Tiguan 2017 2.0d
andy lambert
HELP
Tiguan acting like in limp mode but no error codes and no MIL light??
car has had a DPF chemical clean which cleared glowplug and engine management light.
Has anyone had anything similar?
Please post an Auto-Scan for context even though there are mo faults.
Any chance the ECU has been tuned/mapped/chipped? Some tuners disable detection/reporting of certain faults.
andy lambert
Wednesday,01,February,2023,17:09:44:27331
VCDS Version: 22.10.0.1 (x64)  HEX-NET2 CB: 0.4623.4
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F A5
VIN: WVGZZZ5NZHW397293   Mileage: 193486km-120226miles
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 HQ    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H24 3022
   Revision: B4H24---    CVN: 2526BD574C6C0C4B
   Coding: 0119001203241D082000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906026HQ 004002
   ROD: EV_ECM20TDI01104L906026GQ_004.rod
   VCID: 80526FEB7A852F3B6B2-80D4
   VINID: 9E65EAAAA15EA989C32470890CE7943538
Readiness: 0 0 0 0 X
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 60107000002784
   Coding: 0AEE929A34290B734779060962C64950492CD0E2604692713060F078C0224200002E64121A03102F35351919323200
   VCID: F6BE09332841118B41E-80A2
0297 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 253
                    Mileage: 193482 km
                    Date: 2023.01.24
                    Time: 00:36:18
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 M    HW: 5NA 907 044 M
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000B00381726
   Coding: 00120104202110011105100000101022
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   VCID: C9C4B2CF093F2E73FCC-809C
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
263425 - Air Quality Sensor
          B10AF 04 [009] - Internal System Fault
                    Reset counter: 213
                    Mileage: 193485 km
                    Date: 2023.01.24
                    Time: 01:32:32
                    Outside temperature: 7.5 °C
                    Voltage terminal 30: 12.0 V
                    System run time-Engine running time: 253 s
                    Air quality status: Malfunction
   Part No SW: 5Q0 937 084 CE    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H34 0236
   Serial number: 02001701100768
   ROD: EV_BCMBOSCH_017.rod
   VCID: FDAC161F0D7742D3004-80A8
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 161117  033 0372
   Serial number: 00000001611150411624
   Component: RLHS  042 0105
   Serial number: S5Y17M01D20H20M29S06
   Coding: 00A8DD
   Serial number: 000000000ZY16334111A
   Serial number: 00000000000068164619
   Part No SW: 3Q0 919 294 A    HW: 3Q0 919 294
   Component: PDC 8 Kanal   H07 0020
   Serial number: 002812167478020
   Coding: 0071051001
   ASAM Dataset: EV_EPHBO18VW3260000 007015
   ROD: EV_EPHBO18VW3260000.rod
   VCID: B720C4376FCBA8839A8-80E2
13637426 - Databus
                    Fault Frequency: 8
                    Reset counter: 253
                    Mileage: 193482 km
                    Date: 2023.01.24
                    Time: 00:04:49
1080083 - Rear Parking Aid Sensor(s)
          B107B 13 [008] - Open Circuit
                    Reset counter: 253
                    Mileage: 193483 km
                    Date: 2023.01.24
                    Time: 00:42:09
1079089 - Center Rear Left Parking Aid Sensor
          B1077 31 [025] - No Signal
          Confirmed - Not Tested Since Memory Clear
                    Reset counter: 213
                    Mileage: 193482 km
                    Date: 2023.01.24
                    Time: 00:40:10
1079345 - Center Rear Right Parking Aid Sensor
          B1078 31 [025] - No Signal
                    Reset counter: 213
                    Mileage: 193482 km
                    Date: 2023.01.24
                    Time: 00:40:10
1078833 - Rear Left Parking Aid Sensor
          B1076 31 [025] - No Signal
                    Reset counter: 213
                    Mileage: 193482 km
                    Date: 2023.01.24
                    Time: 00:40:10
1079601 - Rear Right Parking Aid Sensors
          B1079 31 [025] - No Signal
                    Reset counter: 213
                    Mileage: 193482 km
                    Date: 2023.01.24
                    Time: 00:40:10
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 2A00404150FF8728749C8065004087
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_001.rod
   VCID: BB28D80753E38CE37E0-80EE
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 253
                    Mileage: 193482 km
                    Date: 2023.01.24
                    Time: 00:04:49
                    Voltage terminal 15: 11.7 V
                    Control Module temperature: 20 °C
                    Longitudinal_acceleration_vehicle_reference: 0.16 m/s²
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 253
                    Mileage: 193482 km
                    Date: 2023.01.24
                    Time: 00:04:49
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
                    Reset counter: 253
                    Mileage: 193482 km
                    Date: 2023.01.24
                    Time: 00:04:49
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [FAULT_VBAT_BUSMON_LOW]
                    Reset counter: 253
                    Mileage: 193482 km
                    Date: 2023.01.24
                    Time: 00:06:37
                    Voltage terminal 15: 9.7 V
                    Control Module temperature: 25 °C
                    Longitudinal_acceleration_vehicle_reference: 0.13 m/s²
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2FYV4T
   Coding: 98CCC0C00C0000005C5400CF008800000065
   VCID: 90725FAB2AE55FBBFB2-80C4
   Left seat belt tensioner:
   Serial number: 5NC857705C0012R00055
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 5NC857706C0012R00738
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 001 301 17
   Serial number: 3570000000056834F02F
   Subsystem 4 - Part No SW: -----------    HW: 480 001 301 17
   Serial number: 35800000000D0834F02I
   Subsystem 5 - Part No SW: -----------    HW: 480 401 801 17
   Serial number: 3510001C32404065945L
   Subsystem 6 - Part No SW: -----------    HW: 480 401 801 17
   Serial number: 3520001B32404032757G
   Subsystem 7 - Part No SW: -----------    HW: 480 401 701 17
   Serial number: 3550001B32404034A77Q
   Subsystem 8 - Part No SW: -----------    HW: 480 401 801 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001B32404065E23O
   Subsystem 9 - Part No SW: -----------    HW: 480 401 801 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001B3240406566EW
   Subsystem 10 - Part No SW: -----------    HW: 480 401 801 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001992419615D3B-
   Subsystem 11 - Part No SW: -----------    HW: 480 001 201 17
   Serial number: I0M0000000032244D02R
   Subsystem 12 - Part No SW: -----------    HW: 480 001 001 17
   Serial number: I0N00000000ABB506020
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 253
                    Mileage: 193482 km
                    Date: 2023.01.24
                    Time: 00:04:49
   Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20170119500560
   Coding: 0C00
   ROD: EV_SMLSVALEOMQB.rod
   VCID: C1D4AAEF310FE63324C-8094
   Part No SW: 5NA 920 951 A    HW: 5NA 920 951 A
   Component: KOMBI         309 8311
   Coding: 27A401006380060001886A031401000000000000
   VCID: BFD0AC1747FB90C3528-80EA
   Component: GW MQB High   418 4286
   Revision: --------    Serial number: 0005854578
   Coding: 030100045F087300FA00024C080F00010001050000000000000000000000
   GVL: 01543C0000000000408C80000000480000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: AF30FC57979B6043C28-80FA
   Generator:
   Subsystem 2 - Part No SW: 5TA 959 442 A    HW: 5TA 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 0041712253201058AO2B
   Coding: 280000
   Serial number: 6237512804
   Serial number: 040117EA302964
   Coding: 00310220D001048000001000
   VCID: C3D8A0E72B13F423360-8096
   Serial number: 00000000000013022143
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 1107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: C5DCBEFF2527CA13184-8090
16275 - Steering Angle Sensor
                    Reset counter: 218
                    Mileage: 193482 km
                    Date: 2023.01.24
                    Time: 00:04:49
                    Motor status: 00
                    Supply voltage: 11.75 V
                    Temperature: 15.0 °C
                    KFC: 3F
                    KFA: 00 93
                    Freeze frame conditions: 21
                    uioUdNotFilt_xdu16: 11.81 V
                    uAdSensI_SwitchedKl30_xdu16: 11.82 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 01 80
                    RP_VALCNTSAV: activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: activated
   Serial number: 211216ELK34418
   Coding: 00310020DE01048000001000
   VCID: C2D6A5E33409FD2B3D6-8096
   Serial number: 00000000000013074769
   Coding: 050000
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0751
   Coding: 02730601FF00000051110101008808001F0100C601200100CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: B134FA2F81AF76B3D4C-80E4
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL06QUN
   Subsystem 2 - Part No SW: 3G0 919 866 AQ    HW: -----------
   Component: ECE1 2017  --- 0730
   Serial number: 23011712K22338
   Coding: 0003070600000401000213448040A90084000E000020
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Fault Frequency: 8
                    Reset counter: 253
                    Mileage: 193482 km
                    Date: 2023.01.24
                    Time: 00:04:49
                    Control Module temperature: 12 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 183.6 s
                    Voltage terminal 15: 11.6 V
                    mid: 02 E0
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
End----------(Elapsed Time: 01:46, VBatt start/end: 12.3V/12.3V)-----------
andy lambert
DPF has been removed from vehicle and checked which proved to be ok.
still no fault codes, turbo checked via VCDS which was ok.
at a loss now of what direction to go.
