception level antenna 1: 440 mV
                    Offset level antenna 1: 230 mV
8397314 - Front Right TPMS Sensor
          C1051 31 [009] - No Signal
                    Reset counter: 126
                    Mileage: 7004 km
                    Date: 2022.12.04
                    Time: 13:50:06
                    Reception level antenna 1: 470 mV
8397570 - Rear Left TPMS Sensor
          C1052 31 [009] - No Signal
                    Reset counter: 126
                    Mileage: 7004 km
                    Date: 2022.12.04
                    Time: 13:50:06
                    Reception level antenna 1: 460 mV
8397826 - Rear Right TPMS Sensor
          C1053 31 [009] - No Signal
                    Reset counter: 126
                    Mileage: 7004 km
                    Date: 2022.12.04
                    Time: 13:50:06
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H2 907 383     HW: 5H2 907 383
   Component: Anhaenger     H09 0040
   Serial number: 000000000005853
   Coding: 0100000202001300
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   VCID: 6D87CFC9CD15CA63304-8038
   Coding: 0123060123002017000040
   Part No SW: 5WC 959 107     HW: 5WC 959 107
   Component: HDSG-Modul    H04 0430
   Revision: --------    Serial number: A2-C767-1160-5
   Coding: 0A88
   ASAM Dataset: EV_DeckLidCONTIAU536 001001
   ROD: EV_DeckLidCONTIAU536_VW27.rod
   VCID: 0E45A845A0D3517B69E-805A
   Part No SW: 5WA 035 284 E    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0139
   Serial number: 0000000107VIUQ9
   Coding: 023760001968A8209025460161102607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW37.rod
   Part No SW: 2Q0 980 653 C    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1302
   Serial number: E80320004220470
   Coding: 00000908117EC020089F10001030008000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   VCID: 353727A9E5C542A3084-8060
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 5NA 907 159 B    HW: 4K0 907 159
   Component: SAS-GEN 2.5   H08 0001
   Serial number: 220210292357
   VCID: 45D75769B525D223984-8010
   Part No SW: 992 941 572 CE    HW: 992 941 572 C
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_001_VW37.rod
   VCID: 6889BEDDE2F7EF4B432-803C
   Component: LED1R         H08 9202
Address 8126: Trq distrib RearL axle (J492)       Labels: None
   Part No SW: 08E 907 554 G    HW: 08E 525 130
   Component: 4Motion       H05 0124
   Serial number: 010UITN
   Coding: 00010100
   ASAM Dataset: EV_TorquSplitLeftMAGNA 001005
   ROD: EV_TorquSplitLeftMAGNA_001_VW48.rod
   VCID: 323D1CB514AB559B2D6-8066
Address 8127: Trq distrib RearR axle (J492)       Labels: None
   Serial number: 010UISE
   Coding: 00010100
   ASAM Dataset: EV_TorquSplitRightMAGNA 001005
   ROD: EV_TorquSplitRightMAGNA_001_VW48.rod
Ads17
C?ID=396935
A bit further investigation and I think the trailer module has Component Protection which is causing the issue? As it is a new module it came with activation codes so will need to get it activated with ODIS.
I don't recall seeing CP in any trailer module, and yours doesn't show a CP fault either, so I am doubtful of that.
However, if you have activation codes, that's the best way to get it done, because then the factory servers will know that the vehicle is "supposed" to have a trailer module and won't mung things up if the dealer ever runs SVM on the car at some point in the future.
Ads17
C?ID=396935
I agree Uwe, using the activation codes is the cleanest method going forward.
From looking at the activation instructions for ODIS it states that when it is registered with the activation codes there is 'License Protection' which associates the module to the specific vehicle and it can't be used in other vehicles.
I assume out the box the trailer module is locked in some capacity and prevents power being output to the release switch, unless I am missing some coding in VCDS (I have been through all the other modules and can't see anything).
For reference the module part number is 5H2 907 383.
Ads17
C?ID=396935
Trailer now functioning.
I had to do different coding on 10 and 19 though. It is swiveling, not fixed/mechanically removable.
Also needed dataset. As this is being "gen2" dataset seems like it doesn't show up on 1A.
Looking through those posts you seem to say you made changes to your coding but you also had to add a dataset to [69]. Have you got any details of what you did for adding the dataset?
Ads17
C?ID=396935
Trailer module now activated via ODIS with activation codes and operational :thumbs:
For completeness here is a full scan after ODIS configuration as it may help someone who already has the trailer module enabled.
After comparing long coding from all modules the only difference from what I had previously coded with VCDS was to 19 -Can Gateway Byte 03 which changed from "04" to "34", Bit4 in Experimental Coding is what appears to be what has changed.
VIN: WVGZZZ5NZNWxxxxxx   Mileage: 8884km-5520miles
   CVN: B0713AA2
   Coding: 132C2C0723
   Air quality sensor:
   Coding: FFFFFF
   Coding: 0000DE
   Coding: 0331567951
   Shop #: WSC 28628 005 1048576
   Coding: 802006
   Coding: 802006
   Coding: 0B0D00347F085B00FB17AAFE9A0F00010001070000000000000000000000
   Generator:
   Coding: 2F2B00
   Coding: A2A54640
   Coding: 2D0000
   Coding: 931F0000
   Coding: 250000
                    Reset counter: 126
                    Mileage: 7004 km
                    Date: 2022.12.04
                    Time: 13:50:06
                    Reset counter: 126
                    Mileage: 7004 km
                    Date: 2022.12.04
                    Time: 13:50:06
                    Reset counter: 126
                    Mileage: 7004 km
                    Date: 2022.12.04
                    Time: 13:50:06
                    Reset counter: 126
                    Mileage: 7004 km
                    Date: 2022.12.04
                    Time: 13:50:06
   Coding: 0A88
   Coding: 00010100
   Coding: 00010100
End----------(Elapsed Time: 02:02, VBatt start/end: 12.3V/12.1V)-----------
NEtech
Denmark
C?ID=56995
Yes but a lot of Parameterization is done.
Coding Byte 03, yes that is normally done on most VW and Skoda.
vastechnics
C?ID=143747
Button not functional because paramter in module 69
Glyn
C?ID=408159
If you search for a previous thread ‘Seat Ateca Towbar’ you will see I have had the same issue, the ecu that comes with a new towbar is set up for towing electrics only so in order to have the button operational the ecu must be Parameterized. I believe this can be done with a certain software package, or by dealer using a code supplied, as I did not get a code with my very cheap bar I assumed the code had been used, I opted for a replacement fully Parameterized ecu from a company in Poland, and to be fair in the end it simply plugged in and the button worked perfectly, if the car goes to the dealer for any work I tend to swap it out for the original one just in case they do something that may remove the function.
