2016 Audi S7 - P0021 Error Code - Camshaft Variable Timing Solenoid?
2016-Audi-S7
Canada
C?ID=427330
Car: 2016 Audi S7 4.0L V8 (4G)
Couple weeks ago on a cold morning a minute into the drive the EPC light came up, limiting car RPM to 4000. Pulled over and restarted car and the EPC light was gone. No power loss or anything noted other than the light.
A few days later, again 1-2 minutes into the drive the EPC light came back again. Pulled over and restarted, light went away but came back again soon after along with the check engine light. Into the drive the EPC light went away as well as the RPM restriction. CEL stayed however.
Auto-scan produced a P0021 error code (Retard Setpoint not Reached (Over-Advanced)) which is for the Bank 2 intake camshaft. I removed the Camshaft Variable Timing Solenoid and cleaned it as best I could through those screens. I did notice some faint red specks of something on it almost like it was small particles of the O-ring, however the O-ring is a black color so I'm not sure what that could've been. It looked very clean otherwise. Checked the resistance which measured 8.2 Ohms (if I remember correctly). Tried to bench test, but was difficult with such a small electrical connector. When I did get the leads on it wouldn't actuate, but could be because I was using 9v instead of 12v? Will test it again next time I have it out because I have a suspicion it will be coming out again...
Also used the VCDS logging to compare the intake cam signals and timing to see if anything stuck out as a blaring issue. I assume that the difference between the two banks would need to be much more than 1 degree for it to through an EPC/CEL.
Put it back into the car and has been fine for the past 2 weeks. Today on another cold day the EPC light came back on. This time after the engine was already up to operating temp so that somewhat ruled out my concerns about oil viscosity. Restart car, EPC came back again and then the CEL. Same error code after the scan.
My question: is replacing the camshaft solenoid the best next step or am I completely off base thinking that this component is the problem? Could it be the camshaft position sensor? Issue is intermittent, so I don't think my timing is off or is ECU related. It is very tricky to remove these so I don't really want to swap it with the other bank to test because chances are I'll break something else! lol. Tight spacing under the hood... I have ordered a new one, but if that doesn't fix the problem I want to at least have this thread started with other possible causes/solutions or anyone who's dealt with this in the past.
Mileage: 92630km-57557miles
9040 - Bank 2: Camshaft A (Intake)
          P0021 00 [232] - Retard Setpoint not Reached (Over-Advanced)
                    Mileage: 92595 km
                    Date: 2023.01.31
                    Time: 11:39:43
                    Engine RPM: 1221.50 /min
                    Normed load value: 29.0 %
                    Vehicle speed: 71 km/h
                    Coolant temperature: 76 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 14.489 V
                    Engine status: COENG_RUNNING
Readiness: 0000 0100
Might not be related, but not sure why the intake air temp is showing 42C when it was -11C outside?
Tuesday,31,January,2023,12:44:40:00504
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: WAUW2AFC7GN143890   License Plate:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 22 28 34 36 3B 3C 42 44
          46 47 52 53 55 5F 62 6C 6D 72 82 85 8B 8E 8F 90 A9 BA
VIN: WAUW2AFC7GN143890   Mileage: 92630km-57557miles
Address 01: Engine (------CTGE)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 014 D    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H63 0001
   Revision: NCH63---    CVN: B49CBDD6
   Coding: 1A2500326546010E3000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM40TFS0114G0906014D 001001
   ROD: EV_ECM40TFS0114G0906014D.rod
   VCID: 2313E407AB55E793D60-8076
   VINID: 9D19670915931D778110320900A56A2A73
                    Mileage: 92595 km
                    Date: 2023.01.31
                    Time: 11:39:43
   Part No SW: 4G0 927 166 F    HW: 0B5 927 156 K
   Component: 0B5 40TFSINAR H03 0006
   Revision: --H03---    CVN: 0000D096
   ASAM Dataset: EV_TCMDL501021 001022
   ROD: EV_TCMDL501021.rod
   VCID: 30391B4BEAA34C0B5B2-8064
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 65B6D64BA66D6BD21B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DF4E8F5109D583A4C-8014
   Part No SW: 4H0 907 064 GR    HW: 4H0 907 064 GR
   Component: BCM2 2.0      H37 0572
   Coding: 0DAA6F4E000000000000
   VCID: 7F5B087767FD6373928-802A
   Serial number: 3215000194095005
   Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
   Serial number: 31011600040307
   Coding: 680330B85D0000
   VCID: 6A8DC9230CFFF6DB556-803E
   Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