andy lambert
;SW:04L-906-026-HQ HW:04L-907-309-P --- Engine
;Component:R4 2.0l TDI H24 3022Coding:0119001203241D082000
;EV_ECM20TDI01104L906026HQ4002EV_ECM20TDI01104L906026GQ_004.rod
;Monday6February202317:19:38:27331
;VCDS Version: Release 22.10.0 (x64) Data version: 20221026 DS344.0
;VCID: 80526FEB7A852F3B6B2-80D4
GroupDescriptionActual
IDE00011Vehicle Identification Number (VIN)WVGZZZ5NZHW397293
IDE00019Voltage terminal 3014.68V
IDE00020-ENG188621Terminal 15 status-Bits 0-71
IDE00021Engine RPM879/min
IDE00022Transmission input speed10000/min
IDE00025Coolant temperature30°C
IDE00030Status of actuator testnot active
IDE00075Vehicle speed0km/h
IDE00076Status of initial fuel fillingwas not yet started
IDE00078Time since engine start22s
IDE00083Throttle valve position (absolute)83.5%
IDE00085Normed load value34.5%
IDE00086Accelerator pedal position14.9%
IDE00090-ENG188621selected gear-Bits 0-70
IDE00097OBD - requirements for which this vehicle is designedEuro-OBD
IDE00100Engine torque51.8Nm
IDE00102Control Module temperature19.3°C
IDE00151Oil fill level46.88mm
IDE00152Oil warning threshold29.628mm
IDE00172A/C compressor torque20Nm
IDE00178Camshaft adjustment intake bank 1: specified value10°
IDE00179Camshaft adjustment intake bank 1: actual value10°
IDE00182Camshaft adaptation intake bank 1: phase position-0.24°
IDE00190Charge air pressure: specified value996hPa
IDE00194Coolant temperature at radiator output: specified value88°C
IDE00196Engine oil temperature20.5°C
IDE00304Fuel level13l
IDE00322Status of basic settingwas not yet started
IDE00323Security Access: Number of invalid keys12
IDE00347Air mass: actual value:15.77g/s
IDE00348Intake air temperature15°C
IDE00349Throttle valve position: normed99.6%
IDE00350Air mass: specified value250mg/stroke
IDE00351Main injection: start of activation-2.55°
IDE00352Main injection: duration of activation0µs
IDE00353Engine start: start quantity15.48mg/stroke
IDE00354Engine start: start synchronizationEPM_MODE_OK
IDE00354-ENG127291Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE48
IDE00355-ENG188621Cruise Control System (CCS): status-Bits 0-70
IDE00358Limitation: torque150Nm
IDE00359Limitation: smoke200.4Nm
IDE00360Limitation: accelerator pedal0Nm
IDE00363-ENG188621Glow status-Bits 0-70
IDE00363-ENG188621Glow status-Bits 0-7255
IDE00364Pre-glow time0ms
IDE00365Injection quantity deviation cylinder 10.03mg/stroke
IDE00366Injection quantity deviation cylinder 20.16mg/stroke
IDE00367Injection quantity deviation cylinder 3-0.07mg/stroke
IDE00368Injection quantity deviation cylinder 4-0.12mg/stroke
IDE00371Fuel consumption0.95l/h
IDE00373-ENG188621Electric auxiliary heater: shut-off conditions-Bits 0-70
IDE00374-ENG188621Electric auxiliary heater: relay activation-Bits 0-70
IDE00375Generator: load signal48.34%
IDE00383Pre-injection 1: activation start2.7°
IDE00384Pre-injection 1: activation duration0µs
IDE00385Pre-injection 2: activation start9.87°
IDE00386Pre-injection 2: activation duration0µs
IDE00387Post-injection 1: activation start0°
IDE00388Post-injection 1: activation duration0µs
IDE00389Post-injection 2: activation start0°
IDE00390Post-injection 2: activation duration0µs
IDE00396Charge air pressure actuator: acknowledgment99.94%
IDE00399Regulation factor: total1
IDE00405Crankshaft speed (RPM)875.5/min
IDE00406Camshaft RPM437.8/min
IDE00407-ENG188621Rail pressure regulation: status-Bits 0-715
IDE00412-ENG188621Starter control: terminal 50-Bits 0-70
IDE00413-ENG188621Starter control: Interlock- or P/N-signal-Bits 0-70
IDE00416-ENG188621Starter control: terminal 50 feedback-Bits 0-70
IDE00417-ENG188621Starter control: shut-off conditions 1-Bits 0-733
IDE00417-ENG188621Starter control: shut-off conditions 1-Bits 0-70
IDE00420Service regeneration: current duration0s
IDE00430-ENG188621Particle filter: field regeneration request status-Bits 0-71
IDE00432Particle filter: time since last regeneration38.568H
IDE00433Particle filter: oil ash volume0l
IDE00434Particle filter: soot mass calculated45.94g
IDE00435Particle filter: soot mass measured13.68g
IDE00436Particle filter: kilometers since last regeneration982.6km
IDE00443-ENG188621Accelerator pedal: switch positions-Bits 0-78
IDE00445Unlearning counter according OBD255
IDE00450Operating instruction---
IDE00451Currently running routineUnknown (0)
IDE00472Mean injection quantity7.82mg/stroke
IDE00474Ambient air pressure103kPa abs
IDE00477Torque request: sum of auxiliary aggregate11.3Nm
IDE00478Engine-drag torque52.6Nm
IDE00496-ENG188621Oil pressure switch valve activation-Bits 0-71
IDE00497-ENG188621Status of oil pressure switches-Bits 0-737
IDE00541Acceleration0m/s²
IDE00556Outside temperature7°C
IDE00559Current of oxygen sensor bank 1 sensor 1 (broadband sensor)0.300 Lambda / -0.004 mA
IDE00583Throttle valve specified value100%
IDE00584Distance driven since erasing DTC memory0km
IDE00585Dist. driven with exh. Malfunction Indicator Lamp activated0km
IDE00589Fuel pressure29480kPa rel
IDE00594Absolute intake pressure108kPa abs
IDE00595Allocation of oxygen sensorsB1S1
IDE00600Conversion factorsMax eq. ratio 32 / Max V O2s 0 V
IDE00601Monitoring status since erasing DTC memory
IDE00602Monitoring status in current driving cycle
IDE00603Number of driving cycles since erasing DTC memory0
IDE00699ESI: minimum oil level in service interval14.204mm
IDE00700ESI: maximum oil level in service interval21.608mm
IDE00727Test steps still to be performed0
IDE00773Terminal 15 status via CAN1
IDE00784Current test step0
IDE00787Cause for cancellation0
IDE01076Time since ignition off130948s
IDE01260Generator performance1046.15W
IDE01266-ENG188621Coolant shut-off valve-Bits 0-70
IDE01378Fuel high pressure: control deviation-400hPa
IDE01381Pre-injection 3: activation duration0µs
IDE01382Post-injection 3: activation start0°
IDE01383Post-injection 3: activation duration0µs
IDE01385Wear index8m
IDE01386Soot index2m
IDE01387Injector 1: rail pressure calibration point 1-7.6µs
IDE01388Injector 1: rail pressure calibration point 2-8.4µs
IDE01389Injector 1: rail pressure calibration point 3-6µs
IDE01390Injector 2: rail pressure calibration point 18.8µs
IDE01391Injector 2: rail pressure calibration point 2-4.8µs
IDE01392Injector 2: rail pressure calibration point 3-6µs
IDE01393Injector 3: rail pressure calibration point 130µs
IDE01394Injector 3: rail pressure calibration point 2-7.2µs
IDE01395Injector 3: rail pressure calibration point 3-4.8µs
IDE01396Injector 4: rail pressure calibration point 116.8µs
IDE01397Injector 4: rail pressure calibration point 2-12.4µs
IDE01398Injector 4: rail pressure calibration point 3-7.2µs
IDE01405-ENG188621Starter activation: status-Bits 0-72
IDE01406-ENG188621Service regeneration: status-Bits 0-70
IDE01407Particle filter: fuel consumption since last regeneration72.69l
IDE01410Charge limit over-charge50g
IDE01834Battery voltage14720mV
IDE01880Accelerator pedal position 214.5%
IDE01884Camshaft adjustment intake bank 1: activation6.25%
IDE01922Vehicle distance driven193486km
IDE02211Brake pressure-0.06MPa
IDE02228Fuel pressure regulator valve: specified value rail pressure307700hPa
IDE02230Torque reduction due to exhaust temperature1
IDE02540-ENG188621Longitudinal acceleration sensor: status-Bits 0-70
IDE02742Oil pressure actual value0hPa
IDE02756-ENG188621Number of manual engine starts-Bits 0-70
IDE02756-ENG188621Number of manual engine starts-Bits 0-738
IDE02756-ENG188621Number of manual engine starts-Bits 0-7193
IDE02757-ENG188621Number of automatic engine starts-Bits 0-70
IDE02757-ENG188621Number of automatic engine starts-Bits 0-749
IDE02757-ENG188621Number of automatic engine starts-Bits 0-7194
IDE03015Compression test cylinder 10/min
IDE03016Compression test cylinder 20/min
IDE03017Compression test cylinder 30/min
IDE03018Compression test cylinder 40/min
IDE03133Reducing agent metering system heating circuit 1: actual current0mA
IDE03134Reducing agent metering system heating circuit 2: actual current448mA
IDE03135Sensor for reducing agent tank temperature: temperature6.5°C
IDE03137Reducing agent metering system heating circuit 1: actual voltage0mV
IDE03138Reducing agent metering system heating circuit 2: actual voltage141.6mV
IDE03139Reducing agent injector: resistance12639mOhm
IDE03142Remaining vehicle distance until reducing agent deficiency7020.4km
IDE03143-ENG188621Remaining engine starts until reducing agent deficiency-Bits 0-725
IDE03144Used reducing agent since last service172862.576g
IDE03187Checksum of flash493B
IDE03189-ENG102843Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density0counts
IDE03189-ENG102547Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost0counts
IDE03189-ENG103808Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption0counts
IDE03189-ENG101159Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random0counts
IDE03189-ENG104187Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode0counts
IDE03189-ENG100165Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior0counts
