Good day all,
Interested in trying to retrofit power folding and memory mirrors to my 2010 Jetta TDi. I've acquired two sets of modules from vehicles with those options: 2010 CC (module part number: 3C0 959 792/3 A; UDS protocol) and 2012 Tiguan (part #: 5K0 959 792/3 A; CAN protocol), but having difficulty getting them to function correctly. At a minimum, the 2010 CC modules are not allowing full window travel (I've attempted to relearn movement parameters with the window switch multiple times to no avail) and with the Tiguan modules in, the driver's door states it cannot communicate with rear right door and the passenger's door cannot communicate with the rear left door. The part numbers on my factory-installed modules are 1k0 959 792/3 N (CAN protocol). Is there any possibility of getting either set to work in my car or do I need to start with Jetta-specific modules? Any help is greatly appreciated! Including scan below with relevant modules. Thanks in advance.
Thursday,19,January,2023,09:18:11:39930
VCDS Version: 22.10.0.1 (x64)
VIN: 3VWRL7AJ7AM05XXXX License Plate:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 65 72 77
VIN: 3VWRL7AJ7AM05XXXX Mileage: 493850km-306864miles
2E-Media Player 3 -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Malfunction 1010
Part No SW: 5K0 937 085 C HW: 5K0 937 085 C
Component: BCM PQ35 B++ 008 6019
Revision: BI008001
Coding: 6D200B3FE02F3EE4800800056100000403F20E86532085205C8000000000
Shop #: WSC 55475 001 104857
VCID: 334BFA9492AE92154F-8066
Component: RLS 250512 05 54 0403
Coding: 072BAD
Reset counter: 59
Mileage: 493841 km
Voltage: 7.50 V
Reset counter: 59
Mileage: 493841 km
Date: 2023.01.19
Time: 01:00:15
Voltage: 7.15 V
Fault Frequency: 15
Reset counter: 61
Mileage: 493842 km
Date: 2023.01.18
Time: 13:08:47
Term 15 Off
Voltage: 12.10 V
Reset counter: 60
Mileage: 493841 km
Date: 2023.01.19
Time: 01:42:44
Voltage: 13.40 V
Reset counter: 61
Mileage: 493842 km
Date: 2023.01.18
Time: 13:08:47
Term 15 Off
Voltage: 12.10 V
01598 - Drive Battery Voltage
Fault Status: 00101011
Reset counter: 59
Mileage: 493841 km
Date: 2023.01.19
Time: 01:06:36
Voltage: 13.55 V
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H07 0081
Revision: H07 01 Serial number: 240909F1000295
Coding: E9807F07400612001002
Shop #: WSC 00066 123 12345
VCID: 66ED53C051FC37BD18-8032
Fault Frequency: 16
Reset counter: 61
Mileage: 493842 km
Date: 2023.01.18
Time: 13:08:44
Fault Status: 00110100
Reset counter: 60
Mileage: 493841 km
Date: 2023.01.19
Time: 01:42:44
Reset counter: 61
Mileage: 493842 km
Date: 2023.01.18
Time: 13:08:44
Reset counter: 19
Mileage: 493842 km
Date: 2023.01.18
Time: 12:59:24
01304 - Radio
Reset counter: 19
Mileage: 493842 km
Date: 2023.01.18
Time: 12:59:24
03272 - Control Module for Audio Interface
Reset counter: 19
Mileage: 493842 km
Date: 2023.01.18
Time: 12:59:24
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1525
Revision: 72009005 Serial number: 00000920199021
Coding: 0005373
Shop #: WSC 00066 000 00000
VCID: 6FC336E47E06F6F56B-803A
Fault Frequency: 9
Reset counter: 61
Mileage: 493841 km
Date: 2023.01.19
Time: 01:22:48
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1525
Revision: 72009005 Serial number: 00000879698903
Coding: 0005374
VCID: 70C135986338E90D72-8024
00121 - Outside Warning Light/Door exit Light Passenger Side
Fault Status: 01101100
Fault Frequency: 46
Reset counter: 21
Mileage: 488360 km
Date: 2022.11.28
Time: 14:39:12
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000004339606
Coding: 0001232
VCID: 76CD0380015CC73DA8-8022
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000004335150
Coding: 0001232
VCID: 77D30E840656BE35B3-8022
02071 - Local Databus
Reset counter: 61
End-------------------------(Elapsed Time: 01:52)--------------------------
