I've replaced a faulty level sensor on the right front (dealer part)- Following the procedure in UDS - re-adapt adaptive suspension exactly - as well as performing login between steps, waiting extra time in between steps, quickly changing steps immediately after finishing each, filling all bags and res fully before starting, capacitive discharge before starting... I've made at least 40 attempts...always the same result.
Set reference level - go - 10-45 seconds pass, then "abort due to safety reasons".
As far as I know there have been no issues with air leaks - level sensors read appropriately when raising and lowering the vehicle. All other output tests and basic settings finish without error.
Friday,27,January,2023,09:36:54:35376
VCDS Version: 22.9.0.0 (x64) HEX-NET CB: 0.4623.4
VIN: WAUA2AFD7DN029340 License Plate:
Mileage: 152633km-94841mi Repair Order:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 34 36 3B 3C 42 46 47
52 53 55 56 5F 62 6C 6D 6F 72 81 85 88 89 8B 8E 8F 90 BA
VIN: WAUA2AFD7DN029340 Mileage: 152633km-94841miles
85-On Board Cam. -- Status: Malfunction 0010
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CEUA) Labels:. 079-907-560-CFS2.clb
Part No SW: 4H0 906 014 B HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0003
Revision: NCH62--- CVN: 4971D238
Coding: 022A00326546010E1000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM40TFS0114H0906014B 001003
ROD: EV_ECM40TFS0114H0906014B.rod
VCID: 220825723545C19D75-8076
VINID: 9D19510915941D47800890C4003A123216
Readiness: 1110 0101
Part No SW: 4H1 927 158 BK HW: 0BK 927 156 AG
Component: 0BK 40TFSIUSA H16 1004
Revision: --H16--- CVN: F6CB456D
Coding: 000002
ASAM Dataset: EV_TCMALX51011 002020
VCID: 7AB83D12FD55695D0D-802E
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 E HW: 4H0 907 379 E
Component: ESP PREMIUM H10 0352
Coding: C4E5B30023A7CD00E200
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_005_AU64.rod
VCID: 3424D32A9FB15F2D97-8060
Part No SW: 4H0 907 064 CD HW: 4H0 907 064 CD
Component: BCM2 2.0 H33 0433
Coding: 0DA72046000000000000
VCID: 6D92064EB41BCEE598-8038
Serial number: 2313000038734007
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000055153361
Coding: 0018320000047201000001010101112131313333282020
VCID: 3424D32A97B15F2D97-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 K HW: 4H0 820 043 K
Component: Klima 2 Zonen H20 0130
Coding: 6801202E7C
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_001_AU64.rod
VCID: 281C375A53792BCD2B-807C
Part No SW: 4H0 907 063 CD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial number: 00000001531425
Coding: 02002091163C9FE3CB008807A0003908009CD30886000121800008406000
VCID: 6C940B4A8F01C7ED8F-8038
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 130218 H35 0080
Serial number: 130301154621
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10317378
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 D HW: 4H0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 08 02 2013 00001666
Component: USHL4.2 H30 0030
Serial number: 0000002274555R58MF02
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA104972000003066675
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 5E98CA96000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061307501426
Coding: A80B02
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71AA1A3EA0232A05BC-8024
Part No SW: 4H0 907 561 B HW: 4H0 907 561
Component: ACC3 H19 0410
Coding: 7E01010101
ASAM Dataset: EV_AdaptCruisContrAU64X 002021
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2A18CD524D7519DD3D-807E
88064 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_MAR_SLOW_MISALIGNMENT]
Reset counter: 109
Mileage: 152633 km
Date: 2023.01.26
Time: 18:19:25
Control Module temperature: 26 °C
Voltage terminal 15: 14.129 V
88320 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_MAR_FAST_MISALIGNMENT]
Reset counter: 109
Mileage: 152633 km
Date: 2023.01.26
Time: 18:19:25
12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_MAR_PRE_MISALIGNMENT]
Fault Frequency: 9
Reset counter: 109
Mileage: 152633 km
Date: 2023.01.26
Time: 18:19:25
