- Jan 4, 2023
- 8
- 4
- East Yorkshire, UK
- C?ID=531536
Hi,
Boot (tailgate/trunk) handle has never opened boot on this car since my purchase - does nothing when pressed (squeezed..).
Boot opens with long press of the middle button on keyfobs only.
Never been that bothered until I shut the boot with the keys in and had to dismantle the very secure ski flap in rear seats from passenger compartment side (not easy with no tools) to retrieve key (was away from home).
I have replaced the full boot grip handle trim moulding 8E0827576 (not necessary but was very corroded and crap LED number plate lights were corroded and wedged in), the tailgate trunk handle push button 8E0827566 and the number plate light wiring harness 8E0971145 which includes the trunk handle microswitch.
From wiring diagrams, the trunk handle microswitch (F248) goes directly into the J393 Convenience system central control unit (5/10)
My next move would be to locate the Convenience system central control unit and check the loom between switch and unit.
Just wondering if there is any coding which could inhibit the switch, bearing in mind that when purchased the vehicle had wrong VIN and wrong coding (Avant with no light/rain senor) in central electronics unit.
Thanks,
Chris.
Thanks,
Chris.
Saturday,07,January,2023,18:03:07:12360
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
VIN: WAUZZZ8H17K000676 License Plate:
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
63 65 67 73 75 76 77
VIN: WAUZZZ8H17K000676 Mileage: 196820km-122298miles
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 8E0 910 559 Q HW: 8E0 907 559
Component: 3.2l V6 FSI 0020
Revision: --H16--- Serial number:
Coding: 01040003180F0120
Shop #: WSC 00672 785 00200
VCID: 3B233B808F66A453FE0-806E
VINID: 9D196AAAA2180476C00001871897D61152
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL
Component: ESP8 quattro H05 0120
Coding: 0004379
Shop #: WSC 00508 210 59464
VCID: 290FF1C875FA26C39CC-807C
Fault Status: 00101100
Hex Value: 0x0000
Hex Value: 0x4322
Hex Value: 0x0009
Hex Value: 0xB08E
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2832
Coding: 00100
Shop #: WSC 00672
VCID: 6D87C5D88482FAE3304-50F4
01810 - Actuating Motor for Temperature Flap; Right (V159)
41-10 - Blocked or No Voltage - Intermittent
01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
30-00 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 1107
Coding: 21001
Shop #: WSC 06441
VCID: 3D2735989462AA63C04-4AA4
Address 15: Airbags Labels: 8H0-959-655-94.lbl
Part No SW: 8H0 959 655 E HW: 8H0 959 655 E
Component: Airbag 9.42 H09 1840
Revision: 92H09184 Serial number: 0037Y0001LYE
Coding: 0071114
VCID: 3C21389C8A68A36BF7A-8068
Subsystem 1 - Serial number: 6332BRB4009B3B13J
Subsystem 2 - Serial number: 6342BRB4009B46BE.
Subsystem 3 - Serial number: 63729RB400C6EC43Y
Subsystem 4 - Serial number: 63829RB400C6EBD0/
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 R
Component: Lenksáulenmodul 0501
Coding: 04041
Shop #: WSC 00508
VCID: 42DD4664ED9CD59BBD6-4AA4
01301 - Control Module for Voice Recognition (J507)
49-00 - No Communications
Address 17: Instruments Labels: 8E0-920-9xx-8EC.clb
Part No SW: 8H0 920 981 E HW: 8H0 920 981 E
Component: KOMBI+WFS 4 H12 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0023411
Shop #: WSC 00508 210 91413
VCID: 323D16A4583C651B2D6-5118
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.clb
Coding: 0023411
Address 26: Auto Roof Labels: 8H0-959-255.clb
Part No: 8H0 959 255 A
Component: VSG B6 CABRIO 6792
VCID: 343110BCA2286B2B3FA-50F4
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8H0 035 192 A HW: 8H0 035 192 A
Component: RNS-E HIGH EU H70 0650
Revision: 01S Serial number: AUZBZ7E1201285
Coding: 0419717
VCID: 2517FDF819C202A3B84-5160
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8H0 951 178
Component: Innenraumueberw. 0411
Coding: 00001
VCID: 6FBBDFD08E8E08F3028-50AE
01350 - Alarm via Theft Warning System; Rear
43-00 - Closed
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8H0 959 433 H
Component: Komfortgerát T3B 4135
Coding: 06799
Shop #: WSC 00672
VCID: 392F2188804A9643ECC-4AA4
Subsystem 1 - Part No: 8H2959802D
Component: Tõrsteuer.FS BRM 1205
Component: Tõrsteuer.BF BRM 3020
29-00 - Short to Ground
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0419717
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Revision: 00H06000 Serial number: 00067802020532
Coding: 0000024
VCID: 313F19A85D0A5E0354C-5184
Part No SW: 8P0 862 335 F HW: 8P0 862 335 F
Component: FSE_255x BT H21 0190
Revision: 00000001 Serial number: 00000000350398
Coding: 0011802
VCID: 392F2188854A9643ECC-50D0
End----(Elapsed Time: 05:49, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
