2009 VW Tiguan ABS coding
phil.autolec
C?ID=73211
Could you give e suggested coding for this vehicle, attatched file
Tuesday,24,January,2023,14:35:47:44551
VCDS Version: 22.10.0.1
Dealer/Shop Name: Autolec
VIN: WVGZZZ5NZ9W044467   License Plate: YC09UWS
Mileage: 177460km-110268mi   Repair Order:
Chassis Type: 5N (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 53 56 62 72
VIN: WVGZZZ5NZ9W044467   Mileage: 177460km-110268miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 997 016 H    HW: 03L 906 022 G
   Component: R4 2.0l TDI 0000AG  9978
   Revision: 13H01---    Serial number: VWX7Z0H83NF8E4
   Coding: 0000175
   Shop #: WSC 80093 222 71269
   VCID: 3779618F46E3833573-8062
   VINID: 9E65EAAAA15EA899C01041061C62973515
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 177462 km
                    Time: 13:18:58
                    RPM: 782 /min
                    Lambda: 11.0 %
                    Lambda: 1.6 %
                    Voltage: 0.304 V
                    Bin. Bits: 00000000
000406 - Engine Oil Temp. Sensor (G8)
               P0196 - 000 - Implausible Signal
                    Mileage: 177462 km
                    Time: 13:19:03
                    RPM: 782 /min
                    Content: 0.0 mm
                    Content: 27.0 mm
                    Temperature: 67.5°C
                    Temperature: 17.1°C
                    Temperature: 79.2°C
               U1017 - 000 -  - MIL ON
                    Mileage: 177463 km
                    Time: 00:00:43
                    RPM: 989 /min
                    Voltage: 14.44 V
                    Torque: 0.0 Nm
                    Hex Value: 0xFF00
                    Bin. Bits: 00000110
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Voltage: 0.00 V
                    Hex Value: 0xFF00
                    Bin. Bits: 00000000
                    Temperature: -90.0°C
Readiness: 1 1 0 0 1
   Part No SW: 09G 927 750 FD    HW: 09G 927 750 FD
   Component: AQ 250 6F           1124
   Revision: 00H76000    Serial number:
   Coding: 0000328
   Shop #: WSC 01324 785 00200
   VCID: 78FBA2B30B7D4C4DBA-802C
Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
   Part No SW: 5N0 614 517 L    HW: 5N0 614 517 L
   Component: J104    C2 450 V2   0006
   Revision: --H12---    Serial number: 00000001431582
   Coding: 0010000
                    Hex Value: 0x0000
                    Voltage: 0.00 V
                    Bin. Bits: 00000000
                    Count: 166
                    Hex Value: 0x0000
   Part No SW: 1K0 820 047 HM    HW: 1K0 820 047 HM
   VCID: 76E7AC8B01693A3DA8-8022
   Revision: 00H54000    Serial number: 00000008883058
   Coding: E5880FA300041C0047190000140000000008FF475C400124390000000000
   VCID: 3361559F529B6F154F-8066
   Subsystem 1 - Part No: 5N2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 200808  012 0203
   Coding: 00038805
   Shop #: WSC 01324
   Component: RLS     150908 046  0204
   Coding: 00208933
   Shop #: WSC 01324
                    Fault Status: 01101100
                    Reset counter: 146
                    Voltage: 8.55 V
   Component: J234__201 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPJ37EU.