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FAULT_CIS_VIDEO_FAIL]
Fault Frequency: 9
Reset counter: 109
Mileage: 152633 km
Date: 2023.01.26
Time: 18:19:25
Part No SW: 4H0 959 655 D HW: 4H0 959 655 D
Component: Airbag10.43 H45 0042
Revision: -------- Serial number: 003JS001FVFQ
Coding: 303143303230303030314A55304C34483053
VCID: 373EE4268EC7B435B2-8062
Subsystem 1 - Part No SW: 4H0 959 339 A HW: 4H0 959 339 A
Component: BF-Gewichtss. H03 0040
Serial number: 5850000R1321506AN2
Serial number: 3575HRB400A50ED6H91P
Serial number: 3585HRB400A50ED6H0JZ
Serial number: 3515JRB401I50FSMA1IL
Serial number: 3525JRB401850FSMQ22D
Serial number: 3554VRB401450DLOFPF+
Serial number: 3564VRB401050DLOJ0VX
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815MC90001I
Coding: 0000BC
VCID: 373EE42686C7B435B2-8062
Subsystem 1 - Part No SW: 4H0 951 528 L HW: 4H0 951 528 L
Component: E221 - MFL H09 0010
Serial number: 28 09 2012 33299236
Part No SW: 4H0 920 980 K HW: 4H0 920 980 K
Component: TBenUSAACC--- H50 0515
Revision: 34081076 Serial number: 658160313592013
Coding: 0B4608015F40D705020000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU64.rod
VCID: 3326D0369ABF58158E-8066
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 H HW: 4H0 919 204 H
Component: Analoguhr D4 H05 0225
Serial number: 2130312001866
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4H0 907 468 AC HW: 4H0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000857589
Coding: 00ED074800
GVL: FFAFE80CFEE3E0CCC100
ASAM Dataset: EV_GatewPkoUDS 001018
VCID: 72A81532A525111D45-8026
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 50065F42571911093982
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Serial number: 13071001482011200410
U140B 00 [008] - -
[Powermanagement active]
Reset counter: 149
Mileage: 152633 km
Date: 2023.01.27
Time: 06:17:56
Voltage terminal 30: 12.0 V
Voltage terminal 15: 0.0 V
Control Module temperature: 11 °C
System status: Awake_Timer_active
IN ESP_standstill flag: no standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 1
Part No SW: 4H0 907 553 E HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0099
Coding: 008002
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E10C142719D75FDE1-807A
C10C8 00 [009] - -
Reset counter: 109
Mileage: 152633 km
Date: 2023.01.26
Time: 18:44:14
367877 - Ride Height Not Learned
C1044 00 [009] - -
Reset counter: 109
Mileage: 152633 km
Date: 2023.01.26
Time: 18:44:14
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000055132885
Coding: 00183B0000057201000001010101112131313333202020
Part No SW: 4H0 907 637 K HW: 4H0 907 637 F
Component: SARA 6D H02 0056
Revision: -------- Serial number: EJ1BPA7700N2WM
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4H0 907 566 A HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial number: 6PZ 010 287-07
Coding: 0000001
VCID: 2E10C142B99D75FDE1-807A
Subsystem 1 - Part No: 4H0 907 568 A
Component: J770 SWA Slave H02 0040
Subsystem 2 - Serial number: 6PZ 010 287-27
Subsystem 3 - Serial number: 5F19.03.1300H02000AMS15118ÿ
Subsystem 4 - Serial number: S15118ÿ
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H06 0273
Revision: -------- Serial number: 0000055479225
Coding: 011F1F005E00628202003013
VCID: 48DC97DAFB39CBCDCB-801C
Revision: 00002001 Serial number: 0303073432
Coding: 0106023A00FA7585B0B0C7C4020301070000000000000000000000000000
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000132258
Subsystem 3 - Part No SW: 4H0 959 591 HW: 4H0 959 591
Component: J245 PS50.030 H07 0006
Serial number: WOO2041168$
Coding: 101F00
Subsystem 4 - Part No SW: 4H0 947 135 BK HW: 4H0 947 135 BK
Component: Dachelektroni H13 0080
Serial number: A2013000000000690909
Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS010 H06 0005
Serial number: WOO1000X02A
Subsystem 6 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84362909
Part No SW: 4G1 035 223 A HW: 4G1 035 223 A
Component: BOSE-G3C7-ANC H02 0540
Revision: CJ002700 Serial number: 00000000006041
Coding: 030000
VCID: 1C741B8A1F21F76DBF-8048
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0273
Revision: -------- Serial number: 0000055336407