IDE03189-ENG99535Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density0
IDE03189-ENG103192Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost0
IDE03189-ENG99739Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption0
IDE03189-ENG100597Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random0
IDE03189-ENG101689Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode0
IDE03189-ENG100582Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior0
IDE03189-ENG101720Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density0
IDE03189-ENG100669Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost0
IDE03189-ENG100932Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption0
IDE03189-ENG101264Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random0
IDE03189-ENG102430Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode0
IDE03189-ENG101165Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior0
IDE03189-ENG101829Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density0km
IDE03189-ENG99286Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost0km
IDE03189-ENG102800Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption0km
IDE03189-ENG102751Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random0km
IDE03189-ENG101356Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode0km
IDE03189-ENG99669Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior0km
IDE03189-ENG103828Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density0
IDE03189-ENG103959Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost0
IDE03189-ENG102465Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption0
IDE03189-ENG102710Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random0
IDE03189-ENG103568Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode0
IDE03189-ENG100877Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior0
IDE03189-ENG101280Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density0
IDE03189-ENG99226Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost0
IDE03189-ENG101471Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption0
IDE03189-ENG102877Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random0
IDE03189-ENG100198Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode0
IDE03189-ENG101676Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior0
IDE03189-ENG103694Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density0
IDE03189-ENG104142Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost0
IDE03189-ENG100353Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption0
IDE03189-ENG100878Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random0
IDE03189-ENG101433Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode0
IDE03189-ENG100557Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:0
IDE03190-ENG100538Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost0counts
IDE03190-ENG100036Number of requested start processes (statistics)-SSEUI Counter Start Desired By High Engine Temperature0counts
IDE03190-ENG103639Number of requested start processes (statistics)-SSEUI Counter Start Desired By Low Engine Temperature0counts
IDE03190-ENG114942Number of requested start processes (statistics)-SSEUI Counter Start Desired By Super SCR Control0counts
IDE03190-ENG102427Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost0
IDE03190-ENG99459Number of requested start processes (statistics)-SSEUI Day Start Desired By High Engine Temperature0
IDE03190-ENG99665Number of requested start processes (statistics)-SSEUI Day Start Desired By Low Engine Temperature0
IDE03190-ENG112104Number of requested start processes (statistics)-SSEUI Day Start Desired By Super SCR Control0
IDE03190-ENG99329Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost0
IDE03190-ENG100944Number of requested start processes (statistics)-SSEUI Hours Start Desired By High Engine Temperature0
IDE03190-ENG100535Number of requested start processes (statistics)-SSEUI Hours Start Desired By Low Engine Temperature0
IDE03190-ENG112105Number of requested start processes (statistics)-SSEUI Hours Start Desired By Super SCR Control0
IDE03190-ENG102737Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost0km
IDE03190-ENG101377Number of requested start processes (statistics)-SSEUI Mileage Start Desired By High Engine Temperature0km
IDE03190-ENG99682Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Low Engine Temperature0km
IDE03190-ENG112101Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Super SCR Control0km
IDE03190-ENG102760Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost0
IDE03190-ENG103163Number of requested start processes (statistics)-SSEUI Minutes Start Desired By High Engine Temperature0
IDE03190-ENG101771Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Low Engine Temperature0
IDE03190-ENG114943Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Super SCR Control0
IDE03190-ENG100816Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost0
IDE03190-ENG104013Number of requested start processes (statistics)-SSEUI Month Start Desired By High Engine Temperature0
IDE03190-ENG104020Number of requested start processes (statistics)-SSEUI Month Start Desired By Low Engine Temperature0
IDE03190-ENG112103Number of requested start processes (statistics)-SSEUI Month Start Desired By Super SCR Control0
IDE03190-ENG103223Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost0
IDE03190-ENG103563Number of requested start processes (statistics)-SSEUI Year Start Desired By High Engine Temperature0
IDE03190-ENG103316Number of requested start processes (statistics)-SSEUI Year Start Desired By Low Engine Temperature0
IDE03190-ENG112102Number of requested start processes (statistics)-SSEUI Year Start Desired By Super SCR Control0
IDE03235Neutral position sensor: current transmission angle-1.3°
IDE03236Neutral position sensor: adapted transmission angle-1.3°
IDE03241Status of reduction agent levelOK
IDE03241-ENG127378Status of reduction agent level-Test_Program_UDC st U Tnk Lvl st UBYTE3
IDE03242Injector for reduction agent: current holding phase414mA
IDE03243Reducing agent injector: current saturation phase951mA
IDE03246Neutral position sensor: upper adaptation value3390mV
IDE03247Neutral position sensor: lower adaptation value1370mV
IDE03248Pressure control valve adaptation factor1.1731
IDE03288-ENG188621Heating circuit 1 for reducing agent metering: activation-Bits 0-70
IDE03289-ENG188621Heating circuit 2 for reducing agent metering: activation-Bits 0-70
IDE03328Transmission neutral position sensor voltage2040mV
IDE03362Requested transmission torque1000Nm
IDE03383Exhaust mass flow of EGR0kg/h
IDE03384Bypass-valve for EGR cooler: specified value0%
IDE03386Long-term adaptation of reduction agent dosage1
IDE03387Duration of overtemperature at the reduction agent injector1755s
IDE03393-ENG188621Selector lever position-Bits 0-70
IDE03405-ENG188621Particle filter field regeneration: cancel conditions-Bits 0-79
IDE03405-ENG188621Particle filter field regeneration: cancel conditions-Bits 0-70
IDE03583-ENG188621Engine shut-down overrides-Bits 0-720
IDE03584-ENG188621Engine starting requirements-Bits 0-70
IDE03585System status for the start/stop function master1
IDE03586-ENG188621Starting requirements for active participants-Bits 0-70
IDE03587-ENG188621Stopping requirements for active participants-Bits 0-711
IDE03587-ENG188621Stopping requirements for active participants-Bits 0-70
IDE03588-ENG188621System malfunctions for active participants start/stop-Bits 0-70
IDE03589-ENG188621Error status for start-stop related sensors-Bits 0-73
IDE03660Longitudinal acceleration0m/s²
IDE03712-ENG188621Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7255
IDE03712-ENG188621Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7234
IDE03712-ENG188621Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7132
IDE03767Engine statusCOENG_RUNNING
IDE03767-ENG127290Engine status-Test_Program_Co Eng st COMPU VERB UBYTE3
IDE04003Charge air temperature sensorB1S1/B1S2:21/24°C
IDE04015Exhaust gas recirculationEGR A:0/0/0 % / EGR B:0/0/0 %
IDE04083Coolant temperaturesECT 1:30°C
IDE04090Exhaust temperature bank 1S1/S2/S3/S4: / 700/384/67/59 °C
IDE04098NOx-sensorNOx11:0 ppm / NOx21:---
IDE04099Reduction agent dosingReAg Rate/Demand:0.0/0.03 L/h / Reag Tnk Lvl:79.6 %
IDE04260-ENG188621Learning cycle counter of zero quant calib: bottom press pt-Bits 0-770
IDE04260-ENG188621Learning cycle counter of zero quant calib: bottom press pt-Bits 0-74
IDE04261-ENG188621Lrn cyc cntr of zro quan calib: mid press. point-Bits 0-74
IDE04261-ENG188621Lrn cyc cntr of zro quan calib: mid press. point-Bits 0-769
IDE04262-ENG188621Learning cycle counter of zero quant calib: top press pt-Bits 0-74
IDE04262-ENG188621Learning cycle counter of zero quant calib: top press pt-Bits 0-769
IDE04272Counter for regeneration time of particulate filter0s
IDE04468Air mass at air mass meter 156.7kg/h
