Security Access Code
PeterK
C?ID=249326
Hi, I'm new to VCDS and new here so please bear with me!
Autoscan of my vehicle here:
Saturday,25,July,2015,21:17:09:35285
VCDS Version: 15.6.1.0 (x64)
Data version: 20150612
VIN: WVWZZZ3CZFE505601   License Plate: GM15 AUTO
Chassis Type: 3C (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
Address 01: Engine (J623-CRLB)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 AS    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H21 1147
   Revision: B5H21---
   Coding: 0119001203451D083000
   Shop #: WSC 05311 115 00318
   ASAM Dataset: EV_ECM20TDI01104L906026AS 001006
   ROD: EV_ECM20TDI01104L906026AS.rod
   VCID: 7BF5B898F26CB5E7AC-802E
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 60945000001570
   Coding: 0EEC928F34200B71077D060041C44970492CD0E0608292F11460F078C002
   Shop #: WSC 00015 115 00001
   ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
   VCID: 489F1754F33A2E7F71-801C
Address 05: Acc/Start Auth. (J518)       Labels: None
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0524
   Revision: 00023000    Serial number: 0366560980
   Coding: 000F0F0603
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   ROD: EV_KessyHellaMQBAB_SK48.rod
   VCID: 77FDA4A8CE449187C8-8022
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
   Component: AC Manuell    H02 1001
   Revision: 00001K06
   Coding: 11120104202100002000400000000002
   ROD: EV_ACManueBHBVW37X_SE37.rod
   VCID: 3C777B84B7E272DFE5-8068
   Part No SW: 5Q0 937 086 BB    HW: 5Q0 937 086 BB
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86582003150912
   Coding: 03010842C241027703A04084B10007281880000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   Slave 1:
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119
   Component: WWS    150409  043 0607
   Serial number:         150414131809
   Slave 2:
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y15M04D10H21M24S14
   Coding: 90A8DD
   Slave 3:
   Subsystem 3 - Part No SW: 3G0 941 633 A    HW: 3G0 941 633 A
   Serial number: 19 12 2014  00000110
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY150641HZ2
   Serial number: 00000000000062179445
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0053
   Revision: --------    Serial number: 39391508506938
   Coding: 0071051001
   Shop #: WSC 05311 115 00080
   ROD: EV_EPHVA18AU3700000_SK48.rod
   VCID: 408F0F74DB0A163FB9-8014
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0130
   Coding: 2A40608110FFC428949C804C
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 336550B89ABCBDA734-8066
   Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R1P6ZW8MU
   Coding: 98FCC0C0000000005C5400CC008800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X_VW48.rod
   VCID: 0109CA709080DF37F6-8054
   Seat belt tensioner; left:
   Serial number: 3G2857705C0100P00354
   Coding: 80000A
   Seat belt tensioner; right:
   Serial number: 3G2857706C0093P00082
   Coding: 80000A
   Subsystem 3 - Part No SW: -----------    HW: 454 000 304 15
   Serial number: 3576U000000D523DB31G
   Subsystem 4 - Part No SW: -----------    HW: 454 000 304 15
   Serial number: 3586U0000003523DB317
   Subsystem 5 - Part No SW: -----------    HW: 454 800 904 15
   Serial number: 3516RF8874E06000000I
   Subsystem 6 - Part No SW: -----------    HW: 454 801 304 15
   Serial number: 3526R55926406000000.
   Subsystem 7 - Part No SW: -----------    HW: 454 802 003 15
   Serial number: 3556VC74D1806000000F
Address 16: Steering wheel (J524)       Labels: None
   Part No SW: 3Q0 953 521     HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150402501150
   Coding: 0000
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 6DD186C0BC182B5722-8038
Address 17: Instruments (J285)       Labels: None
   Part No SW: 3G0 920 941     HW: 3G0 920 941
   Component: KOMBI         206 5320
   Coding: 27A401102780260001882A001000000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009003
   ROD: EV_DashBoardJCIMQBAB_VW48.rod
   VCID: 63C5E0F86ADC6D2784-8036
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Reset counter: 64
                    Mileage: 84 km
                    Date: 2015.07.11
                    Time: 15:28:39
          U1110 00 [008] - -
                    Reset counter: 64
                    Mileage: 84 km
                    Date: 2015.07.11
                    Time: 15:28:39
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Revision: --------    Serial number: 05041510800032
   Coding: 030300044F087300EF00005C080F00010001070000000000000000000000
   ROD: EV_GatewConti.rod
   VCID: 72EB95BCA526F4AFFF-8026
   Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150000764680035163
   Coding: 2CFFFF
   Serial number: 8188916203
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
   Serial number: 15000069568006
   Coding: 0000000000000000
   Shop #: WSC 00015 115 08193
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E99AB0A020CFB706-8024
   Serial number: 050415BD41240A
   Coding: 00350A208001028000001000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 428B057CD506042FAF-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E
   Serial number: 00000000000001231367
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 8103
   Shop #: WSC 00015 115 00318
   ROD: EV_SteerAssisMQB.rod
   VCID: 43850078CA1C0D27A4-8016
   Serial number: 020415BD113562
   Coding: 003500208001028000001000
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 41890A70D0001F37B6-8014
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E
   Serial number: 00000000000001200160
   Coding: 050000
   Part No SW: 3Q0 035 820     HW: 3Q0 035 820
   Component: MU-S-D-ER     H11 0138
   Serial number: VWZAZ2R8561363
   Coding: 02840100FF00000011111201000808001F0100C60120010000
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 66C3F9EC99EE180F63-8032
   Media Player Position 1:
   Subsystem 1 - Part No SW: 3G0 919 605     HW: 3G0 919 605
   Component: ABT_Std-2  H44 1017
   Serial number: VWZ8Z9RD500R9Y
1637 - Interface for External Media
          U11B8 00 [008] - No Communications
                    Reset counter: 71
                    Mileage: 26 km
                    Date: 2015.06.29
                    Time: 10:21:58
End-------------------------(Elapsed Time: 03:49)--------------------------
I have made one adaptation (seat belt chime) successfully, but would also like to change the doors to one click unlocking with the remote. I'm using 15.6.1.0 Beta version but there are no label files yet for module 9 which I'm fairly sure is the one I need. I've identified the channel I need with a bit of help from Google translate (6, Access control-ZV Tuerentriegelung), but when I try to change the stored value I get a message that security access is required. Until labels are done at some point in the future for this module is there any way of finding the security code? I paid for an hour on erWin but couldn't find anything relevant on there.
Any help or pointers gratefully received
Peter.
Version 15.7 (which is pending) should have a label file for that module. In the meanwhile, try 31347.
PeterK
C?ID=249326
Yes, that did the trick, many thanks for your help.
Peter.
