Help with Air Bag Control Fault on 2003 Beetle Conv
rntrary
C?ID=55741
Yesterday morning cold start, AirBag light came on and won't go off.
Car has never been in an accident.
Scan below. Tried clearing the code but no luck.
Can VCDS reset this module?
Searching, the forum, found a post about similar issue but different module. Called dealer
to find my controller part number is no longer avail. Parts guy wasn't sure but thought
part number with E was replaced by AM 002, which needs special order. No luck searching
online for either of these to find out if thats a correct replacement.
TIA for your help here.
VIN: 3VWCK21Y53M301580
Address 15: Airbags Labels: 1T0-909-605.lbl
Control Module Part Number: 6Q0 909 605 E
Component and/or Version: 08 AIRBAG VW7 0418
Software Coding: 0012344
Work Shop Code: WSC 00066 000 00000
VCID: 392C2758254C6A93C8C-513C
00003 - Control Module
014 - Defective
Called dealer
Did you give the parts guy your VIN? What you have in there right now has Index 008, so I am a bit skeptical that an index 002 would be correct.
rntrary
C?ID=55741
yes, the first thing the parts guy asked for was my VIN.
How did you determine it is "index 8"?
rntrary
C?ID=55741
ah, that's how you decode it
is 6Q0 909 605 Am 008 correct?
no luck googling for it
any advice on how to clear the air bag light?
rntrary
C?ID=55741
What if I find a used module with same part number but unknown internal code.
Can VCDS overwrite the used module with my code?
Also
Can I drive the car with the airbag module removed?
No. That's a question of the parameter set in the airbag module.
Moreover, due to liability concerns, Ross-Tech does not provide support for the installation of used airbag components (and installing used airbag components is actually illegal in a number of States).
JMR
Romania
C?ID=432218
You can do so much more in Europe :).
Uhm, in much of Europe it's illegal to work on / repair airbag systems in cars without having a specific certification to do so.
JMR
Romania
C?ID=432218
ooooh..tell that to my people , bulgarians ,lithuanians, polish, serbs, croatians....they will disagree :))
I don't know whether such requirements exist in any of those countries, but even if they do, I doubt anyone there actually cares. :D
It doesn't really matter to me either. I'm simply explaining why Ross-Tech won't assist with such jobs. You see I have a strong aversion to spending money on lawyers, and given that the OP of this thread is in the USA, there is very much a question of liability.
rntrary
C?ID=55741
Sharing my solution.
I found a repair service in UK. Seller on Ebay is
transelot-ecus​
Shipping took a while...
Installed and my Airbag light behaves normal again; light goes out after engine starts!
VCDS says no faults!
If you have the skills, Youtube has some videos about repairing cold solder joints on these units.
Not sure if that was my issue but I can recommend Transelot.
Reactions: JMR