IDE04623Kick-down threshold4125.2mV
IDE04638Transmission coolant valveFalse result
IDE04638-ENG127289Transmission coolant valve-Test_Program_B TRUE UBYTE0
IDE04651Torque request: A/C compressor0Nm
IDE04652Exhaust gas jet volume in particle filter53.3m³/h
IDE04653Simulated particle filter surface temperature62.9°C
IDE04654-ENG188621CAN status - engine control module-Bits 0-70
IDE04655-ENG188621CAN status - transmission control module-Bits 0-70
IDE04656-ENG188621CAN status - brake control module 1-Bits 0-70
IDE04657-ENG188621CAN status - brake control module 2-Bits 0-70
IDE04666Heat delivery temperature in cooling system-273.1°C
IDE04667-ENG188621Bypass valve for EGR cooler: status-Bits 0-70
IDE04670Crankshaft signal evaluation: statusGAPFOUND
IDE04670-ENG127292Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE7
IDE04682-ENG188621Allowed number of injections-Bits 0-73
IDE04683-ENG188621Injection release status-Bits 0-756
IDE04684-ENG188621Desired injection characteristic-Bits 0-756
IDE04685Setpoint generation interior torque50Nm
IDE04686Calculated clutch limit torque-51.8Nm
IDE04687Mean temperature of SCR catalyst68.3°C
IDE04688-ENG188621Engine control module reset status-Bits 0-72
IDE04688-ENG188621Engine control module reset status-Bits 0-70
IDE04689Starter control: Start interruption statusCorrect result
IDE04689-ENG127289Starter control: Start interruption status-Test_Program_B TRUE UBYTE1
IDE04690-ENG188621Transmission torque intervention status-Bits 0-70
IDE04691Calculated reducing transmission intervention torque1000Nm
IDE04692Reducing desired torque intervention of ESP0Nm
IDE04693Increasing desired torque intervention of ESP-50528.2Nm
IDE04694-ENG188621Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7126
IDE04694-ENG188621Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7235
IDE04694-ENG188621Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7255
IDE04694-ENG188621Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7155
IDE04695-ENG99946Immobilizer snapshot A-Sia Error Snap A00 00 00
IDE04696-ENG102592Immobilizer snapshot B-Sia Error Snap B00 00 00
IDE04814Transmission oil cooler valveFalse result
IDE04814-ENG127289Transmission oil cooler valve-Test_Program_B TRUE UBYTE0
IDE04866Charging of press sensor betw ND and HD turbocharger: adapt1086hPa
IDE04868-ENG188621Glow cycles above temperature threshold-Bits 0-70
IDE04868-ENG188621Glow cycles above temperature threshold-Bits 0-72
IDE04869-ENG188621Glow cycles below temperature threshold-Bits 0-75
IDE04869-ENG188621Glow cycles below temperature threshold-Bits 0-70
IDE04870-ENG188621Glow cycles upon reaching temperature threshold-Bits 0-70
IDE04870-ENG188621Glow cycles upon reaching temperature threshold-Bits 0-77
IDE04872Brake pedal value sensor: relative value filtered0%
IDE04887Powertrain target torque-41Nm
IDE04937Sensor for engine block temperature: raw value31°C
IDE05132-ENG188621Charge pressure control activity-Bits 0-70
IDE05135Status of compressor releaseFalse result
IDE05135-ENG127289Status of compressor release-Test_Program_B TRUE UBYTE0
IDE05136-ENG188621Current operating mode_2-Bits 0-71
IDE05136-ENG188621Current operating mode_2-Bits 0-74
IDE05136-ENG188621Current operating mode_2-Bits 0-70
IDE05137-ENG188621Shut-off timer: instrum panel counter: open circuit in term 30-Bits 0-70
IDE05138Shut-off timer: last engine shut-off time414s
IDE05139Shut-off timer: last ECM after-run time29s
IDE05232Reducing agent fill level65.38%
IDE05261-ENG188621Gear position sensor: last valid value-Bits 0-70
IDE05352-ENG188621Status of trailing throttle detec in trailing throttle coord-Bits 0-70
IDE05353Measured NOx conversion0
IDE05354Calculated efficiency of NOx conversion0.015
IDE05355Efficiency threshold of NOx conversion0
IDE05356Calculated NOx concentration behind turbocharger213ppm
IDE05357Current temperature with NOx Reduction CAT68.5°C
IDE05386Exhaust gas model temperature 0147.5°C
IDE05387Exhaust gas model temperature 1569.2°C
IDE05388Exhaust gas model temperature 2372.2°C
IDE05389Exhaust gas model temperature 363.4°C
IDE05390Exhaust gas model temperature 40°C
IDE05440ESI: Soot equiv 2 calculated from soot index0.00000008
IDE05441ESI: Wear equivalent 2 calculated from wear index0.00000038
IDE05442Roadway slope angle acceleration interface: calculated0rad
IDE05494-ENG188621Air cleaner full/empty detection-Bits 0-70
IDE05521Correction factor of the eng temp for eng protection1
IDE05522Correction factor of the oil temp for eng protection1
IDE05523Correction factor of the fuel temp for eng protection1
IDE05524Charge air press temp correction factor for engine prot1
IDE05623Measured NOx conversion range 10
IDE05624Efficiency threshold of NOx conversion range 10
IDE05626Calculated temperature at reduction agent injection valve48.7°C
IDE05630Reducing agent tank fill level indicator: raw value0%
IDE05861-ENG188621DPF statistics: number of interrupted regenerations-Bits 0-70
IDE05877DPF statistics: regen time slice not poss in charge cycle0
IDE05883DPF statistics: regeneration time0s
IDE05901DPF statistics: route in charge cycle480km
IDE05903DPF statistics: avg driv cycle time during charge cycle0s
IDE05908-ENG188621DPF statistics: regeneration request-Bits 0-70
IDE05910DPF statistics: exhaust temperature regulation average value0.44
IDE05918-ENG188621DPF statistics: regeneration blocked status-Bits 0-70
IDE05922-ENG188621DPF statistics: error status-Bits 0-70
IDE06013Engine start: start synchronization 2EPM_FULL_SYNC
IDE06013-ENG127375Engine start: start synchronization 2-Test_Program_Epm st Sync State t UBYTE30
IDE06041-ENG188621PDTC drive cycle conditions status-Bits 0-736
IDE06058-ENG188621Engine control module reset status info-Bits 0-7208
IDE06058-ENG188621Engine control module reset status info-Bits 0-712
IDE06058-ENG188621Engine control module reset status info-Bits 0-7246
IDE06058-ENG188621Engine control module reset status info-Bits 0-7128
IDE06059Particulate filter: oil ash mass51.5613297g
IDE06060Particulate filter ash load limit80g
IDE06216DPF Statistics: average val.: exhaust temp. ctrl before DPF-1
IDE06255Vehicle lateral acceleration0g
IDE06256Vehicle lateral acceleration: raw value0g
IDE06257Vehicle inclination acceleration angle: raw value-12.557m/s²
IDE06258Charge air temperature at the turbocharger outlet: calculated21.2°C
IDE06259Intake air temperature before throttle valve: calculated0K
IDE06298-ENG188621Status of engine during start-Bits 0-70
IDE06386Oil level: static measurement-2.28mm
IDE06387Oil level: last valid dynamic value14.204mm
IDE06388Oil level: condition for static measurement fulfilled0
IDE06391Oil temperature sensor 2-273.1°C
IDE06393Oil level: dynamic average value131.068mm
IDE06398Temperature sensor for engine temp. management: uncond. voltage4776.4mV
IDE06433Standardized airflow ratio: filtered0.9524
IDE06435A/C compressor: refrigerant pressure0hPa
IDE06445Longitudinal acceleration: raw value0m/s²
IDE06446-ENG188621Status: incline angle-Bits 0-71
IDE06567-ENG188621Frequency counter deactivate start/stop function-Bits 0-70
IDE06568-ENG188621Stop prevention by driver frequency counter-Bits 0-746
IDE06568-ENG188621Stop prevention by driver frequency counter-Bits 0-70
IDE06569-ENG188621Frequency counter vehicle standstill-Bits 0-70
IDE06569-ENG188621Frequency counter vehicle standstill-Bits 0-747
IDE06607Distance at last active oil overfill warning0km
IDE06608Total distance with active oil overfill warnings0km
IDE06610-ENG188621Frequency counter vehicle standstill with stop-Bits 0-70
IDE06647-ENG188621Start-stop switch status-Bits 0-71
IDE06702-ENG188621Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-70
IDE06702-ENG188621Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7131
IDE06703-ENG188621Drivetrain coordinator: ACC fault status-Bits 0-70
IDE06704-ENG188621Drivetrain coordinator: brake fault status-Bits 0-70
IDE06705-ENG188621Drivetrain coordinator: brake function status-Bits 0-70
IDE06705-ENG188621Drivetrain coordinator: brake function status-Bits 0-74
IDE06706-ENG188621ACC variants-Bits 0-70
IDE06707-ENG188621CCS Switch-Bits 0-71
IDE06708-ENG188621Cruise control switch actuation-Bits 0-70
IDE06708-ENG188621Cruise control switch actuation-Bits 0-732
IDE06709-ENG188621ACC variants (coding)-Bits 0-71
IDE06710-ENG188621Cruise control system: permanent deactivation-Bits 0-7255
IDE06711-ENG188621Cruise control system: temporary deactivation-Bits 0-7255
IDE06866-ENG188621Range limit cancellation due to red. agent metering sys. fault-Bits 0-70
IDE06928-ENG188621Auxiliary air heater: activation-Bits 0-70
IDE06946-ENG188621Brake actuated status-Bits 0-70
IDE06983-MAS05386Diesel emissions re-treatment: status-Status of regenerationavailable.
IDE06983-MAS05386Diesel emissions re-treatment: status-Status of regenerationnot active
IDE06983-MAS05387Diesel emissions re-treatment: status-Type of regenerationPassive Regeneration
