This function requires a licensed interface? 6C security access
edwelch4
Columbia, SC, USA
C?ID=529518
Back story..
2013 Audi S5 Cab.
Replaced the camera module 8F0907441 with used one from eBay.
Installed module and camera is working but points more downward than outwards so I want to re-calibrate.
Purchased VCDS and installed on laptop. directory has full access to read and write from. Win 10 Dell
VCDS seems to work fine b/c I was able to remove service warnings.
When I try to start the recalibration, I get the " this function requires a licensed interface" error.
Not sure what to do now?
VCDS About ..https://photos.app.goo.gl/HgeGFnVLeSFJRULJ8
Port Test ..https://photos.app.goo.gl/kc2LCFDZhEMoWPKd6
6C error ..https://photos.app.goo.gl/EottfnMDmqUEAtok6
software code does not seem to be correct so I tried to recode to 1021009 and I got an out of range error...https://photos.app.goo.gl/8LWTMu6L7M2psyoJ7
I have the VCDS HEX-V2 USB plug
Below is the auto-scan
Tuesday,31,January,2023,16:04:53:47285
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: WAUVGAFH3DN013643   License Plate:
Chassis Type: FH-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 22 26 36 3C 42 44 46 47 52
          53 56 5F 62 6C 72 A9
VIN: WAUVGAFH3DN013643   Mileage: 134870km-83804miles
Address 01: Engine (J623-CGXC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0004
   Revision: --H07---    CVN: 450F3A95
   Coding: 1A250034052600060000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
   ROD: EV_ECM30TFS0218K5907551E.rod
   VCID: 382924C4E2D8009B132-806C
   VINID: 9D19665D15980D47800431840C01FB2275
   Part No SW: 8K2 927 156 M    HW: 0B5 927 156 J
   Component: 0B5 30TFSINAR H01 0009
   Revision: --H01---    CVN: 0000ABC6
   ASAM Dataset: EV_TCMDL501021 001012
   ROD: EV_TCMDL501021.rod
   VCID: 40D94C24BA08485BAB2-8014
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 291D1A
   VCID: 04518034EE10947BCFA-8050
   Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H12 0633
   Coding: 0D834000000000000000
   Serial number: 2313000028259004
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0076
   Revision: AA000000    Serial number: 00000053998902
   Coding: 00037025002C00000000
   VCID: 45D75D30A5AA6D73984-8010
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01020320131007
   Coding: 6603228000
   VCID: 392F21C0D9521993ECC-806C
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000565315001
   Coding: 26000091863CAFE0210048C300003D0D0F9CD288A2090221000008004000010200040070000000
   VCID: 7AADFECC9CD4D28BA56-802E
   Subsystem 1 - Part No SW: 8F1 955 119     HW: 8K1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 040313  H07 0080
   Serial number: SWF13030045470
   Coding: 00FD11
   Serial number: 21042728
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002302130352
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R52GV02
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 91784696000000000001
Address 15: Airbags (J234)       Labels:| 8F0-959-655.clb
   Part No SW: 8F0 959 655 E    HW: 8F0 959 655 E
   Component: AirbagVW-AU10 H12 0430
   Serial number: 003KKD8066B1
   Coding: 303741353731303030304A55304C38463053
   ASAM Dataset: EV_AirbaAU10SMEAU485 001004
   ROD: EV_AirbaECUVWAUDI010.rod
   VCID: 3A2D3ECCDCD4128BE56-806E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R130000CPDJ
   Serial number: 6334MSME7862464FP
   Serial number: 6344MSME762162031
   Serial number: 6352QSME58262F64P
   Serial number: 6362QSME0B2C3372I
   Serial number: 63732SME2C2C4E5CJ
   Serial number: 63832SME3E293E7EN
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372MBH0004G
   Coding: 000036
   VCID: 44D14034AE90547B8FA-8010
   Part No SW: 8T0 920 983 P    HW: 8T0 920 983 P
   Component: KOMBIINSTR.   H35 0556
   Revision: 00200000    Serial number: UUZ35MU2E
   Coding: 8BB719008B01D705020000
   VCID: 4BC36B0883CE9B034E0-801E
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0055
   Revision: 1Z100027    Serial number: 2741Z1322701D0
   Coding: 80C303FF00
   VCID: 4CC1681486C09C3B47A-8018
   Serial number: 8062140103
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H14 0100
   Serial number: 002602130001889
   VCID: 2F3B1F981796C723428-807A
Address 26: Auto Roof (J256)       Labels:* 8F0-959-255.clb
   Part No SW: 8F0 959 255     HW: 8F0 959 255
   Component: VSG-AUDI-B8   H12 0190
   Coding: 030000
   ASAM Dataset: EV_ElectRoofContr 001008
   ROD: EV_ElectRoofContr.rod
   VCID: 71BFD9E0C12291D314C-8024
   Component: MEM-FS        H10 0076
   Revision: AA000000    Serial number: 00000053997343
   Coding: 001B7B25002C00000000
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H04 0060
   Serial number: 0192613684
   Coding: 010211
   VCID: 3FDB4FD8C7F637A3D28-806A
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H04 0060
   Serial number: 0192508394
   Coding: 000102
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011C53724E08332C03
   VCID: 56F58A7C480CD6EBE1E-8002
                    Fault Status: 01101100
                    Reset counter: 22
                    Mileage: 134862 km
