I will try to go directly to the problem.
During Christmas holidays I connect VCDS (22.9.0) to the car and play a little bit.
I go to 42-Door Electric Driver -> Output Test - 03 -> Then select IDE04587 Mirror Fold In -> Start
and mirror fold in.
At the end of my tests, I restart VCDS and Update notification appears and I agree. (22.10.0).
Also New Firmware Update for HEX2 was available and done.
I didn't use VCDS since then.
The problem:
This weekend I decide to do same test (fold the mirror) and this is not working anymore.
No possible to do any kind of tests in any menus, result is the same:
This output is not supported by control module
Message 7F 2F 31
Picture with Error
It does not matter if select Action ON or OFF, and Command time Unlimited or 30 sec
I Uninstall and Install 22.10.0 - nothing change
Try with 22.9.0 - same result - no possible to do any tests
And 22.3.1 - Test Mirror Fold In - same result 7F 2F 31
Test lights (on the door). Test started but nothing happened
Best regards!
and mirror fold in.
The problem:
Message 7F 2F 31
Picture with Error
Monday,23,January,2023,16:39:42:16365
VCDS Version: 22.10.0.1 HEX-V2 CB: 0.4622.4
Data version: 20221213 DS344.0
VIN: WAUZZZFY3L2007397 License Plate:
Chassis Type: FY-AU49 (8W7)
Scan: 01 02 03 08 09 13 15 16 17 18 19 29 39 3C 42 44 46 47 52 5F
6C 6D 74 81 82 8B A5 AC BB BC CA CF D6 D7
VIN: WAUZZZFY3L2007397 Mileage: 34214km-21259miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DCPC) Labels: None
Part No SW: 80A 907 401 L HW: 059 907 309 L
Component: 3.0l V6 TDI H26 0001
Revision: CAH26--- CVN: BDB18E58A30C3AD38947E11D8947E11D00000000D6C3ECFE
Coding: 2A2A403A036E050334380000000000000000000000000000
Shop #: WSC 15089 005 1048576
ASAM Dataset: EV_ECM30TDI01180A907401L 001001
ROD: EV_ECM30TDI01180A907401L.rod
VCID: 2A41C671A04013CFA96-807E
VINID: 9D196AAAA5A90DC0800070C91C2E2F3180
Part No SW: 80A 927 158 AC HW: 0D5 927 156 H
Component: 0D5 30TDIRdW H05 0001
Revision: --H05--- CVN: 8A611EAA
Coding: 100000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMALX52011 002013
ROD: EV_TCMALX52011_AU49.rod
VCID: 6D0448269C918134B14-8038
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PRE-V1.clb
Part No SW: 80A 907 379 AA HW: 80A 907 379 A
Component: ESP9 Premium H16 0777
CVN: 92C6B8A1
Coding: 1CAA30BE30A20A9D91A1589A188452A2E5B5DA380C0C50891A184A45A7AD5B
ROD: EV_ESP9BOSCHCMP_004_AU49.rod
VCID: 6E054E2590947B2B89E-803A
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 80A 820 043 N HW: 80A 820 043 N
Component: Klima Zone 3 H60 0251
Coding: 6618481D5544410D02000100080000000000000000000000000000000000
ROD: EV_AirCondiBHTCAU491.rod
VCID: 2843C277A83A1FD1D92-807C
Subsystem 1 - Part No SW: 4M1 820 021 C HW: 4M1 820 021 C
Component: J126 FLuftV H09 0004
Serial number: 00000000000003685839
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 083056A900PAG0MUFU02
Subsystem 3 - Part No SW: 80A 919 158 HW: 80A 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 DG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0313
Coding: 07501F43C13900CD050D51199CAF80F9130B31080000000000000000600016810A4502AB22B70A
ASAM Dataset: EV_BCM1BOSCHAU736 019008
ROD: EV_BCM1BOSCHAU736_019.rod
VCID: 03AE74E4C483FDDEE10-8056
Subsystem 1 - Part No SW: 80B 955 119 A HW: 80B 955 119
Component: 426 LL 190627 040 0581
Serial number: 00000001906142105563
Coding: FFC7F7
Serial number: 23117796X81A955555A0
Coding: 02006E
Subsystem 3 - Part No SW: 4M0 941 531 AH HW: 4M0 941 531 AH
Component: E1 - LDS H06 0008
Serial number: 22 07 2019 92030449
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE117071923610078
Interior Light Module:
Subsystem 5 - Part No SW: 80A 947 135 BJ HW: 80A 947 135
Component: Dachmodul H42 0415
Serial number: Q00000505
Coding: 0D0101
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 80A 907 561 D HW: 8W0 907 561