IDE06983-MAS05387Diesel emissions re-treatment: status-Type of regenerationavailable.
IDE06983-MAS05388Diesel emissions re-treatment: status-Status of DeNOx catalytic converterNot available
IDE06983-MAS05388Diesel emissions re-treatment: status-Status of DeNOx catalytic converterAdsorption
IDE06983-MAS05389Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converterNot available
IDE06983-MAS05389Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converternot active
IDE06983-MAS05390Diesel emissions re-treatment: status-Regeneration criteria fulfilledNot available
IDE06983-MAS05390Diesel emissions re-treatment: status-Regeneration criteria fulfilled0%
IDE06983-MAS05391Diesel emissions re-treatment: status-Average time between DPF regenerationNot available
IDE06983-MAS05391Diesel emissions re-treatment: status-Average time between DPF regeneration0min
IDE06983-MAS05392Diesel emissions re-treatment: status-Average distance between DPF regenerations0km
IDE06983-MAS05392Diesel emissions re-treatment: status-Average distance between DPF regenerationsNot available
IDE07050-ENG188621Starter control: release conditions-Bits 0-798
IDE07050-ENG188621Starter control: release conditions-Bits 0-74
IDE07051-ENG188621Engaged gear: raw signal-Bits 0-70
IDE07081Reducing agent efficiency diagnosis progress 20g
IDE07084Differential pressure ratio: low-pressure EGR3.7kg/h
IDE07086Exhaust mass flow of low-pressure EGR: calculated2.475
IDE07090-ENG188621Speed control: status of external torque request-Bits 0-70
IDE07090-ENG188621Speed control: status of external torque request-Bits 0-74
IDE07091NOx-Raw emission model value before reduction catalyst218ppm
IDE07233-ENG188621Bit string for status of oil level-Bits 0-70
IDE07233-ENG188621Bit string for status of oil level-Bits 0-766
IDE07234Status bid for valid static oil level0
IDE07235Status bid for dynamic oil level0
IDE07236OT Adaptation correction value0°
IDE07373Top dead center adaptation0°
IDE07374Cylinder mass flow: act. value calculated60.2kg/h
IDE07375Charge pressure before throttle valve: calculated actual value1086.3hPa
IDE07376Intake manifold pressure: act. value calculated1085.3hPa
IDE07377EGR valve 1: B1: mass current - specified value0kg/h
IDE07378Exhaust flap actuator 1: B1: inlet pressure - specified value1035.8hPa
IDE07379Cylinder charge: spec. value528.4mg/stroke
IDE07381Cylinder charge: act. value calculated573.2mg/stroke
IDE07382EGR valve 2: B1: mass current - specified value0kg/h
IDE07383NOx storage catalytic converter: aging factor: actual value calculated8.39E+06s
IDE07384Throttle valve actuator 1: B1: outlet pressure - specified value1000.3hPa
IDE07385Exhaust flap actuator 1: B1: inlet pressure - actual value calculated1038.5hPa
IDE07386Total HFM air mass flow: calculated55.9kg/h
IDE07518-ENG188621Reducing agent efficiency-diagnosis releases: current-Bits 0-7150
IDE07518-ENG188621Reducing agent efficiency-diagnosis releases: current-Bits 0-7208
IDE07518-ENG188621Reducing agent efficiency-diagnosis releases: current-Bits 0-764
IDE07518-ENG188621Reducing agent efficiency-diagnosis releases: current-Bits 0-7131
IDE07519-ENG188621Reducing agent efficiency-diagnosis releases: stored-Bits 0-70
IDE07524Reducing agent efficiency-diagnosis releases: short-trip statusinvalid
IDE07524-ENG127377Reducing agent efficiency-diagnosis releases: short-trip status-Test_Program_SCR Chk Compu Valid UBYTE0
IDE07525Reducing agent efficiency-diagnosis progress: short trip0g
IDE07526Efficiency threshold of NOx conversion during short trips0
IDE07527Measured NOx conversion during short trips0
IDE07528-ENG122685Coordinator releases for DPF regeneration-SwSVW st Ctl Cdn Eng11111111 11111111 11111111 11111110
IDE07528-ENG122684Coordinator releases for DPF regeneration-SwSVW st Ctl Cdn Veh11111111 11110111 11111111 11111111
IDE07529-ENG122685Coordinator releases: standard-SwSVW st Ctl Cdn Eng00000000 00000000 00000000 00000000
IDE07529-ENG122684Coordinator releases: standard-SwSVW st Ctl Cdn Veh00000000 00000000 00000000 00000000
IDE07530-ENG122685Coordinator releases for NOx reduction-SwSVW st Ctl Cdn Eng00000000 00000000 00000000 00000000
IDE07530-ENG122684Coordinator releases for NOx reduction-SwSVW st Ctl Cdn Veh00000000 00000000 00000000 00000000
IDE07531-ENG122685Coordinator releases: sulfur removal-SwSVW st Ctl Cdn Eng00000000 00000000 00000000 00000000
IDE07531-ENG122684Coordinator releases: sulfur removal-SwSVW st Ctl Cdn Veh00000000 00000000 00000000 00000000
IDE07532-ENG122685Coordinator releases for short trip-SwSVW st Ctl Cdn Eng00000000 00000000 00000000 00000000
IDE07532-ENG122684Coordinator releases for short trip-SwSVW st Ctl Cdn Veh00000000 00000000 00000000 00000000
IDE07533-ENG122685Coordinator releases: exhaust system heating-SwSVW st Ctl Cdn Eng00000000 00000000 00000000 00000000
IDE07533-ENG122684Coordinator releases: exhaust system heating-SwSVW st Ctl Cdn Veh00000000 00000000 00000000 00000000
IDE07534-ENG188621Target operating mode for engine-Bits 0-74
IDE07534-ENG188621Target operating mode for engine-Bits 0-765
IDE07534-ENG188621Target operating mode for engine-Bits 0-781
IDE07534-ENG188621Target operating mode for engine-Bits 0-716
IDE07535-ENG188621Current operating mode of engine-Bits 0-74
IDE07535-ENG188621Current operating mode of engine-Bits 0-765
IDE07535-ENG188621Current operating mode of engine-Bits 0-781
IDE07535-ENG188621Current operating mode of engine-Bits 0-716
IDE07536-ENG188621Next requested operating mode for engine-Bits 0-74
IDE07536-ENG188621Next requested operating mode for engine-Bits 0-781
IDE07536-ENG188621Next requested operating mode for engine-Bits 0-765
IDE07536-ENG188621Next requested operating mode for engine-Bits 0-716
IDE07538Intake manifold press. sensor: act. value calculated1085hPa
IDE07706Outside temperature sensor 1: B1: raw value7°C
IDE07707Mass airflow sensor 1 bank 1 temperature: raw value13.8°C
IDE07708Turbocharger 1 charger output: temp. sensor 1: B1: raw value21.3°C
IDE07709Turbocharger 1 charger output: temp. sensor 1: B1: raw voltage4467.6mV
IDE07710Charge air cooler output: temp. sensor 1: B1: raw value23.7°C
IDE07711Charge air cooler output: temp. sensor 1: B1: raw voltage4418.6mV
IDE07712Turbocharger 1 turbine input: temp. sensor 1: B1: raw value700°C
IDE07713Turbocharger 1 turbine input: temp. sensor 1: B1: raw voltage4213.4mV
IDE07714Turbocharger 1 turbine output: temp. sensor 1: B1: raw value383.4°C
IDE07715Turbocharger 1 turbine output: temp. sensor 1: B1: raw voltage1115.8mV
IDE07716Particulate filter input: temp. sensor 1: bank 1: raw value69.3°C
IDE07717Particulate filter input: temp. sensor 1: B1: raw voltage4418.6mV
IDE07718Particulate filter output: temp. sensor 1: bank 1: raw value61.4°C
IDE07719Particulate filter output: temp. sensor 1: bank 1: raw voltage4496.8mV
IDE07724Coolant temperature at engine outlet: calculated31°C
IDE07725Coolant temperature sensor 1: B1: on cylinder head: raw value31.6°C
IDE07726Coolant temperature sensor 1: B1: on cylinder head: raw voltage3095mV
IDE07727Coolant temperature sensor 1: B1: on radiator output: raw value2222°C
IDE07728Coolant temperature sensor 1: B1: on radiator output: raw voltage4999.8mV
IDE07729EGR temp. sensor 1: B1: raw value-273.1°C
IDE07731EGR temp. sensor 2: B1: raw value2222°C
IDE07732EGR temp. sensor 2 B1: raw voltage0mV
IDE07733Ambient air pressure sensor 1 bank 1: raw value1037hPa
IDE07738Charge air cooler inlet: pressure sensor 1 bank 1: raw value1086.4hPa
IDE07739Charge air cooler inlet: press.sensor 1 bank 1: uncnd. voltage1170mV
IDE07740Cylinder head: pressure sensor 1 bank 1: raw value0bar
IDE07741Cylinder head: pressure sensor 2 bank 1: raw value0bar
IDE07742Cylinder head: pressure sensor 3 bank 1: raw value52.211bar
IDE07743Cylinder head: pressure sensor 4 bank 1: raw value0bar
IDE07744Particle filter: air pressure sensor 1 bank 1: raw value2hPa
IDE07745Particl.filt.: different.press.sensor 1 bank 1: adaptat. value2hPa
IDE07746Particl.filt.: differential press.sens.1 bank 1: uncnd.voltage0mV
IDE07747Par.fil: diff.pr.sens.1 bank 1: offset0hPa
IDE07748Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset-1hPa
IDE07750Exhaust recirculat.2: different.press.sens.1 bank 1: raw value3hPa
IDE07751Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value3hPa
IDE07752Exh.recirculat.2: different.press.sensor 1 bank 1: uncnd.volt.4999.8mV
IDE07754Exhaust recirculation valve 1 bank 1: activation12.4%
IDE07755Exhaust recirc.valve 1 bank 1: posit.feedback - Raw voltage571.6mV
IDE07756Exhaust recirc.valve 1 bank 1: posit.feedback - Specified value0%
IDE07757Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value0%
IDE07758Exhaust recirc.valve 1 bank 1: posit.feedback - Offset closed4.19%
IDE07759-ENG188621EGR valve 1: B1: position feedback - mechanical stops-Bits 0-729
IDE07759-ENG188621EGR valve 1: B1: position feedback - mechanical stops-Bits 0-70
IDE07759-ENG188621EGR valve 1: B1: position feedback - mechanical stops-Bits 0-7109