                    Date: 2023.01.31
                    Time: 09:48:40
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0011264401
   Coding: 100000010001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 343110F4FEB0E4FB3FA-8060
   Revision: 00002001    Serial number: 0302129271
   Coding: 010602BA00FA402180B0033200000000
   Subsystem 1 - Part No SW: 8F0 959 719 B    HW: 8K0 959 719
   Component: GTO BF  H01 0080
   Serial number: 00000000000000634621
   Part No SW: 8F1 035 223 A    HW: 8F1 035 223 A
   Revision: 00005001    Serial number: 94833011629801
   VCID: 1F1BEF5867B657A3F28-804A
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   Coding: 011C53324E08332C03
   VCID: 55F78D70550ADDF3E84-8000
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 20000000237474
   ROD: EV_ParkiBrake_AU48.rod
   Part No SW: 4G0 035 080 G    HW: 4G0 035 080
   Revision: AB001007    Serial number: 158K$0D7508113
   Coding: 020007010000000101
   Shop #: WSC 64153 001 1048576
   VCID: 221DE6AC54C47A4BDD6-8076
   Part No SW: 8R1 035 746 D    HW: 8R1 035 746 B
   Component: H-BNT-NA      H44 0738
   Revision: --------    Serial number: 204C 0D7565755
   Coding: 140200030206A1EF55028B4E00000401150000000000000000
   VCID: 382924C4E258009B132-806C
   Subsystem 1 - Part No: 8R0 060 884 CS
   Component: NAR 2015  1201
   Component: DU7 High  H42 0104
   Serial number: A130BH0D2663401
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001430695
   Component: CD-Database  4949
   Part No SW: 8T0 959 795 F    HW: 8T0 959 795 F
   Component: TSG HL        H08 0304
   Coding: 010C13304008372C03
   VCID: 4EC5621C70DCAE2B29E-801A
Address 6C: Back-up Cam.        Labels: None
   Part No SW: 470 907 441     HW: 8F0 907 441
   Component: J772__Rearview      0020
   Revision: --H08---    Serial number: 525PA8-J38B092
   Coding: 4020012
   Shop #: WSC 02311 785 00200
   VCID: 54F1707452F0C4FB1FA-8000
   Component: TSG HR        H08 0304
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 130117201166
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: 72BDD6ECC424AACBED6-8026
End----------(Elapsed Time: 02:04, VBatt start/end: 12.2V/12.2V)-----------
Uhm..
That module looks like it has Lambo software in it.
Have you got a scan of the old module?
Are you certain that the old module was HW 8F0 907 441? Because every scan I can find with that hardware part number is in a Lambo? Right now, my sense is you have the wrong module.
edwelch4
Columbia, SC, USA
C?ID=529518
edwelch4
Columbia, SC, USA
C?ID=529518
When I search the forums I don't see anyone with that HW model. I see this one for a Q7 model but they are not on Q7s. Was there a bug in the VCDS software or something?
https://forums.ross-tech.com/index.php?threads/16218/
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8F0 907 441 HW: 4L0 907 441 B
You're conflating Hardware and software part numbers.
The module you're having trouble with is:
Software: 470 907 441 (Lambo)
Hardware: 8F0 907 441 (Audi) (Lambos use lots of Audi hardware)
The module at the thread linked above is:
Software: 8F0 907 441 (Audi)
Hardware: 4L0 907 441 B (Audi)
When you ask a dealer parts department what part your car needs, they always give you the software number. That may or may not match the hardware number, but the part has the right software, then the part "fits".
If you conflate the two and buy a part with that hardware number, it may or may not have the right software in it. In your case, it does not.
edwelch4
Columbia, SC, USA
C?ID=529518
So is there a way to change the SW or maybe calibrate based on the Lambo specs similar to an S5? Do you know what the coding would be for a lambo?
Thoughts?
edwelch4
Columbia, SC, USA
C?ID=529518
Does anyone know where I can find the Lambo Aventador VCDS specs or codes to calibrate the backup camera. I am having no luck searching the internet. I can't even get past the Security Access code yet.. 22351 doesn't work.
DrPeter
16.4905° S, 151.7375° W
Just a friendly suggestion here, but it sounds like you should try to find the proper part number. It maybe more difficult to find a way to 'flash' this controller with the correct software than to just install the correct part.
The [6C- Back-up Cam.] (J772) controller that you need (HW:4L0907441B, SW:8F0907441), fits 2010 to 2017 Audi A5/S5/RS5 Cabriolet. The part number does not supersede or change.
I am not to sure what you paid or if you can get your money back or resell it on eBay? But this auction (trust but verify) is what your looking for: https://www.ebay.com/itm/285114861491
You could also try calling some local auto salvage yards and see if they have any decent/dry A5 Cabriolets? Sometimes they can locate parts for your too in their national parts system. ref: https://car-part.com
If you replace the [6C] (J772) controller with the correct one, be sure to use the correct Coding for this vehicle: 1000009
And in your Auto-Scan you should see something like this when done:
   Revision: --H07---    Serial number: 525PA8-J2YB04U
   Coding: 1000009
Hope this helps and let us know what happens or if you have any questions,
drpeter