Component: LRR4 H10 0340
Coding: 3477E7F358FFEC0A949881A0
ASAM Dataset: EV_ACCBOSCHAU49X 003022
ROD: EV_ACCBOSCHAU49X_003_AU49.rod
VCID: 2940C072AC3D19C8D1C-807C
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 80A 959 655 N HW: 80A 959 655 N
Component: AirbagVW30 051 0605
Serial number: 003WBM0C4MR4
Coding: AACCF0C00C800000985400FFF00C400000C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
VCID: 3E75EEB5D0A49B7B09E-806A
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2040
Serial number: 80A857705L0163T00264
Coding: 88001B
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2040
Serial number: 80A857706L0164T00138
Coding: 88001B
Subsystem 3 - Part No SW: ----------- HW: 480 001 905 19
Serial number: 3570000000000C11CC3D
Subsystem 4 - Part No SW: ----------- HW: 480 002 105 19
Serial number: 35800000000504705B38
Subsystem 5 - Part No SW: ----------- HW: 480 031 406 19
Component: SideSensor_Dr 002 0149
Serial number: 351001C208123D90AC73
Subsystem 6 - Part No SW: ----------- HW: 480 031 406 19
Component: SideSensor_Pr 002 0149
Serial number: 352001C207137D90AE58
Subsystem 7 - Part No SW: ----------- HW: 480 032 206 19
Component: FrontSensor_D 002 0149
Serial number: 355001C208D3F100ECEM
Subsystem 8 - Part No SW: ----------- HW: 480 032 206 19
Component: FrontSensor_P 002 0149
Serial number: 356001C208D37640AEBJ
Subsystem 9 - Part No SW: ----------- HW: 480 030 107 19
Component: PedP_Sensor_C 002 0149
Serial number: 230001C208F9BE207B5G
Subsystem 10 - Part No SW: ----------- HW: 480 001 406 19
Serial number: I0M00000000CD1D8CCB-
Subsystem 11 - Part No SW: ----------- HW: 480 001 406 19
Serial number: I0N00000000DD1D8CCB
Central crash sensor X/Y:
Subsystem 12 - Part No SW: ----------- HW: 480 020 705 19
Component: CentrSensorXY 000 0108
Serial number: I0O0001BD2A66534D1C0
Part No SW: 80A 907 129 CH HW: 80A 907 129 CH
Component: Lenks.Modul H02 0005
VCID: 703B525F88A26FD9992-8024
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 E HW: 8W5 920 790 E
Component: FBenRDW H19 0417
Coding: 05848EC43C98000801A3E9601000400000000000
ASAM Dataset: EV_DashBoardAU736 001032
VCID: 446FFAA338C67715F9A-8010
Address 18: Aux. Heat (J364) Labels:* None
Part No SW: 4M0 265 105 E HW: 4M0 265 105 E
Component: HSG H12 0110
Coding: 050B01
ASAM Dataset: EV_AuxilParkHeateEBEAU736 001019
ROD: EV_AuxilParkHeateEBEAU736_AU49.rod
Part No SW: 8W7 907 468 J HW: 8W7 907 468 G
Component: Gateway H46 0152
Revision: BU000001 Serial number: 018BU782619527
Coding: 03010001000006407F07000000590032DC9A0007180000000175078F10000000
GVL: 01503C080804000040CCC8000006C800110C0000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 004190
ROD: EV_CGateCONTIAU491_004_VW53.rod
VCID: 521916F9000823F7696-8006
Subsystem 1 - Part No SW: 80A 951 523 D HW: 80A 951 523 D
Component: J453 MFL H06 0004
Serial number: 20190722031045 00518
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 1483396700
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 80A 907 397 D HW: 80A 907 397 D
Component: LCM_MLBevo H07 0022
VCID: 307BD29F8862EF99992-8064
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 80A 907 566 B HW: 80A 907 566
Component: MRR1Rear H22 0441
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
VCID: 2C47CA6B984E07FDB9A-8078
Part No SW: 4M1 959 793 D HW: 4M1 959 793 D
Component: TSG FS001 0188
Serial number: CLSM1SFJ000W8
Coding: 005D8B015000048000001030
ROD: EV_DCU2DriveSideMAXHKLO_AU37.rod
VCID: 406BF2AFC8B28F69192-8014
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Coding: B0112101000101
ROD: EV_EPSVWBSAU426_010.rod
VCID: 3279D6998068E397696-8066
Part No SW: 4N0 907 064 DP HW: 4N0 907 064 P
Component: BCM2 MLBevo H15 0182
Coding: 01340000002000E06309A0006C00980213004000804F06502F0000000504803F001F0001000011
ASAM Dataset: EV_BCM2CONTIAU651 010009
ROD: EV_BCM2CONTIAU651_010.rod