   Coding: 0012337
   Shop #: WSC 01324 020 00200
   VCID: 3B717DBF7ACBA75597-806E
   Subsystem 1 - Serial number: 6333FTS677832318
   Subsystem 2 - Serial number: 6343FTS679992318
   Subsystem 3 - Serial number: 6353ETS6936OUVNP
   Subsystem 4 - Serial number: 6363ETS6RRJOUVNH
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Component: J0527           752 0101
   Coding: 0010012
   VCID: 77F9A18F06634335B3-8022
   Part No SW: 5N0 920 970 D    HW: 5N0 920 970 D
   Component: KOMBIINSTRUMENT VDD 2420
   Revision: V0004000    Serial number: VWX7Z0H83NF8E4
   Coding: 0007404
   Shop #: WSC 06594 067 57207
   VCID: 326F509BAD81661D44-8066
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 146
                    Mileage: 177463 km
                    Time: 00:35:58
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 030908F2001486
   Coding: FD827F060002026003
   VCID: 35656B875CEF712561-8060
   Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
   Component: Haldex 4Motion      0041
   Coding: 0000005
   VCID: 4B912D7F2A6B17D527-801E
   Component: IMMO            VDD 2420
   Part No SW: 5N0 959 701     HW: 5N0 959 701
   Component: Tuer-SG         006 1206
   Coding: 0000700
   VCID: 72EF909B6D01261D84-8026
   Part No: 5N0 909 144 C
   Component: EPS_ZFLS Kl. 202    2303
   Revision: 00H15000
   VCID: 316D5F97A8875D053D-8064
            000 - - - MIL ON
                    Mileage: 177463 km
                    Time: 00:35:58
                    Battery Volts: 11.7 V
                        DD
                    Temperature: 6.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Component:    KSG PQ35 G2  020 0205
   Coding: 81800A0052830C7F3F04840570085FCE90FC00
   VCID: 0301C55F42BB1F959F-8056
   Subsystem 2 - Part No: 1K8 951 171
   Component: DWA-Sensor      001 0104
00332 - Control Circuit for Tank Flap
                    Fault Status: 00110111
                    Reset counter: 186
   Part No SW: 5N0 959 702     HW: 5N0 959 702
   Coding: 0000700
   VCID: 73E1959F121B2F158F-8026
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H20       Serial number: 00000000218517
   Coding: 0023057
   Shop #: WSC 12345 321 54321
   VCID: 387B62B34BFD8C4D7A-806C
            013 - Check DTC Memory
                    Fault Status: 01111101
                    Reset counter: 146
                    Mileage: 177463 km
                    Voltage: 11.60 V
                    Count: 69
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0101
02432 - Supply Voltage for Left Parking Brake Motor (V282)
                    Reset counter: 146
                    Mileage: 177463 km
                    Voltage: 13.90 V
                    Count: 29
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0101
02434 - Supply Voltage for Control Module for Left Channel
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 146
                    Mileage: 177463 km
                    Voltage: 13.90 V
                    Count: 15
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0101
03263 - Functional Restriction
                    Fault Status: 01101000
                    Reset counter: 146
                    Mileage: 177463 km
                    Voltage: 14.10 V
                    Count: 135
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0110
                    Fault Status: 01110000
                    Reset counter: 146
                    Mileage: 177463 km
                    Voltage: 11.10 V
                    Count: 41
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 01110101
                    Reset counter: 146
                    Mileage: 177463 km
                    Voltage: 11.10 V
                    Count: 99
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0101
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3H3352242
   Coding: 0500040004
   VCID: 65C5FBC76CCFC1A511-8030
   Part No SW: 5N0 959 703     HW: 5N0 959 703
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 01324 785 1012552
   VCID: 74E396831715282D96-8020
   Part No SW: 5N0 959 704     HW: 5N0 959 704
   Coding: 0000144
   VCID: 75E5AB871C6F3125A1-8020
End-------------------------(Elapsed Time: 02:06)--------------------------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
VIS - In most cases, the coding for that module is 0011551 but I do not know how about RHD.
Next are 0010527, 0011554 and 0010530.
etz2k
C?ID=69430
That's looks close. With RHD, it would be: 0014626
I think we would need to see the PR Codes for this vehicle to be really confident though.
if with iTPMS this should be correct
and if there is no iTPMS i think it should be: 6434.
and if it has a offroad-button the code is different again.
Boki Ar
C?ID=57300
@autocomsoft, what do you think, would it be good to include this coding in the database. ;)
:cool:
etz2k
C?ID=69430
:cool:
They can't do this, because her system is not really "coding", it shows you only the codings that are used by cars, where there simple system "think" it's the same. If you want a correct coding it's better to use a different methode.
Hi guys,
I came up with the same value that Uwe did (0014626) when I looked into the email for this vehicle.
On a different note I missed these when I replied:
The cause of those caliper DTCs may need to be addressed before you get 03-ABS to accept coding and run Basic Settings. I would check all of the fuses to the 53-Parking brake module prior to digging into the wiring and calipers at the back based on this one:
etz2k
C?ID=69430
Are you shure this car has no Offroad option?
Normally im shure the coding from wojciech300 is 100% like the car was sold by VW. Sometimes only his VIN-bytes are wrong, but that's for a different reason.
NEtech
Denmark
C?ID=56995
How do you define Off-road? any PR-code?
I have different 2009 Tiguan with CBA engine, all with Bit 6 active.
Some PR-Code 8LG (Additional switch for off-road), some with 8LA
So does not look like it depends on off-road switch.
Boki Ar
C?ID=57300
We can only hope that the OP comes from somewhere with feedback... :cool:
  • Agree
