- Jan 21, 2023
- 1
- 0
- Wisconsin, USA
- C?ID=540426
Hello all,
First time attempting some car repair here. Got quoted 2000 from the dealer to fix my broken defrost. I'm not really a "car guy" but am pretty handy, have fixed my home HVAC a couple times, so thought I'd give fixing the HVAC in my car a shot. Definitely loving the learning experience already, getting set up with VCDS and some other tools, and maybe I'll turn into a car guy after all.
Anyway, the fault codes I'm getting are for "Missing Calibration / Basic Setting" on my defrost flap motor, and my recirculation flap motor. This made me think simply re-running the Basic Settings "Adapt Door End Stops" might help, but it finished successfully without repairing anything. So probably the motors actually do need to be replaced.
I've seen some good Youtube videos on how to perform this sort of repair, seems like I need to take out the glove box to get at the defrost motor (not sure about the recirculation motor yet). I think my big questions are
Thanks very much for any insight y'all can offer. Or constructive criticism
Cheers and thanks very much, browsing the Ross-Tech forum and website has already been super interesting and helpful. Auto-scan below:
- When I do get to the motors, how do I know the right exact part number? I found this part guide that seems to have the actuator motors as #s 24-28. The dealer said they are both part # "5WA907511C" but I've seen several online repair guides say to get "5WA907511B". It seems like maybe those are both functionally the same, just different versions?
- Is there a better way of figuring out the best way to get at these motors other than trying to find someone doing the same thing on YouTube? As I said, I found a great guide for specifically the defrost motor, but haven't had much luck with the recirculation yet
- VCDS specific question - the expected/actual values for the recirculation and defrost vents - does this mean that the recirculation flap is stuck "open" at 100% and the defrost is stuck "closed" at 0%? Or do those values mean something else?
Saturday,21,January,2023,16:38:02:41630
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
VIN: WAUJ8GFF9G105xxxx License Plate: ARD-xxxx
Mileage: 117893km-73255mi Repair Order: initial
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 42 44 52 55 5F 6C BB
BC
VIN: WAUJ8GFF9G105xxxx Mileage: 117893km-73255miles
Address 01: Engine (J623-CNTC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 D HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: 5FAD45A3
Coding: 0A1D00124426000F3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
ROD: EV_ECM20TFS0205G0906259D.rod
VCID: 2F3B00EE77976593428-807A
VINID: 9D195A2175962570401410482432048C43
Readiness: 1010 1101
Part No SW: 0D9 300 013 B HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4902
Revision: 06253104 Serial number: TFK01509160308 CVN: 000019E2
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1675D50AE80DB45B21E-8042
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 62775000002422
Coding: 13FF6A9234250A6D0178030881CC29C8562C5080C08194B6024100548208
VCID: 79AFFEB6F9537B23ACC-802C
Revision: 00021000 Serial number: 0381197829
Coding: 030C0C
VCID: 3A2D21BABCD5B03BE56-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H14 0060
Revision: 20028000 Serial number: 00000000759030
Coding: 03000014010000000000000000001400
VCID: 33330C9E9BBF4173260-8066
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 7AA84FC7000000000001
329477 - Motor for Fresh Air / Recirculated Air Flap
B108B 54 [009] - Missing Calibration / Basic Setting
Reset counter: 200
Mileage: 117878 km
Date: 2023.01.20
Time: 10:49:17
Voltage terminal 30: 14.6 V
Inside temperature: 19.0 °C
Outside temperature: 17 °C
Fresh air/recirculating air/back pressure door specified value: 863
Actual value for fresh air/recirculation air flow flap: 100.0 %
Actual value for fresh air/recirculation air flow flap: 862
329989 - Motor for Defroster Flap
B1090 54 [009] - Missing Calibration / Basic Setting
Reset counter: 200
Mileage: 117878 km
Date: 2023.01.20
Time: 10:49:17
Defrost door - Specified value: 92
Defroster flap: actual value: 0
Defroster flap: actual value: 1.0 %
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AH HW: 5Q0 937 085 AE
Component: BCM MQBAB MNA H24 0175
Serial number: 01061527500688
Coding: 04151A46C04122F541C04004511007000800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 7F5B10AEE7775513928-802A
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 150801 042 0585
Serial number: 150930191336
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 20735274
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AD HW: 8V0 941 531 AD
Serial number: 24 07 2015 00001585
Serial number: 00000000000033678062
Sunroof control module:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000KULUT00000
Coding: 101F00
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391528101108
Coding: 0010150011
VCID: 43D35C5ECB1FF1F3B60-8016
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR03R1Z
VCID: 47CB484EFF27DDD36A8-8012
Left seat belt tensioner:
Component: BeltPretRevFL H36 0350
Serial number: 34230167A12101540477
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H36 0350
Serial number: 34230168A14101541642
Coding: 333135
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 694000000000001RY5XX
Coding: 303333
Subsystem 4 - Part No SW: ----------- HW: 480 000 810 15
Serial number: 357000000002A2741716
Subsystem 5 - Part No SW: ----------- HW: 480 000 810 15
Serial number: 3580000000069274171A
Subsystem 6 - Part No SW: ----------- HW: 480 402 809 15
Serial number: 3510002B71CF2DA2716C
Subsystem 7 - Part No SW: ----------- HW: 480 402 809 15
Serial number: 3520002A31CF2DA3A3DL
Subsystem 8 - Part No SW: ----------- HW: 480 401 407 15
Serial number: 3550002B51C52F446161
Subsystem 9 - Part No SW: ----------- HW: 480 401 407 15
Component: FrontSensor_P 001 6149
Serial number: 3560002B51C52F427352
Part No SW: 8V0 953 521 FH HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 02101508490350
Coding: A018
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 0557824685AB0FC3D84-8050
Part No SW: 8V0 920 960 M HW: 8V0 920 960 M
Component: KOMBI H03 6420
Coding: 0BE418192B80D7050200A8001800000000000000
VCID: 45D74246C52BCFC3984-8010
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2227
Revision: -------- Serial number: 13101510801583
Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
GVL: 01D43C0000000600400C10000002C80000000000000000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 75B7F286D54B1F43C84-8020
Generator:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 30 09 2015 B0078165
Serial number: HA1-00017.08.15
Coding: 0001
VCID: 4ACD717AEC3520BB756-801E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000220587006
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 34310F829EB1464B3FA-8060
Component: TSG FS 020 0041
Serial number: 020915BI111419
Coding: 00511B204000048000000002
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 0102
VCID: 44D15F42CE11F6CB8FA-8010
Component: TSG BFS 020 0041
Serial number: 250915BIO02705
Coding: 005113204000048000000002
VCID: 42DD595AD405F8FBBD6-8016
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 012A000101000000
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 844 C HW: 8V0 035 844
Component: MU-S-S-US 014 0660
Serial number: A7A01410150028
Coding: 017301000000000021220002001A00002F0001240100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 392F3EB6B9D3BB23ECC-806C
Multimedia System 1:
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0014
Serial number: AUZ8Z9FY30DND6
Subsystem 2 - Part No SW: 8V0 919 614 Q HW: 8V0 919 614 Q
Component: ControlUnit_B H41 0054
Serial number: C1000003081500030252
B11CF 53 [009] - Deactivated
Reset counter: 200
Mileage: 117878 km
Date: 2023.01.20
Time: 10:49:18
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ROD: EV_2CamSysRearPASE.rod
VCID: 303903926AA97A6B5B2-8064
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 280815BHS05339
Coding: 004113204000048000000002
Component: TSG HBFS 020 0041
Serial number: 280815BHS0600A
End----(Elapsed Time: 01:34, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