   Component: BCM1 2.0      H20 0311
   Revision: 21020001    Serial number: 00001278356601
   Coding: 01050014043C8FE2E90048C7A0007800CF9CC308AE0802218000089C710017020060002D0B0000
   VCID: 76B5ED5348C7223BC1E-8022
   Component: WWS57X 151024  H38 0080
   Serial number:         151125220319
   Coding: 0045F7
   Serial number: 61255430
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 AN    HW: 4G0 941 531 AN
   Component: E1 - LDS  H07 0044
   Serial number: 21 01 2016  00001451
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z0226B719
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA122555000017818343
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: A7798E08000000000001
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0055
   Coding: 7E01010101
   ASAM Dataset: EV_AdaptCruisContrAU57X 002015
   VCID: 290FF62FC9793DC39CC-807C
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G0002VU2+
   Coding: 303331333131303134334A55304C34473853
   VCID: 3431175B1EBB702B3FA-8060
   Component: BF-Gewichtss.  H15 0046
   Serial number: 6940000Y150001FXN608
   Serial number: 3575HRB401C55ABC4H8Z
   Serial number: 3585HRB400S55ABAFPP%
   Serial number: 3515JRB40065566UPA2+
   Serial number: 3525JRB40633KVP4FHD+
   Serial number: 3554VRB4008558KMQ18L
   Serial number: 3564VRB4008558KM6935
   Revision: --------    Serial number: 90372OL50003X
   Coding: 0000FC
   VCID: 372B20570F4D9B331A8-8062
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 16 01 2016  C0042729
   Part No SW: 4G8 920 934 L    HW: 4G8 920 934 L
   Component: TBenRdwAccNv  H11 0106
   Revision: 09001101    Serial number: 658250116596029
   Coding: 0B8F01079F530008020300
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K_AU57.rod
   VCID: 3A2D39633CDF865BE56-806E
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002122187
   Coding: C0ED074814
   GVL: FD8FC9CCDCA3680D51040000
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 3B233C6733E5BF53FE0-806E
   Serial number: 1765058903
   Voltage stabilizer:
   Serial number: 15111500000000000165
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04018E64747464545425363E00
   VCID: 678BB0171F6DCBB34A8-8032
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   Serial number: 002101160001003
   VCID: 2809F32BD27304CB832-807C
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0112
   Serial number: 27011600042085
   Coding: 20
   VCID: 3E25357320F7AA7BD9E-806A
   Coding: 008002
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3B1837F79D53F3428-807A
   Revision: AA000000    Serial number: 00000181743892
   VCID: 77ABE0574FCD5B33DA8-8022
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E01Z4U%
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372B20570FCD9B331A8-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0060
   Serial number: 0392864284
   Coding: 040211
   VCID: 392F266F39D98D43ECC-806C
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0060
   Serial number: 0391742395
   Coding: 040211
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F57035E00628002000413
   VCID: 45D75A9F45A1F9A3984-8010
   Component: RCevo         H53 0202
   Revision: 00000003    Serial number: 0000579359
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   Revision: 00002001    Serial number: 0392260045
   Coding: 0126063A20BAF08580B00A8402030D470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000331279
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST000RC9W800000
   Coding: 101F02
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00018026172
   Subsystem 5 - Part No SW: 4G8 959 252 A    HW: 4G8 959 252
   Component: HSP-SG  H11 0031
   Serial number: WA122852000018975265
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93747413
   Part No SW: 4G8 035 223 C    HW: 4G8 035 223
   Component: MIB2_amp_PA   H02 0420
   Serial number: 00000000001138
   Coding: 0175530A018AF02A5A0000010F00
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
   VCID: 2517FA1FA56119A3B84-8070
0527 - Subwoofer
          B106C 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
                    Reset counter: 247
                    Mileage: 92304 km
                    Date: 2023.01.18
                    Time: 19:19:02
                    Voltage terminal 30: 12.3 V
1632 - Active Noise Cancellation
          B1765 F0 [008] - Engine Speed Implausible
                    Fault Frequency: 74
                    Reset counter: 46
                    Mileage: 92304 km
                    Date: 2023.01.18
                    Time: 19:01:31
   Component: TSG BF        H03 0511
   Coding: 011F57035E00628002000402
   VCID: 46D55D9378A7F2BB91E-8012
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001715350
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 313F1E4FE1A9450354C-8064
   Coding: 05FA021122600400
   Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7570