Coding: 011F1F005E00628202003003
VCID: 3C34FB0ABFE1976D5F-8068
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000629892
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B16C856428F00D5C6-807E
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 C HW: 4H4 907 357 A
Component: ....AFS13.... H01 0020
Serial number: 130318-0004-020
Coding: 12116F33301AA500
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
VCID: 3228D53265A5511D85-8066
H02 0010
Coding: 1C0000
H02 0010
Coding: 1C0000
120589 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[Fehlerhaftes Signal in CAN-Message Fahrwerk_01_FR (0x108)]
Reset counter: 109
Mileage: 152633 km
Date: 2023.01.26
Time: 18:19:29
Part No SW: 4H0 035 082 E HW: 4H0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 155C10D7527938
Coding: 020007010000000001
VCID: 23062076225FC8957E-8076
Part No SW: 4H0 035 746 E HW: 4H0 035 746 C
Component: H-BNT-NA H50 0622
Revision: -------- Serial number: 183CV0D7507512
Coding: 020200000001F9EF7D128B1E00000003140001000000000000
VCID: 2A18CD52457519DD3D-807E
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 4H0 919 604 G HW: 4H0 919 604 G
Component: DU8 D4 SV NB H48 0021
Serial number: AUZ8ZDDC9007GEU
Subsystem 3 - Part No SW: 4H1 919 600 H HW: 4H1 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000108741
Component: CD-Database 4949
Reset counter: 109
Mileage: 152633 km
Date: 2023.01.26
Time: 18:19:37
Voltage: 14.10 V
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0273
Revision: -------- Serial number: 0000055500442
Coding: 010F1F004000628202003003
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4H0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J32D029
Coding: 1080002
VCID: 26003962916D3DBD19-8072
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 AB HW: 4H0 959 107 M
Component: HDSG-Modul H11 0043
Revision: 10011001 Serial number: 066300612
Coding: 0210044100
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6E900142B11D35FDA1-803A
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000101702
Coding: 200000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 638660766ADF88953E-8036
Component: TSG HR H06 0273
Revision: -------- Serial number: 0000055498752
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H08 0083
Revision: 0L0D5015 Serial number: SN130131 0557
ROD: EV_GSM2x3Mono_AU64.rod
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Coding: E9060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 26003962596D3DBD19-8072
0793 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[EGD_Fahrwerk_01_Permanent_Error]
Reset counter: 109
Mileage: 152633 km
Date: 2023.01.26
Time: 18:19:27
Outside temperature: -41.0 °C
Voltage terminal 15: 13.9 V
Control Module temperature: 35.0 °C
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 G HW: 4H0 907 182 G
Component: IVB H08 0042
Serial number: 00010371187402
Coding: 602FF2
ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00010371182301
Coding: 202FF2
Part No SW: 4H0 907 541 B HW: 4H0 907 541
Component: ACC3 H19 0400
Coding: 7E01010101
ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
ROD: EV_AdaptCruisContr2AU64X_002.rod
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H31 0041
Serial number: 005000121503137
Coding: 01A19A000111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0161 - Video Cable for Image Processing
C1107 02 [009] - Signal Failure
[No_camera_found_on_startup]
Fault Frequency: 8
Reset counter: 109
Mileage: 152633 km
Date: 2023.01.26
Time: 18:19:34
Outside temperature: 18.5 °C
Voltage terminal 15: 14.2 V
Control Module temperature: 24.0 °C
Component: RGS-VL H13 0080
Coding: 0066F609031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 312ADA3E60A36A05FC-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H05 0006
Revision: 00001001 Serial number: 97804001648504
ASAM Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X.rod
VCID: 6680796299EDFDBDD9-8032
1295 - Drivetran Mounting
C1154 02 [009] - Signal Failure
Reset counter: 109
Mileage: 152633 km
Date: 2023.01.26
Time: 18:19:27
End----------(Elapsed Time: 02:59, VBatt start/end: 13.2V/13.7V)-----------