IDE07759-ENG188621EGR valve 1: B1: position feedback - mechanical stops-Bits 0-714
IDE07760-ENG188621EGR valve 1: B1: position feedback - Break away attempts-Bits 0-70
IDE07761Exhaust recirculation valve 2 bank 1: activation9.52%
IDE07762Exhaust recirc.valve 2 bank 1: posit.feedback - Raw voltage698.8mV
IDE07763Exhaust recirc.valve 2 bank 1: posit.feedback - Specified value0%
IDE07764Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value0%
IDE07765Exhaust recirc.valve 2 bank 1: posit.feedback - Offset closed0.02%
IDE07766-ENG188621EGR valve 2: B1: position feedback - mechanical stops-Bits 0-7118
IDE07766-ENG188621EGR valve 2: B1: position feedback - mechanical stops-Bits 0-70
IDE07766-ENG188621EGR valve 2: B1: position feedback - mechanical stops-Bits 0-73
IDE07766-ENG188621EGR valve 2: B1: position feedback - mechanical stops-Bits 0-7252
IDE07767-ENG188621EGR valve 2: B1: position feedback - Break away attempts-Bits 0-70
IDE07768Throttle valve adapter 1 bank 1: activation8.35%
IDE07769Throttl.valve adapt. 1 bank 1: posit feedback - Raw voltage4178.6mV
IDE07770Throttl.valve adapt. 1 bank 1: posit feedback - Specified value0%
IDE07771Throttl.valve adapt. 1 bank 1: posit feedback - Actual value0.05%
IDE07772Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed0.02%
IDE07773-ENG188621Throttl.valve adapt. 1 bank 1: posit feedback - mechanical stops-Bits 0-7143
IDE07773-ENG188621Throttl.valve adapt. 1 bank 1: posit feedback - mechanical stops-Bits 0-789
IDE07773-ENG188621Throttl.valve adapt. 1 bank 1: posit feedback - mechanical stops-Bits 0-70
IDE07774-ENG188621Throttl.valve adapt.1 bank 1:pos.feedback - Break away attempts-Bits 0-70
IDE07775Exhaust recirculation valve 1 bank 1: activation2.28%
IDE07776Exh.recircul.valve 1 bank 1: pos.feedback - Raw voltage3939.2mV
IDE07777Exh.recircul.valve 1 bank 1: pos.feedback - Specified value0%
IDE07778Exh.recircul.valve 1 bank 1: pos.feedback - Actual value0.01%
IDE07779Exh.recircul.valve 1 bank 1: pos.feedback - Offset closed1.81%
IDE07780-ENG188621Exh.recircul.valve 1 bank 1: pos.feedback - mechanical stops-Bits 0-70
IDE07780-ENG188621Exh.recircul.valve 1 bank 1: pos.feedback - mechanical stops-Bits 0-7161
IDE07780-ENG188621Exh.recircul.valve 1 bank 1: pos.feedback - mechanical stops-Bits 0-764
IDE07781-ENG188621Exh.recircul.valve 1 bank 1: pos.feedback - Break away attempts-Bits 0-70
IDE07781-ENG188621Exh.recircul.valve 1 bank 1: pos.feedback - Break away attempts-Bits 0-71
IDE07783Turbine actuator 1 bank 1: posit.feedback - Raw voltage1040.8mV
IDE07784Turbine actuator 1 bank 1: posit.feedback - Specified value100%
IDE07785Turbine actuator 1 bank 1: posit.feedback - Actual value99.96%
IDE07786Turbine actuator 1 bank 1: posit.feedback - Offset closed-8.3%
IDE07787-ENG188621Turbine actuator 1 bank 1: posit.feedback - mechanical stops-Bits 0-750
IDE07787-ENG188621Turbine actuator 1 bank 1: posit.feedback - mechanical stops-Bits 0-73
IDE07787-ENG188621Turbine actuator 1 bank 1: posit.feedback - mechanical stops-Bits 0-7112
IDE07787-ENG188621Turbine actuator 1 bank 1: posit.feedback - mechanical stops-Bits 0-70
IDE07788-ENG188621Turbine actuator 1 bank 1: posit.feedback - Break away attempts-Bits 0-70
IDE07789Turbine actuator 1 bank 1: activation90.52%
IDE07797Injector 1 bank 1 for reducing agent before SCR cat: activation0%
IDE07798Heater support pump 1 bank 1 second.circuit: activat.94.18%
IDE07799Heater support pump 1 bank 1 primary circuit: activation5%
IDE07800Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.10%
IDE07801Mass airflow sensor 1 bank 1 airflow: raw value543.7mg/stroke
IDE07807Fuel temperature sensor 1: B1: raw value0°C
IDE07808Fuel temperature sensor 1: B1: before CR pump: raw voltage0mV
IDE07812Transmission neutral position sensor 1: raw value40.84%
IDE07815-ENG188621Transmission neutral position sensor: adaptation status-Bits 0-762
IDE07818Fuel high pressure sensor: actual value345800hPa
IDE07819Fuel high pressure sensor: unconditioned voltage1124mV
IDE07820Fuel high pressure sensor: nominal value342900hPa
IDE07821Fuel metering valve: activation26.74%
IDE07822Fuel pressure regulator valve: activation8.92%
IDE07823-ENG188621Tank-internal presupply pump 1 bank 1: status-Bits 0-70
IDE07824Tank-internal presupply pump 1 bank 1: activation33.71%
IDE07825Tank-internal presupply pump 1 bank 1: nominal value89.4l/h
IDE07826Accelerator pedal travel: raw value0%
IDE07827Accelerator pedal: sensor voltage 1757.4mV
IDE07828Accelerator pedal: sensor voltage 2376.2mV
IDE07830Exhaust recirculation cooler bypass valve: activation0%
IDE07832Coolant fan 1: activation10.15%
IDE07834-ENG188621Status of starter activation relay-Bits 0-70
IDE07841Precontrol value of map15.35µs
IDE07842-ENG188621Precontrol map value index-Bits 0-733
IDE07904-ENG188621Brake test switch status-Bits 0-70
IDE07905-ENG188621Brake light switch status-Bits 0-70
IDE07906-ENG188621Upper clutch switch: status-Bits 0-70
IDE07920Oxygen sensor bank 1 before oxi cat: adjustable resistor290.2Ohm
IDE07924Oxygen sensor bank 1 before oxi cat: heater activation37.994%
IDE07928Oxygen sensor bank 1 before oxi cat: exhaust temper. calculated383.4°C
IDE07930Oxygen sensor bank 1 before oxi cat: signal qual. temperature regulator0
IDE07932Oxygen sensor bank 1 before oxi cat: signal qual. pump flow controller0
IDE07935Oxyg.sensor bank 1 before oxi cat: curr.pump curr.adaptation1
IDE07936Oxygen sensor bank 1 before oxi cat: act.-integr. pump current actuation0g
IDE07979Particle filter: unburned fuel calculated0
IDE08064Mass airflow sensor 1 bank 1 temperature sensor: raw value0°C
IDE08065Mass airflow sensor 1 bank 1 temperature sensor: raw value0mV
IDE08069-ENG188621Fuel filter: water level sensor 1-Bits 0-70
IDE08071-ENG188621Remote start cancellation reason store 1-Bits 0-70
IDE08072-ENG188621Remote start cancellation reason store 2-Bits 0-70
IDE08073-ENG188621Remote start cancellation reason store 3-Bits 0-70
IDE08074-ENG188621Remote start cancellation reason store 4-Bits 0-70
IDE08075-ENG188621Remote start cancellation reason store 5-Bits 0-70
IDE08076Fuel filter: water level sensor 1 raw voltage0mV
IDE08081Pressure sensor in cylinder head: angle correction value0.2°
IDE08132-ENG122793SCR error notification reset status-SCR Inducement Group0
IDE08132-ENG122794SCR error notification reset status-SCR Inducement State DFCC0
IDE08132-ENG176596SCR error notification reset status-SCR Inducement Tester DFCC Five0
IDE08132-ENG176595SCR error notification reset status-SCR Inducement Tester DFCC Four0
IDE08132-ENG176592SCR error notification reset status-SCR Inducement Tester DFCC One0
IDE08132-ENG176594SCR error notification reset status-SCR Inducement Tester DFCC Three0
IDE08132-ENG176593SCR error notification reset status-SCR Inducement Tester DFCC Two0
IDE08212Standardized air flow ratio0.934
IDE08213-ENG188621Standardised airflow ratio plausibility-Bits 0-7136
IDE08700NOx sens.dwnstrm.SCR cat conv: NOx conc. according to diagnosis0ppm
IDE09007NOx sensor before SCR catalytic converter: supply voltage14560mV
IDE09008NOx sens.dwnstrm.SCR cat conv: NOx conc. limit value diagnosis0ppm
IDE09011-ENG188621NOx sensor before SCR cataly convert.: status of el faults-Bits 0-70
IDE09012NOx sensor before SCR cat conv: air mass to enable offset test0g
IDE09016-ENG188621NOx sensor upstrm. SCR cat.: target heat. temp. reached-Bits 0-71
IDE09018NOx sensor before SCR cat conv: NOx emiss0ppm
IDE09020NOx sensor before SCR cat conv: O2 concen.0
IDE09022NOx sensor before SCR cat conv: offset correction factor0ppm
IDE09023-ENG188621NOx sensor before SCR cat conv: status-Bits 0-70
IDE09024-ENG188621NOx sensor after SCR cat conv: status-Bits 0-70
IDE09025NOx sensor before SCR cat conv: NOx concentration96ppm
IDE09163Exhaust recircul.2: different.press.sens.1 bank 1: dyn. offset0hPa
IDE09164Efficiency of the SCR catalytic converter0.015
IDE09165Low-pres.exhaust gas recirc.filt.diagn.:release condit.10641
IDE09327Cylinder 1 bank 1 internal moment48.8Nm
IDE09328Cylinder 2 bank 1 internal moment48.3Nm
IDE09329Cylinder 3 bank 1 internal moment47.6Nm
IDE09330Cylinder 4 bank 1 internal moment48.2Nm
IDE09331Cylinder 1 bank 1 primary combustion position0°
IDE09332Cylinder 2 bank 1 primary combustion position0°
IDE09333Cylinder 3 bank 1 primary combustion position-9.93°
IDE09334Cylinder 4 bank 1 primary combustion position0°
IDE09339Charge limit for service regeneration while driving40g
IDE09490Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value3.5hPa
IDE09648EGR travel diagnosis: slightly increased NOx emission0kg/h
IDE09649EGR travel diagnosis: strongly increased NOx emission3.8kg/h
IDE09650AGR travel diag.: increased NOx emission effect. throttle valve60kg/h
IDE09651EGR travel diagnosis: marginally increased NOx emission4kg/h
IDE09652Air mass dynamic during negative increase: error criterion0kg/h
IDE09653Air mass dynamic during positive increase: error criterion0kg/h
