- Jan 30, 2023
- 7
- 0
- Columbia, SC, USA
- C?ID=529518
Back story..
2013 Audi S5 Cab.
Replaced the camera module 8F0907441 with used one from eBay.
Installed module and camera is working but points more downward than outwards so I want to re-calibrate.
Purchased VCDS and installed on laptop. directory has full access to read and write from. Win 10 Dell
VCDS seems to work fine b/c I was able to remove service warnings.
When I try to start the recalibration, I get the " this function requires a licensed interface" error.
Not sure what to do now?
VCDS About ..https://photos.app.goo.gl/HgeGFnVLeSFJRULJ8
Port Test ..https://photos.app.goo.gl/kc2LCFDZhEMoWPKd6
6C error ..https://photos.app.goo.gl/EottfnMDmqUEAtok6
software code does not seem to be correct so I tried to recode to 1021009 and I got an out of range error...https://photos.app.goo.gl/8LWTMu6L7M2psyoJ7
I have the VCDS HEX-V2 USB plug
Below is the auto-scan
2013 Audi S5 Cab.
Tuesday,31,January,2023,16:04:53:47285
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
VIN: WAUVGAFH3DN013643 License Plate:
Chassis Type: FH-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 22 26 36 3C 42 44 46 47 52
53 56 5F 62 6C 72 A9
VIN: WAUVGAFH3DN013643 Mileage: 134870km-83804miles
Address 01: Engine (J623-CGXC) Labels:. 06E-907-551-CGW.clb
Part No SW: 8K5 907 551 E HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0004
Revision: --H07--- CVN: 450F3A95
Coding: 1A250034052600060000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
ROD: EV_ECM30TFS0218K5907551E.rod
VCID: 382924C4E2D8009B132-806C
VINID: 9D19665D15980D47800431840C01FB2275
Part No SW: 8K2 927 156 M HW: 0B5 927 156 J
Component: 0B5 30TFSINAR H01 0009
Revision: --H01--- CVN: 0000ABC6
ASAM Dataset: EV_TCMDL501021 001012
ROD: EV_TCMDL501021.rod
VCID: 40D94C24BA08485BAB2-8014
Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK
Component: ESP8 quattro H09 0100
Coding: 291D1A
VCID: 04518034EE10947BCFA-8050
Part No SW: 8K0 907 064 GP HW: 8K0 907 064 FP
Component: BCM2 2.0 H12 0633
Coding: 0D834000000000000000
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2313000028259004
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 E HW: 8T0 959 760 E
Component: MEM-BFS H10 0076
Revision: AA000000 Serial number: 00000053998902
Coding: 00037025002C00000000
VCID: 45D75D30A5AA6D73984-8010
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01020320131007
Coding: 6603228000
VCID: 392F21C0D9521993ECC-806C
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000565315001
Coding: 26000091863CAFE0210048C300003D0D0F9CD288A2090221000008004000010200040070000000
VCID: 7AADFECC9CD4D28BA56-802E
Subsystem 1 - Part No SW: 8F1 955 119 HW: 8K1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 040313 H07 0080
Serial number: SWF13030045470
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 21042728
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000002302130352
Component: USHL4.2 H30 0030
Serial number: 0000002274555R52GV02
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 91784696000000000001
Address 15: Airbags (J234) Labels:| 8F0-959-655.clb
Part No SW: 8F0 959 655 E HW: 8F0 959 655 E
Component: AirbagVW-AU10 H12 0430
Serial number: 003KKD8066B1
Coding: 303741353731303030304A55304C38463053
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaECUVWAUDI010.rod
VCID: 3A2D3ECCDCD4128BE56-806E
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R130000CPDJ
Serial number: 6334MSME7862464FP
Serial number: 6344MSME762162031
Serial number: 6352QSME58262F64P
Serial number: 6362QSME0B2C3372I
Serial number: 63732SME2C2C4E5CJ
Serial number: 63832SME3E293E7EN
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Revision: -------- Serial number: 90372MBH0004G
Coding: 000036
VCID: 44D14034AE90547B8FA-8010
Part No SW: 8T0 920 983 P HW: 8T0 920 983 P
Component: KOMBIINSTR. H35 0556
Revision: 00200000 Serial number: UUZ35MU2E
Coding: 8BB719008B01D705020000
VCID: 4BC36B0883CE9B034E0-801E
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0055
Revision: 1Z100027 Serial number: 2741Z1322701D0
Coding: 80C303FF00
VCID: 4CC1681486C09C3B47A-8018
Serial number: 8062140103
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H14 0100
Serial number: 002602130001889
VCID: 2F3B1F981796C723428-807A
Address 26: Auto Roof (J256) Labels:* 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H12 0190
Coding: 030000
ASAM Dataset: EV_ElectRoofContr 001008
ROD: EV_ElectRoofContr.rod
VCID: 71BFD9E0C12291D314C-8024
Component: MEM-FS H10 0076
Revision: AA000000 Serial number: 00000053997343
Coding: 001B7B25002C00000000
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H04 0060
Serial number: 0192613684
Coding: 010211
VCID: 3FDB4FD8C7F637A3D28-806A
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H04 0060
Serial number: 0192508394
Coding: 000102
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C53724E08332C03
VCID: 56F58A7C480CD6EBE1E-8002
Fault Status: 01101100
Reset counter: 22
Mileage: 134862 km
Date: 2023.01.31
Time: 09:48:40
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0011264401
Coding: 100000010001
ROD: EV_RCEPSAU48X_008.rod
VCID: 343110F4FEB0E4FB3FA-8060
Revision: 00002001 Serial number: 0302129271
Coding: 010602BA00FA402180B0033200000000
Subsystem 1 - Part No SW: 8F0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000634621
Part No SW: 8F1 035 223 A HW: 8F1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94833011629801
VCID: 1F1BEF5867B657A3F28-804A
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
Coding: 011C53324E08332C03
VCID: 55F78D70550ADDF3E84-8000
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 20000000237474
ROD: EV_ParkiBrake_AU48.rod
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 080 G HW: 4G0 035 080
Revision: AB001007 Serial number: 158K$0D7508113
Coding: 020007010000000101
Shop #: WSC 64153 001 1048576
VCID: 221DE6AC54C47A4BDD6-8076
Part No SW: 8R1 035 746 D HW: 8R1 035 746 B
Component: H-BNT-NA H44 0738
Revision: -------- Serial number: 204C 0D7565755
Coding: 140200030206A1EF55028B4E00000401150000000000000000
VCID: 382924C4E258009B132-806C
Subsystem 1 - Part No: 8R0 060 884 CS
Component: NAR 2015 1201
Component: DU7 High H42 0104
Serial number: A130BH0D2663401
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001430695
Component: CD-Database 4949
Part No SW: 8T0 959 795 F HW: 8T0 959 795 F
Component: TSG HL H08 0304
Coding: 010C13304008372C03
VCID: 4EC5621C70DCAE2B29E-801A
Address 6C: Back-up Cam. Labels: None
Part No SW: 470 907 441 HW: 8F0 907 441
Component: J772__Rearview 0020
Revision: --H08--- Serial number: 525PA8-J38B092
Coding: 4020012
Shop #: WSC 02311 785 00200
VCID: 54F1707452F0C4FB1FA-8000
Component: TSG HR H08 0304
Part No SW: 8K0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 130117201166
VCID: 72BDD6ECC424AACBED6-8026
End----------(Elapsed Time: 02:04, VBatt start/end: 12.2V/12.2V)-----------