   Coding: E02000
   Subsystem 2 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7570
   Coding: E02000
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 4G1 035 047 L    HW: 4G1 035 047
   Component: MU-H-NS-US    043 0387
   Serial number: A280A0GB001843
   Coding: 017553020000000013220002041A00002F000DE4F17001047E
   VCID: 2B030C27C3852FD36E0-807E
   Subsystem 1 - Part No SW: V03 959 801 GE    HW: -----------
   Component: NAR 2016  --- 0048
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9FY803XZY
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349PB1000WK
   Compact disc data bank:
   Component: Gracenote2  --- 3006
          B11CF 53 [009] - Deactivated
                    Reset counter: 247
                    Mileage: 92304 km
                    Date: 2023.01.18
                    Time: 19:19:05
                    Voltage terminal 30: 12.4 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Component: TSG HL        H03 0511
   Coding: 010F17024000628002000002
   VCID: 49CF56AF69B91DC37CC-801C
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0361
   Revision: 11001001    Serial number: 82330JG0142409
   Coding: 0217000001010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
   Part No SW: 4G8 959 107 T    HW: 4G8 959 107 J
   Component: HDSG-Modul    H14 0049
   Revision: 12014001    Serial number: 348500935
   Coding: 0A3305C122
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 46D55D937827F2BB91E-8012
   Component: TSG HR        H03 0511
Address 82: Head Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G8 919 604 M    HW: 4G8 919 604 M
   Component: HeadUpDisplay H08 0306
   Coding: C60000
   ASAM Dataset: EV_HUDContiC7 001027
   ROD: EV_HUDContiC7.rod
   VCID: 3D27327F2DF1B163C04-8068
   Component: DPC-SG        H27 0081
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C010F3BC68B28EB67A-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E01010101
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   VCID: 270BF017DF6D0BB38A8-8072
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000622101167
   Coding: 03C1BA1A0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Component: RGS-VL        H14 0080
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   Component: RGS-VR        H14 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323D1143E4AF7E1B2D6-8066
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 151124200605
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813006248501
   ROD: EV_AEMLearAU64X_AU57.rod
End----(Elapsed Time: 02:42, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
This is a turbo-charged engine, right? What the ECU needs to know to do its job correctly is the temperature of the air going into the engine. The temperature of the air ahead of the turbos and intercooler is much less relevant.
Thus I would suppose that temperature is measured after the turbos and after the intercooler. And even if the turbos aren't doing much compressing at 1220 RPM, they're still hot and the air passing through them will pick up some of that heat.
Jef
HQ
Ohm spec for the camshaft adjuster valves is 12 to 20Ω at 20C... so technically, replace it. But before you do that, 0n bank 2, swap the intake and exhaust adjuster valves around and see if the code moves from intake to exhaust cam. If so, great, replace the valve. If not... :banghead:
2016-Audi-S7
Canada
C?ID=427330
It was probably 0C or lower in the garage when I did the Ohm test. Could be why it was ~8Ω. Wish I knew to bring it inside to warm up before testing it.
The bank 2 exhaust adjuster valve is the hardest to get to. I would probably be better off swapping it with the other bank instead to do that test.
I am starting to get really worried that it will end up not being the adjuster... only other thing I could think of would be that the VVT cam gear sprocket itself could be sticking or something. :facepalm: If it turns out to be, best case the symptom goes away in warmer weather and doesn't come back (maybe some oil flushes or something as well?). Worst case, I bet the entire engine has to come out in order to remove the gear.
Bruce
Near Philadelphia, PA, USA
I used to have a business winding coils..
I highly doubt you would see the coil change 4 ohms in 12C temp diff.. My guess is the lower resistance measured is because some of the turns have been shorted and if that be true, the induced magnetic field operating the solenoid would be reduced and perhaps changing the distance or the strength of the pull.
Your reading leads me to think that solenoid is not to spec.
I don't recall the specific temperature coefficient of copper wire - I'm sure I could look it up. Even super fine wire, I would not expect a 12C temp difference to reduce the value by 4 ohms. I'm not saying it is not possible but I am skeptical.
Given that it is hard to get to it - I get why you really want to be sure about it.