IDE09654Air mass dynamic during negative increase: error threshold0kg/h
IDE09655Air mass dynamic during positive increase: error threshold0kg/h
IDE09657Chg. press. dynamic during pos. increase: error criterion0
IDE09658Chg. press. dynamic during pos. increase: error threshold0
IDE09659Chg. press. dynamic during neg. increase: error criterion0
IDE09660Chg. press. dynamic during neg. increase: error threshold0
IDE09671-ENG188621Cyl. head: pos. controller main combust. 1 bank 1: limit stat.-Bits 0-716
IDE09672-ENG188621Cyl. head: pos. controller main combust. 2 bank 1: limit stat.-Bits 0-716
IDE09673-ENG188621Cyl. head: pos. controller main combust. 3 bank 1: limit stat.-Bits 0-70
IDE09674-ENG188621Cyl. head: pos. controller main combust. 4 bank 1: limit stat.-Bits 0-716
IDE09675Cylinder head pressures sensor 1 bank 1: pressure corr. intern. torque0Nm
IDE09676Cylinder head pressures sensor 2 bank 1: pressure corr. intern. torque0Nm
IDE09677Cylinder head pressures sensor 3 bank 1: pressure corr. intern. torque47.3Nm
IDE09678Cylinder head pressures sensor 4 bank 1: pressure corr. intern. torque0Nm
IDE09679-ENG188621Cyl. head: press. sen 1 bank 1: error stat. combust. rm. press.-Bits 0-7255
IDE09680-ENG188621Cyl. head: press. sen 2 bank 1: error stat. combust. rm. press.-Bits 0-7255
IDE09681-ENG188621Cyl. head: press. sen 3 bank 1: error stat. combust. rm. press.-Bits 0-70
IDE09682-ENG188621Cyl. head: press. sen 4 bank 1: error stat. combust. rm. press.-Bits 0-7255
IDE09683-ENG188621Cylinder head: controller internal moment 1 bank 1: limit stat.-Bits 0-70
IDE09684-ENG188621Cylinder head: controller internal moment 2 bank 1: limit stat.-Bits 0-70
IDE09685-ENG188621Cylinder head: controller internal moment 3 bank 1: limit stat.-Bits 0-70
IDE09686-ENG188621Cylinder head: controller internal moment 4 bank 1: limit stat.-Bits 0-70
IDE09842-ENG188621Delete engine diagnostic stat. since error memory (end-of-line)-Bits 0-7255
IDE09842-ENG188621Delete engine diagnostic stat. since error memory (end-of-line)-Bits 0-7234
IDE09842-ENG188621Delete engine diagnostic stat. since error memory (end-of-line)-Bits 0-7175
IDE09843-ENG188621Delete engine diagn. stat. 2 since error memory (end-of-line)-Bits 0-7235
IDE09843-ENG188621Delete engine diagn. stat. 2 since error memory (end-of-line)-Bits 0-7155
IDE09843-ENG188621Delete engine diagn. stat. 2 since error memory (end-of-line)-Bits 0-7255
IDE09843-ENG188621Delete engine diagn. stat. 2 since error memory (end-of-line)-Bits 0-7126
IDE09879Oxygen sensor bank 1 before oxi cat: electric. corrected Pump current0.0033493A
IDE09880O2 sens. 1 bank 1 upstrm oxi cat: raw value5.6418
IDE09884O2 sensor bank 1 upstrm oxi cat: pump current adapt. successfulFalse result
IDE09884-ENG127289O2 sensor bank 1 upstrm oxi cat: pump current adapt. successful-Test_Program_B TRUE UBYTE0
IDE09885O2 sensor bank 1 upstrm oxi cat: status of signal quality8
IDE09886Exhaust gas recirc. valve 2 bank 1: mass flow - calculated0kg/h
IDE09960Cyl. head: press. sensor 1 bank 1 primary combustion position0°
IDE09961Cyl. head: press. sensor 2 bank 1 primary combustion position0°
IDE09962Cyl. head: press. sensor 3 bank 1 primary combustion position-9.62°
IDE09963Cyl. head: press. sensor 4 bank 1 primary combustion position0°
IDE09964Cyl. head: press. sensor 1 bank 1: primary comb. Std. deviat.0°
IDE09965Cyl. head: press. sensor 2 bank 1: primary comb. Std. deviat.0°
IDE09966Cyl. head: press. sensor 3 bank 1: primary comb. Std. deviat.0.15°
IDE09967Cyl. head: press. sensor 4 bank 1: primary comb. Std. deviat.0°
IDE09968Cyl. head: press. sens. 1 bank 1: max press. in decelerat.mode0°
IDE09969Cyl. head: press. sens. 2 bank 1: max press. in decelerat.mode0°
IDE09970Cyl. head: press. sens. 3 bank 1: max press. in decelerat.mode0°
IDE09971Cyl. head: press. sens. 4 bank 1: max press. in decelerat.mode0°
IDE09972Cylinder head: press. sensor 1 bank 1: grp. run time0µs
IDE09973Cylinder head: press. sensor 2 bank 1: grp. run time0µs
IDE09974Cylinder head: press. sensor 3 bank 1: grp. run time11.9µs
IDE09975Cylinder head: press. sensor 4 bank 1: grp. run time0µs
IDE09976Coolant fan 1: activation10.15%
IDE09977Control module temp.: max. value66.5°C
IDE10032Reducing agent quality sensor: urea concentration0%
IDE10223-ENG188621Install. list for actuators bank 1-Bits 0-70
IDE10223-ENG188621Install. list for actuators bank 1-Bits 0-711
IDE10223-ENG188621Install. list for actuators bank 1-Bits 0-7138
IDE10224-ENG188621Install. list for pressure and O2 sensors bank 1-Bits 0-7196
IDE10224-ENG188621Install. list for pressure and O2 sensors bank 1-Bits 0-70
IDE10224-ENG188621Install. list for pressure and O2 sensors bank 1-Bits 0-736
IDE10225-ENG188621Install. list for temperature sensors bank 1-Bits 0-70
IDE10225-ENG188621Install. list for temperature sensors bank 1-Bits 0-7151
IDE10225-ENG188621Install. list for temperature sensors bank 1-Bits 0-724
IDE10241Reducing agent pump module relative press.: calculated0hPa
IDE10246Reducing agent tank volume: act. value filtered10940ml
IDE10247Reducing agent tank volume: act. value calculated10.67l
IDE10248Reducing agent supply pump: offset factor calculated0.983
IDE10249Reducing agent fill level sensor: act. value85mm
IDE10250Reducing agent return pump: adapted displacement0.038ml
IDE10251Reducing agent supply pump: measured resistance4359mOhm
IDE10252Operatingn hour reducing agent system: flawless655350s
IDE10253Exh. gas recirc. valve 1 bank 1: pos. contr. spec. value-25%
IDE10254Turbine actuator 1 bank 1: pos. contr. spec. value170%
IDE10255Throttle valve adapter 1 bank 1: pos. contr. spec. value-0.01%
IDE10560-ENG188621Adaption of radiator shutters: status-Bits 0-70
IDE10569-ENG188621Turbo charger 1 Turbine inp.: Temp. sensor 1 Bank 1: raw data-Bits 0-70
IDE10570Turbo charger.1 turbine inp.: temp.sensor 1 bank 1: comp. temp.0°C
IDE10571Turbo charger.1 turbine inp.: temp.sens. 1 bank 1: ins.resist.0kOhm
IDE10572-ENG188621Exh. gas temp. sens. upstrm. of turbo chgr.: intern. error code-Bits 0-70
IDE10573-ENG188621Exh. gas temp. sens. upstrm. of turbo chgr.: sens. type-Bits 0-70
IDE10574-ENG188621Exh. gas temp. sens. upstrm. of turbo chgr.: sens. mod.-Bits 0-70
IDE10575-ENG188621Exh. gas temp. sens. upstrm. of turbo chgr.: manf. ID-Bits 0-70
IDE10576-ENG188621Reducing agent system and actuator: condition-Bits 0-71
IDE10576-ENG188621Reducing agent system and actuator: condition-Bits 0-724
IDE10578-ENG188621Reducing agent system release: cancel conditions quick start-Bits 0-70
IDE10579-ENG188621Reducing agent system pressurization release conditions-Bits 0-7239
IDE10811-ENG188621Release requirement for DPF regeneration-Bits 0-70
IDE10812-ENG188621Particulate filter regeneration: status-Bits 0-716
IDE10813Temp. dwnstrm. of oxi-cat without fuel combustion: calculated361°C
IDE10814Exhaust recirculation cooler 2 Bank 1: efficiency calculated0
IDE10815Post injection 2: quantity spec. value0mg/stroke
IDE10816-ENG188621Particulate filter regeneration level: current-Bits 0-715
IDE10817Lambda value at inlet of particulate filter5.649
IDE10818Temp. spec. value for exhaust gas temp.con.dwnstrm. of oxi-cat0°C
IDE10819Exh. gas temp.control dwnstrm. of oxi-cat: filtered model error0°C
IDE10820Exh. gas temp. ctrl. upstrm. of turbine: spec. value341.8°C
IDE10823Exhaust gas model temperature 50°C
IDE10824Exhaust gas model temperature 60°C
IDE10825Exhaust gas model temperature 70°C
IDE10826Exh. gas temp. controller upstrm. of turbine: I-part0
IDE10827Exh.gas temp.contr. dwnstrm.of oxi-cat:post inject.qty.spec.val0mg/stroke
IDE10828Exh. gas temp.contr. upstrm. of turbine: post inject.qty.corr.0mg/injection
IDE10829Post injection 1: quantity spec. value0mg/stroke
IDE10830Post injection 3: quantity spec. value0mg/stroke
IDE10831Exhaust recirculat.2: different.press.sens.1 bank 1: calculated1039hPa
IDE10916Reducing agent system debounce distance0m
IDE10917Reducing agent delivery pump: coil temperature11.6°C
IDE10919Reducing agent: dosing qty. test: calculated specified volume0g
IDE10920Temp. upstrm. of reducing agent cat.: calculated72.4°C
IDE10921-ENG188621Reducing agent delivery pump: number of strokes-Bits 0-70
IDE10968Activation radiator shutter result0%
IDE10994-ENG188621Poor start counter at start-stop-Bits 0-70
IDE11074Fuel pres.sen. 1 bank 1 upstream from HD pump: press. dev.0kPa
IDE11111Fuel pres.sen 1 bank 1 upstr from HD pump: act.value averaged1100kPa
IDE11112Fuel pres.sens.1 bank 1 upstr from HD pump: act.val. filtered0kPa
IDE11113Fuel pres.sen. 1 bank 1 upstream from HD pump: raw volt.4.998V
IDE11114Fuel press. sensor 1 bank 1 upstr. from HD pump: adapt. value0kPa
IDE11115-ENG188621Start/stop driver request: counter restart by starter-Bits 0-70
IDE11116-ENG188621Start/stop driver request: counter internal-motor restart-Bits 0-70
IDE11117Charge press. ctrl deviation after throttle valve bank 11086hPa
IDE11118Pressure after throttle valve: calculated-86hPa
IDE11119Pressure corr. value after low pressure EGR valve: calculated0hPa