VCID: 00AB72EFC8720F29192-8054
ID - sensor:
Subsystem 2 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11760401
Part No SW: 80A 035 223 A HW: 80A 035 223
Component: MIB2_amp_P_Q5 H03 0420
Revision: 00000001 Serial number: AUZ8ZAKTK04KKM5
Coding: 0194010800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
VCID: 1950A0226CED797851C-804C
Part No SW: 4M1 959 792 D HW: 4M1 959 792 D
Component: TSG BFS001 0188
Serial number: CLSM1SFC001F4
Coding: 005D8B015C00048000001030
ROD: EV_DCU2PasseSideMAXHKLO_AU37.rod
VCID: 3F6AECB0D4AF9572018-806A
Part No SW: 8W5 035 036 D HW: 8W5 035 036
Component: MU-P-LN-EU 035 1329
Serial number: A795G0K9284814
Coding: 012406010000000053110002000A00332F0015E501700100BE
VCID: 3970E082EC8DB95851C-806C
Subsystem 1 - Part No SW: V03 959 802 TP HW: -----------
Component: ECE 2022/2023 --- 0197
Multimedia System 1:
Subsystem 2 - Part No SW: 80A 919 605 HW: 80A 919 605
Component: AU426_DU_HIGH H42 0008
Serial number: AUZ8Z9KBL08REQ
Subsystem 3 - Part No SW: 80A 919 615 HW: 80A 919 615
Component: ControlUnit_P H15 0209
Serial number: 15051900000000000467
Compact disc data bank:
Component: Gracenote2 --- 1017
Part No SW: 4M0 907 428 F HW: 4M0 907 428
Component: Areaview 2 H13 0318
Serial number: C854607JG082503
Coding: 02240601BE0FA10008404000
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
ROD: EV_CamSysRVAV2CE2MLBEv_005_AU49.rod
VCID: 357CD88EFC79D1BC714-8060
Part No SW: 8W8 959 107 D HW: 8W8 959 107
Component: HDSG-Modul H13 0171
Revision: -------- Serial number: A2-C748-5750-8
Coding: 0730
VCID: 4A6106D120E0532FA96-801E
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 80A 907 777 AK HW: 80A 907 777 C
Component: Fahrwerk-SG H37 1253
Serial number: 1105190822
Coding: 18504032F8
ASAM Dataset: EV_ChassContrContiAU426 001004
ROD: EV_ChassContrContiAU426.rod
VCID: 7A316641E0D0339F296-802E
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130541696
Coding: 303030
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 80B 713 041 M HW: 80B 713 041 M
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 20190702001010
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 2742BC78B43725DAC18-8072
Address 82: Head Up Display (J898) Labels:* None
Part No SW: 80A 919 617 HW: 80A 919 617
Component: HeadUpDisplay H14 1640
Coding: 4F01C0
ASAM Dataset: EV_HudNSEIKAU736 001017
ROD: EV_HudNSEIKAU736_AU49.rod
VCID: 6A014631A080930FA96-803E
Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb
Part No SW: 80A 907 541 B HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 003022
ROD: EV_ACC2BOSCHAU49X_003_AU49.rod
VCID: 254CB87EBC29312CF14-8070
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 80A 907 217 C HW: 80A 907 217 A
Component: BVS H17 0055
Coding: 0404020600000402022023A6CD0000FEB0F0C020E280
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 264DBE7DB02C2B23C9E-8072
Address AC: Reductant Control (J880) Labels: 80A-907-355.clb
Part No SW: 80A 907 355 F HW: 80A 907 355 D
Component: SCR-Stg-G4H08 0004
ASAM Dataset: EV_RDCMHelbaAU426 003011
ROD: EV_RDCMHelbaAU426_003.rod
Part No SW: 4M1 959 795 D HW: 4M1 959 795 D
Component: TSG HFS003 0188
Serial number: CLSM1SFK00377
Coding: 000D89000000048000001020
VCID: 4269F6A9C0B88367E96-8016
Component: TSG HBFS003 0188
Serial number: CLSM1SFK000MX
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 62800004260C
ROD: EV_SunRoofCONTIAU736_009_AU37.rod
VCID: 753C584EFCB951FC714-8020
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 80A 907 590 B HW: 80A 907 590
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-592.clb
Part No SW: 7PP 941 592 CB HW: 7PP 941 592 C
Component: LED1L H10 2003
VCID: 1A51A62160F0737F296-804E
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-592.clb
Component: LED1R H10 2003
End----------(Elapsed Time: 02:20, VBatt start/end: 12.1V/12.1V)-----------
Best regards!
