- Jan 24, 2023
- 14
- 4
- Santa Cruz, CA, USA
- C?ID=536258
Hi all- recent owner of a 2007 Jetta. Bought it with only one key, so I went to local dealer to order new key and fob. They programmed chip and fob, now every time I unlock the doors, the trunk pops open. Prior to reprogramming, all worked just fine with original key, prior to the reprogramming. Now also the interior switchs located on DS door do not work for trunk and gas door. Dealer says I need new wiring harness for $1,000. Can’t believe it, because it worked fine when I handed it over to them. Below is scan with VCDS. Note, I am aware of clock spring/airbag code, coolant thermostat, the rear passenger door lock has always been inoperable, and radio antenna open circuit. All preexisting issues. I also checked in controller 42, and tested the gas door switch and it shows as inactive and then active when I pull up on it. The trunck switch does not test ok and the module for locking of rear lid (F327) does nothing and when I look at controller 46, I get an error of “Refused by control module.”
Wednesday,25,January,2023,20:56:03:44836
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
VIN: 3VWEF81K87M199726 License Plate: 6BFY986
Mileage: 125670km-78087mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWEF81K87M199726 Mileage: 125670km-78087miles
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 S HW: 07K 906 032 Q
Component: 2.5l R5/4V G 9652
Revision: --H01--- Serial number: VWZ7Z0G9031120
Coding: 0000003
Shop #: WSC 00066 000 00000
VCID: 392F210CD5536083ECC-806C
VINID: 0E69D558805B2077412491C218FF815096
008577 - Performance Malfunction in Cooling System
P2181 - 008 - - MIL ON
Fault Status: 11101000
Mileage: 125251 km
Time: 19:57:06
RPM: 2503 /min
Load: 79.6 %
Speed: 96.0 km/h
Temperature: 66.0°C
Temperature: 34.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.843 V
001110 - EVAP System
P0456 - 001 - Very Small Leak Detected
Fault Status: 01100001
Mileage: 125505 km
Time: 18:11:48
RPM: 700 /min
Load: 25.9 %
Temperature: 69.0°C
Temperature: 30.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.716 V
Part No SW: 09G 927 750 FL HW: 09G 927 750 FL
Component: AQ 250 6F 0920
Revision: 00H69000 Serial number:
Coding: 0000072
VCID: 00598CE8F609F14BEB2-8054
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73B3D324B7BFDAD3E60-8026
Part No SW: 1K0 820 047 GG HW: 1K0 820 047 GG
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
VCID: 6FBBDF54DB97FE33028-803A
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000000647201
Coding: 14058E234004150007140000001400000008730B5C0000
VCID: 6B83CB44EF8F02132E0-803E
Component: Wischer 160607 020 0501
Coding: 00038805
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 69 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M024SLB
Coding: 0013881
VCID: 6C81C858EA81052B27A-8038
Subsystem 1 - Part No: 1K0 959 339 F
Component: BF-Gewichtsens. 007 0005
Subsystem 2 - Serial number: 6332MSME19427907A
Subsystem 3 - Serial number: 6342MSME131508561
Subsystem 4 - Serial number: 6351HSME0D3A2F60G
Subsystem 5 - Serial number: 6361HSME0D7C183BN
Subsystem 6 - Serial number: 63727SME0D190D062
Subsystem 7 - Serial number: 63827SME0D190843%
Part No SW: 1K0 953 549 AP HW: 1K0 953 549 AP
Component: Lenksäulenmodul 036 0070
Coding: 0010021
Part No SW: 1K0 920 953 P HW: 1K0 920 953 P
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0G9031120
Coding: 0023207
Shop #: WSC 26101 444 89165
VCID: 38292408EE59798B132-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 060507F1000424
Coding: 3FBF034007001002
VCID: 2F3B1F541B17BE33428-807A
Component: IMMO 3HL 1610
Shop #: WSC 62481 004 1048576
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1133
Revision: 32008001 Serial number: 00000563978525
Coding: 0001205
VCID: 3B233B04DF6F5293FE0-806E
00109 - Left Mirror Turn Signal Lamp (L131)
Fault Status: 00101100
Reset counter: 139
Mileage: 125653 km
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Shop #: WSC 02069 000 90108
VCID: 34311038F2319DEB3FA-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: A_ KSG PQ35 RDK 052 0218
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F887F86081B0904058FB0880F0488DCA0
VCID: 045180F8E211ED6BCFA-8050
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1133
Revision: 32008001 Serial number: 00000556278531
Coding: 0001204
VCID: 3C213818DA6155ABF7A-8068
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 B HW: 1K0 035 161 B
Component: Radio DE2 014 0017
Revision: 00014000 Serial number: VWZ4Z7G6267409
Coding: 0040401
VCID: 1E65D2906CBD27BBF9E-804A
00856 - Radio Antenna
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1120
Revision: 12006001 Serial number: 00000001685898
Coding: 0001168
VCID: 3E253210CC7D47BBD9E-806A
Component: RDK 0440
Coding: 0100101
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1120
Revision: 12006001 Serial number: 00000001684355
Coding: 0001168
VCID: 3FDB4F14CB774EB3D28-806A
Fault Status: 01111000
Fault Frequency: 14
Reset counter: 100
Mileage: 125589 km
Fault Status: 01111100
Reset counter: 100
Mileage: 125589 km
End----------(Elapsed Time: 01:21, VBatt start/end: 12.4V/12.3V)-----------
Coding: 0000003
Mileage: 125251 km
Time: 19:57:06
RPM: 2503 /min
Load: 79.6 %
Speed: 96.0 km/h
Temperature: 66.0°C
Temperature: 34.0°C
Voltage: 13.843 V
Mileage: 125505 km
Time: 18:11:48
RPM: 700 /min
Load: 25.9 %
Temperature: 69.0°C
Temperature: 30.0°C
Voltage: 13.716 V
Coding: 0000072
Revision: 00H11001
Coding: 0021122
Coding: 00038805
Coding: 0013881
Coding: 0010021
Coding: 0023207
Coding: 0001205
Coding: 0001204
Coding: 0040401
Coding: 0001168
Component: RDK 0440
Coding: 0100101
Coding: 0001168
End----------(Elapsed Time: 01:18, VBatt start/end: 14.1V/14.1V)-----------
Coding: 0000003
Mileage: 125251 km
Time: 19:57:06
RPM: 2503 /min
Load: 79.6 %
Speed: 96.0 km/h
Temperature: 66.0°C
Temperature: 34.0°C
Voltage: 13.843 V
Mileage: 125505 km
Time: 18:11:48
RPM: 700 /min
Load: 25.9 %
Temperature: 69.0°C
Temperature: 30.0°C
Voltage: 13.716 V
Coding: 0000072
Revision: 00H11001
Coding: 0021122
Coding: 00038805
Coding: 0013881
Coding: 0010021
Coding: 0023207
Coding: 0001205
Coding: 0001204
Coding: 0040401
Coding: 0001168
Component: RDK 0440
Coding: 0100101
Coding: 0001168