2016-Audi-S7
Canada
C?ID=427330
Thanks, that makes me feel a lot better about replacing it. Gives me hope!
I'll be replacing it shortly and will report back in a few weeks if no codes reappear. Helpful for anyone else who comes across the P0021 or the code for the other bank or exhaust solenoid.
Jef
HQ
So the coil might be looking a bit crispy like this coil... and there is something else wrong in that photo, 5 points to whoever spots it first.
Bruce
HEX-V2 ain't Blue...
2016-Audi-S7
Canada
C?ID=427330
Update: Put the new valve actuator part in yesterday. Before I did I tested the resistance at 8.2Ω at room temp. Tested the old part at room temp which was ~7.9Ω.
If the fault code doesn't come back it could be because there was something clogging up the valve or it was starting to go electrically on the inside. Will report back if all is good.... or bad.
Reactions: Jef
Gremling
Norway, Nordland
C?ID=319714
Dirty bad oil, how often do you change oil? Sticky VVT, contaminated channels, defect valve can cause this.
Can also be timing jumped a tooth, check in accordance with manual, to be sure.
Regards
Gremlig
2016-Audi-S7
Canada
C?ID=427330
Well it seems I should've triple checked before starting the work, but it appears that I mixed up the intake and exhaust cams even though I thought I was being super careful not to. I REALLY wish I mixed up the engine banks because Bank 1 is SO much easier to work on and access compared to Bank 2.
The bank 2 intake cam valve solenoid is buried under the coil pack harness.... so this is going to be a huge PITA to swap in.
Chain side is facing the rear of the car, so bank 2 is on the right hand side when facing the engine. Intake cam on the bottom right. Everything is in the way including the coolant tank. :banghead:
2016-Audi-S7
Canada
C?ID=427330
With the brand new OEM camshaft adjuster I have still received the EPC warning light and when checking the codes it's still a P0021. I even tried to blow out the oil passage ways with compressed air and outlined by Audi: Audi Technical Update - 1.0 TFSI Camshaft Diagnosis
My next step will be to try an engine flush and oil change in hopes that it clears or unsticks whatever is causing the issue. Otherwise I may be trying to access the camshaft timing chain while the engine is still in the car to see if the chain guide has disintegrated looks like it can be done while in the car based off of this: Audi Technical Service Bulletin to me though it is not necessary to remove the front bumper and cooling fan housing..... unless of course you have to in order to turn the crank.
I used VCDS to look at the Camshaft adaptation intake bank 1&2: phase position - in order to see if there is a mechanical issue. Bank 1 phase position was 2.83° and Bank 2 was 0.79° at idle. Is that a large discrepancy between banks? Luckily I have not experienced any misfires, rough idle, engine chain noise, loss of power or fuel mileage. It seems entirely electronic at this point.
Any suggestions where to go next?
Larry Manton
C?ID=112505
Your off a little over 2 degrees, don't know what is acceptable, but you are certainly not out a tooth. count the teeth, divide 360 by it and that is a tooth.
My guess do the oil change, hope for the best. Mentioned small red specs, and screens. Don't know how many screens are on this motor. And the red specs, maybe silicone from a repair, just talking out loud here.
2016-Audi-S7
Canada
C?ID=427330
Funny that the 2 degrees is off on the opposite bank that is throwing the code.
Appreciate the feedback on the oil and possible silicone. At first I thought maybe it was bits of the chain guide, but they should be rigid and not sure how they would make it up into the oil passages for the camshafts. Silicone makes sense if it is. After attempting to blow compressed air down through the hole I am starting to get the EPC more frequently, but it goes off more quickly. Before I went 500km without getting the EPC, but now after putting the new solenoid I am getting the light again. Oil change and time will tell....
Larry Manton
C?ID=112505
I know in doing dianostices with a scope they always say," WHAT DOES A GOOD ONE LOOK LIKE'? That is why it is always nice to capture data on a known good runnin unit.
Maybe some input from other players as I have none.
Larimore
Larry Manton
C?ID=112505
Audi Technical Update - 1.0 TFSI Camshaft Diagnosisa
After reading this, I'm thinking there is still some parts of an adjuster floating around in the system, probably at a screen again. My comment on silicon probably off, as adjuster are orange/yellow. If changing oil, tear open the oil filter and see what you find. 2egrees not a jumped tooth but adjustment not allowed to get back to zero, JMO.
Larimore