IDE11219Reducing agent inj. quantity: spec. value0mg/s
IDE11220Reducing agent system: current statusCOSCR_NOPRESSURECTL
IDE11220-ENG127431Reducing agent system: current status-Test_Program_SCR Con State 01 UBYTE2
IDE11221Reducing agent system: last statusCOSCR_STANDBY
IDE11221-ENG127431Reducing agent system: last status-Test_Program_SCR Con State 01 UBYTE1
IDE11222Reducing agent system: current substatusCOSCR_INVALID
IDE11222-ENG127432Reducing agent system: current substatus-Test_Program_SCR Con State 02 UBYTE255
IDE11223Reducing agent system: last substatusCOSCR_INVALID
IDE11223-ENG127432Reducing agent system: last substatus-Test_Program_SCR Con State 02 UBYTE255
IDE11250Reducing agent quality sensor: raw temperature value-273.1°C
IDE11448Reducing agent over-pressure: diagnosis progress0%
IDE11449Reducing agent under-pressure: diagnosis progress0%
IDE11574Status max. oil level dynamically exceeded0
IDE11575Status max. oil level permanently exceeded0
IDE11576Oil level: last valid dynamic value overfilling0mm
IDE11854Mileage of the oxidation catalytic converter0km
IDE11895-ENG188621Particle filter: differential press. sens.1 bank 1: raw data 1-Bits 0-7150
IDE11895-ENG188621Particle filter: differential press. sens.1 bank 1: raw data 1-Bits 0-72
IDE11896Particle filter: differential press. sens.1 bank 1: raw value 11hPa
IDE11897Particle filter: differential press. sens.1 bank 1: raw value 23hPa
IDE11898-ENG188621Particle filter: differential press. sens.1 bank 1: raw data 2-Bits 0-7157
IDE11898-ENG188621Particle filter: differential press. sens.1 bank 1: raw data 2-Bits 0-72
IDE11899Par.fil: diff.pr.sens.1 bank 1: sensor temperature14.59°C
IDE11900Par.fil: diff.pr.sens.1 bank 1: data quality100%
IDE11901-ENG188621Par.fil: diff.pr.sens.1 bank 1: sensor configuration-Bits 0-71
IDE11901-ENG188621Par.fil: diff.pr.sens.1 bank 1: sensor configuration-Bits 0-70
IDE11902-ENG188621Par.fil: diff.pr.sens.1 bank 1: manufacturer ID-Bits 0-75
IDE11902-ENG188621Par.fil: diff.pr.sens.1 bank 1: manufacturer ID-Bits 0-70
IDE11903-ENG188621Par.fil: diff.pr.sens.1 bank 1: internal error code-Bits 0-70
IDE11904-ENG188621Par.fil: diff.pr.sens.1 bank 1: sensor type-Bits 0-79
IDE11904-ENG188621Par.fil: diff.pr.sens.1 bank 1: sensor type-Bits 0-70
IDE11905-ENG188621Exhaust recirculation valve 2 bank 1: adaptation status-Bits 0-70
IDE11905-ENG188621Exhaust recirculation valve 2 bank 1: adaptation status-Bits 0-7142
IDE11906-ENG188621Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-70
IDE11906-ENG188621Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7142
IDE11907-ENG188621Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-715
IDE11907-ENG188621Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-70
IDE11908-ENG188621Throttle position actuator 1 bank 1: adaptation status-Bits 0-715
IDE11908-ENG188621Throttle position actuator 1 bank 1: adaptation status-Bits 0-70
IDE11910-ENG188621Turbine actuator 1 bank 1: adaptation status-Bits 0-70
IDE11910-ENG188621Turbine actuator 1 bank 1: adaptation status-Bits 0-7143
IDE11981Turbocharg. 1 turb: input temp.sensor 1 bank 1: data quality0%
ENG119898Actual_section_of_standard_test0
ENG128810-ENG188621Boost_pressure_adaption_index_value-Bits 0-736
ENG128811Boost_pressure_adaption_learning_value0hPa
ENG101413Calibration Identification04L026HQ3022BEBD
ENG99697Calibration Verification Number25 26 BD 57
ENG126402-ENG188621Cruise_control_shutoff_conditions_irreversible-Bits 0-70
ENG126403-ENG188621Cruise_control_shutoff_conditions_reversible-Bits 0-764
ENG126403-ENG188621Cruise_control_shutoff_conditions_reversible-Bits 0-725
ENG126403-ENG188621Cruise_control_shutoff_conditions_reversible-Bits 0-71
ENG126403-ENG188621Cruise_control_shutoff_conditions_reversible-Bits 0-74
ENG122710Cruise_control_velocity_setpoint0km/h
ENG105734Cylinder_pressure_offset_cylinder_10bar
ENG113333Cylinder_pressure_offset_cylinder_20bar
ENG105735Cylinder_pressure_offset_cylinder_3-0.781bar
ENG105736Cylinder_pressure_offset_cylinder_40bar
ENG126404-ENG188621Drive_train_coordinator_checked_coding-Bits 0-71
ENG100152-ENG104003ECUNAME-ECUECM
ENG100152ECUNAMEEngineControl
ENG106086-ENG188621EGR_governor_deviation_monitoring_enabling-Bits 0-70
ENG106223Engine_torque_limitation_mechanical188.4Nm
ENG106774-ENG188621General_rail_press_calibr_ctrl_duration_enble_stat-Bits 0-7255
ENG107036-ENG188621Injctr_spec_rail_press_calibr_ctrl_dur_enbl_stat-Bits 0-715
ENG103875-ENG99452In-use perform. track.: 16 counters-Boost Pressure Monitor Completion Condition Counts0counts
ENG103875-ENG103994In-use perform. track.: 16 counters-Boost Pressure Monitor Conditions Encountered Counts0counts
ENG103875-ENG125935In-use perform. track.: 16 counters-Counters 17-18|Fuel Monitor Completion Condition CountsFuel Monitor Conditions Encountered Counts|00|counts
ENG103875-ENG100817In-use perform. track.: 16 counters-EGR and/or VVT Monitor Completion Condition Counts0counts
ENG103875-ENG101113In-use perform. track.: 16 counters-EGR and/or VVT Monitor Conditions Encountered Counts0counts
ENG103875-ENG104133In-use perform. track.: 16 counters-Exhaust Gas Sensor Monitor Completion Condition Counts0counts
ENG103875-ENG104165In-use perform. track.: 16 counters-Exhaust Gas Sensor Monitor Conditions Encountered Counts0counts
ENG103875-ENG102823In-use perform. track.: 16 counters-Ignition Cycle Counter0counts
ENG103875-ENG99234In-use perform. track.: 16 counters-NMHC Catalyst Monitor Completion Condition Counts0counts
ENG103875-ENG99167In-use perform. track.: 16 counters-NMHC Catalyst Monitor Conditions Encountered Counts0counts
ENG103875-ENG101363In-use perform. track.: 16 counters-NOx Adsorber Monitor Completion Condition Counts0counts
ENG103875-ENG103522In-use perform. track.: 16 counters-NOx Adsorber Monitor Conditions Encountered Counts0counts
ENG103875-ENG125933In-use perform. track.: 16 counters-NOx/SCR Catalyst Monitor Completion Condition Counts0counts
ENG103875-ENG125934In-use perform. track.: 16 counters-NOx/SCR Catalyst Monitor Conditions Encountered Counts0counts
ENG103875-ENG99988In-use perform. track.: 16 counters-OBD Monitoring Conditions Encountered Counts0counts
ENG103875-ENG100240In-use perform. track.: 16 counters-PM Filter Monitor Completion Condition Counts0counts
ENG103875-ENG103730In-use perform. track.: 16 counters-PM Filter Monitor Conditions Encountered Counts0counts
ENG107569Main_injection_quantity3.87mg/stroke
ENG107674Model_correction_factor_of_volumetric_efficiency0
ENG127395Nox_ratio_upstream_reduction_system_model207ppm
ENG108270Preinjection_1_quantity0mg/stroke
ENG108271Preinjection_2_quantity1.57mg/stroke
ENG108272Preinjection_3_quantity1.5mg/stroke
ENG119902-ENG188621Prioritize_exceptional_case_control-Bits 0-70
ENG127401Reductant_inducement_system_error0
ENG127396Reduction_system_efficiency_diagnosis_average_ratio0
ENG127400-ENG188621Reduction_system_efficiency_diagnosis_basic_release_conditions-Bits 0-70
ENG127400-ENG188621Reduction_system_efficiency_diagnosis_basic_release_conditions-Bits 0-7160
ENG127393Reduction_system_efficiency_diagnosis_release_progress 10g
ENG127394Reduction_system_efficiency_diagnosis_release_progress 30g
ENG157416-ENG188621Reduction_system_efficiency_diagnosis_release_state_1-Bits 0-70
ENG157416-ENG188621Reduction_system_efficiency_diagnosis_release_state_1-Bits 0-71
ENG157417-ENG188621Reduction_system_efficiency_diagnosis_release_state_3-Bits 0-71
ENG157417-ENG188621Reduction_system_efficiency_diagnosis_release_state_3-Bits 0-70
ENG127397Reduction_system_efficiency_diagnosis_threshold_ratio0
ENG110382-ENG151591SCR inducem system status-deviation of reagent consumptionUnknown (0)
ENG110382-ENG151584SCR inducem system status-Distance traveled in current 10K block5km
ENG110382-ENG151585SCR inducem system status-Distance traveled while inducement system active in 20K block0km
ENG110382-ENG151586SCR inducem system status-Distance traveled while inducement system active in 30K block0km
ENG110382-ENG151587SCR inducem system status-Distance traveled while inducement system active in 40K block0km
ENG110382-ENG151583SCR inducem system status-Distance traveled while inducement system active in current 10K block0km
ENG110382-ENG151590SCR inducem system status-incorrect reagentUnknown (0)
ENG110382-ENG151588SCR inducem system status-inducement system activenot_active
ENG110382-ENG151592SCR inducem system status-NOx emissions too highUnknown (0)
ENG110382-ENG151589SCR inducem system status-reagent level too lowUnknown (0)
ENG109107Stat_of_adaption_of_toothed_spd_snsr_disc_fr_TDCEPMTDC_FILT_ON
ENG109107-ENG127376Stat_of_adaption_of_toothed_spd_snsr_disc_fr_TDC-Test_Program_Epm TDC st Adap Val Signal t UBYTE0
ENG119903-ENG188621State_control_circuit_shutoff_gas_engine_control-Bits 0-70
ENG121093-ENG188621State_of_cruise_control_or_speedlimiter-Bits 0-70
ENG109106-ENG188621Status_of_adaption_of_toothed_speed-Bits 0-71
Elapsed Time: 01:10
