back to stock and DRL problems
elbcano718
C?ID=213134
im new to the vdcs wolrd, also my English is not so good.
How can I reset my vcds settings back to stock
Problems
1: my drl is active on my MFI but they don't come on when i disengage the E-brake
2: I bought a uspmotorsports RBF automatic headlight conversion kit and im having some problems for when I turn on my parking light my low beam also comes on
3: im getting the light indicator because i installed some led back up lights, how can I clear that up
elbcano718
C?ID=213134
Chassis Type: AJ (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 72
VIN: WVWGD7AJ7CW092017   Mileage: 63590km-39512miles
Address 01: Engine (CBF)       Labels: 06J-907-115-CBF.clb
   Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
   Revision: E3H26---    Serial number:
   Coding: 0403010818070160
   VCID: 78FFBAB40B0718E156F-802D
005924 - Starter Interlock Signal
               P1724 - 000 - Short to Ground - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    RPM: 161 /min
                    Load: 81.9 %
                    Temperature: 96.0°C
                    Temperature: 55.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 10.922 V
050217 - Implausible Data Received from Steering Column Control Module
               U0429 - 000 -  - Intermittent
                    Mileage: 63080 km
                    Date: 2015.07.17
                    Time: 13:02:29
                    RPM: 1231 /min
                    Load: 9.0 %
                    Temperature: 96.0°C
                    Temperature: 54.0°C
                    Voltage: 12.065 V
005386 - Engine Off Timer Performance
               P150A - 000 -  - Intermittent
                    Mileage: 63353 km
                    Date: 2015.07.19
                    Time: 19:54:30
                    RPM: 1016 /min
                    Load: 14.5 %
                    Temperature: 87.0°C
                    Temperature: 73.0°C
                    Voltage: 11.938 V
   Revision: 00H31001
   Coding: 114B600C492B00FC880B06E592200041B70800
   VCID: 7BF5A5B8FA3133F93BD-802E
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0404
   Revision: 00001015
   Coding: 0000001002
   VCID: 000FD2549BD750216EF-8055
   Part No SW: 1K0 937 086 P    HW: 1K0 937 086 P
   Component: BCM PQ35  M   110 0651
   Revision: 00110 AC
   Coding: 6F180A1A90272AC4008800C170000D4448052086434D8D20E48420240040
   VCID: 3D716BA0A4A5FDC9459-8068
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 12081  26  0512
   Coding: 009795
00332 - Control Circuit for Tank Flap
                    Fault Status: 00100111
                    Reset counter: 240
                    Mileage: 62827 km
                    Date: 2015.07.15
                    Time: 11:13:36
                        Term 15 Off
                    Voltage: 12.30 V
                        Term 50 Off
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 24
                    Reset counter: 200
                    Mileage: 63341 km
                    Date: 2015.07.19
                    Time: 18:21:32
                    Voltage: 12.30 V
                        Term 50 On
                    Fault Frequency: 24
                    Reset counter: 200
                    Mileage: 63341 km
                    Date: 2015.07.19
                    Time: 18:22:12
                    Voltage: 12.30 V
                        Term 50 On
   Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
   Component: AirbagVW10G   013 0724
   Serial number: 003GVRA0GXDK
   Coding: 00003131
   ROD: EV_AirbaVW10SMEVW360_SK35.rod
   VCID: 3F8D11A8A6A9EFD9575-806A
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--00060WHR00
   Serial number: 3572MSME2C6B1363ZZZ.
   Serial number: 3582MSME7E015362ZZZW
   Serial number: 3512QSME76035D61ZZZW
   Serial number: 3522QSME4E445A46ZZZ0
   Serial number: 35527SME4A1B1728ZZZK
   Serial number: 35627SME5B341728ZZZI
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Revision: --------    Serial number:  90422KGT000RI
   Coding: 108A140000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 72EB889CA57B72B168B-8027
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0428503
   Coding: 820000
   Part No SW: 5K6 920 972 C    HW: 5K6 920 972 C
   Coding: 270F01
   VCID: 3663748C89932E91843-8063
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 030811F1001134
   Coding: 350002
   VCID: 356173809C9525898D9-8060
   VCID: 6ADB90FC8DABBA71D0B-803F
   Revision: A1001003    Serial number: 7660641902
   Coding: 020000
   VCID: 2959AFF0402D7169191-807C
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H32 0265
   Serial number: VWZAZ2L8465234
   Coding: 04000401040005000000100A
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 2345BDD82A01AB3953D-8076
   Component: NAR_V2  0002
1048669 - Tuner for Satelite Radio
          B11CF 53 [008] - Deactivated
                    Reset counter: 238
                    Mileage: 40448 km
                    Date: 2014.01.04
                    Time: 19:42:07
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2119
   Coding: 0001204
   VCID: 31694790A8FD09A9D11-8064
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 74     3201
   Revision: 00H20000
   VCID: 34674E8457EF3C81BA7-8061
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0001204
   VCID: 326B489CADFB32B1A8B-8067
   Coding: 1446940
   Subsystem 1 - Part No: 7L6 941 329 B
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B
   Coding: 00000022
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 356173805C9525898D9-8060
   Coding: 0001168
   VCID: 3663748C41932E91843-8063
End-------------------------(Elapsed Time: 02:20)--------------------------
In the Debug sub-folder where you installed VCDS, typically C:\Ross-Tech\VCDS\Debug\ there will be a file called Coding-Log.txt; it will contain a list of all the changes you made.
elbcano718
C?ID=213134
thank you for your help
